  4. Alias subscription error für Netatmo-adapter
3 Beiträge 3 Kommentatoren 198 Aufrufe 3 Beobachtet
  • C Offline
    chris299
    schrieb am zuletzt editiert von chris299
    ich habe sowas ähnliches wie https://forum.iobroker.net/topic/51737/alias-subscription-error
    allerdings für den Netatmo Adapter:
    2022-09-23 09:11:25.505 - error: admin.0 (2170) Alias subscription error. Please check your alias definitions: sourceId=netatmo.0.5eba6f90f3778f084daa7df3.70-ee-50-00-0a-18.03-00-00-01-d4-aa.Temperature.Temperature, sourceObj={"type":"state","common":{"name":"Temperature","type":"number","role":"value.temperature","read":true,"write":false,"unit":"°C"},"from":"system.adapter.netatmo.0","user":"system.user.admin","ts":1663916878029,"_id":"netatmo.0.5eba6f90f3778f084daa7df3.70-ee-50-00-0a-18.03-00-00-01-d4-aa.Temperature.Temperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    Was genau bedeutet denn dieser Fehler? die Werte bekomme ich durch den Alias ja einwandfrei gelesen und auch sonst sieht das völlig in Ordnung aus....
      "common": {
        "alias": {
          "id": "netatmo.0.5eba6f90f3778f084daa7df3.70-ee-50-00-0a-18.03-00-00-01-d4-aa.Temperature.Temperature"
        "name": "Temperature",
        "role": "value.temperature",
        "type": "number",
        "unit": "°C",
        "read": true,
        "write": false,
        "custom": {
          "history.0": {
            "enabled": true,
            "aliasId": "",
            "changesOnly": false,
            "debounce": "1000",
            "changesRelogInterval": "0",
            "changesMinDelta": "0",
            "maxLength": "960",
            "retention": "63072000"
      "native": {},
      "type": "state",
      "user": "system.user.admin",
      "ts": 1654863156460,
      "_id": "alias.0.TemperaturXXXXXXXX.Temperature",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    • C chris299
        "common": {
          "alias": {
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
          "custom": {
            "history.0": {
              "enabled": true,
              "aliasId": "",
              "debounce": "1000",
              "maxLength": "960",
        "native": {},
        "type": "state",
        "acl": {
          "object": 1636,
          "state": 1636,
      ManfredHi
      @chris299 said in Alias subscription error für Netatmo-adapter:
      Habe ebenfalls das Problem, dass 1-2x am Tag bei sämtlichen angelegten Alias die nachfolgenden Fehler auftreten. Manche Alias zeigen auf MQTT, manche auf den Solaredge-Modbus-Adapter, manche auf selbst angelegte Datenpunkte. Bei allen tritt dies auf. Die Alias funktionieren aber trotzdem einwandfrei, da sie mit InfluxDB und SourceAnalytix geloggt werden und dort keine Fehler auftreten.
      Kann man des Fehler einfach ignorieren oder was hat es damit auf sich ?
      • G Offline
        Gabe
        Bei mir besteht auch weiterhin das Problem. Ich habe kein System erkennt, kommt aber bei allen Aliases vor…
