  2. English
  3. Scripting / Logic
  4. JavaScript
  5. Check if an element contains a class in JavaScript?
    6.8k
3 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • R Offline
    roshan.sharma
    schrieb am zuletzt editiert von roshan.sharma
    Hi
    I'm not a big fan of dynamic programming languages, although I've written a lot of JavaScript code. I never quite understood the concept of prototype-based programming; does anyone know how it works?
    I was working on a JavaScript project with the source checking if an element contains a class.
    I'm currently doing this:
    code_text
    var test = document.getElementById("test");
    var testClass = test.className;
    switch (testClass) {
      case "class1":
        test.innerHTML = "I have class1";
        break;
      case "class2":
        test.innerHTML = "I have class2";
        break;
      case "class3":
        test.innerHTML = "I have class3";
        break;
      case "class4":
        test.innerHTML = "I have class4";
        break;
      default:
        test.innerHTML = "";
    <div id="test" class="class1"></div>
    The problem is when I change the HTML code to...
    <div id="test" class="class1 class5"></div>
    There is no longer an exact match, so I get the standard output of nothing (""). But I still want the output to be I have class1 because <div> still contains class .class1 .
    Can someone help me
    liv-in-skyL OliverIOO 2 Antworten Letzte Antwort
    • R roshan.sharma
      Hi
      code_text
        case "class1":
          break;
        case "class2":
          break;
        case "class3":
          break;
        case "class4":
          break;
        default:
      Can someone help me
      liv-in-skyL Offline
      liv-in-skyL Offline
      @roshan-sharma
      I have tried this in a standard html widget:
      <div id="test" class="class1 class3"></div>
      <script>
      console.log(test.className);
      console.log(test.getAttribute('class'));
        case "class1":
          break;
        case "class2":
          break;
        case "class3":
          break;
        case "class4":
          break;
        default:
      if (test.classList.contains("class3")) {console.log("with class3");
                                              test.innerHTML = "I have class3";}
      if (test.classList.contains("class1")) {console.log("with class1");
                                              test.innerHTML += "<br> I have class1";}
      </script>
      the result is:
      the problem is the switch command !
      • R roshan.sharma
        Hi
        code_text
          case "class1":
            break;
          case "class2":
            break;
          case "class3":
            break;
          case "class4":
            break;
          default:
        Can someone help me
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @roshan-sharma
        better is to use jquery
        https://api.jquery.com/hasclass/
        var test = $("#test");
        if ($(test).hasClass("class1")) {
           $(test).html("I have class1");
        if ($(test).hasClass("class2")) {
           $(test).html("I have class2");
        jquery is in vis already loaded
        Meine Adapter und Widgets
        Links im Profil
