  4. Objekt in JSON Array umwandeln
10 Beiträge 5 Kommentatoren 277 Aufrufe 4 Beobachtet
  • dirk_1930D Offline
    dirk_1930D Offline
    dirk_1930
    Folgenden Objekt erhalte ich per API Abruf...
    {'time':['2022-03-01','2022-03-02','2022-03-03','2022-03-04','2022-03-05','2022-03-06','2022-03-07','2022-03-08'],'pictocode':[2,2,2,2,1,2,2,2],'uvindex':[3,2,2,3,3,2,2,2],'temperature_max':[9.55,11.29,13.07,10.56,9.06,8.07,9.19,8.98],'temperature_min':[-0.3,-0.47,2.34,0.42,-1.79,-1.73,-1.18,-1.43],'temperature_mean':[4.34,5.12,7.27,5,3.12,2.92,3.53,3.53],'felttemperature_max':[5.63,8.28,9.82,6.61,3.86,3.58,4.82,2.45],'felttemperature_min':[-4.93,-4.59,-0.68,-2.47,-5.69,-5.55,-5.04,-5.47],'winddirection':[135,135,0,180,90,90,45,90],'precipitation_probability':[0,0,1,1,0,5,3,4],'rainspot':['0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000'],'predictability_class':[5,4,4,4,4,4,3,3],'predictability':[82,78,77,72,74,69,60,50],'precipitation':[0,0,0,0,0,0,0,0],'snowfraction':[0,0,0,0,0,0,0,0],'sealevelpressure_max':[1029,1027,1020,1020,1021,1023,1022,1018],'sealevelpressure_min':[1026,1020,1014,1017,1019,1020,1017,1010],'sealevelpressure_mean':[1028,1023,1017,1018,1020,1021,1020,1013],'windspeed_max':[2.7,2.1,2.31,2.32,2.88,2.08,2.25,5.2],'windspeed_mean':[1.68,1.22,1.29,1.36,1.93,1.36,1.52,3.64],'windspeed_min':[0.64,0.49,0.49,0.45,0.94,0.57,0.55,1.73],'relativehumidity_max':[63,73,81,82,65,54,63,78],'relativehumidity_min':[26,40,42,37,25,27,33,31],'relativehumidity_mean':[45,56,63,60,41,40,45,53],'convective_precipitation':[0,0,0,0,0,0,0,0],'precipitation_hours':[0,0,0,0,0,0,0,0],'humiditygreater90_hours':[0,0,0,0,0,0,0,0],'indexto1hvalues_start':[0,24,48,72,96,120,144,168],'indexto1hvalues_end':[23,47,71,95,119,143,167,191]}
    Ich würde jetzt gerne diese Daten in dem MaterialDesign-Widget Table verwenden. Dazu muss das Objekt ja noch in ein JSON Array umgewandelt werden.
    Leider sind meine Javascript Fähigkeiten noch nicht so weit, und ich schaffe es nicht dieses Objekt umzuwandeln.
    Könnt Ihr mir auf die Sprünge helfen?
    Könnte ich auch nur Teile dieses Objektes verwenden?
    Danke für Eure Hilfe 😊
    Dirk
    OliverIOO SokomotoS paul53P 4 Antworten Letzte Antwort
    • dirk_1930D dirk_1930
      Dirk
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @dirk_1930
      also als erstes beschreibt dieses JSON ein objekt mit vielen Attributen.
      Die Attribute sind wiederum immer Arrays.
      Um den Text in ein verarbeitbares Objekt umzuwandeln wendest du den folgenden Befehl an:
      var obj = JSON.parse(variableDieDenJSONTextEnthält);
      um danach noch beispielsweise nur das windspeed_max array weiterzu verwenden
      var windMax = obj.windspeed_max
      um auf das erste Element des Arrays zugreifen zu können
      console.debug(windMax[0]);
      Leider weiß ich nicht in welcher Form das table widget die Daten erwartet.
