  4. [GELÖST] IOT, Influxdb und scenes adapter starten nicht
    5.7k
5 Beiträge 2 Kommentatoren 423 Aufrufe 1 Beobachtet
  • peterk34P Offline
    peterk34P Offline
    peterk34
    schrieb am zuletzt editiert von peterk34
    Hab plötzlich das Problem, dass nach einem Iob restart diese Adapter nicht mehr starten.
    was soll ich denn da tun?
    2022-10-23 15:30:31.017 - error: iot.0 (11794) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:30:31.032 - error: iot.0 (11794) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:31.057 - error: iot.0 (11794) TypeError: Cannot read properties of null (reading '_id')
    at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    at Array.map ()
    at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:30:31.059 - error: iot.0 (11794) Cannot read properties of null (reading '_id')
    2022-10-23 15:30:31.226 - error: iot.0 (11794) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:30:31.227 - error: iot.0 (11794) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:31.229 - error: iot.0 (11794) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:30:31.231 - error: iot.0 (11794) Cannot read properties of null (reading '_id')
    2022-10-23 15:30:31.430 - info: iot.0 (11794) terminating
    2022-10-23 15:30:31.433 - warn: iot.0 (11794) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:30:31.779 - info: iot.0 (11794) Connection changed: connect
    2022-10-23 15:30:32.201 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:30:32.205 - error: host.IOB-KEP Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:32.207 - error: host.IOB-KEP Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:30:32.207 - error: host.IOB-KEP Caught by controller[1]: at Array.map ()
    2022-10-23 15:30:32.208 - error: host.IOB-KEP Caught by controller[1]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:30:32.209 - error: host.IOB-KEP Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:30:32.213 - error: host.IOB-KEP Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:30:32.214 - error: host.IOB-KEP Caught by controller[3]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:32.215 - error: host.IOB-KEP Caught by controller[3]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:30:32.216 - error: host.IOB-KEP Caught by controller[3]: at Array.map ()
    2022-10-23 15:30:32.217 - error: host.IOB-KEP Caught by controller[3]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:30:32.218 - error: host.IOB-KEP Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:30:32.220 - error: host.IOB-KEP instance system.adapter.iot.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:30:32.224 - info: host.IOB-KEP Restart adapter system.adapter.iot.0 because enabled
    2022-10-23 15:30:33.718 - info: host.IOB-KEP instance system.adapter.cloud.0 started with pid 11860
    2022-10-23 15:30:35.952 - info: yahka.0 (11812) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:37.133 - info: host.IOB-KEP instance system.adapter.tesla-motors.0 started with pid 11884
    2022-10-23 15:30:36.054 - info: yahka.0 (11812) adapter ready, checking config
    2022-10-23 15:30:36.132 - info: yahka.0 (11812) adding Weihnachtsstern with UUID: b53931b6-542c-4b75-af2f-af9758833f7d
    2022-10-23 15:30:36.174 - info: yahka.0 (11812) adding Pott with UUID: e9413155-c5b8-423b-a1d4-03b24a1b132c
    2022-10-23 15:30:36.210 - info: yahka.0 (11812) adding Rollo Terrasse Süd with UUID: 15d4096d-67d8-431f-bd1f-da9cd4e2bb93
    2022-10-23 15:30:36.251 - info: yahka.0 (11812) adding Filter with UUID: cf342739-9ba9-4687-8168-8226aac21e54
    2022-10-23 15:30:36.263 - info: yahka.0 (11812) adding Aussentemperatur with UUID: 64c2c532-3e10-40e7-8812-1d1948de34a4
    2022-10-23 15:30:36.270 - info: yahka.0 (11812) adding Küche with UUID: 7410fb91-b30d-4c98-9816-8a1e70d90a6a
    2022-10-23 15:30:36.299 - info: yahka.0 (11812) adding Esstisch with UUID: 61b6b24a-20f1-4163-8a64-744d79397d1c
    2022-10-23 15:30:36.328 - info: yahka.0 (11812) adding Wohnzimmer with UUID: 709f80df-e61a-4552-8acc-ea8cf98cab20
    2022-10-23 15:30:36.342 - info: yahka.0 (11812) adding Windfang with UUID: cf3d3dbd-03a7-48dd-b0ab-51376a9988e7
    2022-10-23 15:30:36.359 - info: yahka.0 (11812) adding Terrasse Pott with UUID: d6680a1c-4d05-4aae-a343-a50afeef2ea9
    2022-10-23 15:30:36.372 - info: yahka.0 (11812) adding Sandfilter with UUID: 072ec803-bd46-4c15-956e-a10af19e7714
    2022-10-23 15:30:36.377 - info: yahka.0 (11812) adding Heizung Sandfilter with UUID: 01438e49-5e90-42a3-8232-239a6aa54582
