  4. [Frage] Blockly - "if" mit Wochentage eingrenzen
    5.6k
22 Beiträge 3 Kommentatoren 5.6k Aufrufe
    Stormbringer
    Ah, jetzt weiß ich auch wie ihr das macht :D hoffe habs hinbekommen
    ! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
    ! <block type="comment" id="eJb}g8KK|QLIQdnXwqWD" x="65" y="-965"><field name="COMMENT">Mo-So</field>
    ! <next><block type="schedule" id="c|;MRuVnd8fva-~-4=[U"><field name="SCHEDULE">/26 /30 * * * 0-6</field>
    ! <statement name="STATEMENT"><block type="comment" id=")Ci(qYIfWczY%jgw[qS8"><field name="COMMENT">Arbeit</field>
    ! <next><block type="controls_if" id="#?v{k7:OfCqcqtIzH~z"><mutation else="1"></mutation>
    ! <value name="IF0"><block type="logic_compare" id="lg5igbNtX-UN/fL%s}U6"><field name="OP">EQ</field>
    ! <value name="A"><block type="get_value" id=".Kzi#@mU+8GM
    ~AWVXj%"><field name="ATTR">val</field>
    ! <field name="OID">javascript.0.Variable.Person.VAR100_Arbeit</field></block></value>
    ! <value name="B"><block type="logic_boolean" id="y42H^{%jaLi#2=7|Zde/"><field name="BOOL">TRUE</field></block></value></block></value>
    ! <statement name="DO0"><block type="comment" id="]tjA!-+r);r^t
    nrZ@Y]"><field name="COMMENT">Aufstehen Arbeit Mo-Fr</field>
    ! <next><block type="controls_if" id="?n5I
    [By}J~m_kFcQdBS"><value name="IF0"><block type="logic_operation" id="@.5WQLLngW?9j@Rt3xJ:"><field name="OP">AND</field>
    ! <value name="A"><block type="logic_compare" id="630ho-4EA3L(R19tP*p"><field name="OP">EQ</field> ! <value name="A"><block type="time_get" id="?mXL_j%XkZWqH/ckQZMt"><mutation format="false" language="false"></mutation> ! <field name="OPTION">wd</field></block></value> ! <value name="B"><block type="text" id="iWyIrO06;|(Qoq^IV!}C"><field name="TEXT">1-5</field></block></value></block></value> ! <value name="B"><block type="time_compare_ex" id="uPfeP_GZLr{idZllO[Wn"><mutation end_time="true" actual_time="true"></mutation> ! <field name="USE_ACTUAL_TIME">TRUE</field> ! <field name="OPTION">between</field> ! <value name="START_TIME"><shadow type="text" id="9Z)6:x6:US2mm/Sk%QL8"><field name="TEXT">04:00</field></shadow></value> ! <value name="END_TIME"><shadow type="text" id="Ra2Q)|9.}3piNeggm^fL"><field name="TEXT">05:50</field></shadow></value></block></value></block></value> ! <statement name="DO0"><block type="control" id="w+co9}p?})8i-[|75Cs*"><mutation delay_input="false"></mutation> ! <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="text" id="XFE_1AYk580G1/MF;3:*"><field name="TEXT">Aufstehzeit Arbeit Mo-Fr Hue</field></block></value> ! <next><block type="debug" id="hXGMK@9.5{Kf?n7A0(Cw"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
    ! <block type="text_join" id="fbS7.9}v{;},7-EE~Z_"><mutation items="2"></mutation> ! <value name="ADD0"><block type="field_oid" id="Fhb}8=Cq2aPbDA-he2[k"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> ! <value name="ADD1"><block type="text" id="4u/9O%k@s)4dkyfn(,eo"><field name="TEXT">auf Aufstehzeit Arbeit Mo-Fr gesetzt</field></block></value></block></value></block></next></block></statement> ! <next><block type="comment" id="dwFeoHF:(%YV]1cMPW^7"><field name="COMMENT">Aufstehen Arbeit WE</field> ! <next><block type="controls_if" id="2-6p:]3RzEQ:*,7#^zFe"><value name="IF0"><block type="logic_operation" id="*Afx}KWJtCypPPt:2|HD"><field name="OP">AND</field> ! <value name="A"><block type="logic_compare" id="9BnWtUYlTju~Ij2f.0T"><field name="OP">EQ</field>
    ! <value name="A"><block type="time_get" id=";GKJXkbvGsFJ({5u*@0"><mutation format="false" language="false"></mutation> ! <field name="OPTION">wd</field></block></value> ! <value name="B"><block type="text" id=",ti,OTc!jU.1-InP,AM%"><field name="TEXT">0,6</field></block></value></block></value> ! <value name="B"><block type="time_compare_ex" id="t|2pOSv4Oa,{tb?]_kc*"><mutation end_time="true" actual_time="true"></mutation> ! <field name="USE_ACTUAL_TIME">TRUE</field> ! <field name="OPTION">between</field> ! <value name="START_TIME"><shadow type="text" id="l[cj@u/2FtGdq(,.M*8["><field name="TEXT">09:30</field></shadow></value> ! <value name="END_TIME"><shadow type="text" id="A|Pkt?]]a:~6_zhY|wX"><field name="TEXT">12:30</field></shadow></value></block></value></block></value>
    ! <statement name="DO0"><block type="control" id="Sy!jY|;r_I;2[gF.aZt6"><mutation delay_input="false"></mutation>
    ! <value name="VALUE"><block type="text" id="@U-#HIP)sD[L1?Q+t33c"><field name="TEXT">Aufstehzeit Arbeit WE Hue</field></block></value>
    ! <next><block type="debug" id="pS1t{E0a/G^0V{aysh#"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
    ! <block type="text_join" id="pCH!8EYu]mPlyRsN(Rs"><mutation items="2"></mutation> ! <value name="ADD0"><block type="field_oid" id="pE~D6n:*iZdB1yA)hR|/"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> ! <value name="ADD1"><block type="text" id="BZ9-Q~!/P,6WI6(jl6b"><field name="TEXT">auf Aufstehzeit Arbeit WE gesetzt</field></block></value></block></value></block></next></block></statement>
    ! <next><block type="comment" id="+H1T6|DoH}3fnckp8_z"><field name="COMMENT">Daemmerung Arbeit HiFi Mo-So</field> ! <next><block type="controls_if" id="1yv,9_cZu?{s|8R}G0S"><value name="IF0"><block type="logic_operation" id=".yT#mK]/k|tc!1cR!p{|"><field name="OP">AND</field>
    ! <value name="A"><block type="logic_compare" id="+={uCVHyCS},lv7E@}Se"><field name="OP">EQ</field>
    ! <value name="A"><block type="get_value" id="8s12K-0B]GO[pxHZBfhm"><field name="ATTR">val</field>