      Aber evtl hilft dir das weiter
      Meine Adapter und Widgets
      Links im Profil
      dirk_1930D 1 Antwort Letzte Antwort
      • OliverIOO OliverIO
        @dirk_1930
        dirk_1930D Offline
        dirk_1930D Offline
        dirk_1930
        @oliverio
        Danke für die schnelle Antwort...
        Laut Beschreibung soll das JSON folgende Struktur haben:
        Data - JSON Stucture
        Input data must be a json array of objects. You can use any property, there is no fixes structure. Column 0 gets the value of the first property, column 1 gets the value of the second property and so on. Important is, that every Object has the same structure.
        		"img": "/vis.0/myImages/erlebnis_50.png",
        		"name": "Empire",
        		"betriebszeit": "4h 06m",
        		"funk": "5G",
        		"ip": "10.0.0.1"
        		"img": "/vis.0/myImages/erlebnis_100.png",
        		"name": "Handy",
        		"betriebszeit": "13m",
        		"funk": "5G",
        		"ip": "10.0.0.2"
        		"name": "Harmony Hub - Wohnzimmer",
        		"betriebszeit": "18T 07h 21m",
        		"funk": "2G",
        		"ip": "10.0.0.3"
        liv-in-skyL OliverIOO 2 Antworten Letzte Antwort
          Dirk
          SokomotoS Offline
          SokomotoS Offline
          Sokomoto
          @dirk_1930 sagte in Objekt in JSON Array umwandeln:
          Dein String verwendet einfache Anführungszeichen anstelle von doppelten Anführungszeichen.
          Das Problem sind die Anführungszeichen, wandle die mal in " um, mit Notepad++ z.B, dann passt das.
          x=deinString
          var obj=JSON.parse(x);
          log( 'Ausgabe = '+obj.time[0])
          console>Ausgabe = 2022-03-01
          tschuess
          • SokomotoS Sokomoto
            x=deinString
            tschuess
            @sokomoto sagte: Dein String verwendet einfache Anführungszeichen anstelle von doppelten Anführungszeichen.
            Das ist kein String (JSON), sondern ein Objekt. Umwandlung in JSON:
            let json = JSON.stringify(obj);
              @oliverio
              		"name": "Empire",
              		"funk": "5G",
              		"ip": "10.0.0.1"
              		"name": "Handy",
              		"funk": "5G",
              		"ip": "10.0.0.2"
              		"funk": "2G",
              		"ip": "10.0.0.3"
              liv-in-skyL Offline
              liv-in-skyL Offline
              @dirk_1930
              kann dir nur eine umwandlung in ein anderes json bieten
              die anpassung an material design ist nicht dabei - da brauchst du wieder ein script, welches die umsetzung macht - mit dem erbnis von hier
              du kannst das im inventwo json widget ansehen
              du musst dir einen datenpunkt anlegen und im blockly auswählen
               <variables>
                 <variable id="ufb_74:Rl4u[t3tsm-)U">x</variable>
                 <variable id="?j:hG`+CH@lHRS#sl=BF">myString</variable>
                 <variable id="ju_axXKM0evm)kFjt0^x">i</variable>
                 <variable id="Z=?7wCQ1-49/,bxoE1#|">counter</variable>
               </variables>
               <block type="procedures_defcustomreturn" id="*YUTilQ+*5,A$vpoL$Ot" x="588" y="-487">
                 <mutation statements="false">
                   <arg name="x" varid="ufb_74:Rl4u[t3tsm-)U"></arg>
                 </mutation>
                 <field name="NAME">etwas tun</field>
                 <field name="SCRIPT">cmV0dXJuIHgucmVwbGFjZSgvJy9tZywnIicpOw==</field>
               </block>
