  4. Einstellungsmenü nicht aufrufbar
    5.9k
52 Beiträge 5 Kommentatoren 4.9k Aufrufe 5 Beobachtet
  • Marko1974M Marko1974
    @fastfoot
    [23:57:30] openhabian@openhab:/opt/iobroker/log$ ls -lt /opt/iobroker/iobroker-data
    insgesamt 47436
    drwxrwxr-x+  2 iobroker iobroker     4096 Apr 25 00:00 objects.jsonl.lock
    drwxrwxr-x+  2 iobroker iobroker     4096 Apr 25 00:00 states.jsonl.lock
    -rw-rw-r--+  1 iobroker iobroker 11184907 Apr 25 00:00 objects.jsonl
    -rw-rw-r--+  1 iobroker iobroker 14367073 Apr 24 23:59 states.jsonl
    -rwxrwxrwx+  1 iobroker iobroker     4779 Apr 24 23:46 iobroker.json
    -rw-rwxr--+  1 iobroker iobroker        3 Apr 24 23:45 notifications.json
    drwxrwxr-x+  2 iobroker iobroker     4096 Apr 24 20:45 backitup
    drwxrwxrwx+  2 iobroker iobroker    12288 Apr 24 20:27 backup-objects
    drwxrwxr-x+ 51 iobroker iobroker     4096 Apr 22 22:25 files
    drwxrwxr-x+  6 iobroker iobroker     4096 Apr 21 01:18 node-red
    drwxrwxr-x+  3 iobroker iobroker     4096 Mär  7 00:42 eusec.0
    -rw-rwxr--+  1 iobroker iobroker  1269405 Mär  3 17:02 states.json.migrated
    -rw-rwxr--+  1 iobroker iobroker  8102145 Mär  3 17:02 objects.json.migrated
    -rw-rwxr--+  1 iobroker iobroker  8102149 Mär  3 17:02 objects.json.bak.migrated
    -rw-rwxr--+  1 iobroker iobroker  1269376 Mär  3 17:00 states.json.bak.migrated
    -rw-rwxr--+  1 iobroker iobroker  4194304 Feb 27 13:55 objects.json.broken
    drwxrwxr-x+  2 iobroker iobroker     4096 Nov 16 12:41 history
    drwxrwxr-x+  3 iobroker iobroker     4096 Nov  9 00:23 tmp
    drwxrwxr-x+  5 iobroker iobroker     4096 Jun  6  2021 ham_0
    drwxrwxr-x+  2 iobroker iobroker     4096 Jun  6  2021 yahka.2.hapdata
    drwxrwxr-x+  2 iobroker iobroker     4096 Jun  5  2021 yahka.1.hapdata
    drwxrwxr-x+  2 iobroker iobroker     4096 Jun  1  2021 yahka.0.hapdata
    fastfoot
    @marko1974 zeig trotzdem mal noch cat /opt/iobroker/iobroker-data/iobroker.json
    Marko1974M 1 Antwort Letzte Antwort
    • F fastfoot
      Marko1974M Offline
      Marko1974M Offline
      Marko1974
      @fastfoot
      [00:11:38] openhabian@openhab:/opt/iobroker/log$ cat /opt/iobroker/iobroker-data/iobroker.json
        "system": {
          "memoryLimitMB": 0,
          "hostname": "",
          "statisticsInterval": 15000,
          "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
          "checkDiskInterval": 300000,
          "checkDiskIntervalComment": "Interval how often the disk size will be checked",
          "instanceStartInterval": 2000,
          "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
          "compact": false,
          "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in io-package.json",
          "allowShellCommands": false,
          "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands",
          "memLimitWarn": 100,
          "memLimitWarnComment": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
          "memLimitError": 50,
          "memLimitErrorComment": "If the available RAM is below this threshold on adapter start, an error will be logged."