    ! <field name="OID">javascript.0.Variable.WHG.VAR200_HiFi_An</field></block></value>
    ! <value name="B"><block type="logic_boolean" id="[sk}|x|Co7.FJI@7OQFb"><field name="BOOL">TRUE</field></block></value></block></value>
    ! <value name="B"><block type="logic_compare" id="d]424_6QhEdZQ,qC48,z"><field name="OP">EQ</field>
    ! <value name="A"><block type="time_compare_ex" id="fbhTH2!e52EySHRPB=X|"><mutation end_time="true" actual_time="true"></mutation>
    ! <value name="START_TIME"><shadow type="text" id="d+La6SVqr6jUF_1X?#~"><field name="TEXT">14:00</field></shadow></value> ! <value name="END_TIME"><shadow type="text" id="1d!SpDWMg1Eg;UcdXwo4"><field name="TEXT">21:25</field></shadow></value></block></value> ! <value name="B"><block type="logic_boolean" id="r%/RWZVDIrmS5k?h2Stk"><field name="BOOL">TRUE</field></block></value></block></value></block></value> ! <statement name="DO0"><block type="control" id="YFZYKcWiwFK9i9T7xGFD"><mutation delay_input="false"></mutation> ! <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="text" id="l3xz5iteH8235OwCpZ50"><field name="TEXT">Daemmerung Arbeit Hue</field></block></value> ! <next><block type="debug" id="#tcTGQ8AJWbJE^1w*(x"><field name="Severity">log</field>
    ! <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow> ! <block type="text_join" id="(I-D~gQ]:W!-yK?/:Z5Q"><mutation items="2"></mutation> ! <value name="ADD0"><block type="field_oid" id="6=^*t]3y.[-=Qu3C+aE"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
    ! <value name="ADD1"><block type="text" id="v=0j|u3|aPFZyY9a#ppo"><field name="TEXT">auf Daemmerung Arbeit gesetzt</field></block></value></block></value></block></next></block></statement>
    ! <next><block type="comment" id="`0=^8i`IZ5R9Fd=ESC:u"><field name="COMMENT">Einschlaf Arbeit Mo-Do</field>
    ! <next><block type="controls_if" id="FK3Zu093D,TDqegvptie"><value name="IF0"><block type="logic_operation" id="/`%u{Vsp,qG14{^w:lqv"><field name="OP">AND</field>
    ! <value name="A"><block type="logic_compare" id="jc1@)wFzgi-Px?^SG9vL"><field name="OP">EQ</field>
    ! <value name="A"><block type="time_get" id="|PZ7Jq;;7Z[Y_gfTgH3-"><mutation format="false" language="false"></mutation>
    ! <value name="B"><block type="text" id="Q?![c~5qR/hs+;/!AMa^"><field name="TEXT">1-4</field></block></value></block></value>
    ! <value name="B"><block type="time_compare_ex" id="||-4;9Qo35;B^EXB#IWV"><mutation end_time="true" actual_time="true"></mutation>
    ! <value name="START_TIME"><shadow type="text" id="w./M~,?{5B`=:?F.nvuO"><field name="TEXT">21:26</field></shadow></value>
    ! <value name="END_TIME"><shadow type="text" id="w#yY0A%V_k17:`jk-Hj="><field name="TEXT">23:30</field></shadow></value></block></value></block></value>
    ! <statement name="DO0"><block type="control" id=";[iyF:Ch9iuUrL.1GJZU"><mutation delay_input="false"></mutation>
    ! <value name="VALUE"><block type="text" id="55Y`+OS-h4N?A+[IP72x"><field name="TEXT">Einschlaf Hue</field></block></value>
    ! <next><block type="debug" id=":B.S8.x:QH0yg[2=Uh"><field name="Severity">log</field>
    ! <value name="TEXT"><shadow type="text" id="i614)}`m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
    ! <block type="text_join" id="hHgj4i55J[?T8T/;6dNn"><mutation items="2"></mutation>
    ! <value name="ADD0"><block type="field_oid" id="uepHj2:iYuWz%ppnOKh["><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
    ! <value name="ADD1"><block type="text" id="9Xg{4)WlU/UDQ2ml19x"><field name="TEXT">Einschlaf gesetzt</field></block></value></block></value></block></next></block></statement>
    ! <next><block type="comment" id="WugZZP[c}p~Wy
    #i1?Q]"><field name="COMMENT">Auto Daemmerung Fr-So</field>
    ! <next><block type="controls_if" id="ijfiUP/@3d~U7.d@nL7w"><value name="IF0"><block type="logic_operation" id="0@nwqy6.@hrl,mxeBcU^"><field name="OP">AND</field>
    ! <value name="A"><block type="logic_compare" id="tHr{RUhqhO2QYQ[ib+xH"><field name="OP">EQ</field>
    ! <value name="A"><block type="time_get" id="D3o8}NL.:C#??jl1]`T|"><mutation format="false" language="false"></mutation>
    ! <value name="B"><block type="text" id="HZ8xHd71/0iA;Iqa0k}C"><field name="TEXT">0,4-6</field></block></value></block></value>
    ! <value name="B"><block type="time_compare_ex" id="mE0:Q.jc[s:TAI6HR`+D"><mutation end_time="true" actual_time="true"></mutation>
    ! <value name="START_TIME"><shadow type="text" id="!S[a@]4rG;Y{xp5[R7|w"><field name="TEXT">21:26</field></shadow></value>
    ! <value name="END_TIME"><shadow type="text" id="8lcdrYv38}K-qQlGdc{F"><field name="TEXT">23:30</field></shadow></value></block></value></block></value>
    ! <statement name="DO0"><block type="control" id="R6Dz#,njq}OTiD67`;Qd"><mutation delay_input="false"></mutation>
    ! <value name="VALUE"><block type="text" id="Jq92-2w@GoQ^.4L3Xiun"><field name="TEXT">Daemmerung Hue</field></block></value>
    ! <next><block type="debug" id="emlhh*#hq!fT(shY_(x"><field name="Severity">log</field>
    ! <block type="text_join" id="Zl#2{^NAf?c`/bWnCiW"><mutation items="2"></mutation>
    ! <value name="ADD0"><block type="field_oid" id="ptHjb?r4:Dbmhkx4QW9q"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
    ! <value name="ADD1"><block type="text" id="I^j4.,VM|!~^,^tA
    7,{"><field name="TEXT">Daemmerung gesetzt</field></block></value></block></value></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement>