               <block type="variables_set" id=",,sDrj|CT[_JGj8(=lh[" x="138" y="-412">
                 <field name="VAR" id="?j:hG`+CH@lHRS#sl=BF">myString</field>
                 <value name="VALUE">
                   <block type="procedures_callcustomreturn" id="v,5a7cp]qV9^543W(:A9">
                     <mutation name="etwas tun">
                       <arg name="x"></arg>
                     </mutation>
                     <value name="ARG0">
                       <block type="text" id="{+_|6aTnAzc)dJxtBbO,">
                         <field name="TEXT">{'time':['2022-03-01','2022-03-02','2022-03-03','2022-03-04','2022-03-05','2022-03-06','2022-03-07','2022-03-08'],'pictocode':[2,2,2,2,1,2,2,2],'uvindex':[3,2,2,3,3,2,2,2],'temperature_max':[9.55,11.29,13.07,10.56,9.06,8.07,9.19,8.98],'temperature_min':[-0.3,-0.47,2.34,0.42,-1.79,-1.73,-1.18,-1.43],'temperature_mean':[4.34,5.12,7.27,5,3.12,2.92,3.53,3.53],'felttemperature_max':[5.63,8.28,9.82,6.61,3.86,3.58,4.82,2.45],'felttemperature_min':[-4.93,-4.59,-0.68,-2.47,-5.69,-5.55,-5.04,-5.47],'winddirection':[135,135,0,180,90,90,45,90],'precipitation_probability':[0,0,1,1,0,5,3,4],'rainspot':['0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000','0000000000000000000000000000000000000000000000000'],'predictability_class':[5,4,4,4,4,4,3,3],'predictability':[82,78,77,72,74,69,60,50],'precipitation':[0,0,0,0,0,0,0,0],'snowfraction':[0,0,0,0,0,0,0,0],'sealevelpressure_max':[1029,1027,1020,1020,1021,1023,1022,1018],'sealevelpressure_min':[1026,1020,1014,1017,1019,1020,1017,1010],'sealevelpressure_mean':[1028,1023,1017,1018,1020,1021,1020,1013],'windspeed_max':[2.7,2.1,2.31,2.32,2.88,2.08,2.25,5.2],'windspeed_mean':[1.68,1.22,1.29,1.36,1.93,1.36,1.52,3.64],'windspeed_min':[0.64,0.49,0.49,0.45,0.94,0.57,0.55,1.73],'relativehumidity_max':[63,73,81,82,65,54,63,78],'relativehumidity_min':[26,40,42,37,25,27,33,31],'relativehumidity_mean':[45,56,63,60,41,40,45,53],'convective_precipitation':[0,0,0,0,0,0,0,0],'precipitation_hours':[0,0,0,0,0,0,0,0],'humiditygreater90_hours':[0,0,0,0,0,0,0,0],'indexto1hvalues_start':[0,24,48,72,96,120,144,168],'indexto1hvalues_end':[23,47,71,95,119,143,167,191]} </field>
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                   <block type="debug" id="|n`0($^$DSDq@#M|v`*N" disabled="true">
                     <value name="TEXT">
                       <shadow type="text" id="c:Qeo]i#$^2~!(3:4s0{">
                       </shadow>
                       <block type="convert_tostring" id="-X|5=a7cpnmLlErO9Hvx">
                           <block type="get_attr" id="0~^wix__Ktr9/LT7|!Lc">
                             <value name="PATH">
                               <shadow type="text" id="77PNfY!@sD64E3l^[R=s">
                                 <field name="TEXT">time</field>
                               </shadow>
                             </value>
                             <value name="OBJECT">
                               <block type="variables_get" id="?h#Qe+(fX2K3h2DKJr4Z">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                       <block type="debug" id="c*?oUN6,O[a4XIQ|p(27">
                         <value name="TEXT">
                           <shadow type="text" id="krDt]i3.}2gSZh)hD]u%">
                           </shadow>
                           <block type="procedures_callcustomreturn" id="x6ncpwY9,Mk!Q3{nQ2|J">
                             <mutation name="etwas tun2">
                             </mutation>
                             <value name="ARG0">