    2022-10-23 15:30:36.395 - info: yahka.0 (11812) adding Stiege OG with UUID: e891951f-f16c-42dc-95a9-2495c935e7b9
    2022-10-23 15:30:36.403 - info: yahka.0 (11812) adding Stiege KG with UUID: 0ff1eb65-67f8-4595-bb9a-5a367719087a
    2022-10-23 15:30:36.410 - info: yahka.0 (11812) adding WC EG with UUID: cfe8e06c-ca72-45b1-89bb-71c4e49e55d5
    2022-10-23 15:30:36.416 - info: yahka.0 (11812) adding Rollo Terrasse West with UUID: 4faac5a4-a76a-4ee2-b65f-2b4172b4e839
    2022-10-23 15:30:36.427 - info: yahka.0 (11812) adding Rollo Wohnzimmer with UUID: b04a2f36-b555-4446-8135-8e24102f28f9
    2022-10-23 15:30:36.435 - info: yahka.0 (11812) adding Rollo Küche Süd with UUID: ee844746-5ca8-4e35-9048-ed0a2a98cab0
    2022-10-23 15:30:36.444 - info: yahka.0 (11812) adding Küche Ost with UUID: d916afa6-90ca-4546-bcfa-2d63f32d7b95
    2022-10-23 15:30:36.464 - info: yahka.0 (11812) adding Rollo Abstellraum with UUID: cdeaea6f-fbc1-4f00-85bf-741b43d10642
    2022-10-23 15:30:36.472 - info: yahka.0 (11812) adding Rollo Lisa links with UUID: 39f061a1-8deb-4185-ba1d-df27cc2b8cbf
    2022-10-23 15:30:36.482 - info: yahka.0 (11812) adding Rollo Balkontüre with UUID: 1135505e-6f18-44d5-b068-9d38e1097b9d
    2022-10-23 15:30:36.489 - info: yahka.0 (11812) adding Abstellraum with UUID: 1eb72d12-e90b-4761-a327-48c4078f2e81
    2022-10-23 15:30:36.498 - info: yahka.0 (11812) adding WC OG with UUID: 1809c4a6-0aeb-4a1a-bfe8-347febb633fa
    2022-10-23 15:30:36.504 - info: yahka.0 (11812) adding Gang OG with UUID: 9bde4210-bccc-48dd-9072-8b29ea6901e4
    2022-10-23 15:30:36.509 - info: yahka.0 (11812) adding Schlaf Zimmer with UUID: 71c95999-fc0d-4348-ba19-822a69f8ae2d
    2022-10-23 15:30:36.516 - info: yahka.0 (11812) adding Lisa with UUID: f264f4fb-a30f-41bd-84f3-72908b7b1c1b
    2022-10-23 15:30:36.521 - info: yahka.0 (11812) adding Niklas with UUID: b316eb59-9872-4e05-ae10-8ed9d0fdfa47
    2022-10-23 15:30:36.526 - info: yahka.0 (11812) adding David with UUID: ccdd12a5-3640-4df8-97b6-96f15ffeae0d
    2022-10-23 15:30:36.533 - info: yahka.0 (11812) adding Dachboden with UUID: 86bd0815-7577-4ab9-b127-dc72a7e2d45c
    2022-10-23 15:30:36.537 - info: yahka.0 (11812) adding Gang KG with UUID: 46a80e8e-f724-434e-b163-c36ebabc0b75
    2022-10-23 15:30:36.543 - info: yahka.0 (11812) adding Dusche KG with UUID: 6efa6934-31c2-4d5d-84a6-8a76daf0673f
    2022-10-23 15:30:36.550 - info: yahka.0 (11812) adding Schutzraum with UUID: 9cfd038f-7c87-426d-ab94-9c5bc58856df
    2022-10-23 15:30:36.562 - info: yahka.0 (11812) adding Praxis with UUID: 07e1c908-7b1c-4239-b0c5-a9ee1ca328d1
    2022-10-23 15:30:36.567 - info: yahka.0 (11812) adding Büro with UUID: ae6ca9bf-4c02-4dde-a603-66782567eb68
    2022-10-23 15:30:36.572 - info: yahka.0 (11812) adding Wärmepumpe with UUID: 1a4a930f-4e68-42c3-a00e-c67ecbdd1046
    2022-10-23 15:30:36.576 - info: yahka.0 (11812) adding Schuko vor Büro with UUID: c947dbf4-6268-42f1-b2ec-a0000b308ce1
    2022-10-23 15:30:36.579 - info: yahka.0 (11812) adding Stall with UUID: 188b50db-3b86-4ab4-aa6f-129161585431
    2022-10-23 15:30:36.587 - info: yahka.0 (11812) adding Clubhaus with UUID: b21ccb04-f04a-4fb5-827e-d63d623f25a7
    2022-10-23 15:30:36.593 - info: yahka.0 (11812) adding Heizung Stall with UUID: 71918f7c-604e-4bd8-b288-5233e6aea85b
    2022-10-23 15:30:36.598 - info: yahka.0 (11812) adding Mikrowelle with UUID: e2650c41-4fda-4326-99aa-f088301db4f1
    2022-10-23 15:30:36.604 - info: yahka.0 (11812) adding TV David with UUID: 13f92415-ab9e-426c-ae7e-542e2dd04c98
    2022-10-23 15:30:36.609 - info: yahka.0 (11812) adding Rollo Esstisch with UUID: e83a9ae4-e37a-4db6-9c1f-eefaf86ef2d4
    2022-10-23 15:30:36.617 - info: yahka.0 (11812) adding Schatten Tisch with UUID: 6925f2bc-5c08-48ca-a622-b357069a36c9
    2022-10-23 15:30:36.625 - info: yahka.0 (11812) adding Terrasse with UUID: 8a0d8827-3ab5-4472-b34c-346292097a39
    2022-10-23 15:30:36.633 - info: yahka.0 (11812) adding Schatten Küche with UUID: c3a9bc7c-53cb-4592-a415-af6a26618b5b
    2022-10-23 15:30:36.640 - info: yahka.0 (11812) adding Rollo David with UUID: df12fd14-a573-45ad-a51c-a40bdf49a96b
    2022-10-23 15:30:36.650 - info: yahka.0 (11812) adding Rollo Niklas with UUID: 543f8e85-df55-49e1-b947-b042b262fc11
    2022-10-23 15:30:36.658 - info: yahka.0 (11812) adding Schuko bei Balkontüre with UUID: ae84869c-e5e5-4b51-92e5-dbb4cd9e79f8
    2022-10-23 15:30:36.664 - info: yahka.0 (11812) adding Kühlschrank with UUID: 69199983-0052-4549-acc5-bddc3e0fbd83
    2022-10-23 15:30:36.671 - info: yahka.0 (11812) adding Schuko bei Haustüre with UUID: 866476fc-3181-42f4-be5b-c7f4715f071a
