  4. Synology Cam Problem..(no existing object) [gelöst]
  • Weihnachtsangebot 2025! 🎄
    2.5k
20 Beiträge 3 Kommentatoren 1.1k Aufrufe 2 Watching
    Kellerkind-86
    schrieb am zuletzt editiert von Kellerkind-86
    Hallo..
    ich hab da nochmal was..
    ich habe im log diese meldung..am anfang kam es mal und jetzt kommt es häufiger..
    synology.0
    2022-10-16 20:30:06.189	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 20:23:28.242	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 20:23:28.193	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 20:21:48.608	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 20:21:48.560	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:29:20.665	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:29:20.619	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:19:18.377	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:19:18.290	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:18:34.988	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:18:34.943	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:16:42.513	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 19:16:42.466	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 18:28:18.880	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 18:28:18.835	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 18:26:47.832	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.motionDetected" has no existing object, this might lead to an error in future versions
    synology.0
    2022-10-16 18:26:47.786	warn	State "synology.0.SurveillanceStation.cameras.Matilda´s Cam.recStatus" has no existing object, this might lead to an error in future versions
    ich habe momentan 3 cams.. und die cam strahlt momentan das problem aus..
    habe auch schon den beitrag mit dem gleichen issue gelesen aber bin zu keinem ergebnis gekommen..(post von januar-2021)
    hier nochmal ein screenshot vom objekt
    danke im voraus.
    Gruss Marcell
    Gruß Marcell
    • K Kellerkind-86
      Hallo..
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      synology.0
      danke im voraus.
      Gruss Marcell
      GlasfaserG Offline
      GlasfaserG Offline
      @kellerkind-86
      Diese Datenpunkte löschen und vom Adapter neu anlegen lassen .
      • Adapter stoppen , Datenpunkte löschen , Adapter starten
      Welche Syn Adapter version hast du !?
      • K Kellerkind-86
        Hallo..
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        synology.0
        danke im voraus.
        Gruss Marcell
        GlasfaserG Offline
        GlasfaserG Offline
        @kellerkind-86 sagte in Synology Cam Problem..(no existing object):
        Da fehlen die kompletten Werte auch in den Datenpunkten , was ist denn mit der Cam !?
        • GlasfaserG Glasfaser
          Kellerkind-86
          @glasfaser said in Synology Cam Problem..(no existing object):
          hier mal ein Bild dazu:
          die cam wird wie die anderen kameras erkannt.
          6.2.3
          @kellerkind-86
          @Glasfaser
          soll ich das trotzdem mal machen ?
          Gruß Marcell
          • K Kellerkind-86
            6.2.3
            @kellerkind-86
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            6.2.3
            Kenn ich leider nicht , nur diese Aktuelle Version
            https://github.com/iobroker-community-adapters/ioBroker.synology
            • K Kellerkind-86
              6.2.3
              @kellerkind-86
              @Glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              6.2.3
              ist das vielleicht deine Synology DSM Version !?
              K HomoranH 2 Antworten Letzte Antwort
                6.2.3
                Kellerkind-86
                @glasfaser ´
                sorry..bin noch recht frisch was iobroker angeht....sorry..
                ehm.das ist die adapter version.
                welche meinst du denn bitte ?
                Gruß Marcell
                • K Kellerkind-86
                  @glasfaser ´
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @kellerkind-86
                    6.2.3
                    @glasfaser sagte in Synology Cam Problem..(no existing object):
                    sehr wahrscheinlich!
                    (Alter Screenshot!)
                      @kellerkind-86
                      Kellerkind-86
                      @glasfaser
                      v2.1.9 hab ich auch
                      Gruß Marcell
                      • K Kellerkind-86
                        @glasfaser
                        v2.1.9 hab ich auch
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @kellerkind-86
                        Ok , dann so wie oben vorgehen !
                        Was war hiermit
                        Wichtig ... !
                        ist das wirklich die 6 ... Version von deiner Synology !???
                          @kellerkind-86
                          Was war hiermit
                          Wichtig ... !
                          Kellerkind-86
                          @glasfaser
                          sorry..
                          DSM 7.0.1-42218 Update 3
                          kann aber by the way jetzt updaten..
                          Gruß Marcell
                          • K Kellerkind-86
                            @glasfaser
                            sorry..
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @kellerkind-86
                            Ok alles gut ...
                            aber woher hast du diese Nummer :
                            6.2.3
                              @kellerkind-86
                              Ok alles gut ...
                              6.2.3
                              Kellerkind-86
                              @glasfaser
                              ich hatte im adapter..diese version stehen gehabt...hatte beim adapter installieren nicht drauf geachtet..sorry :pensive:
                              Gruß Marcell
                              • K Kellerkind-86
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @kellerkind-86
                                Da gehört aber das rein
                                  @kellerkind-86
                                  Kellerkind-86
                                  @glasfaser
                                  jap..das hab ich dann auch geändert..danke.. ich update..erst mal alles..und dann starte ich nochmal den adapter neu
                                  Gruß Marcell
                                  • K Kellerkind-86
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @kellerkind-86
                                    Klappt es jetzt , werden die Datenpunkte neu angelegt und auch mit Werte befüllt !?
                                    Es kann auch sein , wegen dem Sonderzeichen im Namen , das es nicht funktioniert
                                    Matilda´s Cam
                                    also auf
                                    Matildas_Cam
                                    in der Synology SurveillanceStation ändern
                                      @kellerkind-86
                                      Matilda´s Cam
                                      also auf
                                      Matildas_Cam
                                      Kellerkind-86
                                      @glasfaser
                                      update gerade die SS und die DSM
                                      werde auch den namen mal vorsichtshalber ändern.. danke bis hier hin..
                                      werde auf jedenfall gleich rückmeldung geben
                                      Gruß Marcell
                                      • K Kellerkind-86
                                        @glasfaser
                                        Kellerkind-86
                                        jetzt bekomme ich alle datenpunkte..
                                        danke für die Hilfe wieder Mals..:+1: :+1: :+1:
                                        Gruß Marcell
                                        • K Kellerkind-86
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @kellerkind-86
                                          Sehr gerne ....
                                          Dann setze den Thread auf [gelöst]
                                          Im Startbeitrag gehen und bei den 3 Punkten kannst du es ändern
                                          also den Thread Titel auf :
                                          [gelöst] Synology Cam Problem..(no existing object)
                                          32.7k
                                          82.4k