                               <block type="variables_get" id="HYhKCKl-s~SHhwm^$GGb">
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                           <block type="control" id="T!5@xzFe0un^1}L9j7Mq">
                             <field name="OID">0_userdata.0.CONTROL-OWN.AAATEST.TestString6</field>
                               <block type="procedures_callcustomreturn" id="dd/xz=!@9[?c$}$gI.Rs">
                                 </mutation>
                                 <value name="ARG0">
                                   <block type="variables_get" id=".(mq%vXfphFT:A6i,j0*">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
               <block type="procedures_defcustomreturn" id="cfAe~MsgrVq?.?[9mYb@" x="638" y="-438">
                 </mutation>
                 <field name="NAME">etwas tun2</field>
                 <field name="SCRIPT">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</field>
               </block>
               <block type="controls_forEach" id="jL-wx^K=wd/$._Lu`8MU" disabled="true" x="-313" y="-87">
                 <field name="VAR" id="ju_axXKM0evm)kFjt0^x">i</field>
                 <statement name="DO">
                   <block type="math_change" id="/(`nr]L}0~UAa;X|Nm3V">
                     <field name="VAR" id="Z=?7wCQ1-49/,bxoE1#|">counter</field>
                     <value name="DELTA">
                       <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="sN*$vrmlN4}$m!x%0/}W">
                         <field name="NUM">1</field>
                       </shadow>
                       <block type="math_number" id=";=rNkeJrp_)K.+TproOf">
                       </block>
                     </value>
                     <next>
                       <block type="debug" id="u{V[RjJVxAB+H/VInKER">
                         <value name="TEXT">
                           <shadow type="text" id="$0=*eBZ5gCWFxE6sr,9)">
                           </shadow>
                           <block type="variables_get" id="YR@ccm#6%FohNIpMfRDe">
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
              </xml>
              die inventwo widgets müssen installiert sein, bei den adaptern
              [{"tpl":"i-vis-jsontable","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iTblRowLimit":"41","iTableRefreshRate":"0","iTblSortOrder":"asc","iColCount":"28","iColShow1":"true","iTblHeadTextAlign1":"center","iTblTextAlign1":"left","iTblCellFormat1":"normal","iTblCellImageSize1":"200","iTblCellBooleanCheckbox1":"false","iTblCellBooleanColorFalse1":"#ff0000","iTblCellBooleanColorTrue1":"#00ff00","iTblCellNumberDecimals1":"2","iTblCellNumberDecimalSeperator1":".","iTblCellNumberThousandSeperator1":",","iTblCellThresholdsDp1":"","iTblCellThresholdsText1":"","iOpacityAll":"1","iTblRowEvenColor":"#333333","iTblRowUnevenColor":"#455618","iTblHeaderColor":"#333333","iRowSpacing":"10","iTblRowEvenTextColor":"#ffffff","iTblRowUnevenTextColor":"#ffffff","iTblHeaderTextColor":"#ffffff","iBorderSize":"0","iBorderStyleLeft":"none","iBorderStyleRight":"none","iBorderStyleUp":"none","iBorderStyleDown":"none","iBorderColor":"#ffffff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"0_userdata.0.CONTROL-OWN.AAATEST.TestString6","iColShow2":"true","iTblHeadTextAlign2":"center","iTblTextAlign2":"left","iTblCellFormat2":"normal","iTblCellImageSize2":"200","iTblCellBooleanCheckbox2":"false","iTblCellBooleanColorFalse2":"#ff0000","iTblCellBooleanColorTrue2":"#00ff00","iTblCellNumberDecimals2":"