    ! <statement name="ELSE"><block type="comment" id="A5B.6R.}ZLM6-EO`uXXx"><field name="COMMENT">Urlaub</field>
    ! <next><block type="controls_if" id="d9R@IHuCPqW0Q5cXQaN7"><value name="IF0"><block type="logic_compare" id="-5%s!K):_]
    ,y_RV2~[G"><field name="OP">EQ</field>
    ! <value name="A"><block type="get_value" id=";xn6+pwzvyY6@mhntq~L"><field name="ATTR">val</field>
    ! <value name="B"><block type="logic_boolean" id="bYhI|5WMubvj/D6c:aj1"><field name="BOOL">FALSE</field></block></value></block></value>
    ! <statement name="DO0"><block type="comment" id="sDxm|E]Pi8NASyvE%XCo"><field name="COMMENT">Aufstehen Urlaub</field>
    ! <next><block type="controls_if" id="~c^AEtQBSV5;RPmo]Z57"><value name="IF0"><block type="time_compare_ex" id="(zqTbNDYKu0:zxp+wL3"><mutation end_time="true" actual_time="true"></mutation>
    ! <value name="START_TIME"><shadow type="text" id="@}:#Q0[k*~Jd^BL[Gl[V"><field name="TEXT">09:30</field></shadow></value>
    ! <value name="END_TIME"><shadow type="text" id=")|e5}OO|0UPQ/@DeQe^
    "><field name="TEXT">11:00</field></shadow></value></block></value>
    ! <statement name="DO0"><block type="control" id="/QE?sY(al4eyD`G||5Yr"><mutation delay_input="false"></mutation>
    ! <value name="VALUE"><block type="text" id="#]IJCc.ui%cDqw_J5D`T"><field name="TEXT">Aufstehzeit Urlaub Hue</field></block></value>
    ! <next><block type="debug" id="Zu[;@Id7mJzS%)u0+JXQ"><field name="Severity">log</field>
    ! <block type="text_join" id=")fneWOZ_GW{IC@/%mvp("><mutation items="2"></mutation>
    ! <value name="ADD0"><block type="field_oid" id="F^)j03giLn(Bc7Bw0-q9"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
    ! <value name="ADD1"><block type="text" id="M9{E#5ie[~A7nhi));)C"><field name="TEXT">auf Aufstehzeit Urlaub gesetzt</field></block></value></block></value></block></next></block></statement></block></next></block></statement>
    ! <next><block type="comment" id="Pe~J38p.]m^jo@D_69CB"><field name="COMMENT">Daemmerung HiFi Urlaub</field>
    ! <next><block type="controls_if" id="JG{)garR5(ydf`L.dwN%"><value name="IF0"><block type="logic_operation" id="%@6r=VKASm(r~mF.wOk"><field name="OP">AND</field>
    ! <value name="A"><block type="logic_compare" id="#Z^,Ov?qS[iotjI+^,83"><field name="OP">EQ</field>
    ! <value name="A"><block type="get_value" id="yH%b(%JeT8r:I(DXuXTn"><field name="ATTR">val</field>
    ! <value name="B"><block type="logic_boolean" id="OT32T_C-MOrLfX(/~|M"><field name="BOOL">TRUE</field></block></value></block></value>
    ! <value name="B"><block type="logic_compare" id="?eS:N
    S-J)O}uONFfMzZ"><field name="OP">EQ</field>
    ! <value name="A"><block type="time_compare_ex" id="MNXF:1bOwHD{%@uyy(C;"><mutation end_time="true" actual_time="true"></mutation>
    ! <value name="START_TIME"><shadow type="text" id="uzqHBIek61}}O,qyf*^6"><field name="TEXT">14:00</field></shadow></value>
    ! <value name="END_TIME"><shadow type="text" id="0^kf?Ml?nGjf9+`)rL4}"><field name="TEXT">21:25</field></shadow></value></block></value>
    ! <value name="B"><block type="logic_boolean" id="LHIqmO6`Ymca3TwyG[`G"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
    ! <statement name="DO0"><block type="control" id="jkn06thS2ocl6}Q6Eyzd"><mutation delay_input="false"></mutation>
    ! <value name="VALUE"><block type="text" id="b}rP^zC50Y/:~9?ud8|?"><field name="TEXT">Daemmerung Urlaub Hue</field></block></value>
    ! <next><block type="debug" id=",K2ZJ)f;1N@4YaIWc@W|"><field name="Severity">log</field>
    ! <block type="text_join" id="?FRFcBj*0%[zsAp+fxm|"><mutation items="2"></mutation>
    ! <value name="ADD0"><block type="field_oid" id="BbfkC@#-eo`)|}5Z?pP6"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
    ! <value name="ADD1"><block type="text" id="Q|Ws4`g0
    @0O(KKbPgo="><field name="TEXT">auf Daemmerung Urlaub gesetzt</field></block></value></block></value></block></next></block></statement>
    ! <next><block type="comment" id="?VUemN18J(1E,8c-S~kY"><field name="COMMENT">Daemmerung Auto Urlaub</field>
    ! <next><block type="controls_if" id="?fiA1}^!|eZBocthy??A"><value name="IF0"><block type="time_compare_ex" id="GN:j{6pBd{zIU7wKf}e="><mutation end_time="true" actual_time="true"></mutation>
    ! <value name="START_TIME"><shadow type="text" id="uBGWU/8n`yBa1|NI7elZ"><field name="TEXT">21:26</field></shadow></value>
    ! <value name="END_TIME"><shadow type="text" id="ne62D@EJrbwRBC`G+V9s"><field name="TEXT">23:30</field></shadow></value></block></value>
    ! <statement name="DO0"><block type="control" id="tCVvl7I(rutr.L_#|yta"><mutation delay_input="false"></mutation>
    ! <value name="VALUE"><block type="text" id="#AC!uQOBb~LKDS,0;I/M"><field name="TEXT">Daemmerung Urlaub Hue</field></block></value>
    ! <next><block type="debug" id="2{DikCKC){}Y!G?;s)y#"><field name="Severity">log</field>
    ! <block type="text_join" id="`l^m+m}TK?/KC%[8=k%g"><mutation items="2"></mutation>
    ! <value name="ADD0"><block type="field_oid" id="c5~N4^)HL6Hc+5/1,oT0"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
    ! <value name="ADD1"><block type="text" id="p(2!.,fJc[!v/6ac0k6H"><field name="TEXT">Daemmerung Urlaub gesetzt</field></block></value></block></value></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement></block></next></block></statement></block></next></block></xml>
    Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
    • rantanplanR Offline
      rantanplanR Offline
      rantanplan
      Fast ;)
      Jetzt hast Du den Code Tag vergessen.
