  4. Adapter: Radar
Adapter: Radar
350 Beiträge 59 Kommentatoren 109.7k Aufrufe 2 Beobachtet
  • P Offline
    ple
    #117
    Hatte den Adapter gerade mal neuinstalliert, aber mit ner Menge Fehlermeldung.
    Kann wer was damit anfangen?
    iobroker	2017-03-23 17:08:26.771	info	exit 0
    iobroker	2017-03-23 17:08:26.736	info	host.iobroker_Pi3 object system.adapter.radar.0 created
    iobroker	2017-03-23 17:08:26.676	info	host.iobroker_Pi3 object system.adapter.radar.0.alive created
    iobroker	2017-03-23 17:08:26.627	info	host.iobroker_Pi3 object system.adapter.radar.0.connected created
    iobroker	2017-03-23 17:08:26.583	info	host.iobroker_Pi3 object system.adapter.radar.0.memHeapUsed created
    iobroker	2017-03-23 17:08:26.536	info	host.iobroker_Pi3 object system.adapter.radar.0.memHeapTotal created
    iobroker	2017-03-23 17:08:26.494	info	host.iobroker_Pi3 object system.adapter.radar.0.memRss created
    iobroker	2017-03-23 17:08:26.426	info	host.iobroker_Pi3 object system.adapter.radar.0.uptime created
    iobroker	2017-03-23 17:08:26.398	info	host.iobroker_Pi3 create instance radar
    iobroker	2017-03-23 17:08:26.161	info	host.iobroker_Pi3 object system.adapter.radar created
    iobroker	2017-03-23 17:08:25.936	info	upload [0] radar.admin /opt/iobroker/node_modules/iobroker.radar/admin/index.html index.html text/html
    iobroker	2017-03-23 17:08:25.643	info	upload [1] radar.admin /opt/iobroker/node_modules/iobroker.radar/admin/radar.png radar.png image/png
    iobroker	2017-03-23 17:08:25.603	info	got /opt/iobroker/node_modules/iobroker.radar/admin
    iobroker	2017-03-23 17:08:25.560	info	host.iobroker_Pi3 install adapter radar
    iobroker	2017-03-23 17:07:30.571	info	optional dep failed, continuing usb@1.2.0
    iobroker	2017-03-23 17:07:30.565	info	npm WARN
    iobroker	2017-03-23 17:07:30.528	info	node-pre-gyp ERR! not ok
    iobroker	2017-03-23 17:07:30.528	info	node-pre-gyp ERR! node-pre-gyp -v v0.6.30
    iobroker	2017-03-23 17:07:30.528	info	node-pre-gyp ERR! node -v v4.6.2
    iobroker	2017-03-23 17:07:30.528	info	ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-
    iobroker	2017-03-23 17:07:30.523	info	node-pre-gyp
    iobroker	2017-03-23 17:07:30.520	info	node-pre-gyp ERR! System Linux 4.4.26-v7+
    iobroker	2017-03-23 17:07:30.517	info	node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
    iobroker	2017-03-23 17:07:30.517	info	node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:854:16)
    iobroker	2017-03-23 17:07:30.517	info	node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    iobroker	2017-03-23 17:07:30.517	info	node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
    iobroker	2017-03-23 17:07:30.517	info	ERR! stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.radar/node
    iobroker	2017-03-23 17:07:30.515	info	node-pre-gyp
    iobroker	2017-03-23 17:07:30.500	info	ERR! build error
    iobroker	2017-03-23 17:07:30.497	info	node-pre-gyp
    iobroker	2017-03-23 17:07:30.486	info	gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
    iobroker	2017-03-23 17:07:30.481	info	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usbgyp ERR! node -v v4.6.2
    iobroker	2017-03-23 17:07:30.479	info	gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.radar/node_modules/nob
    iobroker	2017-03-23 17:07:30.476	info	gyp ERR! System Linux 4.4.26-v7+
    iobroker	2017-03-23 17:07:30.473	info	at ChildProcess.emit (events.js:172:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
    iobroker	2017-03-23 17:07:30.470	info	gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack
    iobroker	2017-03-23 17:07:30.466	info	ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    iobroker	2017-03-23 17:07:30.463	info	gyp
    iobroker	2017-03-23 17:07:30.446	info	ERR! build error
    iobroker	2017-03-23 17:07:30.444	info
    iobroker	2017-03-23 17:07:30.435	info	gyp
    iobroker	2017-03-23 17:07:30.419	info	make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
    iobroker	2017-03-23 17:07:29.593	info	compilation terminated.
