  4. Fehlermeldungen bei Installation mac
    5.7k
114 Beiträge 8 Kommentatoren 20.9k Aufrufe
  • BuZZyB Offline
    BuZZyB Offline
    BuZZy
    Die Zip Datei in den Ordner ioBrokermac dann rein in den Zip Ordner und da dann
    npm install iobroker.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac
      thoduh
      Wenn die Zipdatei angeklickt wird, öffnet sich der Download-Ordner…
      Last login: Wed Jul 26 18:33:21 on ttys001
      MacMini-LAN:~ MacMini$ cd /Users/MacMini/Downloads/ioBroker.js-controller-master\ 2
      MacMini-LAN:ioBroker.js-controller-master 2 MacMini$ npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
      npm ERR! code ENOSELF
      npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
      npm ERR! also called "iobroker.js-controller". Did you name your project the same
      npm ERR! as the dependency you're installing?
      npm ERR!
      npm ERR! For more information, see:
      npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
      npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_16_46_223Z-debug.log
      MacMini-LAN:ioBroker.js-controller-master 2 MacMini$ sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
      Password:
      npm ERR!
      npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_17_01_883Z-debug.log
      MacMini-LAN:ioBroker.js-controller-master 2 MacMini$</https:></https:>
      Der Inhalt des iobrokermac-Ordners entspricht doch dem Inhalt der Zipdatei :?:
      • BuZZyB Offline
        BuZZyB Offline
        BuZZy
        Bald raste ich aus.. :D
        Nächster Versuch:
        npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
          thoduh
          @BuZZy:
          Bald raste ich aus.. :D `
          Frag mich mal ;)
          MacMini-LAN:~ MacMini$ cd /Users/MacMini/Documents/iobrokermac
          MacMini-LAN:iobrokermac MacMini$ sudo npm install https://github.com/ioBroker/ioBroker/tarball/master
          > iobroker@1.0.0 install /Users/MacMini/Documents/iobrokermac/node_modules/iobroker
          > node lib/setup.js
          npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
          npm ERR! path /Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs
          npm ERR! code EACCES
          npm ERR! errno -13
          npm ERR! syscall rmdir
          npm ERR! Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
          npm ERR!  { Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
          npm ERR!   cause:
          npm ERR!      errno: -13,
          npm ERR!      code: 'EACCES',
          npm ERR!      syscall: 'rmdir',
          npm ERR!      path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs' },
          npm ERR!   stack: 'Error: EACCES: permission denied, rmdir \'/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs\'',
          npm ERR!   path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs',
          npm ERR!   parent: 'iobroker.js-controller' }
          npm ERR!
          npm ERR! Please try running this command again as root/Administrator.
          npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_40_08_563Z-debug.log
          Cannot install as normal user. Try sudo...
          sudo npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
          • BuZZyB Offline
            BuZZyB Offline
            BuZZy
            Lösche den kompletten inhalt von dem ioBrokermac ordner.
            Dann versuch es mit````
            sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
            Dann nochmal den Log posten.
            EDIT: Hab gesehen du hast es schon mit sudo probiert..
            Gib dem Ordner ioBrokermac mal (nachdem du den Inhalt komplett gelöscht hast) die Rechte 777 - dann nochmal versuchen mit dem oben genannten Befehl!
              thoduh
              Jetzt hats gekappt !!!
              Habe den iobroker-Ordner direkt auf Macintosh/ erstellt. per sudo npm install https://github.com/ioBroker/ioBroker/tarball/master –unsafe-perm installiert.
              Anschließend den Ordner an meinen gewünschten Platz verschoben und es läuft :D :D :D :D
              Vielen Dank für deine Hilfe !!!!
              Aber jetzt hab ich was anderes:
              Muss ich die Pfade noch anpassen ??