    2022-10-23 15:30:36.678 - info: yahka.0 (11812) adding Türöffner with UUID: 21772c44-f126-420e-b9dc-cbe93907ab7f
    2022-10-23 15:30:36.706 - info: yahka.0 (11812) adding LED Haustüre with UUID: e4150059-9f67-4fde-b9c4-2e4ee3ac8710
    2022-10-23 15:30:36.712 - info: yahka.0 (11812) adding Heizung Werkstatt with UUID: 15508b2c-e31c-48e8-b6e7-9b77ffd714ac
    2022-10-23 15:30:36.715 - info: yahka.0 (11812) adding Lade Steckdose with UUID: ee8bf58d-3fe6-4a61-83bb-d4141a74bbf1
    2022-10-23 15:30:36.724 - info: yahka.0 (11812) adding Abstellraum Nord with UUID: 3f94962a-6a79-4fd7-b8c7-437e5cdddc4e
    2022-10-23 15:30:36.732 - info: yahka.0 (11812) adding Rollo Lisa rechts with UUID: 69bc75b6-5612-4120-bbb8-f2f831014ccf
    2022-10-23 15:30:36.741 - info: yahka.0 (11812) adding Bürotür with UUID: 4a11196d-e0b8-40f3-940e-654cd5b02e31
    2022-10-23 15:30:36.755 - error: yahka.0 (11812) [undefined] unable to establish link between Bürotüre and undefined - one of the services was not found or is disabled
    2022-10-23 15:30:36.758 - info: yahka.0 (11812) adding Weihnachtsdeko with UUID: 2e8c693e-5e7b-4c53-8e5b-2c605a7bbc53
    2022-10-23 15:30:36.764 - info: yahka.0 (11812) adding Werkstatt with UUID: bc361fa1-8828-4359-a33d-cadc2b8470da
    2022-10-23 15:30:36.771 - info: yahka.0 (11812) adding Jetzt Laden with UUID: 6dd67fc6-0d0e-40ce-a2cc-d147198b5d08
    2022-10-23 15:30:36.779 - info: yahka.0 (11812) adding Werkstatt Dachboden with UUID: b5465164-0d0c-41f4-943f-6995332b8cdd
    2022-10-23 15:30:36.785 - info: yahka.0 (11812) adding Weg with UUID: edd837c4-6d63-4915-855a-a8c77cc84466
    2022-10-23 15:30:36.792 - info: yahka.0 (11812) adding Hühnerauslauf with UUID: 9aa7a1f1-52e3-43a5-b6d7-498bdb677594
    2022-10-23 15:30:36.801 - info: yahka.0 (11812) adding Carport with UUID: 3cf68dde-e1da-44ab-afd9-885f3e1739fc
    2022-10-23 15:30:36.808 - info: yahka.0 (11812) adding Poolheizung with UUID: 83fef8ae-cd2d-4036-834b-c6749a988c59
    2022-10-23 15:30:36.815 - info: yahka.0 (11812) adding UV Lampe with UUID: 82b6348f-3ab8-40ea-a6f2-3e6a2fcf3de3
    2022-10-23 15:30:36.821 - info: yahka.0 (11812) adding Kompressor with UUID: 73bcfec6-5bcf-49cd-9d85-9bf66fa0d4dd
    2022-10-23 15:30:36.828 - info: yahka.0 (11812) adding TWC with UUID: e3021a3d-724f-448c-9371-753f2edddf27
    2022-10-23 15:30:36.837 - info: yahka.0 (11812) adding Christbaum with UUID: efeb0341-f17f-43df-a590-8cef2c8dff1f
    2022-10-23 15:30:36.846 - info: yahka.0 (11812) adding Futteraufzug with UUID: 5f1d0758-34f5-4bc1-a049-e5232501c4a3
    2022-10-23 15:30:36.854 - info: yahka.0 (11812) adding Überschussladen with UUID: 194536ce-20e8-4cfe-921e-a07b1eba41db
    2022-10-23 15:30:36.872 - info: yahka.0 (11812) adding StarteTesla with UUID: ebbf37f3-de73-4bb9-9144-1a427433d487
    2022-10-23 15:30:36.897 - info: yahka.0 (11812) adding Ladestart durch App with UUID: 679b1b81-1c13-43c1-9b72-8e2a7e9fe868
    2022-10-23 15:30:36.917 - info: yahka.0 (11812) adding Ladestart nach Anstecken with UUID: d9e2a4e5-d2a8-4b53-ad59-c9665a0addc7
    2022-10-23 15:30:36.923 - info: yahka.0 (11812) adding Hühner Klappe with UUID: 5b6af14e-603c-41b2-9adb-04f6068ad67b
    2022-10-23 15:30:36.933 - info: yahka.0 (11812) adding KG Auto OFF with UUID: 7fb49074-227f-4d8f-b449-70881d5c289f
    2022-10-23 15:30:36.937 - info: yahka.0 (11812) adding FBH Lisa with UUID: 079d814a-549d-4d20-ac33-f2b6c24fcb72
    2022-10-23 15:30:36.943 - info: yahka.0 (11812) adding FBH Niklas with UUID: 8c806922-f67f-46a5-b629-8a4c9b6b3a0d
    2022-10-23 15:30:36.947 - info: yahka.0 (11812) adding FBH David with UUID: ef5fbdbc-977c-4116-b11e-5d0d8e0f0ffb
    2022-10-23 15:30:36.952 - info: yahka.0 (11812) adding Geschirrspüler with UUID: 9a5de821-d2db-46c7-a63d-2675378e26d0
    2022-10-23 15:30:36.958 - info: yahka.0 (11812) adding Waschmaschine with UUID: 092549f0-dc4d-4738-8eb2-8d216055c5ad
    2022-10-23 15:30:36.963 - info: yahka.0 (11812) adding Trockner with UUID: 9ec01dd4-25a6-43e0-90fe-a1b97e231a79
    2022-10-23 15:30:36.976 - info: yahka.0 (11812) adding FBH AR with UUID: 231bd759-05f5-43bc-a938-87da17a1eb60
    2022-10-23 15:30:36.980 - info: yahka.0 (11812) adding FBH Gang KG with UUID: 4cbedd37-b7c3-4b3f-b269-97ebb9ab4585
    2022-10-23 15:30:36.989 - info: yahka.0 (11812) publishing bridge Iobroker on 0.0.0.0 using ciao
    2022-10-23 15:30:37.365 - info: host.IOB-KEP instance system.adapter.influxdb.0 started with pid 11891
    2022-10-23 15:30:40.073 - info: yr.0 (11600) Data updated.
