  4. [Gelöst] Logs im Sekundentakt: Updating repository "stable"
    5.8k
39 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @seyav sagte in Logs im Sekundentakt: Updating repository "stable":
    http://download.iobroker.net/sources-dist.json
    Bau da mal ein Fehler ein :
    http://download.iobroker.xxxx/sources-dist.json
    was kommt dann im Log
    Habe so etwas noch nie gesehn ....... wie bei dir !
    seyav
    @glasfaser said in Logs im Sekundentakt: Updating repository "stable":
    Cool! Das Logging hat gestoppt:
    admin.0
    2022-08-18 21:05:37.696	info	Repository received successfully.
    host.raspberrypi
    2022-08-18 21:05:33.313	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    admin.0
    2022-08-18 21:05:32.893	info	Request actual repository...
    admin.0
    2022-08-18 21:05:32.411	info	Repository received successfully.
    host.raspberrypi
    2022-08-18 21:05:25.989	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    admin.0
    2022-08-18 21:05:25.710	info	Request actual repository...
    admin.0
    2022-08-18 21:05:25.440	info	Repository received successfully.
    host.raspberrypi
    2022-08-18 21:05:23.341	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    admin.0
    2022-08-18 21:05:23.065	info	Request actual repository..
    • S seyav
      admin.0
      host.raspberrypi
      admin.0
      admin.0
      host.raspberrypi
      admin.0
      admin.0
      host.raspberrypi
      admin.0
      GlasfaserG Offline
      GlasfaserG Offline
      Jetzt im Admin bei Adapter :
      was steht im Log
        was steht im Log
        seyav
        @glasfaser Siehe:
        admin.0
        2022-08-18 21:10:55.832	info	Use link "http://localhost:8081" to configure.
        admin.0
        2022-08-18 21:10:55.831	info	http server listening on port 8081
        admin.0
        2022-08-18 21:10:55.515	info	received all objects
        admin.0
        2022-08-18 21:10:54.646	info	requesting all objects
        admin.0
        2022-08-18 21:10:54.644	info	requesting all states
        admin.0
        2022-08-18 21:10:54.590	info	starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.17.0, js-controller: 4.0.23
        admin.0
        2022-08-18 21:10:54.384	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        host.raspberrypi
        2022-08-18 21:10:52.494	info	instance system.adapter.admin.0 started with pid 2515
        host.raspberrypi
        2022-08-18 21:10:50.390	info	instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        admin.0
        2022-08-18 21:10:50.337	error	May not read "system.config"
        admin.0
        2022-08-18 21:10:49.467	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        admin.0
        2022-08-18 21:10:49.466	info	terminating
        admin.0
        2022-08-18 21:10:49.465	info	terminating http server on port 8081
        admin.0
        2022-08-18 21:10:49.463	info	Got terminate signal TERMINATE_YOURSELF
        host.raspberrypi
        2022-08-18 21:10:49.375	info	stopInstance system.adapter.admin.0 send kill signal
        host.raspberrypi
        2022-08-18 21:10:49.246	info	stopInstance system.adapter.admin.0 (force=false, process=true)
        • S seyav
          @glasfaser Siehe:
          admin.0
          admin.0
          admin.0
          admin.0
          admin.0
          admin.0
          admin.0
          host.raspberrypi
          host.raspberrypi
          admin.0
          admin.0
          admin.0
          admin.0
          admin.0
          host.raspberrypi
          host.raspberrypi
          GlasfaserG Offline
          GlasfaserG Offline
          @seyav
          Jetzt wieder richtig ...
          was ist dann
          • S seyav
            @glasfaser Siehe:
            admin.0
            admin.0
            admin.0
            admin.0
            admin.0
            admin.0
            admin.0
            host.raspberrypi
            host.raspberrypi
            admin.0
            admin.0
            admin.0
            admin.0
            admin.0
            host.raspberrypi
            host.raspberrypi
            GlasfaserG Offline
            GlasfaserG Offline
            admin.0
            admin.0
            Hast du ein Neustart gemacht !???
              admin.0
              admin.0
              seyav
              @glasfaser Nein. Hatte nicht. Habe das richtige URL wieder drin. Siehe da ... keine Logs mehr !!! Ich glaube es nicht 😳
              • S seyav
                seyav
                Restart auf admin -- immer noch stabil. Keine Logs mehr. Wahnsinn! Danke Danke! Hast meine Nacht gerettet
                • S seyav
                  admin.0
                  host.raspberrypi
                  admin.0
                  admin.0
                  host.raspberrypi
                  admin.0
                  admin.0
                  host.raspberrypi
                  admin.0
                  GlasfaserG Offline
                  GlasfaserG Offline
                  admin.0
                  admin.0
                  Von der Meldung her war es OK ..
                  Da war mal was .... deshalb die Falsche Verlinkung zum testen .
                    admin.0
                    admin.0
                    seyav
                    @glasfaser Tja... Man muss mal darauf kommen. Genial
                    • S seyav
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @seyav
                      Dann ist ja gut ... wenn es wieder geht ... ohne den Log zu müllen
                      Der nächste Schritt wäre die Logstufe DEBUG beim Admin gewesen .. da kann man mehr sehen was so los ist .