              Oder hätte ich es nicht verschieben dürfen ??
              host.MacMini-LAN.fritz.box 2017-07-26 20:12:16.220 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
              host.MacMini-LAN.fritz.box 2017-07-26 20:11:46.212 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
              host.MacMini-LAN.fritz.box 2017-07-26 20:11:16.205 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
              host.MacMini-LAN.fritz.box 2017-07-26 20:10:46.204 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
              host.MacMini-LAN.fritz.box 2017-07-26 20:10:16.193 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
              host.MacMini-LAN.fritz.box 2017-07-26 20:09:46.187 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
              host.MacMini-LAN.fritz.box 2017-07-26 20:09:16.176 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
              host.MacMini-LAN.fritz.box 2017-07-26 20:08:46.166 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
              host.MacMini-LAN.fritz.box 2017-07-26 20:08:16.156 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
              host.MacMini-LAN.fritz.box 2017-07-26 20:07:46.151 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
              iobroker 2017-07-26 20:07:29.113 info exit 1
              iobroker 2017-07-26 20:07:29.108 error at bootstrap_node.js:575:3
              iobroker 2017-07-26 20:07:29.108 error at startup (bootstrap_node.js:158:16)
              iobroker 2017-07-26 20:07:29.108 error at Function.Module.runMain (module.js:605:10)
              iobroker 2017-07-26 20:07:29.108 error at Function.Module._load (module.js:437:25)
              iobroker 2017-07-26 20:07:29.108 error at Function.Module._resolveFilename (module.js:485:15)
              iobroker 2017-07-26 20:07:29.108 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              iobroker 2017-07-26 20:07:29.108 error ^
              iobroker 2017-07-26 20:07:29.108 error module.js:487 throw err;
              iobroker 2017-07-26 20:07:28.844 info install hm-rega
              iobroker 2017-07-26 20:07:28.811 info exit 1
              iobroker 2017-07-26 20:07:28.807 error at bootstrap_node.js:575:3
              iobroker 2017-07-26 20:07:28.807 error at startup (bootstrap_node.js:158:16)
              iobroker 2017-07-26 20:07:28.807 error at Function.Module.runMain (module.js:605:10)
              iobroker 2017-07-26 20:07:28.807 error at Function.Module._load (module.js:437:25)
              iobroker 2017-07-26 20:07:28.807 error at Function.Module._resolveFilename (module.js:485:15)
              iobroker 2017-07-26 20:07:28.807 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              iobroker 2017-07-26 20:07:28.807 error ^
              iobroker 2017-07-26 20:07:28.807 error module.js:487 throw err;
              iobroker 2017-07-26 20:07:28.543 info install hm-rpc
              iobroker 2017-07-26 20:07:28.515 info exit 1
              iobroker 2017-07-26 20:07:28.511 error at bootstrap_node.js:575:3
              iobroker 2017-07-26 20:07:28.511 error at startup (bootstrap_node.js:158:16)
              iobroker 2017-07-26 20:07:28.511 error at Function.Module.runMain (module.js:605:10)
              iobroker 2017-07-26 20:07:28.511 error at Function.Module._load (module.js:437:25)
              iobroker 2017-07-26 20:07:28.511 error at Function.Module._resolveFilename (module.js:485:15)
              iobroker 2017-07-26 20:07:28.511 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              iobroker 2017-07-26 20:07:28.511 error ^
              iobroker 2017-07-26 20:07:28.511 error module.js:487 throw err;
              iobroker 2017-07-26 20:07:28.245 info install hm-rpc
              iobroker 2017-07-26 20:07:28.230 info exit 1
              iobroker 2017-07-26 20:07:28.226 error at bootstrap_node.js:575:3
              iobroker 2017-07-26 20:07:28.226 error at startup (bootstrap_node.js:158:16)
              iobroker 2017-07-26 20:07:28.226 error at Function.Module.runMain (module.js:605:10)
              iobroker 2017-07-26 20:07:28.226 error at Function.Module._load (module.js:437:25)
              iobroker 2017-07-26 20:07:28.226 error at Function.Module._resolveFilename (module.js:485:15)
              iobroker 2017-07-26 20:07:28.226 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              iobroker 2017-07-26 20:07:28.226 error ^
              iobroker 2017-07-26 20:07:28.226 error module.js:487 throw err;
              iobroker 2017-07-26 20:07:27.964 info install web
              iobroker 2017-07-26 20:07:27.935 info exit 1
              iobroker 2017-07-26 20:07:27.931 error at bootstrap_node.js:575:3
              iobroker 2017-07-26 20:07:27.931 error at startup (bootstrap_node.js:158:16)
              iobroker 2017-07-26 20:07:27.931 error at Function.Module.runMain (module.js:605:10)
              iobroker 2017-07-26 20:07:27.931 error at Function.Module._load (module.js:437:25)
              iobroker 2017-07-26 20:07:27.931 error at Function.Module._resolveFilename (module.js:485:15)
              iobroker 2017-07-26 20:07:27.931 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              iobroker 2017-07-26 20:07:27.931 error ^
              iobroker 2017-07-26 20:07:27.931 error module.js:487 throw err;
              iobroker 2017-07-26 20:07:27.663 info install hue
              iobroker 2017-07-26 20:07:27.643 info exit 1
              iobroker 2017-07-26 20:07:27.632 error at enableAdapters (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:47:21)
              iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:157:39
              iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup.js:753:41
              iobroker 2017-07-26 20:07:27.632 error at Install.uploadStaticObjects (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:339:17)
              iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup.js:754:44
              iobroker 2017-07-26 20:07:27.632 error at Upload.uploadAdapter (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:254:27)
              iobroker 2017-07-26 20:07:27.632 error at require (internal/module.js:11:18)
              iobroker 2017-07-26 20:07:27.632 error at Module.require (module.js:513:17)
              iobroker 2017-07-26 20:07:27.632 error at Function.Module._load (module.js:437:25)