    2022-10-23 15:30:40.077 - info: yr.0 (11600) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-23 15:30:40.094 - info: cloud.0 (11860) starting. Version 4.2.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:40.214 - info: cloud.0 (11860) Connecting with https://iobroker.pro:10555 with "@pro_peterk34@msn.com_2659ba20-3709-11eb-81d0-0da9bca32909"
    2022-10-23 15:30:40.670 - info: cloud.0 (11860) Trying to connect as system.user.admin to cloud
    2022-10-23 15:30:40.727 - info: host.IOB-KEP instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-23 15:30:41.168 - info: cloud.0 (11860) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
    2022-10-23 15:30:41.174 - info: cloud.0 (11860) Connection changed: disconnect
    2022-10-23 15:30:43.731 - info: tesla-motors.0 (11884) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.tesla-motors, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:44.224 - info: host.IOB-KEP instance system.adapter.scenes.0 started with pid 11962
    2022-10-23 15:30:45.062 - info: host.IOB-KEP instance system.adapter.text2command.0 started with pid 11973
    2022-10-23 15:30:45.362 - info: vis.0 (11939) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:45.725 - error: influxdb.0 (11891) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:30:45.730 - error: influxdb.0 (11891) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:45.748 - error: influxdb.0 (11891) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:30:45.749 - error: influxdb.0 (11891) Cannot read properties of null (reading '_id')
    2022-10-23 15:30:45.843 - warn: influxdb.0 (11891) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:30:46.154 - info: vis.0 (11939) vis license is OK.
    2022-10-23 15:30:46.652 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:30:46.663 - error: host.IOB-KEP Caught by controller[0]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:46.664 - error: host.IOB-KEP Caught by controller[0]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:30:46.665 - error: host.IOB-KEP Caught by controller[0]: at Array.map ()
    2022-10-23 15:30:46.666 - error: host.IOB-KEP Caught by controller[0]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:30:46.666 - error: host.IOB-KEP Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:30:46.667 - error: host.IOB-KEP instance system.adapter.influxdb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:30:46.668 - info: host.IOB-KEP Restart adapter system.adapter.influxdb.0 because enabled
    2022-10-23 15:30:46.669 - warn: host.IOB-KEP Do not restart adapter system.adapter.influxdb.0 because restart loop detected
    2022-10-23 15:30:49.113 - info: host.IOB-KEP instance system.adapter.terminal.0 started with pid 11994
    2022-10-23 15:30:49.509 - info: vis.0 (11939) Terminated (NO_ERROR): Without reason
    2022-10-23 15:30:50.212 - info: host.IOB-KEP instance system.adapter.vis.0 terminated while should be started once
    2022-10-23 15:30:50.268 - info: scenes.0 (11962) starting. Version 2.3.9 in /opt/iobroker/node_modules/iobroker.scenes, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:50.900 - info: text2command.0 (11973) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:51.820 - error: scenes.0 (11962) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:30:51.823 - error: scenes.0 (11962) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:51.845 - error: scenes.0 (11962) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:30:51.847 - error: scenes.0 (11962) Cannot read properties of null (reading '_id')
    2022-10-23 15:30:51.932 - info: scenes.0 (11962) terminating
    2022-10-23 15:30:51.934 - warn: scenes.0 (11962) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:30:52.606 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:30:52.607 - error: host.IOB-KEP Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:30:52.607 - error: host.IOB-KEP Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:30:52.608 - error: host.IOB-KEP Caught by controller[1]: at Array.map ()
    2022-10-23 15:30:52.608 - error: host.IOB-KEP Caught by controller[1]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:30:52.609 - error: host.IOB-KEP Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:30:52.609 - error: host.IOB-KEP instance system.adapter.scenes.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:30:52.610 - info: host.IOB-KEP Restart adapter system.adapter.scenes.0 because enabled
    2022-10-23 15:30:52.611 - warn: host.IOB-KEP Do not restart adapter system.adapter.scenes.0 because restart loop detected
    2022-10-23 15:30:53.135 - info: host.IOB-KEP instance system.adapter.vis-inventwo.0 started with pid 12050
    2022-10-23 15:30:54.439 - info: shelly.1 (11682) [MQTT] Device 192.168.8.22 (shelly1 / shelly1-76FB3F / SHSW-1#76FB3F#1) connected! Polltime set to 45 sec.
    2022-10-23 15:30:54.944 - info: terminal.0 (11994) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.terminal, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:55.139 - info: terminal.0 (11994) http server listening on port 8089
    2022-10-23 15:30:56.323 - info: vis-inventwo.0 (12050) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:30:57.043 - info: host.IOB-KEP instance system.adapter.e3dc-rscp.0 started with pid 12069
    2022-10-23 15:30:57.548 - info: shelly.1 (11682) [MQTT] Device 192.168.8.54 (shellyswitch25 / shellyswitch25-C4CCCC / SHSW-25#C4CCCC#1) connected! Polltime set to 45 sec.
    2022-10-23 15:30:58.577 - info: shelly.1 (11682) [MQTT] Device 192.168.8.37 (shelly1 / shelly1-76B63D / SHSW-1#76B63D#1) connected! Polltime set to 45 sec.