      Der ist schon wichtig wenn man Code einsetzt.
      Und wirklich nur über Strg-C und Strg-V einfügen. NICHT über den Zwischenweg von Word oder ähnlichem.
      Du kannst auch Deinen ersten Eintrag ändern und das lange Zeugs nachträglich in Tags packen.
      Aber nun kurz zu Deinem Problem.
      Wie ich bereits geschrieben habe werden die Wochentage von 1 bis 7 dargestellt. Nicht von 0 bis 6.
      Z.B.
      Wochentag = 2 = Dienstag
      Wochentag > 5 = Wochenende (Samstag oder Sonntag)
      Wochentad < 6 = Arbeitswoche (Montag bis Freitag)
      usw.usw. usw….
      Rantanplan
        Stormbringer
        Vielen Dank auf das wäre ich nie gekommen. Einzeln getestet würde es jetzt funktionieren. Im Ganzen leider noch immer nicht also muß wohl noch was falsch sein. Hoffe das lange Zeugs geht jetzt, vorher habe ich auch nur copy paste gemacht…
        ! <block type="comment" id="eJb}g8KK|QLIQdnXwqWD" x="65" y="-965"><field name="COMMENT">Mo-So Wochentag = 2 = Dienstag Wochentag > 5 = Wochenende (Samstag oder Sonntag) Wochentad < 6 = Arbeitswoche (Montag bis Freitag)</field>
        ! <next><block type="schedule" id="c|;MRuVnd8fva-~-4=[U"><field name="SCHEDULE">/30 * * * 0-6</field>
        nrZ@Y]"><field name="COMMENT">Aufstehen Arbeit Mo-Fr <6</field>
        ! <next><block type="controls_if" id="?n5I*[By}J~m_kFcQdBS"><value name="IF0"><block type="logic_operation" id="@.5WQLLngW?9j@Rt3xJ:"><field name="OP">AND</field>
        ! <value name="A"><block type="logic_compare" id="630ho-4EA3L(R19tP*p"><field name="OP">LT</field> ! <value name="A"><block type="time_get" id="?mXL_j%XkZWqH/ckQZMt"><mutation format="false" language="false"></mutation> ! <field name="OPTION">wd</field></block></value> ! <value name="B"><block type="text" id="iWyIrO06;|(Qoq^IV!}C"><field name="TEXT">6</field></block></value></block></value> ! <value name="B"><block type="time_compare_ex" id="uPfeP_GZLr{idZllO[Wn"><mutation end_time="true" actual_time="true"></mutation> ! <field name="USE_ACTUAL_TIME">TRUE</field> ! <field name="OPTION">between</field> ! <value name="START_TIME"><shadow type="text" id="9Z)6:x6:US2mm/Sk%QL8"><field name="TEXT">04:00</field></shadow></value> ! <value name="END_TIME"><shadow type="text" id="Ra2Q)|9.}3piNeggm^fL"><field name="TEXT">05:50</field></shadow></value></block></value></block></value> ! <statement name="DO0"><block type="control" id="w+co9}p?})8i-[|75Cs*"><mutation delay_input="false"></mutation> ! <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> ! <field name="WITH_DELAY">FALSE</field> ! <value name="VALUE"><block type="text" id="XFE_1AYk580G1/MF;3:*"><field name="TEXT">Aufstehzeit Arbeit Mo-Fr Hue</field></block></value> ! <next><block type="debug" id="hXGMK@9.5{Kf?n7A0(Cw"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
        ! <block type="text_join" id="fbS7.9}v{;},7-EE~Z_"><mutation items="2"></mutation> ! <value name="ADD0"><block type="field_oid" id="Fhb}8=Cq2aPbDA-he2[k"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> ! <value name="ADD1"><block type="text" id="4u/9O%k@s)4dkyfn(,eo"><field name="TEXT">auf Aufstehzeit Arbeit Mo-Fr gesetzt</field></block></value></block></value></block></next></block></statement> ! <next><block type="comment" id="dwFeoHF:(%YV]1cMPW^7"><field name="COMMENT">Aufstehen Arbeit WE >5</field> ! <next><block type="controls_if" id="2-6p:]3RzEQ:*,7#^zFe"><value name="IF0"><block type="logic_operation" id="*Afx}KWJtCypPPt:2|HD"><field name="OP">AND</field> ! <value name="A"><block type="logic_compare" id="9BnWtUYlTju~Ij2f.0T"><field name="OP">GT</field>
        ! <value name="A"><block type="time_get" id=";GKJXkbvGsFJ({5u*@0"><mutation format="false" language="false"></mutation> ! <field name="OPTION">wd</field></block></value> ! <value name="B"><block type="text" id=",ti,OTc!jU.1-InP,AM%"><field name="TEXT">5</field></block></value></block></value> ! <value name="B"><block type="time_compare_ex" id="t|2pOSv4Oa,{tb?]_kc*"><mutation end_time="true" actual_time="true"></mutation> ! <field name="USE_ACTUAL_TIME">TRUE</field> ! <field name="OPTION">between</field> ! <value name="START_TIME"><shadow type="text" id="l[cj@u/2FtGdq(,.M*8["><field name="TEXT">09:30</field></shadow></value> ! <value name="END_TIME"><shadow type="text" id="A|Pkt?]]a:~6_zhY|wX"><field name="TEXT">12:30</field></shadow></value></block></value></block></value>
        ! <next><block type="comment" id="`0=^8i`IZ5R9Fd=ESC:u"><field name="COMMENT">Einschlaf Arbeit Mo-Do <5</field>
        ! <value name="A"><block type="logic_compare" id="jc1@)wFzgi-Px?^SG9vL"><field name="OP">LT</field>
        ! <value name="B"><block type="text" id="Q?![c~5qR/hs+;/!AMa^"><field name="TEXT">5</field></block></value></block></value>
        #i1?Q]"><field name="COMMENT">Auto Daemmerung Fr-So >4</field>
        ! <value name="A"><block type="logic_compare" id="tHr{RUhqhO2QYQ[ib+xH"><field name="OP">GT</field>
        ! <value name="B"><block type="text" id="HZ8xHd71/0iA;Iqa0k}C"><field name="TEXT">4</field></block></value></block></value>
          rantanplanR Offline
          rantanplan
          Tut mit leid, ich kann Deinen Export nicht importieren.