              iobroker 2017-07-26 20:07:27.632 error at Function.Module._resolveFilename (module.js:485:15)
              iobroker 2017-07-26 20:07:27.632 error Error: Cannot find module 'mime'
              iobroker 2017-07-26 20:07:27.632 error ^
              iobroker 2017-07-26 20:07:27.632 error module.js:487 throw err;
              iobroker 2017-07-26 20:07:27.630 error host.MacMini-LAN.fritz.box Adapter directory "/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/adapter/tr-064" does not exists
              iobroker 2017-07-26 20:07:15.025 info npm install iobroker.tr-064 --production --prefix "/usr/local/lib/node_modules/iobroker" (System call)
              iobroker 2017-07-26 20:07:14.282 info install tr-064
              discovery.0 2017-07-26 20:05:54.558 info Discovery finished
              discovery.0 2017-07-26 20:05:54.549 info Discovery finished. Found new or modified 14 instances
              discovery.0 2017-07-26 20:05:54.545 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:54.045 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:53.545 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:52.532 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:52.031 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:51.531 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:51.024 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:50.525 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:50.023 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:49.515 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:49.017 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:48.514 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:47.504 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:47.009 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:46.508 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:45.500 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:45.000 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:44.500 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:43.991 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:43.493 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:42.990 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:42.484 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:41.987 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:41.487 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:40.480 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:39.980 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:39.480 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:38.971 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:38.474 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:37.972 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:36.965 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:36.464 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:35.965 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:34.954 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:34.457 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:33.954 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:32.952 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:32.450 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:31.951 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:31.445 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:30.940 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:30.446 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:29.440 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:28.936 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:28.439 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:27.933 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:27.432 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:26.931 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:25.921 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:25.419 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:24.920 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:24.415 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:23.915 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:23.414 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:22.908 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:22.409 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:21.907 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:21.402 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:20.903 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:20.405 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:19.896 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:19.397 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:18.896 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:17.887 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:17.389 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:16.885 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:16.382 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:15.884 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:15.383 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:14.875 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:14.375 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:13.875 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:12.863 warn LG TV ERR: timeout
              discovery.0 2017-07-26 20:05:12.361 warn MAX! Cube err: timeout
              discovery.0 2017-07-26 20:05:11.863 warn Mihome err: timeout
              discovery.0 2017-07-26 20:05:11.312 info Found 25 addresses
              discovery.0 2017-07-26 20:05:11.244 info Done discovering ping devices. 15 packages received
              discovery.0 2017-07-26 20:05:01.130 info Done discovering upnp devices. 10 packages received
              discovery.0 2017-07-26 20:05:00.972 info Done discovering mdns devices. 0 packages received
              discovery.0 2017-07-26 20:04:55.137 info Done discovering wifi-mi-light devices. 0 packages received
              discovery.0 2017-07-26 20:04:46.142 info Done discovering tr064 devices. 0 packages received
              discovery.0 2017-07-26 20:04:46.142 warn tr-064.0 not installed
              discovery.0 2017-07-26 20:04:46.129 info Discovering wifi-mi-light devices...