    2022-10-23 15:30:59.816 - info: e3dc-rscp.0 (12069) starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.e3dc-rscp, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:00.174 - info: e3dc-rscp.0 (12069) Connection to E3/DC is established
    2022-10-23 15:31:00.260 - info: host.IOB-KEP instance system.adapter.yr.0 started with pid 12121
    2022-10-23 15:31:01.031 - info: host.IOB-KEP instance system.adapter.deconz.1 started with pid 12128
    2022-10-23 15:31:02.149 - info: shelly.1 (11682) [MQTT] Device 192.168.8.28 (shelly1 / shelly1-76F012 / SHSW-1#76F012#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:02.411 - info: host.IOB-KEP instance system.adapter.iot.0 started with pid 12135
    2022-10-23 15:31:03.557 - info: shelly.1 (11682) [MQTT] Device 192.168.8.35 (shelly1 / shelly1-767894 / SHSW-1#767894#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:03.880 - info: shelly.1 (11682) [MQTT] Device 192.168.8.77 (shelly1 / shelly1-115F59 / SHSW-1#115F59#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:03.902 - info: shelly.1 (11682) [MQTT] Device 192.168.8.33 (shelly1 / shelly1-768BDB / SHSW-1#768BDB#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:04.157 - info: shelly.1 (11682) [MQTT] Device 192.168.8.27 (shelly1 / shelly1-768B43 / SHSW-1#768B43#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:04.350 - info: shelly.1 (11682) [MQTT] Device 192.168.8.75 (shellyswitch25 / shellyswitch25-C4BD59 / SHSW-25#C4BD59#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:04.604 - info: yr.0 (12121) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:04.715 - info: yr.0 (12121) longitude/longitude not set, get data from system
    2022-10-23 15:31:04.759 - info: yr.0 (12121) system latitude: 47.57459550809082 longitude: 14.240491133346408
    2022-10-23 15:31:05.059 - info: host.IOB-KEP instance system.adapter.discovery.0 started with pid 12155
    2022-10-23 15:31:06.144 - info: deconz.1 (12128) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:06.365 - error: deconz.1 (12128) Could not connect to deConz/Phoscon. Error: connect ECONNREFUSED 192.168.8.164:8078
    2022-10-23 15:31:07.058 - info: shelly.1 (11682) [MQTT] Device 192.168.8.8 (shellyswitch25 / shellyswitch25-BCDDC277456C / SHSW-25#BCDDC277456C#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:07.249 - info: shelly.1 (11682) [MQTT] Device 192.168.8.85 (shelly1pm / shelly1pm-76DDEA / SHSW-PM#76DDEA#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:07.259 - info: shelly.1 (11682) [MQTT] Device 192.168.8.68 (shelly1 / shelly1-8CAAB54B510D / SHSW-1#8CAAB54B510D#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.257 - info: shelly.1 (11682) [MQTT] Device 192.168.8.67 (shelly1pm / shelly1pm-E09806AA068A / SHSW-PM#E09806AA068A#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.264 - info: shelly.1 (11682) [MQTT] Device 192.168.8.78 (shelly1 / shelly1-483FDA6FA854 / SHSW-1#483FDA6FA854#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.291 - info: shelly.1 (11682) [MQTT] Device 192.168.8.21 (shelly1 / shelly1-7683A7 / SHSW-1#7683A7#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.301 - info: shelly.1 (11682) [MQTT] Device 192.168.8.32 (shelly1 / shelly1-BA43F6 / SHSW-1#BA43F6#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.308 - info: shelly.1 (11682) [MQTT] Device 192.168.8.40 (shelly1pm / shelly1pm-E09806A9CB4F / SHSW-PM#E09806A9CB4F#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.337 - info: shelly.1 (11682) [MQTT] Device 192.168.8.36 (shelly1 / shelly1-771A3D / SHSW-1#771A3D#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.941 - info: shelly.1 (11682) [MQTT] Device 192.168.8.19 (shelly1 / shelly1-B8DCDD / SHSW-1#B8DCDD#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:08.983 - info: host.IOB-KEP instance system.adapter.ekey.0 started with pid 12174
    2022-10-23 15:31:09.449 - info: iot.0 (12135) starting. Version 1.11.9 in /opt/iobroker/node_modules/iobroker.iot, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:09.733 - info: iot.0 (12135) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-10-23 15:31:10.515 - error: iot.0 (12135) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:31:10.516 - error: iot.0 (12135) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:10.540 - error: iot.0 (12135) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:31:10.542 - error: iot.0 (12135) Cannot read properties of null (reading '_id')
    2022-10-23 15:31:10.712 - error: iot.0 (12135) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:31:10.725 - error: iot.0 (12135) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:10.727 - error: iot.0 (12135) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:31:10.729 - error: iot.0 (12135) Cannot read properties of null (reading '_id')
    2022-10-23 15:31:10.812 - info: iot.0 (12135) terminating
    2022-10-23 15:31:10.834 - warn: iot.0 (12135) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:31:11.193 - info: discovery.0 (12155) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:11.268 - info: cloud.0 (11860) Trying to connect as system.user.admin to cloud
    2022-10-23 15:31:11.500 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:31:11.500 - error: host.IOB-KEP Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:11.501 - error: host.IOB-KEP Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:31:11.502 - error: host.IOB-KEP Caught by controller[1]: at Array.map ()
    2022-10-23 15:31:11.502 - error: host.IOB-KEP Caught by controller[1]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:31:11.503 - error: host.IOB-KEP Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:31:11.504 - error: host.IOB-KEP Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:31:11.505 - error: host.IOB-KEP Caught by controller[3]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:11.505 - error: host.IOB-KEP Caught by controller[3]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:31:11.506 - error: host.IOB-KEP Caught by controller[3]: at Array.map ()