2","iTblCellNumberDecimalSeperator2":".","iTblCellNumberThousandSeperator2":",","iTblCellThresholdsDp2":"","iTblCellThresholdsText2":"","iColShow3":"true","iTblHeadTextAlign3":"center","iTblTextAlign3":"left","iTblCellFormat3":"normal","iTblCellImageSize3":"200","iTblCellBooleanCheckbox3":"false","iTblCellBooleanColorFalse3":"#ff0000","iTblCellBooleanColorTrue3":"#00ff00","iTblCellNumberDecimals3":"2","iTblCellNumberDecimalSeperator3":".","iTblCellNumberThousandSeperator3":",","iTblCellThresholdsDp3":"","iTblCellThresholdsText3":"","iColShow4":"true","iTblHeadTextAlign4":"center","iTblTextAlign4":"left","iTblCellFormat4":"normal","iTblCellImageSize4":"200","iTblCellBooleanCheckbox4":"false","iTblCellBooleanColorFalse4":"#ff0000","iTblCellBooleanColorTrue4":"#00ff00","iTblCellNumberDecimals4":"2","iTblCellNumberDecimalSeperator4":".","iTblCellNumberThousandSeperator4":",","iTblCellThresholdsDp4":"","iTblCellThresholdsText4":"","iColShow5":"true","iTblHeadTextAlign5":"center","iTblTextAlign5":"left","iTblCellFormat5":"normal","iTblCellImageSize5":"200","iTblCellBooleanCheckbox5":"false","iTblCellBooleanColorFalse5":"#ff0000","iTblCellBooleanColorTrue5":"#00ff00","iTblCellNumberDecimals5":"2","iTblCellNumberDecimalSeperator5":".","iTblCellNumberThousandSeperator5":",","iTblCellThresholdsDp5":"","iTblCellThresholdsText5":"","iColShow6":"true","iTblHeadTextAlign6":"center","iTblTextAlign6":"left","iTblCellFormat6":"normal","iTblCellImageSize6":"200","iTblCellBooleanCheckbox6":"false","iTblCellBooleanColorFalse6":"#ff0000","iTblCellBooleanColorTrue6":"#00ff00","iTblCellNumberDecimals6":"2","iTblCellNumberDecimalSeperator6":".","iTblCellNumberThousandSeperator6":",","iTblCellThresholdsDp6":"","iTblCellThresholdsText6":"","iColShow7":"true","iTblHeadTextAlign7":"center","iTblTextAlign7":"left","iTblCellFormat7":"normal","iTblCellImageSize7":"200","iTblCellBooleanCheckbox7":"false","iTblCellBooleanColorFalse7":"#ff0000","iTblCellBooleanColorTrue7":"#00ff00","iTblCellNumberDecimals7":"2","iTblCellNumberDecimalSeperator7":".","iTblCellNumberThousandSeperator7":",","iTblCellThresholdsDp7":"","iTblCellThresholdsText7":"","iColShow8":"true","iTblHeadTextAlign8":"center","iTblTextAlign8":"left","iTblCellFormat8":"normal","iTblCellImageSize8":"200","iTblCellBooleanCheckbox8":"false","iTblCellBooleanColorFalse8":"#ff0000","iTblCellBooleanColorTrue8":"#00ff00","iTblCellNumberDecimals8":"2","iTblCellNumberDecimalSeperator8":".","iTblCellNumberThousandSeperator8":",","iTblCellThresholdsDp8":"","iTblCellThresholdsText8":"","iColShow9":"true","iTblHeadTextAlign9":"center","iTblTextAlign9":"left","iTblCellFormat9":"normal","iTblCellImageSize9":"200","iTblCellBooleanCheckbox9":"false","iTblCellBooleanColorFalse9":"#ff0000","iTblCellBooleanColorTrue9":"#00ff00","iTblCellNumberDecimals9":"2","iTblCellNumberDecimalSeperator9":".","iTblCellNumberThousandSeperator9":",","iTblCellThresholdsDp9":"","iTblCellThresholdsText9":"","iColShow10":"true","iTblHeadTextAlign10":"center","iTblTextAlign10":"left","iTblCellFormat10":"normal","iTblCellImageSize10":"200","iTblCellBooleanCheckbox10":"false","iTblCellBooleanColorFalse10":"#ff0000","iTblCellBooleanColorTrue10":"#00ff00","iTblCellNumberDecimals10":"2","iTblCellNumberDecimalSeperator10":".","iTblCellNumberThousandSeperator10":",","iTblCellThresholdsDp10":"","iTblCellThresholdsText10":"","iColShow11":false,"iTblHeadTextAlign11":"center","iTblTextAlign11":"left","iTblCellFormat11":"normal","iTblCellImageSize11":"200","iTblCellBooleanCheckbox11":