    iobroker	2017-03-23 17:07:29.593	info	^
    iobroker	2017-03-23 17:07:29.593	info	../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefunden #include
    iobroker	2017-03-23 17:06:45.136	info	Pre-built binaries not found for usb@1.2.0 and node@4.6.2 (node-v46 ABI) (falling back to source compile with node-gyp)
    iobroker	2017-03-23 17:06:45.131	info	node-pre-gyp ERR!
    iobroker	2017-03-23 17:06:45.128	info	Tried to download: https://github.com/tessel/node-usb/releases/download/1.2.0/usb_bindings-v1.2.0-node-v46-linux-arm.tar.gz
    iobroker	2017-03-23 17:06:45.125	info	ERR!
    iobroker	2017-03-23 17:06:45.122	info	node-pre-gyp
    iobroker	2017-03-23 17:06:10.026	info	WARN optional dep failed, continuing xpc-connection@0.1.4
    iobroker	2017-03-23 17:06:10.023	info	npm
    iobroker	2017-03-23 17:05:57.566	info	npm install iobroker.radar --production --prefix "/opt/iobroker" (System call)
    iobroker	2017-03-23 17:05:54.499	info	add radar
    Intel Nuc + Proxmox
    • C Offline
      CBeck
      #118
      Moin!
      Leider funktioniert der Adapter bei mir nicht zuverlässig und für mich ist es schon DAS zentrale Thema im Smarthome, verlässlich unterschiedlich bei An- und Abwesenheit mit Regeln reagieren zu können.
      Ich habe in Radar mein Nexus 6P mit IP- und Bluetoothadresse hinterlegt. Ich lasse mir Telegramnachrichten beim Verlassen und Ankommen zu Hause schicken. Jetzt bin ich den Tag über auf der Arbeit und habe fünf mal die Meldung bekommen, ich sei zu Hause und danach, ich bin nicht mehr zu Hause.
      Die große Frage, wieso erkennt Radar ich sei zu Hause? Er muss ja irgendwie die IP- oder Bluetoothadresse kurzfristig finden? Liegt es am Easyboxrouter von Vodafone?
      Würde es den Fehler beheben, wenn man einbaut, dass man zweimal als zu Hause erkannt werden muss? Von den mir geschickten Meldungen zu urteilen, erkennt er nur einmal dass ich zu Hause bin, die folgenden sind dann wieder false, bis ich abwesend bin. Kann man ja gut an den Zeiten der Telegramnachrichten sehen. Also als Workaround würde es wohl funktionieren.
      Danke!
      • apollon77A Offline
        #119
        Auf Bluetooth-Ebene habe ich exakt das gleiche Problem und finde es sehr interessant.
        Warum er überhaupt per Bluetooth etwas findet was die ID ist obwohl das Handy nicht daheim ist finde ich hoch interessant. Und bei mir ist es nur Bluetooth wo das Problem existiert.
        Vllt damit primär für Bluetooth so einen 2er-Zähler einbauen ?!
        Ingo F
        • C Offline
          CBeck
          #120
          @CBeck:
          Moin!
          Danke! `
          Ich bin inzwischen neun mal zu Hause angekommen. Von der Uhrzeit lässt sich keine Regelmäßigkeit erkennen.
          • P Offline
            ple
            #121
            Ich benutze für die Anwesenheit die G-Tags, diese funktioniere einwandfrei seit mehreren Wochen. Insgesamt habe ich 2 Stück im Einsatz und lasse mir auch per Telegram was schicken, wenn einer zu Hause ist oder abwesend. Steuer damit auch die Steckdosen sowie Lichter.
            Hast du mal versucht, nur das Bluetooth zu orten und nicht noch die IP Adresse?
            Intel Nuc + Proxmox
              #122
              Ich habe gerade geschaut. Es wird definitiv in den Fällen "btHere" gesetzt.
              Ich habe aktuell Kontakt dazu auch mit Frank per Github: https://github.com/frankjoke/iobroker.r … -316496115
              ich hab ein Log angefügt,
              Vielleicht kann @CBeck auch mal auf Debug schalten und logs schicken? :-)
              • C Offline
                CBeck
                #123
                Na klar, ich helfe gerne mit und kann heute Abend das umstellen.
                Ich muss dazu nur im Script bei Debug einen Haken setzen und was dort dann im Log ausgegeben wird, stelle ich hier rein?
                  #124
                  Hier oder ins Github-Ticket vllt noch besser. Und am besten dann log von der "minute" wo Du fälschlicherweise als "anwesend" erkannt wurdest
                  • C Offline
                    CBeck
                    #125
                    ähmmm…ne Anfängerfrage, wo stelle ich denn für einen Adapter den Debugmodus ein?? :oops:
                      #126
                      Unter "Instanzen" den Expertenmodus (eins der Icons oben links) einschalten, dann kommt eine weitere Spalte dazu wo du das Loglevel wählen kannst.