          Du hast den Code-Tag wieder vergessen. :roll:
          Wenn Du es nicht mit beiden Tags hinbekommst, nimm NUR den Code-Tag. der ich wichtiger.
          Auf ein Neues.
          Rantanplan
            Stormbringer
            Sorry, woher bekomme ich denn den Code-Tag? Ich drücke auf den "Pfeil" mit Exportieren, dann öffnet sich ein Fenster wo der ganze Text schon blau markiert ist. Ich mach dann Strg. C und hier im Forum Strg. V zwischen den Strings.
            • paul53P Offline
              In der Antwort oben: Der 5. Button von links.
                Stormbringer
                <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="eJb}g8KK|QLIQdnXwqWD" x="65" y="-965"><field name="COMMENT">Mo-So Wochentag = 2 = Dienstag Wochentag > 5 = Wochenende (Samstag oder Sonntag) Wochentad < 6 = Arbeitswoche (Montag bis Freitag)</field>
                <value name="A"><block type="logic_compare" id="630ho-4EA3L(R19tP*p"><field name="OP">LT</field> <value name="A"><block type="time_get" id="?mXL_j%XkZWqH/ckQZMt"><mutation format="false" language="false"></mutation> <field name="OPTION">wd</field></block></value> <value name="B"><block type="text" id="iWyIrO06;|(Qoq^IV!}C"><field name="TEXT">6</field></block></value></block></value> <value name="B"><block type="time_compare_ex" id="uPfeP_GZLr{idZllO[Wn"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="9Z)6:x6:US2mm/Sk%QL8"><field name="TEXT">04:00</field></shadow></value> <value name="END_TIME"><shadow type="text" id="Ra2Q)|9.}3piNeggm^fL"><field name="TEXT">05:50</field></shadow></value></block></value></block></value> <statement name="DO0"><block type="control" id="w+co9}p?})8i-[|75Cs*"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="XFE_1AYk580G1/MF;3:*"><field name="TEXT">Aufstehzeit Arbeit Mo-Fr Hue</field></block></value> <next><block type="debug" id="hXGMK@9.5{Kf?n7A0(Cw"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
                <block type="text_join" id="fbS7.9}v{;},7-EE~Z_"><mutation items="2"></mutation> <value name="ADD0"><block type="field_oid" id="Fhb}8=Cq2aPbDA-he2[k"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> <value name="ADD1"><block type="text" id="4u/9O%k@s)4dkyfn(,eo"><field name="TEXT">auf Aufstehzeit Arbeit Mo-Fr gesetzt</field></block></value></block></value></block></next></block></statement> <next><block type="comment" id="dwFeoHF:(%YV]1cMPW^7"><field name="COMMENT">Aufstehen Arbeit WE >5</field> <next><block type="controls_if" id="2-6p:]3RzEQ:*,7#^zFe"><value name="IF0"><block type="logic_operation" id="*Afx}KWJtCypPPt:2|HD"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="9BnWtUYlTju~Ij2f.0T"><field name="OP">GT</field>
                <value name="A"><block type="time_get" id=";GKJXkbvGsFJ({5u*@0"><mutation format="false" language="false"></mutation> <field name="OPTION">wd</field></block></value> <value name="B"><block type="text" id=",ti,OTc!jU.1-InP,AM%"><field name="TEXT">5</field></block></value></block></value> <value name="B"><block type="time_compare_ex" id="t|2pOSv4Oa,{tb?]_kc*"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="l[cj@u/2FtGdq(,.M*8["><field name="TEXT">09:30</field></shadow></value> <value name="END_TIME"><shadow type="text" id="A|Pkt?]]a:~6_zhY|wX"><field name="TEXT">12:30</field></shadow></value></block></value></block></value>
                <next><block type="debug" id="pS1t{E0a/G^0V{aysh#"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
                <block type="text_join" id="pCH!8EYu]mPlyRsN(Rs"><mutation items="2"></mutation> <value name="ADD0"><block type="field_oid" id="pE~D6n:*iZdB1yA)hR|/"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> <value name="ADD1"><block type="text" id="BZ9-Q~!/P,6WI6(jl6b"><field name="TEXT">auf Aufstehzeit Arbeit WE gesetzt</field></block></value></block></value></block></next></block></statement>
                <next><block type="comment" id="+H1T6|DoH}3fnckp8_z"><field name="COMMENT">Daemmerung Arbeit HiFi Mo-So</field> <next><block type="controls_if" id="1yv,9_cZu?{s|8R}G0S"><value name="IF0"><block type="logic_operation" id=".yT#mK]/k|tc!1cR!p{|"><field name="OP">AND</field>
                <value name="START_TIME"><shadow type="text" id="d+La6SVqr6jUF_1X?#~"><field name="TEXT">14:00</field></shadow></value> <value name="END_TIME"><shadow type="text" id="1d!SpDWMg1Eg;UcdXwo4"><field name="TEXT">21:25</field></shadow></value></block></value> <value name="B"><block type="logic_boolean" id="r%/RWZVDIrmS5k?h2Stk"><field name="BOOL">TRUE</field></block></value></block></value></block></value> <statement name="DO0"><block type="control" id="YFZYKcWiwFK9i9T7xGFD"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="l3xz5iteH8235OwCpZ50"><field name="TEXT">Daemmerung Arbeit Hue</field></block></value> <next><block type="debug" id="#tcTGQ8AJWbJE^1w*(x"><field name="Severity">log</field>