"false","iTblCellBooleanColorFalse11":"#ff0000","iTblCellBooleanColorTrue11":"#00ff00","iTblCellNumberDecimals11":"2","iTblCellNumberDecimalSeperator11":".","iTblCellNumberThousandSeperator11":",","iTblCellThresholdsDp11":"","iTblCellThresholdsText11":"","iColShow12":"true","iTblHeadTextAlign12":"center","iTblTextAlign12":"left","iTblCellFormat12":"normal","iTblCellImageSize12":"200","iTblCellBooleanCheckbox12":"false","iTblCellBooleanColorFalse12":"#ff0000","iTblCellBooleanColorTrue12":"#00ff00","iTblCellNumberDecimals12":"2","iTblCellNumberDecimalSeperator12":".","iTblCellNumberThousandSeperator12":",","iTblCellThresholdsDp12":"","iTblCellThresholdsText12":"","iColShow13":"true","iTblHeadTextAlign13":"center","iTblTextAlign13":"left","iTblCellFormat13":"normal","iTblCellImageSize13":"200","iTblCellBooleanCheckbox13":"false","iTblCellBooleanColorFalse13":"#ff0000","iTblCellBooleanColorTrue13":"#00ff00","iTblCellNumberDecimals13":"2","iTblCellNumberDecimalSeperator13":".","iTblCellNumberThousandSeperator13":",","iTblCellThresholdsDp13":"","iTblCellThresholdsText13":"","iColShow14":"true","iTblHeadTextAlign14":"center","iTblTextAlign14":"left","iTblCellFormat14":"normal","iTblCellImageSize14":"200","iTblCellBooleanCheckbox14":"false","iTblCellBooleanColorFalse14":"#ff0000","iTblCellBooleanColorTrue14":"#00ff00","iTblCellNumberDecimals14":"2","iTblCellNumberDecimalSeperator14":".","iTblCellNumberThousandSeperator14":",","iTblCellThresholdsDp14":"","iTblCellThresholdsText14":"","iColShow15":"true","iTblHeadTextAlign15":"center","iTblTextAlign15":"left","iTblCellFormat15":"normal","iTblCellImageSize15":"200","iTblCellBooleanCheckbox15":"false","iTblCellBooleanColorFalse15":"#ff0000","iTblCellBooleanColorTrue15":"#00ff00","iTblCellNumberDecimals15":"2","iTblCellNumberDecimalSeperator15":".","iTblCellNumberThousandSeperator15":",","iTblCellThresholdsDp15":"","iTblCellThresholdsText15":"","iColShow16":"true","iTblHeadTextAlign16":"center","iTblTextAlign16":"left","iTblCellFormat16":"normal","iTblCellImageSize16":"200","iTblCellBooleanCheckbox16":"false","iTblCellBooleanColorFalse16":"#ff0000","iTblCellBooleanColorTrue16":"#00ff00","iTblCellNumberDecimals16":"2","iTblCellNumberDecimalSeperator16":".","iTblCellNumberThousandSeperator16":",","iTblCellThresholdsDp16":"","iTblCellThresholdsText16":"","iColShow17":"true","iTblHeadTextAlign17":"center","iTblTextAlign17":"left","iTblCellFormat17":"normal","iTblCellImageSize17":"200","iTblCellBooleanCheckbox17":"false","iTblCellBooleanColorFalse17":"#ff0000","iTblCellBooleanColorTrue17":"#00ff00","iTblCellNumberDecimals17":"2","iTblCellNumberDecimalSeperator17":".","iTblCellNumberThousandSeperator17":",","iTblCellThresholdsDp17":"","iTblCellThresholdsText17":"","iColShow18":"true","iTblHeadTextAlign18":"center","iTblTextAlign18":"left","iTblCellFormat18":"normal","iTblCellImageSize18":"200","iTblCellBooleanCheckbox18":"false","iTblCellBooleanColorFalse18":"#ff0000","iTblCellBooleanColorTrue18":"#00ff00","iTblCellNumberDecimals18":"2","iTblCellNumberDecimalSeperator18":".","iTblCellNumberThousandSeperator18":",","iTblCellThresholdsDp18":"","iTblCellThresholdsText18":"","iColShow19":"true","iTblHeadTextAlign19":"center","iTblTextAlign19":"left","iTblCellFormat19":"normal","iTblCellImageSize19":"200","iTblCellBooleanCheckbox19":"false","iTblCellBooleanColorFalse19":"#ff0000","iTblCellBooleanColorTrue19":"#00ff00","iTblCellNumberDecimals19":"2","iTblCellNumberDecimalSeperator19":".","iTblCellNumberThousandSeperator19":",","iTblCellThresholdsDp19":"","iTblCellThresholdsText19":"","iColShow20":"true","iTblHeadTextAlign20":"center","iTblTextAlign20":"left","iTblCellFormat20":"normal","iTblCellImageSize20":"200","iTblCellBooleanCheckbox20":"false","iTblCellBooleanColorFalse20":"#ff0000","iTblCellBooleanColorTrue20":"#00ff00","iTblCellNumberDecimals20":"2","iTblCellNumberDecimalSeperator20":".","iTblCellNumberThousandSeperator20":",","iTblCellThresholdsDp20":"","iTblCellThresholdsText20":"","iColShow21":"true","iTblHeadTextAlign21":"center","iTblTextAlign21":"left","iTblCellFormat21":"normal","iTblCellImageSize21":"200","iTblCellBooleanCheckbox21":"false","iTblCellBooleanColorFalse21":"#ff0000","iTblCellBooleanColorTrue21":"#00ff00","iTblCellNumberDecimals21":"2","iTblCellNumberDecimalSeperator21":".","iTblCellNumberThousandSeperator21":",","iTblCellThresholdsDp21":"","iTblCellThresholdsText21":"","iColShow22":"true","iTblHeadTextAlign22":"center","iTblTextAlign22":"left","iTblCellFormat22":"normal","iTblCellImageSize22":"200","iTblCellBooleanCheckbox22":"false","iTblCellBooleanColorFalse22":"#ff0000","iTblCellBooleanColorTrue22":"#00ff00","iTblCellNumberDecimals22":"2","iTblCellNumberDecimalSeperator22":".","iTblCellNumberThousandSeperator22":",","iTblCellThresholdsDp22":"","iTblCellThresholdsText22":"","iColShow23":"true","iTblHeadTextAlign23":"center","iTblTextAlign23":"left","iTblCellFormat23":"normal","iTblCellImageSize23":"200","iTblCellBooleanCheckbox23":"false","iTblCellBooleanColorFalse23":"#ff0000","iTblCellBooleanColorTrue23":"#00ff00","iTblCellNumberDecimals23":"2","iTblCellNumberDecimalSeperator23":".","iTblCellNumberThousandSeperator23":",","iTblCellThresholdsDp23":"","iTblCellThresholdsText23":"","iColShow24":"true","iTblHeadTextAlign24":"center","iTblTextAlign24":"left","iTblCellFormat24":"normal","iTblCellImageSize24":"200","iTblCellBooleanCheckbox24":"false","iTblCellBooleanColorFalse24":"#ff0000","iTblCellBooleanColorTrue24":"#00ff00","iTblCellNumberDecimals24":"2","iTblCellNumberDecimalSeperator24":".","iTblCellNumberThousandSeperator24":",","iTblCellThresholdsDp24":"","iTblCellThresholdsText24":"","iColShow25":"true","iTblHeadTextAlign25":"center","iTblTextAlign25":"left","iTblCellFormat25":"normal","iTblCellImageSize25":"200","iTblCellBooleanCheckbox25":"false","iTblCellBooleanColorFalse25":"#ff0000","iTblCellBooleanColorTrue25":"#00ff00","iTblCellNumberDecimals25":"2","iTblCellNumberDecimalSeperator25":".","iTblCellNumberThousandSeperator25":",","iTblCellThresholdsDp25":"","iTblCellThresholdsText25":"","iColShow26":"true","iTblHeadTextAlign26":"center","iTblTextAlign26":"left","iTblCellFormat26":"normal","iTblCellImageSize26":"200","iTblCellBooleanCheckbox26":"false","iTblCellBooleanColorFalse26":"#ff0000","iTblCellBooleanColorTrue26":"#00ff00","iTblCellNumberDecimals26":"2","iTblCellNumberDecimalSeperator26":".","iTblCellNumberThousandSeperator26":",","iTblCellThresholdsDp26":"","iTblCellThresholdsText26":"","iColShow27":"true","iTblHeadTextAlign27":"center","iTblTextAlign27":"left","iTblCellFormat27":"normal","iTblCellImageSize27":"200","iTblCellBooleanCheckbox27":"false","iTblCellBooleanColorFalse27":"#ff0000","iTblCellBooleanColorTrue27":"#00ff00","iTblCellNumberDecimals27":"2","iTblCellNumberDecimalSeperator27":".","iTblCellNumberThousandSeperator27":",","iTblCellThresholdsDp27":"","iTblCellThresholdsText27":"","iColShow28":"true","iTblHeadTextAlign28":"center","iTblTextAlign28":"left","iTblCellFormat28":"normal","iTblCellImageSize28":"200","iTblCellBooleanCheckbox28":"false","iTblCellBooleanColorFalse28":"#ff0000","iTblCellBooleanColorTrue28":"#00ff00","iTblCellNumberDecimals28":"2","iTblCellNumberDecimalSeperator28":".","iTblCellNumberThousandSeperator28":",","iTblCellThresholdsDp28":"","iTblCellThresholdsText28":"","iTblShowHead":false},"style":{"left":"37px","top":"135px","width":"1344px","height":"562px"},"widgetSet":"vis-inventwo"}]
