  4. Log Fehlermeldung durch SONOS Adapter oder JS?
    5.8k
6 Beiträge 2 Kommentatoren 633 Aufrufe 1 Beobachtet
    BlackTigga
    ich erhalte seit kurzem folgende Fehlermeldung im LOG:
    sonos.0	2022-08-23 07:55:25.028	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:54:10.874	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:50:39.880	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:49:40.555	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:46:09.551	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:44:53.829	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:41:24.883	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:40:09.140	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:37:37.603	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:35:22.433	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:30:07.032	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:26:52.470	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:18:20.487	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versions
    sonos.0	2022-08-23 07:15:34.534	warn	(16273) State "sonos.0.root.192_168_178_32.current_track_number" has no existing object, this might lead to an error in future versionss
    Ich habe das JS https://github.com/Mic-M/iobroker-sonos-script mit den entsprechend notwendigen Anpassungen Script angepasst.txt laufen. Und natürlich auch den SONOS Adapter installiert.
    Ich finde jetzt aber keine "Spur" zum Versursacher dieser Meldung. Wenn ich z.B. in meinem Skript nach "current_track_number" suche, finde ich dazu nichts.
    An welcher Stelle (JS, Adapter, ???) generiert sich dieser Fehler?
    Besten Dank für jeglichen Hinweis
    Saludos
    • B BlackTigga
      Saludos
      @blacktigga sagte in Log Fehlermeldung durch SONOS Adapter oder JS?:
      und exakt:
        und exakt:
        BlackTigga
        @homoran sagte in Log Fehlermeldung durch SONOS Adapter oder JS?:
        Ok, ich versuche es zu verstehen.
        In den Objekten befindet sich kein State "current_track_number". Das scheint schon mal entscheident zu sein.
        Aber was triggert die Fehlermeldung jetzt an. In meinem JS befindet sich an keiner Stelle etwas mit "current_track_number", somit kann ich das als Triggerquelle ausschließen, oder?
        • B BlackTigga
          das ist das Problem.
          ich würde den ganzen Baum löschen und die Instanz neu starten. Dann müsste der Baum neu eingelesen werden.
          vielleicht taucht er dann ja auf
          wieso meinst du dass das js die Ursache ist?
            BlackTigga
            Hier löschen, oder? Nur um sicher zu gehen.
            Ich verstehe nicht, warum die gleiche Fehlermeldung nicht auch für 192_168_178_46 und 192_168_178_49 ausgegeben wird, denn dort existiert auch kein State "current_track_number".
            Jetzt zu meiner laienhaften Vermutung warum jetzt JS eine Rolle spielen hätte können:
            Im Skript Zeile 80 wird 192_168_178_32 als channelMain festgelegt und somit hatte ich die Vermutung, dass das irgendwie ursächlich sein könnte.
              BlackTigga
              Danke, hat funktioniert !!
              Ist auch wieder aufgetaucht.