              discovery.0 2017-07-26 20:04:46.128 info Discovering UPnP devices...
              discovery.0 2017-07-26 20:04:45.970 info Discovering ping devices...
              discovery.0 2017-07-26 20:04:45.967 info Discovering mDNS devices...
              discovery.0 2017-07-26 20:04:00.125 info system.adapter.admin.0: logging true
              admin.0 2017-07-26 20:04:00.124 info system.adapter.admin.0: logging true
              admin.0 2017-07-26 20:04:00.122 info Change log subscriber state: true
              discovery.0 2017-07-26 20:03:50.592 info starting. Version 0.4.4 in /usr/local/lib/node_modules/iobroker/node_modules/iobroker.discovery, node: v8.2.1
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:50.089 info instance system.adapter.discovery.0 started with pid 2568
              admin.0 2017-07-26 20:03:48.314 info Repository received successfully.
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:47.538 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
              admin.0 2017-07-26 20:03:47.483 info Use link "http://localhost:8081" to configure.
              admin.0 2017-07-26 20:03:47.483 info http server listening on port 8081
              admin.0 2017-07-26 20:03:47.475 info received all states
              admin.0 2017-07-26 20:03:47.473 info Request actual repository...
              admin.0 2017-07-26 20:03:47.473 warn Repository cannot be read
              admin.0 2017-07-26 20:03:47.471 info received all objects
              admin.0 2017-07-26 20:03:47.461 info requesting all objects
              admin.0 2017-07-26 20:03:47.461 info requesting all states
              admin.0 2017-07-26 20:03:47.453 info starting. Version 1.8.1 in /usr/local/lib/node_modules/iobroker/node_modules/iobroker.admin, node: v8.2.1
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.111 info instance system.adapter.admin.0 started with pid 2567
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.085 info starting 2 instances
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.083 info 2 instances found
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.080 info InMemoryDB connected
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.076 info inMem-objects listening on port 9001
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.052 info inMem-states listening on port 9000
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info ip addresses: fe80::ca9:c83e:4baf:8132 192.168.178.55 fe80::108f:d048:a985:98f1 192.168.178.51 fe80::d000:a1ff:feb1:f8bf fe80::3806:31be:1f46:2f80
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info hostname: MacMini-LAN.fritz.box, node: v8.2.1
              host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info Copyright (c) 2014-2017 bluefox, hobbyquaker
              • BuZZyB Offline
                BuZZyB Offline
                BuZZy
                In welchem Ordner hast du installiert? Direkt auf "/"? Also auf der obersten Ebene?
                Von wo nach wo hast du verschoben?
                  thoduh
                  Wenn ich es direkt an einen anderen Ort installieren will, geht es aber wieder nicht. Deshalb wollte ich verschieben.
                  iobroker liegt jetzt hier: /usr/local/lib/node_modules/iobroker weil meine Homebridge auch schon da lag :D
                  iobroker läuft ja jetzt, kann es noch an Rechten liegen?
                  • BuZZyB Offline
                    BuZZyB Offline
                    BuZZy
                    Du kannst mal versuchen dem Ordner /usr/local/lib/node_modules/iobroker/ die Rechte 777 zuzuweisen.
                    Aber: Existiert der Ordner /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller überhaupt?
                      thoduh
                      Den Ordner: /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller gibt es doch nicht in meiner Kopie.
                      Muss morgen weiterschauen…
                      Danke nochmal !!
                      • BuZZyB Offline
                        BuZZyB Offline
                        BuZZy
                        Frage 1:
                        Existiert der Ordner?
                        Edit: hier stand Mist
                        Frage 2:
                        /usr/local/lib/node_modules/iobroker/iobroker-data/
                          thoduh
                          @BuZZy:
                          Frage 2:
                          Ja den gibt es bei mir.
                          Den ersten nicht…
                          Wie war der Befehl nochmal um an einen bestimmten Platz zu installieren?
                          • BuZZyB Offline
                            BuZZyB Offline
                            BuZZy
                            Ich vermute dein Mac versuche auf den falschen Ordner zuzugreifen.