    2022-10-23 15:31:11.509 - error: host.IOB-KEP Caught by controller[3]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:31:11.510 - error: host.IOB-KEP Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:31:11.510 - error: host.IOB-KEP instance system.adapter.iot.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:31:11.512 - info: host.IOB-KEP Restart adapter system.adapter.iot.0 because enabled
    2022-10-23 15:31:11.656 - info: cloud.0 (11860) Connection changed: connect
    2022-10-23 15:31:08.954 - info: shelly.1 (11682) [MQTT] Device 192.168.8.41 (shelly1pm / shelly1pm-F4CFA2E389A1 / SHSW-PM#F4CFA2E389A1#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.668 - info: shelly.1 (11682) [MQTT] Device 192.168.8.17 (shellyswitch25 / shellyswitch25-BCDDC277525E / SHSW-25#BCDDC277525E#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.684 - info: shelly.1 (11682) [MQTT] Device 192.168.8.88 (shelly1 / shelly1-76DCCF / SHSW-1#76DCCF#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.693 - info: shelly.1 (11682) [MQTT] Device 192.168.8.23 (shelly1pm / shelly1pm-76B3AE / SHSW-PM#76B3AE#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.701 - info: shelly.1 (11682) [MQTT] Device 192.168.8.87 (shelly1 / shelly1-76911E / SHSW-1#76911E#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.708 - info: shelly.1 (11682) [MQTT] Device 192.168.8.66 (shelly1pm / shelly1pm-F4CFA2E3B5D0 / SHSW-PM#F4CFA2E3B5D0#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.716 - info: shelly.1 (11682) [MQTT] Device 192.168.8.13 (shelly1 / shelly1-40F5201D0AD0 / SHSW-1#40F5201D0AD0#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.739 - info: shelly.1 (11682) [MQTT] Device 192.168.8.29 (shelly1 / shelly1-767CC3 / SHSW-1#767CC3#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.745 - info: shelly.1 (11682) [MQTT] Device 192.168.8.76 (shellyswitch25 / shellyswitch25-BCDDC2776D02 / SHSW-25#BCDDC2776D02#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.758 - info: shelly.1 (11682) [MQTT] Device 192.168.8.61 (shellyswitch25 / shellyswitch25-C4E6DB / SHSW-25#C4E6DB#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.773 - info: shelly.1 (11682) [MQTT] Device 192.168.8.34 (shelly1 / shelly1-767716 / SHSW-1#767716#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:12.973 - info: host.IOB-KEP instance system.adapter.g-homa.0 started with pid 12230
    2022-10-23 15:31:14.195 - info: ekey.0 (12174) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.ekey, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:14.507 - info: ekey.0 (12174) adapter listening 0.0.0.0:5555
    2022-10-23 15:31:14.733 - info: shelly.1 (11682) [MQTT] Device 192.168.8.73 (shelly1pm / shelly1pm-766595 / SHSW-PM#766595#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:14.753 - info: shelly.1 (11682) [MQTT] Device 192.168.8.79 (shelly1 / shelly1-B91FB0 / SHSW-1#B91FB0#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:16.226 - info: shelly.1 (11682) [MQTT] Device 192.168.8.51 (shellyswitch25 / shellyswitch25-C470DF / SHSW-25#C470DF#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:16.509 - info: shelly.1 (11682) [MQTT] Device 192.168.8.42 (shelly1 / shelly1-40F5201CA21A / SHSW-1#40F5201CA21A#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:16.517 - info: shelly.1 (11682) [MQTT] Device 192.168.8.50 (shellyswitch25 / shellyswitch25-76C7C5 / SHSW-25#76C7C5#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:16.531 - info: shelly.1 (11682) [MQTT] Device 192.168.8.11 (shellypro4pm / shellypro4pm-84cca87fff48 / shellypro4pm#84cca87fff48#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:16.556 - info: shelly.1 (11682) [MQTT] Device 192.168.8.59 (shellyswitch25 / shellyswitch25-C4D5DC / SHSW-25#C4D5DC#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:16.567 - info: shelly.1 (11682) [MQTT] Device 192.168.8.90 (shellyswitch25 / shellyswitch25-BCDDC27799EF / SHSW-25#BCDDC27799EF#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:16.970 - info: shelly.1 (11682) [MQTT] Device 192.168.8.26 (shelly1 / shelly1-7678F8 / SHSW-1#7678F8#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:17.119 - info: host.IOB-KEP instance system.adapter.info.0 started with pid 12245
    2022-10-23 15:31:16.981 - info: shelly.1 (11682) [MQTT] Device 192.168.8.10 (shellyem3 / shellyem3-84CCA8AD0EA1 / SHEM-3#84CCA8AD0EA1#1) connected! Polltime set to 45 sec.
    2022-10-23 15:31:19.131 - info: g-homa.0 (12230) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.g-homa, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:19.283 - info: g-homa.0 (12230) enumerating known plugs...
    2022-10-23 15:31:19.338 - info: g-homa.0 (12230) found plug with id 620836 (offline)
    2022-10-23 15:31:19.350 - info: g-homa.0 (12230) found plug with id 6252c6 (offline)
    2022-10-23 15:31:19.360 - info: g-homa.0 (12230) found plug with id ce0dca (offline)
    2022-10-23 15:31:19.363 - info: g-homa.0 (12230) starting server...
    2022-10-23 15:31:19.380 - info: g-homa.0 (12230) server started on port 50000
    2022-10-23 15:31:19.392 - info: g-homa.0 (12230) searching plugs
    2022-10-23 15:31:23.388 - info: yr.0 (12121) Data updated.
    2022-10-23 15:31:23.393 - info: yr.0 (12121) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-23 15:31:23.926 - info: host.IOB-KEP instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-23 15:31:24.529 - info: info.0 (12245) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:24.668 - info: info.0 (12245) Reading/updating systemdata.
