  4. Probleme mit hm-rpc.2 Adapter
    5.8k
5 Beiträge 2 Kommentatoren 451 Aufrufe
    shigi76
    mein Adapter hm-rpc.2 verbindet sich nicht mehr korrekt.
    Woran kann das liegen?
    hm-rpc.2
    PID
    Zeit
    silly
    Nachricht
    hm-rpc.2
    26672	2022-09-06 15:07:48.831	info	xmlrpc client is trying to connect to 192.168.0.10:2010/ with ["http://192.168.0.22:2010","raspberrypi:hm-rpc.2:d74b09cb348bbd1c0b5d5da40bd3ec5d"]
    hm-rpc.2
    26672	2022-09-06 15:07:48.817	info	xmlrpc server is trying to listen on 192.168.0.22:2010
    hm-rpc.2
    26672	2022-09-06 15:07:47.369	info	starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.17.0, js-controller: 4.0.23
    hm-rpc.2
    21400	2022-09-06 15:07:05.088	info	Terminated (NO_ERROR): Without reason
    hm-rpc.2
    21400	2022-09-06 15:07:05.082	info	terminating
    hm-rpc.2
    21400	2022-09-06 15:07:04.751	error	Init not possible, going to stop: read ECONNRESET
    hm-rpc.2
    21400	2022-09-06 15:07:04.067	info	xmlrpc -> 192.168.0.10:2010/ init ["http://192.168.0.22:2010",""]
    hm-rpc.2
    21400	2022-09-06 15:06:34.059	error	Init not possible, going to stop: read ECONNRESET
    hm-rpc.2
    21400	2022-09-06 15:04:48.886	info	xmlrpc client is trying to connect to 192.168.0.10:2010/ with ["http://192.168.0.22:2010","raspberrypi:hm-rpc.2:b68be594ac034c9285d04fafde47e8bd"]
    hm-rpc.2
    21400	2022-09-06 15:04:48.881	info	xmlrpc server is trying to listen on 192.168.0.22:2010
    hm-rpc.2
    21400	2022-09-06 15:04:47.689	info	starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.17.0, js-controller: 4.0.23
    hm-rpc.2
    15912	2022-09-06 15:04:05.881	info	Terminated (NO_ERROR): Without reason
    hm-rpc.2
    15912	2022-09-06 15:04:05.874	info	terminating
    hm-rpc.2
    15912	2022-09-06 15:04:04.859	info	xmlrpc -> 192.168.0.10:2010/ init ["http://192.168.0.22:2010",""]
    hm-rpc.2
    15912	2022-09-06 15:04:00.432	error	Init not possible, going to stop: read ECONNRESET
    hm-rpc.2
    15912	2022-09-06 15:03:34.850	error	Init not possible, going to stop: read ECONNRESET
    hm-rpc.2
    15912	2022-09-06 15:01:45.600	info	xmlrpc client is trying to connect to 192.168.0.10:2010/ with ["http://192.168.0.22:2010","raspberrypi:hm-rpc.2:653e69c8078340134d7b7668ea4365a7"]
    hm-rpc.2
    15912	2022-09-06 15:01:45.585	info	xmlrpc server is trying to listen on 192.168.0.22:2010
    Danke schon mal vorab!
    • S shigi76
      hm-rpc.2
      PID
      Zeit
      silly
      Nachricht
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      hm-rpc.2
      @shigi76 sagte in Probleme mit hm-rpc.2 Adapter:
      Wenn die Instanz .2 nicht klappt, aber die anderen beiden Instanzen 0 und 1, liegt es nicht am Adapter.
      Um helfen zu können braucht es mehr I fos zu deiner Konfiguration.
      Sonst bleibt nur
      ECONNRESET
        Sonst bleibt nur
        ECONNRESET
        shigi76
        Was genau ist der econnreset?
        Die beiden anderen Adapter sind grün, dieser verbindet sich nicht.
          shigi76
          • S shigi76
            @homoran sagte in Probleme mit hm-rpc.2 Adapter:
            Um helfen zu können braucht es mehr Infos zu deiner Konfiguration.
            E rror
            CONN ection
            RESET ted.
            =Verbindung zur CCU zurückgesetzt