                <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow> <block type="text_join" id="(I-D~gQ]:W!-yK?/:Z5Q"><mutation items="2"></mutation> <value name="ADD0"><block type="field_oid" id="6=^*t]3y.[-=Qu3C+aE"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
                <next><block type="comment" id="0=^8iIZ5R9Fd=ESC:u"><field name="COMMENT">Einschlaf Arbeit Mo-Do <5</field>
                <next><block type="controls_if" id="FK3Zu093D,TDqegvptie"><value name="IF0"><block type="logic_operation" id="/%u{Vsp,qG14{^w:lqv"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="jc1@)wFzgi-Px?^SG9vL"><field name="OP">LT</field> <value name="A"><block type="time_get" id="|PZ7Jq;;7Z[Y_gfTgH3-"><mutation format="false" language="false"></mutation> <field name="OPTION">wd</field></block></value> <value name="B"><block type="text" id="Q?![c~5qR/hs+;/!AMa^"><field name="TEXT">5</field></block></value></block></value> <value name="B"><block type="time_compare_ex" id="||-4;9Qo35;B^EXB#IWV"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="w./M~,?{5B=:?F.nvuO"><field name="TEXT">21:26</field></shadow></value>
                <value name="END_TIME"><shadow type="text" id="w#yY0A%V_k17:jk-Hj="><field name="TEXT">23:30</field></shadow></value></block></value></block></value> <statement name="DO0"><block type="control" id=";[iyF:Ch9iuUrL.1GJZU"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="55Y+OS-h4N?A+[IP72x"><field name="TEXT">Einschlaf Hue</field></block></value>
                <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow> <block type="text_join" id="hHgj4i55J[?T8T/;6dNn"><mutation items="2"></mutation> <value name="ADD0"><block type="field_oid" id="uepHj2:iYuWz%ppnOKh["><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> <value name="ADD1"><block type="text" id="9Xg{4)WlU/UDQ2*ml19x"><field name="TEXT">Einschlaf gesetzt</field></block></value></block></value></block></next></block></statement> <next><block type="comment" id="WugZZP[c}p~Wy*#i1?Q]"><field name="COMMENT">Auto Daemmerung Fr-So >4</field> <next><block type="controls_if" id="ijfiUP/@3d~U7.d@nL7w"><value name="IF0"><block type="logic_operation" id="0@nwqy6.@hrl,mxeBcU^"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="tHr{RUhqhO2QYQ[ib+xH"><field name="OP">GT</field> <value name="A"><block type="time_get" id="D3o8}NL.:C#??jl1]T|"><mutation format="false" language="false"></mutation>
                <value name="B"><block type="time_compare_ex" id="mE0:Q.jc[s:TAI6HR+D"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="!S[a@]4rG;Y{xp5[R7|w"><field name="TEXT">21:26</field></shadow></value> <value name="END_TIME"><shadow type="text" id="8lcdrYv38}K-qQlGdc{F"><field name="TEXT">23:30</field></shadow></value></block></value></block></value> <statement name="DO0"><block type="control" id="R6Dz#,njq}OTiD67;Qd"><mutation delay_input="false"></mutation>
                <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow> <block type="text_join" id="*Zl#2{^NAf?c/bWnCiW"><mutation items="2"></mutation>
                <statement name="ELSE"><block type="comment" id="A5B.6R.}ZLM6-EOuXXx"><field name="COMMENT">Urlaub</field> <next><block type="controls_if" id="d9R@IHuCPqW0Q5cXQaN7"><value name="IF0"><block type="logic_compare" id="-5%s!K):_]*,y_RV2~[G"><field name="OP">EQ</field> <value name="A"><block type="get_value" id=";xn6+pwzvyY6@mhntq~L"><field name="ATTR">val</field> <field name="OID">javascript.0.Variable.Person.VAR100_Arbeit</field></block></value> <value name="B"><block type="logic_boolean" id="bYhI|5WMubvj/D6c:aj1"><field name="BOOL">FALSE</field></block></value></block></value> <statement name="DO0"><block type="comment" id="sDxm|E]Pi8NASyvE%XCo"><field name="COMMENT">Aufstehen Urlaub</field> <next><block type="controls_if" id="~c^AEtQBSV5;RPmo]Z57"><value name="IF0"><block type="time_compare_ex" id="(zqTbNDYKu0:zxp+_wL3"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="@}:#Q0[k*~Jd^BL[Gl[V"><field name="TEXT">09:30</field></shadow></value> <value name="END_TIME"><shadow type="text" id=")|e5}OO|0UPQ/@DeQe^_"><field name="TEXT">11:00</field></shadow></value></block></value> <statement name="DO0"><block type="control" id="/QE?sY(al4eyDG||5Yr"><mutation delay_input="false"></mutation>
                <value name="VALUE"><block type="text" id="#]IJCc.ui%cDqw_J5DT"><field name="TEXT">Aufstehzeit Urlaub Hue</field></block></value> <next><block type="debug" id="Zu[;@Id7mJzS%)u0+JXQ"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