                            EDIT […...]
                              thoduh
                              Kannst du mir nochmal den Befehl zum installieren an einem bestimmten Platz nennen?
                              Du hattest ihn vorhin mal irgendwo geschrieben, jetzt ist er leider weg.
                              • BuZZyB Offline
                                BuZZyB Offline
                                BuZZy
                                Ich bin mir nicht sicher ob iobroker bzw. npm das mag..
                                Aber du kannst es hiermit versuchen:
                                sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm --prefix /ort/wohin/es/soll
                                • BuZZyB Offline
                                  BuZZyB Offline
                                  BuZZy
                                  Edit; hier stand Müll..
                                    thoduh
                                    sudo npm install https://github.com/ioBroker/ioBroker/tarball/master –unsafe-perm --prefix /ort/wohin/es/soll
                                    Leider nicht funktioniert:
                                    MacMini-LAN:node_modules MacMini$ cd node_modules/iobroker.js-controller
                                    -bash: cd: node_modules/iobroker.js-controller: No such file or directory
                                    MacMini-LAN:node_modules MacMini$ cd iobroker
                                    MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controlle
                                    -bash: cd: node_modules/iobroker.js-controlle: No such file or directory
                                    MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controller
                                    MacMini-LAN:iobroker.js-controller MacMini$ chmod +x iobroker
                                    MacMini-LAN:iobroker.js-controller MacMini$ node controller.js
                                    host.MacMini-LAN.fritz.box check instance "system.adapter.admin.0" for host "MacMini-LAN.fritz.box"
                                    host.MacMini-LAN.fritz.box check instance "system.adapter.discovery.0" for host "MacMini-LAN.fritz.box"
                                    { Error: EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/log/iobroker.2017-07-26.log'
                                      errno: -13,
                                      code: 'EACCES',
                                      syscall: 'open',
                                      path: '/usr/local/lib/node_modules/iobroker/log/iobroker.2017-07-26.log' }
                                    EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                                    Error: EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                                        at Object.fs.openSync (fs.js:652:18)
                                        at Object.fs.writeFileSync (fs.js:1299:33)
                                        at saveConfig (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1749:16)
                                        at ObjectsInMemServer.destroy (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2677:26)
                                        at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/controller.js:2244:49
                                        at Timeout.waitForInstances [as _onTimeout] (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/controller.js:2197:49)
                                        at ontimeout (timers.js:469:11)
                                        at tryOnTimeout (timers.js:304:5)
                                        at Timer.listOnTimeout (timers.js:264:5)
                                    Bis morgen dann :lol:
                                    • BuZZyB Offline
                                      BuZZyB Offline
                                      BuZZy
                                      In welchem Ordner landest du wenn du den Befehl
                                      cd /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data
                                      eingibst?
                                        thoduh
                                        Hab ich noch nicht versucht, wollte es erneut aber diesmal an den richtigen Platz installieren. War ja nix ;) Morgen teste ich mal deinen anderen Vorschlag…
                                        • BuZZyB Offline
                                          BuZZyB Offline
                                          BuZZy
                                          Also halten wir kurz fest:
                                          1. Ich kenne mich nicht mit Mac aus… :D
                                          ````im Hauptverzeichnis "/" ausgeführt hat die Installation "korrekt" beendet. Die Versuche vorher in einem /User/ Ordner die Installation auszuführen hat nicht funktioniert.
                                          (Eventuell gibt es Probleme mit der Berechtigung wenn ein Script versucht in einen /User/ Ordner zu schreiben bzw. Dateien zu erstellen?!)
                                          3.
                                          Du hast den durch die Installation erstellen Ordner verschoben und jetzt gibts einen Haufen von Fehlern beim starten dass die Module nicht existieren bzw. nicht gefunden werden können.
                                          Dadurch dass du jetzt nochmal versucht hast ioBroker zu installieren bin ich mir nicht ganz sicher was passiert ist.
                                          Versuche nochmal ioBroker zu stoppen und dann wieder zu starten.
                                          Welche Ausgabe bekommst du dann im Log auf dem ioBroker Webinterface? Die gleiche die du vorhin schon gepostet hast?
                                          Bis Morgen. :D
