  4. [gelöst] Zigbee-Adapter bleibt rot nach Upgrade nodejs
    5.8k
6 Beiträge 2 Kommentatoren 712 Aufrufe 2 Beobachtet
  • J Offline
    Ja.rod
    schrieb am zuletzt editiert von Ja.rod
    ich habe gestern mein System von nodejs 14 auf 16 upgegradet, leider bleibt der Zigbee Adapter rot, folgende Fehlermeldung wird im log des iobrokers angezeigt
    host.iobroker
    2022-07-09 07:55:13.292	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2022-07-09 07:55:13.291	error	Caught by controller[0]: }
    host.iobroker
    2022-07-09 07:55:13.291	error	Caught by controller[0]: ]
    host.iobroker
    2022-07-09 07:55:13.291	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v93-linux-x64/bindings.node'
    host.iobroker
    2022-07-09 07:55:13.291	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.291	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.291	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.290	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/16.16.0/linux/x64/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.290	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.290	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.290	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.290	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.289	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.289	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.289	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.289	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
    host.iobroker
    2022-07-09 07:55:13.288	error	Caught by controller[0]: tries: [
    host.iobroker
    2022-07-09 07:55:13.288	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14) {
    host.iobroker
    2022-07-09 07:55:13.288	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
    host.iobroker
    2022-07-09 07:55:13.288	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.iobroker
    2022-07-09 07:55:13.287	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    host.iobroker
    2022-07-09 07:55:13.287	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    host.iobroker
    2022-07-09 07:55:13.287	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
    host.iobroker
    2022-07-09 07:55:13.287	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    host.iobroker
    2022-07-09 07:55:13.286	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
    host.iobroker
    2022-07-09 07:55:13.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.iobroker
    2022-07-09 07:55:13.285	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
    host.iobroker
    2022-07-09 07:55:13.285	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v93-linux-x64/bindings.node
    host.iobroker
    2022-07-09 07:55:13.285	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
    host.iobroker
    2022-07-09 07:55:13.284	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
    host.iobroker
    2022-07-09 07:55:13.284	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
    host.iobroker
    2022-07-09 07:55:13.284	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/16.16.0/linux/x64/bindings.node
    host.iobroker
    2022-07-09 07:55:13.284	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
    host.iobroker
    2022-07-09 07:55:13.283	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
    host.iobroker
    2022-07-09 07:55:13.283	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
    host.iobroker
    2022-07-09 07:55:13.283	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
    host.iobroker
    2022-07-09 07:55:13.282	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
    host.iobroker
    2022-07-09 07:55:13.282	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
    host.iobroker
    2022-07-09 07:55:13.282	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
    host.iobroker
    2022-07-09 07:55:13.282	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
    host.iobroker
    2022-07-09 07:55:13.281	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    Was habe ich schon gemacht:
    • Adapter neu gestartet
    • System neu gebootetd
    • Nach dem im log folgende Zeile aufgetaucht ist "Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually." habe ich das ausgeführt.
      Das Ergebnis waren dann folgende Fehlermeldungen auf der Konsole:
    iobroker@iobroker:/opt/iobroker/node_modules/iobroker.zigbee$ npm install --production
    npm WARN config production Use `--omit=dev` instead.
    npm ERR! code ERESOLVE
    npm ERR! ERESOLVE unable to resolve dependency tree
    npm ERR!
    npm ERR! While resolving: iobroker.zigbee@1.7.5
    npm ERR! Found: eslint@7.32.0
    npm ERR! node_modules/eslint
    npm ERR!   dev eslint@"^7.18.0" from the root project
    npm ERR!
    npm ERR! Could not resolve dependency:
    npm ERR! peer eslint@"4.x" from lint-diff@1.2.1
    npm ERR! node_modules/lint-diff
    npm ERR!   dev lint-diff@"*" from the root project
    npm ERR!
    npm ERR! Fix the upstream dependency conflict, or retry
    npm ERR! this command with --force, or --legacy-peer-deps
    npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
    npm ERR!
    npm ERR! See /home/iobroker/.npm/eresolve-report.txt for a full report.
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-08T19_36_33_611Z-debug-0.log
    * Adapter gelöscht und  neu installiert
    Kann mir jemand damit weiterhelfen? Ich habe das Thema auch schon im Thread "Diskussionen zum nodejs-Update" gefragt, da das meiner Ansicht aber nur indirekt damit zu tun hat habe ich ein separates Thema aufgemacht.
    Ja.rod
    • DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @ja-rod sagte in Zigbee-Adapter bleibt rot nach Upgrade nodejs:
      installier den Adapter nochmal neu
      EDIT: https://forum.iobroker.net/topic/43370/zigbee-adapter-bleibt-nach-update-auf-rot?_=1657349650520
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        Ja.rod
        @djmarc75 Entschuldige, habe ich vergessen reinzuschreiben, habe mich zu sehr auf das Reinkopieren der Meldungen konzentriert. Habe ich gestern schon gemacht.
        • J Ja.rod
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @ja-rod
          @djmarc75 sagte in Zigbee-Adapter bleibt rot nach Upgrade nodejs:
          die Vorgehensweise im Link schon probiert ?
            @ja-rod
            Ja.rod
            @djmarc75
            Habe die Schritte aus dem von dir genannten Link durchgeführt, die Installation an sich war in Ordnung, ich habe dann den Adapter nochmals deinstalliert, die Verzeichnisse in der Konsole gelöscht, dann neu installiert - Ergebnis: Adapter "gelb"
            Dann noch die PAN-ID angepaßt - Ergebnis: Adapter "grün" und alle Geräte da
            Vielen Dank!!!!
            Ja.rod
            • J Ja.rod
              @djmarc75
              Vielen Dank!!!!
              Ja.rod
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @ja-rod sagte in [gelöst] Zigbee-Adapter bleibt rot nach Upgrade nodejs:
              Vielen Dank!!!!
              Hier wird gerne geholfen 😀 👍