                Dirk
                @dirk_1930 sagte: MaterialDesign-Widget Table
                Das Original-Objekt mit vielen Arrays muss erst in ein Array mit vielen Objekten gewandelt und anschließend nach JSON konvertiert werden.
                const arr = [];
                const time = obj.time; // 1. Array im Original-Objekt
                for(let i = 0; i < time.length; i++) {
                    const newObj = {};
                    for(let prop in obj) {
                        newObj[prop] = obj[prop][i];
                    arr.push(newObj);
                setState(idJson, JSON.stringify(arr), true)
                  @oliverio
                  		"name": "Empire",
                  		"funk": "5G",
                  		"ip": "10.0.0.1"
                  		"name": "Handy",
                  		"funk": "5G",
                  		"ip": "10.0.0.2"
                  		"funk": "2G",
                  		"ip": "10.0.0.3"
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @oliverio
                  		"name": "Empire",
                  		"funk": "5G",
                  		"ip": "10.0.0.1"
                  		"name": "Handy",
                  		"funk": "5G",
                  		"ip": "10.0.0.2"
                  		"funk": "2G",
                  		"ip": "10.0.0.3"
                  Das muss nicht exakt diese Struktur sein, denke ich. aber da musst du in der Doku nachlesen.
                  Aber ich denke es müsste wie folgt sein, Ein Array von Objekten, ein Objekt ist eine Zeile, jedes Attribut ist eine Spalte, also:
                  "name" : "zeile1",
                  "feld1":"feld1",
                  "feld2":"feld2"
                  "name" : "zeile2",
                  "feld1":"feld1",
                  "feld2":"feld2"
                  "name" : "zeile3",
                  "feld1":"feld1",
                  "feld2":"feld2"
                  müsste eine tabelle mit 3 zeilen und 3 spalten ergeben
                  Links im Profil
                    Dirk
                    @dirk_1930 sagte: Könnte ich auch nur Teile dieses Objektes verwenden?
                    Verwende eine Liste mit den zu selektierenden Eigenschaften:
                    const idJson = '0_userdata.0.xyz'; // Ziel-DP mit JSON-Tabelle
                    const selector = ['time', 'uvindex', 'temperature_mean'];
                    // Objekt in Variable obj einlesen
                    const arr = [];
                    const length = obj.time.length; // Länge 1. Array im Original-Objekt
                    for(let i = 0; i < length; i++) {
                        const newObj = {};
                            if(selector.includes(prop)) newObj[prop] = obj[prop][i];
                        arr.push(newObj);
                    setState(idJson, JSON.stringify(arr), true);
                      const arr = [];
                          const newObj = {};
                          arr.push(newObj);
                      dirk_1930D Offline
                      dirk_1930D Offline
                      dirk_1930
                      👍 😳 Perfekt... Vielen Dank für die Hilfe!
                      82.8k