    2022-10-23 15:31:25.261 - info: info.0 (12245) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    2022-10-23 15:31:25.330 - info: info.0 (12245) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    2022-10-23 15:31:25.503 - info: info.0 (12245) cpu Temp res = {"main":54.043,"cores":[],"max":54.043,"socket":[],"chipset":null}
    2022-10-23 15:31:38.314 - info: admin.0 (11262) ==> Connected system.user.admin from ::ffff:192.168.8.135
    2022-10-23 15:31:41.651 - info: host.IOB-KEP instance system.adapter.iot.0 started with pid 12859
    2022-10-23 15:31:45.641 - info: iot.0 (12859) starting. Version 1.11.9 in /opt/iobroker/node_modules/iobroker.iot, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:31:45.756 - info: iot.0 (12859) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-10-23 15:31:46.006 - error: iot.0 (12859) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:31:46.009 - error: iot.0 (12859) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:46.022 - error: iot.0 (12859) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:31:46.024 - error: iot.0 (12859) Cannot read properties of null (reading '_id')
    2022-10-23 15:31:46.063 - error: iot.0 (12859) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:31:46.064 - error: iot.0 (12859) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:46.065 - error: iot.0 (12859) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:31:46.066 - error: iot.0 (12859) Cannot read properties of null (reading '_id')
    2022-10-23 15:31:46.075 - info: iot.0 (12859) terminating
    2022-10-23 15:31:46.078 - warn: iot.0 (12859) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:31:46.465 - info: iot.0 (12859) Connection changed: connect
    2022-10-23 15:31:46.696 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:31:46.697 - error: host.IOB-KEP Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:46.698 - error: host.IOB-KEP Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:31:46.699 - error: host.IOB-KEP Caught by controller[1]: at Array.map ()
    2022-10-23 15:31:46.699 - error: host.IOB-KEP Caught by controller[1]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:31:46.700 - error: host.IOB-KEP Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:31:46.700 - error: host.IOB-KEP Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:31:46.700 - error: host.IOB-KEP Caught by controller[3]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:31:46.701 - error: host.IOB-KEP Caught by controller[3]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:31:46.705 - error: host.IOB-KEP Caught by controller[3]: at Array.map ()
    2022-10-23 15:31:46.705 - error: host.IOB-KEP Caught by controller[3]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:31:46.706 - error: host.IOB-KEP Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:31:46.707 - error: host.IOB-KEP instance system.adapter.iot.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:31:46.708 - info: host.IOB-KEP Restart adapter system.adapter.iot.0 because enabled
    2022-10-23 15:31:46.709 - warn: host.IOB-KEP Do not restart adapter system.adapter.iot.0 because restart loop detected
    2022-10-23 15:31:51.048 - info: admin.0 (11262) <== Disconnect system.user.admin from ::ffff:192.168.8.135 scenes
    2022-10-23 15:31:55.463 - info: admin.0 (11262) ==> Connected system.user.admin from ::ffff:192.168.8.135
    2022-10-23 15:31:59.014 - info: alexa2.0 (11517) Subscribing to states...
    2022-10-23 15:32:04.008 - info: alexa2.0 (11517) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2022-10-23 15:32:31.456 - info: alexa2.0 (11517) Initialization Done ...
    2022-10-23 15:32:43.193 - info: host.IOB-KEP instance system.adapter.iot.0 started with pid 13085
    2022-10-23 15:32:45.910 - info: iot.0 (13085) starting. Version 1.11.9 in /opt/iobroker/node_modules/iobroker.iot, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:32:45.998 - info: iot.0 (13085) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-10-23 15:32:46.183 - error: iot.0 (13085) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:32:46.184 - error: iot.0 (13085) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:32:46.192 - error: iot.0 (13085) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:32:46.193 - error: iot.0 (13085) Cannot read properties of null (reading '_id')
    2022-10-23 15:32:46.223 - error: iot.0 (13085) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:32:46.223 - error: iot.0 (13085) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:32:46.225 - error: iot.0 (13085) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:32:46.226 - error: iot.0 (13085) Cannot read properties of null (reading '_id')
    2022-10-23 15:32:46.235 - info: iot.0 (13085) terminating
    2022-10-23 15:32:46.237 - warn: iot.0 (13085) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:32:46.624 - info: iot.0 (13085) Connection changed: connect
    2022-10-23 15:32:46.830 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:32:46.830 - error: host.IOB-KEP Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:32:46.831 - error: host.IOB-KEP Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:32:46.831 - error: host.IOB-KEP Caught by controller[1]: at Array.map ()
    2022-10-23 15:32:46.831 - error: host.IOB-KEP Caught by controller[1]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:32:46.831 - error: host.IOB-KEP Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:32:46.832 - error: host.IOB-KEP Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:32:46.832 - error: host.IOB-KEP Caught by controller[3]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:32:46.832 - error: host.IOB-KEP Caught by controller[3]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:32:46.832 - error: host.IOB-KEP Caught by controller[3]: at Array.map ()
    2022-10-23 15:32:46.833 - error: host.IOB-KEP Caught by controller[3]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:32:46.833 - error: host.IOB-KEP Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:32:46.833 - error: host.IOB-KEP instance system.adapter.iot.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:32:46.833 - info: host.IOB-KEP Restart adapter system.adapter.iot.0 because enabled
    2022-10-23 15:33:12.433 - info: ws.0 (11723) ==> Connected system.user.admin from ::ffff:192.168.8.135
    2022-10-23 15:33:16.970 - info: host.IOB-KEP instance system.adapter.iot.0 started with pid 13214
    2022-10-23 15:33:19.561 - info: iot.0 (13214) starting. Version 1.11.9 in /opt/iobroker/node_modules/iobroker.iot, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:33:19.639 - info: iot.0 (13214) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-10-23 15:33:19.845 - error: iot.0 (13214) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:33:19.846 - error: iot.0 (13214) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:19.855 - error: iot.0 (13214) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:33:19.856 - error: iot.0 (13214) Cannot read properties of null (reading '_id')
    2022-10-23 15:33:19.885 - error: iot.0 (13214) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:33:19.885 - error: iot.0 (13214) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:19.887 - error: iot.0 (13214) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:33:19.888 - error: iot.0 (13214) Cannot read properties of null (reading '_id')