                      • HomoranH Offline
                        HomoranH Offline
                        #127
                        Liesmich
                        http://www.iobroker.net/docu/?page_id=5 … inschalten
                        Und
                        http://www.iobroker.net/docu/?page_id=5 … _Log_Stufe
                          #128
                          Bitte Update von Github einspielen, da ist am Timing was geändert (vllt fix es das) und Debug-Log erweitert.
                          Also bitte nach dem Update schauen ob es nochmal passiert und wenn ja das Log schicken
                          • C Offline
                            CBeck
                            #129
                            Ich habe gestern Abend die neue Version installiert und bislang keine 'Geisterankunft' zu Hause mehr gehabt!
                            • N Offline
                              N Offline
                              Neledo
                              #130
                              Mal ne frage, ich wollte kein neues Thema anfangen.
                              Ist den mal angedacht einen BACnet Adapter einzupflegen bzw. überhaupt zu machen….? :roll:
                                #131
                                Ein neues Thema wäre aber genau das richtige dafür :-)
                                • N Offline
                                  N Offline
                                  Neledo
                                  #132
                                  @apollon77:
                                  Ein neues Thema wäre aber genau das richtige dafür :-) `
                                  Erledigt… :D
                                  • frankjokeF Offline
                                    frankjokeF Offline
                                    frankjoke
                                    #133
                                    Danke appollon77 für die Erkärung mit den '.'ten :)
                                    Namen sollten nur Zeichenketten aus Buchstaben, '_-' und Zahlen sein…
                                    Übrigens, es gibt ein Radar-Update auf Git, auch auf NPM aber noch nicht in ioBrober ...
                                    Frank,
                                    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
                                    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
                                    • C Offline
                                      csamaggi
                                      #134
                                      Ich stehe auch vor dem Problem das mein IO meint ich wäre zu hause aber bin ich eben nicht.
                                      Meine Frage ist auch reicht es wenn das Handy nur gekoppelt ist oder muss eine Verbindung zum IO bestehen.
                                      Ich benutze die Windowsversion auf dem aktuellsten Stand.
                                      Mein Gedanke war eben auch damit ein Anwesenheitserkennung zu erstellen.
                                      Da meine Galaxy S8 Geräte ja in den Deep Sleep gehen und somit eine Erkennung mittels IP fast unmöglich ausser die Handys hängen am Strom.
                                      Muss ich bei der Installation was beachten?
                                      Ich habe es nochmal gelöscht und neu installiert und bekomme dies hier im Log.
                                      iobroker	2017-08-19 18:52:28.517	info	exit 0
                                      iobroker	2017-08-19 18:52:28.503	info	host.ioBroker object system.adapter.radar.0 created
                                      host.ioBroker	2017-08-19 18:52:28.476	info	object change system.adapter.radar.0
                                      iobroker	2017-08-19 18:52:28.436	info	host.ioBroker object system.adapter.radar.0.alive created
                                      iobroker	2017-08-19 18:52:28.401	info	host.ioBroker object system.adapter.radar.0.connected created
                                      iobroker	2017-08-19 18:52:28.373	info	host.ioBroker object system.adapter.radar.0.memHeapUsed created
                                      iobroker	2017-08-19 18:52:28.306	info	host.ioBroker object system.adapter.radar.0.memHeapTotal created
                                      iobroker	2017-08-19 18:52:28.269	info	host.ioBroker object system.adapter.radar.0.memRss created
                                      iobroker	2017-08-19 18:52:28.233	info	host.ioBroker object system.adapter.radar.0.uptime created
                                      iobroker	2017-08-19 18:52:28.199	info	host.ioBroker object system.adapter.radar.0.inputCount created
                                      iobroker	2017-08-19 18:52:28.166	info	host.ioBroker object system.adapter.radar.0.outputCount created
                                      iobroker	2017-08-19 18:52:28.156	info	host.ioBroker create instance radar
                                      iobroker	2017-08-19 18:52:28.099	info	host.ioBroker object system.adapter.radar created
                                      iobroker	2017-08-19 18:52:27.944	info	upload [0] radar.admin C:/ioBroker/node_modules/iobroker.radar/admin/index.html index.html text/html
                                      iobroker	2017-08-19 18:52:27.825	info	upload [1] radar.admin C:/ioBroker/node_modules/iobroker.radar/admin/radar.png radar.png image/png