                <next><block type="controls_if" id="JG{)garR5(ydfL.dwN%"><value name="IF0"><block type="logic_operation" id="%@6r=VKASm(r~_mF.wOk"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="#Z^,Ov?qS[iotjI+^,83"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="yH%b(%JeT8r:I(DXuXTn"><field name="ATTR">val</field> <field name="OID">javascript.0.Variable.WHG.VAR200_HiFi_An</field></block></value> <value name="B"><block type="logic_boolean" id="OT32T_C-*MOrLfX(/~|M"><field name="BOOL">TRUE</field></block></value></block></value> <value name="B"><block type="logic_compare" id="?eS:N*S-J)O}uONFfMzZ"><field name="OP">EQ</field> <value name="A"><block type="time_compare_ex" id="MNXF:1bOwHD{%@uyy(C;"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="uzqHBIek61}}O,qyf*^6"><field name="TEXT">14:00</field></shadow></value> <value name="END_TIME"><shadow type="text" id="0^kf?Ml?nGjf9+)rL4}"><field name="TEXT">21:25</field></shadow></value></block></value>
                <value name="B"><block type="logic_boolean" id="LHIqmO6Ymca3TwyG[G"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow> <block type="text_join" id="?FRFcBj*0%[zsAp+fxm|"><mutation items="2"></mutation> <value name="ADD0"><block type="field_oid" id="BbfkC@#-eo)|}5Z?pP6"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value>
                <value name="ADD1"><block type="text" id="Q|Ws4g0_@0O(KKbPgo="><field name="TEXT">auf Daemmerung Urlaub gesetzt</field></block></value></block></value></block></next></block></statement> <next><block type="comment" id="?VUemN18J(1E,8c-S~kY"><field name="COMMENT">Daemmerung Auto Urlaub</field> <next><block type="controls_if" id="?fiA1}^!|eZBocthy??A"><value name="IF0"><block type="time_compare_ex" id="GN:j{6pBd{zIU7wKf}e="><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="uBGWU/8nyBa1|NI7elZ"><field name="TEXT">21:26</field></shadow></value>
                <value name="END_TIME"><shadow type="text" id="ne62D@EJrbwRBCG+V9s"><field name="TEXT">23:30</field></shadow></value></block></value> <statement name="DO0"><block type="control" id="tCVvl7I(rutr.L_#|yta"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="#AC!uQOBb~LKDS,0;I/M"><field name="TEXT">Daemmerung Urlaub Hue</field></block></value> <next><block type="debug" id="2{DikCKC){}Y!G?;s)y#"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
                  Stormbringer
                  Danke :D So? Hab mich jetzt nichts mehr dazu schreiben trauen :?
                    rantanplanR Offline
                    rantanplan
                    @Stormbringer:
                    Danke :D So? Hab mich jetzt nichts mehr dazu schreiben trauen :? `
                    Du hast jetzt wohl alles richtig gemacht.
                    Ich kann den Export allerdings immer noch nicht einlesen. :(
                    Bekommst Du eine Fehlermeldung wenn Du auf "Blöcke prüfen" klickst?
                    Vielleicht liegt es ja auch an mir.
                    Kann jemand anders den Export importieren?
                    Rantanplan
                      Stormbringer
                      Glaub schon, dass ich die Blöcke geprüft habe. Kann nur leider gerade nicht nochmal nachschauen, glaube shreddere gerade ioBroker mit z wave adapter und admin adapter update :oops: melde mich wieder, wenns wieder geht
                      • paul53P Offline
                        @Stormbringer:
                        Könntet ihr mir eventuell sagen was in das Textfeld reingehört? `
                        Das Feld zum Vergleichen mit dem Wochentag ist <u>kein Textfeld</u>, sondern mus eine Zahl sein, so wie von rantanplan geschrieben.
                        @rantanplan:
                        Z.B.
                        Wochentag < 6 = Arbeitswoche (Montag bis Freitag) `
                        Für das Auslösen zu jeder Minute trage einfach 5 Sterne in den Zeitplan ein: * * * * *
                          Stormbringer
                          Dankeschön aber haut leider noch immer nicht hin. Zu Testzwecken habe ich den Parsus "Daemmerung Arbeit HiFi Mo-So" rausgelöscht, weil das ja jetzt zutreffen würde und er dann ohne die Wochentage triggert. Dafür habe ich bei "Aufstehen Arbeit WE >5" die Uhrzeit bis 15:00 eingetragen. Objektvariable ändert sich leider nicht.
                          Kann man "jede Sekunde" prüfen eigentlich dann auch im Produktiven so lassen? Fordert ihm das nicht zu viel Rechenleistung ab wenn da mehrere Sachen alle Sekunden laufen? Der Grund von meinem Umstieg von Homey war, dass das ganze so lahm wurde. Lichteinschalten dauerte von 10-50 Sekunden. Vermute, dass die Regeln einfach zu komplex wurden für das Maschinchen und daher bin ich auf das tolle ioBroker gestoßen :D Macht ioBroker sowas komplexes gar nichts aus? Oder geht der auch irgendwann in die Knie? Hardware ist momentan noch ein Rasperry Pi 3, wenn ich alles einigermaßen hinbekomme würde ich aber auf nen Intel Nuc Gen 7 wechseln.