        "multihostService": {
          "enabled": false,
          "secure": false
        "objects": {
          "type": "jsonl",
          "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
          "host": "127.0.0.1",
          "port": 9001,
          "noFileCache": false,
          "maxQueue": 1000,
          "connectTimeout": 2000,
          "writeFileInterval": 5000,
          "dataDir": "../../iobroker-data/",
          "options": {
            "auth_pass": null,
            "retry_max_delay": 5000,
            "retry_max_count": 19,
            "db": 0,
            "family": 0
          "backup": {
            "disabled": false,
            "files": 24,
            "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
            "hours": 48,
            "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
            "period": 120,
            "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
            "path": "",
            "pathComment": "Absolute path to backup directory or empty to backup in data directory"
        "states": {
          "type": "jsonl",
          "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
          "port": 9000,
          "writeFileInterval": 30000,
          "options": {
            "auth_pass": null,
            "db": 0,
            "family": 0
          "backup": {
            "disabled": false,
            "files": 24,
            "hours": 48,
            "period": 120,
            "path": "",
        "log": {
          "level": "info",
          "maxDays": 3,
          "noStdout": true,
          "transport": {
            "file1": {
              "type": "file",
              "enabled": true,
              "filename": "log/iobroker",
              "fileext": ".log",
              "maxsize": null,
              "maxFiles": null,
              "maxSize": null,
              "level": ""
            "syslog1": {
              "type": "syslog",
              "enabled": false,
              "host": "localhost",
              "hostComment": "The host running syslogd, defaults to localhost.",
              "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
              "protocol": "udp4",
              "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
              "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
              "facilityComment": "Syslog facility to use (Default: local0).",
              "localhost": "iobroker",
              "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
              "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
              "app_nameComment": "The name of the application (Default: process.title).",
              "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications).",
              "level": "",
              "facility": ""
        "plugins": {},
      F Great SUNG 2 Antworten Letzte Antwort
        @fastfoot
          "system": {
            "memoryLimitMB": 0,
            "hostname": "",
            "compact": false,
            "enabled": false,
            "secure": false
          "objects": {
            "type": "jsonl",
            "port": 9001,
            "maxQueue": 1000,
            "options": {
              "auth_pass": null,
              "db": 0,
              "family": 0
            "backup": {
              "disabled": false,
              "files": 24,
              "hours": 48,
              "period": 120,
              "path": "",
          "states": {
            "type": "jsonl",
            "port": 9000,
            "options": {
              "auth_pass": null,
              "db": 0,
              "family": 0
            "backup": {
              "disabled": false,
              "files": 24,
              "hours": 48,
              "period": 120,
              "path": "",
          "log": {
            "level": "info",
            "maxDays": 3,
            "noStdout": true,
            "transport": {
              "file1": {
                "type": "file",
                "enabled": true,
                "fileext": ".log",
                "maxsize": null,
                "maxFiles": null,
                "maxSize": null,
                "level": ""
              "syslog1": {
                "type": "syslog",
                "enabled": false,
                "protocol": "udp4",
                "level": "",
                "facility": ""
          "plugins": {},
        fastfoot
        @marko1974 'leider' auch ok. tippe evtl noch auf defekte sd-karte, aber da befinde ich mich voll auf Glatteis
          @fastfoot
            "system": {
              "memoryLimitMB": 0,
              "hostname": "",
              "compact": false,
              "enabled": false,
              "secure": false
            "objects": {
              "type": "jsonl",
              "port": 9001,
              "maxQueue": 1000,
              "options": {
                "auth_pass": null,
                "db": 0,
                "family": 0
              "backup": {
                "disabled": false,
                "files": 24,
                "hours": 48,
                "period": 120,
                "path": "",
            "states": {
              "type": "jsonl",
              "port": 9000,
              "options": {
                "auth_pass": null,
                "db": 0,
                "family": 0
              "backup": {
                "disabled": false,
                "files": 24,
                "hours": 48,
                "period": 120,
                "path": "",
            "log": {
              "level": "info",
              "maxDays": 3,
              "noStdout": true,
              "transport": {
                "file1": {
                  "type": "file",
                  "enabled": true,
                  "fileext": ".log",
                  "maxsize": null,
                  "maxFiles": null,
                  "maxSize": null,
                  "level": ""
                "syslog1": {
                  "type": "syslog",
                  "enabled": false,
                  "protocol": "udp4",
                  "level": "",
                  "facility": ""
            "plugins": {},
          Great SUNG Offline
          Great SUNG Offline
          Great SUN
          @marko1974 ich hab hier zwei andere threads, die evtl. noch weiterhelfen könnten:
          https://forum.iobroker.net/post/794880
          https://forum.iobroker.net/post/794610
          Da geht es genau um dasselbe Problem.
          F 1 Antwort Letzte Antwort
          • Great SUNG Great SUN
            fastfoot
            @great-sun sagte in Einstellungsmenü nicht aufrufbar:
            das Problem im zweiten Link haben wir gerade geprüft :-)
            Great SUNG 1 Antwort Letzte Antwort
            • Marko1974M Offline
              Marko1974M Offline
              Marko1974
              schrieb am zuletzt editiert von Marko1974
              @fastfoot ist aber auch irgendwie anders :-)
              [00:22:20] openhabian@openhab:/opt/iobroker/log$ iob status
              Objects type: jsonl
              States  type: jsonl
              • F fastfoot
                Great SUNG Offline
                Great SUNG Offline
                Great SUN
                @fastfoot Ich such gerade nach einem anti-theft 10,5" Wallmount für ein Tablet ;-)
                Hab nicht so genau hingeschaut ;-)
                Sorry
                  Sorry
                  fastfoot
                  @great-sun alles gut :-)
                    Marko1974M Offline
                    Marko1974
                    @fastfoot eben...alles gut....
                    Ich dachte ich könnte es irgendwie beheben....ist ja nett von euch, dass ihr alle helfen mögt.
                    Kommt Zeit, kommt rat
                      fastfoot
                      @marko1974 ja wenn der iobroker ansonsten läuft. einstellungen kannst du fast alle auf der Konsole vornehmen, aber das Problem wird wohl nicht von selbst weggehen. ich weiss nicht was iob fix so alles treibt aber das frisst kein Brot und hilft evtl. trotzdem. vorher iob stop. sonst fällt mir da auch nix mehr ein
                        Great SUNG Offline
                        Great SUNG Offline
                        Great SUN
                        @marko1974 Helfen tun wir uns alle untereinander, denn jeder geht den ein oder anderen Weg und nicht alle laufen gemeinsam ;-)
                        So kommt es immer Mal vor, dass einer wo war, wo ein anderer nicht war und so kann der eine dann dem anderen helfen ;-)
                        Eine Hand und so...