                                      iobroker	2017-08-19 18:52:27.798	info	got C:/ioBroker/node_modules/iobroker.radar/admin
                                      javascript.0	2017-08-19 18:52:27.758	info	script.js.Telegram.Telegram_Patrick_Handy: Anzahl Wegepunkte: 13
                                      iobroker	2017-08-19 18:52:27.759	info	host.ioBroker install adapter radar
                                      javascript.0	2017-08-19 18:52:27.753	info	script.js.Telegram.Telegram_Patrick_Handy: Anzahl Wegepunkte: 13
                                      javascript.0	2017-08-19 18:52:26.428	info	script.js.Telegram.Telegram_Patrick_Handy: registered 2 subscriptions and 2 schedules
                                      javascript.0	2017-08-19 18:52:26.412	info	Start javascript script.js.Telegram.Telegram_Patrick_Handy
                                      iobroker	2017-08-19 18:51:59.121	info	WARN optional dep failed, continuing bluetooth-hci-socket@0.5.1
                                      iobroker	2017-08-19 18:51:59.119	info	npm
                                      iobroker	2017-08-19 18:51:59.097	info
                                      iobroker	2017-08-19 18:51:59.097	info	ERR! node-gyp -v v3.4.0gyp ERR! not ok
                                      iobroker	2017-08-19 18:51:59.095	info	gyp ERR! node -v v4.5.0gyp
                                      iobroker	2017-08-19 18:51:59.091	info
                                      iobroker	2017-08-19 18:51:59.091	info	gyp ERR! cwd C:\ioBroker\node_modules\iobroker.radar\node_modules\noble\node_modules\bluetooth-hci-socket
                                      iobroker	2017-08-19 18:51:59.091	info	gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
                                      iobroker	2017-08-19 18:51:59.091	info	gyp ERR! System Windows_NT 10.0.16257
                                      iobroker	2017-08-19 18:51:59.091	info	stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
                                      iobroker	2017-08-19 18:51:59.087	info	stack at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:449:14)gyp ERR!
                                      iobroker	2017-08-19 18:51:59.082	info	gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR!
                                      iobroker	2017-08-19 18:51:59.079	info	gyp ERR! configure error
                                      iobroker	2017-08-19 18:51:26.357	info	WARN optional dep failed, continuing xpc-connection@0.1.4
                                      iobroker	2017-08-19 18:51:26.355	info	npm
                                      iobroker	2017-08-19 18:51:17.612	info	npm install iobroker.radar --production --prefix "C:/ioBroker" (System call)
                                      iobroker	2017-08-19 18:51:15.630	info	add radar
                                      Nachtrag ich habe noch etwas in meinen Logs gefunden.````
                                      radar.0 2017-08-20 09:39:45.797 warn Noble not available, Error: { [Error: Cannot find module 'bluetooth-hci-socket'] code: 'MODULE_NOT_FOUND' }
                                      MFG Maggi
                                      • lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        #135
                                        Ich habe neuerdings den Radar Adapter bei mir am Laufen und bin damit sehr zufrieden.
                                        Ich hatte den Adapter mal vor einigen Monaten ausprobiert und leider lief er nicht so gut… ich weiß nicht mehr genau, ich glaube noble wollte nicht, und das obwohl ich das BT-Scanner Script laufen hatte, welches erfolgreich den Einsatz von noble bestätigte.
                                        Ich glaube das Problem war der parallele Einsatz vom BT-Scanner-Script!? Vielleicht hilft es ja jemandem.
                                        Bei mir läuft Version 1.0.2 und BT auf einem brix3150 unter ubuntu server:
                                        radar.0	2017-08-23 15:50:15.168	info	radar set use of noble(true), fping(true), doMac(true), doHci(true) and doBtv(false).
                                        Im Gegensatz zum Ping-Adapter erkennt Radar bei mir auch die Alexa Echo Geräte. Benutzen tue ich 5 g-tags.
                                        Was bei mir noch nicht so rund läuft ist die Auflistung AllUnknownIPs. Hier werden ganz viele Geräte angezeigt, die ich im Adapter eingetragen werden und hier auch zuverlässig angezeigt werden. Außerdem werden diese 17 - 20 x wiederholt angezeigt.
                                        Host: NUC8i3 mit Proxmox:
                                        • Slave: Pi4
                                        • N Offline
                                          N Offline
                                          Nabla
                                          #136
                                          @ple:
                                          Gruß `
                                          Auch wieder ein super Adapter. Und die G-Tags sehen auch super aus. Na das wird wieder alles teuer…
                                          Frage: Wo kriege ich die Blutooth-Codes der G-Tags für den Radar-Adapter her? Kriegt man die über die Gigaset-App? (Habe noch nichts bestellt...)
