  4. Befehle an Aktor werden nicht umgesetzt
    5.8k
13 Beiträge 5 Kommentatoren 1.1k Aufrufe 4 Beobachtet
    TobStar
    Hallo @glasfaser,
    hier mal der Output
    root@ioBroker:/opt/iobroker# iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.10.7   , installed 1.10.7
    Adapter    "history"      : 1.11.1   , installed 1.11.1
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "ical"         : 1.12.1   , installed 1.12.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "snmp"         : 1.0.0    , installed 1.0.0
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sql"          : 1.16.2   , installed 1.16.2
    Adapter    "synology"     : 2.1.7    , installed 2.1.6  [Updatable]
    Adapter    "text2command" : 2.2.1    , installed 2.2.1
    Adapter    "trashschedule": 2.0.2    , installed 2.0.2
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    root@ioBroker:/opt/iobroker# uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &>
     /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.19.3
    v14.19.3
    6.14.17
    root
    /opt/iobroker
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
    Reading package lists... Done
    1 package can be upgraded. Run 'apt list --upgradable' to see it.
    nodejs:
      Installed: 14.19.3-deb-1nodesource1
      Candidate: 14.19.3-deb-1nodesource1
      Version table:
     *** 14.19.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    Hab eben nochmal was getestet, die Befehle an die Heizungsthermostate z.B. werden umgesetzt, aber die Rolläden nicht. Kann da auch manuell beim Objekt 100 oder was anderes eintragen, es passiert nix.
    Hab jetzt beim Befehl die Bestätigung rausgenommen, also statt
    setState( rolladen +'LEVEL', Number(getState(objekt[0] +'.Positionen.Soll-Position').val, true ) );
    habe ich jetzt
    setState( rolladen +'LEVEL', Number(getState(objekt[0] +'.Positionen.Soll-Position').val ) );
    Damit scheint es zu funktionieren, mal sehen ob es von Dauer ist.
    GlasfaserG DJMarc75D hsteinmeH 3 Antworten Letzte Antwort
    • T TobStar
      Hallo @glasfaser,
      hier mal der Output
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.3
      v14.19.3
      6.14.17
      root
      /opt/iobroker
      nodejs:
        Version table:
      habe ich jetzt
      GlasfaserG Offline
      GlasfaserG Offline
      @tobstar sagte in Befehle an Aktor werden nicht umgesetzt:
      hier mal der Output
      Wo ist dein ioBroker installiert !?
      • T TobStar
        Hallo @glasfaser,
        hier mal der Output
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.3
        v14.19.3
        6.14.17
        root
        /opt/iobroker
        nodejs:
          Version table:
        habe ich jetzt
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @tobstar und wieder jemand der mit root rumhampelt 🙄
        Lehrling seit 1975 !!!
        • DJMarc75D DJMarc75
          GlasfaserG Offline
          GlasfaserG Offline
          @djmarc75 sagte in Befehle an Aktor werden nicht umgesetzt:
          Nee .. nicht so voreilig ... kann eine Synology sein !!!!
          • GlasfaserG Glasfaser
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @glasfaser sagte in Befehle an Aktor werden nicht umgesetzt:
            ok, da haste Recht ! dann zieh ich meine Aussage (vorerst) zurück 😀
              GlasfaserG Offline
              GlasfaserG Offline
              @djmarc75
              deshalb ... erstmal .... laut seinem Log
              x86_64
                @djmarc75
                x86_64
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @glasfaser und deconz ist auch nicht zu verachten
                  TobStar
                  schrieb am zuletzt editiert von TobStar
                  Ja es ist ne Synology / Docker Installation. Deco z wird abgeschafft, Haus ist zu groß für zigbee. Stelle das auch auf homematic um.
                  Hatte jetzt auch erst das Lan Gateway der ccu in Verdacht und alles mal neu positioniert, was aber eben nicht ursächlich war. Scheinbar darf der Wert lediglich nicht bestätigt werden.
                  • T TobStar
                    @tobstar sagte: Scheinbar darf der Wert lediglich nicht bestätigt werden.
                    Er darf definitiv nicht bestätigt werden, wenn er an die CCU gesendet werden soll.
                    • T TobStar
                      Hallo @glasfaser,
                      hier mal der Output
                      x86_64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.19.3
                      v14.19.3
                      6.14.17
                      root
                      /opt/iobroker
                      nodejs:
                        Version table:
                      habe ich jetzt
                      hsteinmeH Offline
                      hsteinmeH Offline
                      hsteinme
                      Klar! Lies mal hier.