    2022-10-23 15:33:19.897 - info: iot.0 (13214) terminating
    2022-10-23 15:33:19.900 - warn: iot.0 (13214) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:33:20.320 - info: iot.0 (13214) Connection changed: connect
    2022-10-23 15:33:20.525 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:33:20.526 - error: host.IOB-KEP Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:20.526 - error: host.IOB-KEP Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:33:20.527 - error: host.IOB-KEP Caught by controller[1]: at Array.map ()
    2022-10-23 15:33:20.527 - error: host.IOB-KEP Caught by controller[1]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:33:20.528 - error: host.IOB-KEP Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:33:20.528 - error: host.IOB-KEP Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:33:20.528 - error: host.IOB-KEP Caught by controller[3]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:20.529 - error: host.IOB-KEP Caught by controller[3]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:33:20.529 - error: host.IOB-KEP Caught by controller[3]: at Array.map ()
    2022-10-23 15:33:20.529 - error: host.IOB-KEP Caught by controller[3]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:33:20.530 - error: host.IOB-KEP Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:33:20.530 - error: host.IOB-KEP instance system.adapter.iot.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:33:20.531 - info: host.IOB-KEP Restart adapter system.adapter.iot.0 because enabled
    2022-10-23 15:33:50.681 - info: host.IOB-KEP instance system.adapter.iot.0 started with pid 13342
    2022-10-23 15:33:53.119 - info: iot.0 (13342) starting. Version 1.11.9 in /opt/iobroker/node_modules/iobroker.iot, node: v16.18.0, js-controller: 4.0.23
    2022-10-23 15:33:53.195 - info: iot.0 (13342) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-10-23 15:33:53.395 - error: iot.0 (13342) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:33:53.396 - error: iot.0 (13342) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:53.405 - error: iot.0 (13342) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:33:53.405 - error: iot.0 (13342) Cannot read properties of null (reading '_id')
    2022-10-23 15:33:53.434 - error: iot.0 (13342) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-23 15:33:53.434 - error: iot.0 (13342) unhandled promise rejection: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:53.436 - error: iot.0 (13342) TypeError: Cannot read properties of null (reading '_id')
    at Array.map ()
    2022-10-23 15:33:53.437 - error: iot.0 (13342) Cannot read properties of null (reading '_id')
    2022-10-23 15:33:53.446 - info: iot.0 (13342) terminating
    2022-10-23 15:33:53.448 - warn: iot.0 (13342) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-23 15:33:53.856 - info: iot.0 (13342) Connection changed: connect
    2022-10-23 15:33:54.051 - error: host.IOB-KEP Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:33:54.052 - error: host.IOB-KEP Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:54.053 - error: host.IOB-KEP Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:33:54.053 - error: host.IOB-KEP Caught by controller[1]: at Array.map ()
    2022-10-23 15:33:54.053 - error: host.IOB-KEP Caught by controller[1]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:33:54.054 - error: host.IOB-KEP Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:33:54.054 - error: host.IOB-KEP Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-10-23 15:33:54.054 - error: host.IOB-KEP Caught by controller[3]: TypeError: Cannot read properties of null (reading '_id')
    2022-10-23 15:33:54.055 - error: host.IOB-KEP Caught by controller[3]: at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3422:42
    2022-10-23 15:33:54.055 - error: host.IOB-KEP Caught by controller[3]: at Array.map ()
    2022-10-23 15:33:54.055 - error: host.IOB-KEP Caught by controller[3]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3414:39)
    2022-10-23 15:33:54.056 - error: host.IOB-KEP Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-10-23 15:33:54.056 - error: host.IOB-KEP instance system.adapter.iot.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-23 15:33:54.057 - info: host.IOB-KEP Restart adapter system.adapter.iot.0 because enabled
    2022-10-23 15:33:54.057 - warn: host.IOB-KEP Do not restart adapter system.adapter.iot.0 because restart loop detected
    UPDATE: Ich hab jetzt gar nicht lang weitergesucht und den Stand von gestern eingespielt und jetzt funktioniert wieder alles ...
    HomoranH peterk34P 2 Antworten Letzte Antwort
    • peterk34P peterk34
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      at Array.map ()
      HomoranH Offline
      HomoranH Offline
      @peterk34 sagte in IOT, Influxdb und scenes adapter starten nicht:
      wie genau durchgeführt?
      peterk34P 1 Antwort Letzte Antwort
        peterk34P Offline
        peterk34P Offline
        peterk34
        iob stop
        iob fix
        iob start
        danach noch einmal mit iob restart
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          at Array.map ()
          peterk34P Offline
          peterk34P Offline
          peterk34
          @peterk34
          Das Fenster kommt auch noch ...
            @peterk34
            peterk34P Offline
            peterk34P Offline
            peterk34
            und auch beim Start von Javascript kommen Errors - obwohl ich bereits alle scripts gestoppt habe
            2022-10-23 16:33:40.971 - info: host.IOB-KEP "system.adapter.javascript.0" enabled
            2022-10-23 16:33:41.089 - info: host.IOB-KEP instance system.adapter.javascript.0 started with pid 29741
            2022-10-23 16:33:41.661 - info: host.IOB-KEP "system.adapter.javascript.1" enabled
            2022-10-23 16:33:41.838 - info: host.IOB-KEP instance system.adapter.javascript.1 started with pid 29748
            2022-10-23 16:33:45.348 - info: javascript.0 (29741) starting. Version 6.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.18.0, js-controller: 4.0.23
            2022-10-23 16:33:45.636 - error: javascript.0 (29741) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
            2022-10-23 16:33:45.638 - error: javascript.0 (29741) Error: Cannot read properties of null (reading '_id')
            2022-10-23 16:33:45.639 - error: javascript.0 (29741) TypeError: Cannot read properties of null (reading '_id')
            at Array.map ()
            2022-10-23 16:33:45.973 - info: javascript.1 (29748) starting. Version 6.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.18.0, js-controller: 4.0.23
            2022-10-23 16:33:46.207 - error: javascript.1 (29748) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
            2022-10-23 16:33:46.208 - error: javascript.1 (29748) Error: Cannot read properties of null (reading '_id')
            2022-10-23 16:33:46.209 - error: javascript.1 (29748) TypeError: Cannot read properties of null (reading '_id')
            at Array.map ()
            2022-10-23 16:33:47.816 - info: shelly.1 (27775) [MQTT] Device 192.168.8.17 (shellyswitch25 / shellyswitch25-BCDDC277525E / SHSW-25#BCDDC277525E#1) connected! Polltime set to 45 sec.