                          <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="c|;MRuVnd8fva-~-4=[U" x="65" y="-939"><field name="SCHEDULE">*****</field>
                          <statement name="DO0"><block type="comment" id="]tjA!-+r);r^tnrZ@Y]"><field name="COMMENT">Aufstehen Arbeit Mo-Fr <6</field>
                          <value name="A"><block type="logic_compare" id="630ho-4EA3L(R19tP*p"><field name="OP">LT</field> <value name="A"><block type="time_get" id="?mXL_j%XkZWqH/ckQZMt"><mutation format="false" language="false"></mutation> <field name="OPTION">wd</field></block></value> <value name="B"><block type="math_number" id="t[S6ZXf!K*~ZSH|S4%e="><field name="NUM">6</field></block></value></block></value> <value name="B"><block type="time_compare_ex" id="uPfeP_GZLr{idZllO[Wn"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="9Z)6:x6:US2mm/Sk%QL8"><field name="TEXT">04:00</field></shadow></value> <value name="END_TIME"><shadow type="text" id="Ra2Q)|9.}3piNeggm^fL"><field name="TEXT">05:50</field></shadow></value></block></value></block></value> <statement name="DO0"><block type="control" id="w+co9}p?})8i-[|75Cs*"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="XFE_1AYk580G1/MF;3:*"><field name="TEXT">Aufstehzeit Arbeit Mo-Fr Hue</field></block></value> <next><block type="debug" id="hXGMK@9.5{Kf?n7A0(Cw"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
                          <value name="A"><block type="time_get" id=";GKJXkbvGsFJ({5u*@0"><mutation format="false" language="false"></mutation> <field name="OPTION">wd</field></block></value> <value name="B"><block type="math_number" id=";Uhz{yb?r~by!MA@bN-5"><field name="NUM">5</field></block></value></block></value> <value name="B"><block type="time_compare_ex" id="t|2pOSv4Oa,{tb?]_kc*"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="l[cj@u/2FtGdq(,.M*8["><field name="TEXT">09:30</field></shadow></value> <value name="END_TIME"><shadow type="text" id="A|Pkt?]]a:~6_zhY|wX"><field name="TEXT">12:30</field></shadow></value></block></value></block></value>
                          <next><block type="controls_if" id="FK3Zu093D,TDqegvptie"><value name="IF0"><block type="logic_operation" id="/%u{Vsp,qG14{^w:lqv"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="jc1@)wFzgi-Px?^SG9vL"><field name="OP">LT</field> <value name="A"><block type="time_get" id="|PZ7Jq;;7Z[Y_gfTgH3-"><mutation format="false" language="false"></mutation> <field name="OPTION">wd</field></block></value> <value name="B"><block type="math_number" id=":vQfL+JuuV*7beR:Mb:l"><field name="NUM">5</field></block></value></block></value> <value name="B"><block type="time_compare_ex" id="||-4;9Qo35;B^EXB#IWV"><mutation end_time="true" actual_time="true"></mutation> <field name="USE_ACTUAL_TIME">TRUE</field> <field name="OPTION">between</field> <value name="START_TIME"><shadow type="text" id="w./M~,?{5B=:?F.nvuO"><field name="TEXT">21:26</field></shadow></value>
                          <value name="B"><block type="math_number" id="O-:RW#uG{Es[e2.G~[K"><field name="NUM">4</field></block></value></block></value> <value name="B"><block type="time_compare_ex" id="mE0:Q.jc[s:TAI6HR+D"><mutation end_time="true" actual_time="true"></mutation>
                          <statement name="DO0"><block type="control" id="R6Dz#,njq}OTiD67;Qd"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="Jq92-2w@GoQ^.4L3Xiun"><field name="TEXT">Daemmerung Hue</field></block></value> <next><block type="debug" id="emlhh*#hq!fT(shY_*(x"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
                          <block type="text_join" id="Zl#2{^NAf?c/bWnCiW"><mutation items="2"></mutation> <value name="ADD0"><block type="field_oid" id="ptHjb?r4:Dbmhkx4QW9q"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> <value name="ADD1"><block type="text" id="I^j4.,VM|!~^,^tA*7,{"><field name="TEXT">Daemmerung gesetzt</field></block></value></block></value></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement> <statement name="ELSE"><block type="comment" id="A5B.6R.}ZLM6-EOuXXx"><field name="COMMENT">Urlaub</field>
                          <statement name="DO0"><block type="control" id="/QE?sY(al4eyDG||5Yr"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="#]IJCc.ui%cDqw_J5DT"><field name="TEXT">Aufstehzeit Urlaub Hue</field></block></value>
                          <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow> <block type="text_join" id=")fneWOZ_GW{IC@/%mvp("><mutation items="2"></mutation> <value name="ADD0"><block type="field_oid" id="F^)j03giLn(Bc7Bw0-q9"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> <value name="ADD1"><block type="text" id="M9{E#5ie[~A7nhi));)C"><field name="TEXT">auf Aufstehzeit Urlaub gesetzt</field></block></value></block></value></block></next></block></statement></block></next></block></statement> <next><block type="comment" id="Pe~J38p.]m^jo@D_69CB"><field name="COMMENT">Daemmerung HiFi Urlaub</field> <next><block type="controls_if" id="JG{)garR5(ydfL.dwN%"><value name="IF0"><block type="logic_operation" id="%@6r=VKASm(r~mF.wOk"><field name="OP">AND</field>
                          <value name="END_TIME"><shadow type="text" id="0^kf?Ml?nGjf9+)rL4}"><field name="TEXT">21:25</field></shadow></value></block></value> <value name="B"><block type="logic_boolean" id="LHIqmO6Ymca3TwyG[G"><field name="BOOL">TRUE</field></block></value></block></value></block></value> <statement name="DO0"><block type="control" id="jkn06thS2ocl6}Q6Eyzd"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="text" id="b}rP^zC50Y/:~9?ud8|?"><field name="TEXT">Daemmerung Urlaub Hue</field></block></value> <next><block type="debug" id=",K2ZJ)f;1N@4YaIWc@W|"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow>
                          <value name="ADD0"><block type="field_oid" id="BbfkC@#-eo)|}5Z?pP6"><field name="oid">javascript.0.Variable.HUE.WHG_VAR800_Tageseinteilung</field></block></value> <value name="ADD1"><block type="text" id="Q|Ws4g0
                          <value name="START_TIME"><shadow type="text" id="uBGWU/8nyBa1|NI7elZ"><field name="TEXT">21:26</field></shadow></value> <value name="END_TIME"><shadow type="text" id="ne62D@EJrbwRBCG+V9s"><field name="TEXT">23:30</field></shadow></value></block></value>
                          <value name="TEXT"><shadow type="text" id="i614)}m8~UK+G?RiO|f"><field name="TEXT">test</field></shadow> <block type="text_join" id="l^m+m}TK?/KC%[8=k%g"><mutation items="2"></mutation>
                          • paul53P Offline
                            Zwischen den Sternen im Zeitplan müssen Leerzeichen stehen.
                            • paul53P Offline
                              Du hast generell (außer um 21:25 Uhr) vergessen, zu programmieren, was am Ende der angegebenen Zeitspanne passieren soll (Sonst-Zweige fehlen).
                                Stormbringer
                                looool jetzt habe ich alle Böcke geschossen, die man schießen kann? Vielen lieben Dank, jetzt geht es. Wünsche euch schon einmal Frohe Ostern, falls wir uns nicht mehr lesen….
                                  rantanplanR Offline
                                  rantanplan
                                  @Stormbringer:
                                  looool jetzt habe ich alle Böcke geschossen, die man schießen kann? `
                                  Also doch ein Fehler im Blockly?
                                  Frohe Ostern
                                  Rantanplan
                                    Stormbringer
                                    Jein. Das was du gesagt hast war schon der Fehler. Habe dann beim Trigger Zeitplan noch einen Fehler eingebaut, weil kein Leerzeichen zwischen den Sternen war.
