  4. History Adapter speichert keine Werte mehr
    1.0k
    6.1k
32 Beiträge 4 Kommentatoren 4.0k Aufrufe 2 Beobachtet
  • S Scheddy
    @homoran habe gerade noch mal das Speicherverzeichnis geändert und sehe jetzt mehr Fehler im Log die vielleicht helfen können.
    history.0 2022-02-03 17:00:49.256	error	Cannot find search "custom" in "system"
    history.0 2022-02-03 17:00:49.167	info	starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.0, js-controller: 3.3.22
    host.9e4f3ab9a04d 2022-02-03 17:00:47.612	info	instance system.adapter.history.0 started with pid 28218
    host.9e4f3ab9a04d 2022-02-03 17:00:32.311	info	instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.9e4f3ab9a04d 2022-02-03 17:00:17.575	info	Restart adapter system.adapter.history.0 because enabled
    host.9e4f3ab9a04d 2022-02-03 17:00:17.575	info	instance system.adapter.history.0 terminated with code NaN ()
    host.9e4f3ab9a04d 2022-02-03 17:00:17.574	warn	instance system.adapter.history.0 terminated due to SIGABRT
    host.9e4f3ab9a04d 2022-02-03 17:00:17.574	error	Caught by controller[20]: 19: 0x1448e19 [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.574	error	Caught by controller[19]: 18: 0x10b673a v8::internal::Runtime_DeleteProperty(int, unsigned long*, v8::internal::Isolate*) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.574	error	Caught by controller[18]: 17: 0x10b4600 v8::internal::Runtime::DeleteObjectProperty(v8::internal::Isolate*, v8::internal::Handle<v8::internal::JSReceiver>, v8::internal::Handle<v8::internal::Object>, v8::internal::LanguageMode) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.573	error	Caught by controller[17]: 16: 0xf2c55b v8::internal::JSReceiver::DeleteProperty(v8::internal::LookupIterator*, v8::internal::LanguageMode) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.573	error	Caught by controller[16]: 15: 0xf556cc v8::internal::LookupIterator::Delete() [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.573	error	Caught by controller[15]: 14: 0xf35be1 v8::internal::JSObject::MigrateToMap(v8::internal::Isolate*, v8::internal::Handle<v8::internal::JSObject>, v8::internal::Handle<v8::internal::Map>, int) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.573	error	Caught by controller[14]: 13: 0xf81cf9 v8::internal::Handle<v8::internal::NameDictionary> v8::internal::BaseNameDictionary<v8::internal::NameDictionary, v8::internal::NameDictionaryShape>::New<v8::internal::Isolate>(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.573	error	Caught by controller[13]: 12: 0xf80ffe v8::internal::Handle<v8::internal::NameDictionary> v8::internal::HashTable<v8::internal::NameDictionary, v8::internal::NameDictionaryShape>::New<v8::internal::Isolate>(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.572	error	Caught by controller[12]: 11: 0xd4aa54 v8::internal::FactoryBase<v8::internal::Factory>::NewFixedArrayWithFiller(v8::internal::Handle<v8::internal::Map>, int, v8::internal::Handle<v8::internal::Oddball>, v8::internal::AllocationType) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.572	error	Caught by controller[11]: 10: 0xd4a999 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawArray(int, v8::internal::AllocationType) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.572	error	Caught by controller[10]: 9: 0xd4e73d v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.572	error	Caught by controller[9]: 8: 0xd88f6c v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.571	error	Caught by controller[8]: 7: 0xd853ab v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.571	error	Caught by controller[7]: 6: 0xd7756f [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.571	error	Caught by controller[6]: 5: 0xd769e5 [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.571	error	Caught by controller[5]: 4: 0xbba7d7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.570	error	Caught by controller[4]: 3: 0xbba45e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.570	error	Caught by controller[3]: 2: 0x970199 node::FatalError(char const*, char const*) [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.570	error	Caught by controller[2]: 1: 0xa3aaf0 node::Abort() [io.history.0]
    host.9e4f3ab9a04d 2022-02-03 17:00:17.570	error	Caught by controller[1]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    host.9e4f3ab9a04d 2022-02-03 17:00:17.569	error	Caught by controller[0]: <--- JS stacktrace --->
    host.9e4f3ab9a04d 2022-02-03 17:00:17.569	error	Caught by controller[0]: [25686:0x540bc00] 179820 ms: Scavenge (reduce) 3973.7 (4105.3) -> 3973.7 (4106.3) MB, 17.4 / 0.0 ms (average mu = 0.130, current mu = 0.060) allocation failure
    host.9e4f3ab9a04d 2022-02-03 17:00:17.569	error	Caught by controller[0]: [25686:0x540bc00] 179795 ms: Scavenge (reduce) 3972.8 (4098.8) -> 3972.6 (4101.3) MB, 24.3 / 0.0 ms (average mu = 0.130, current mu = 0.060) allocation failure
    host.9e4f3ab9a04d 2022-02-03 17:00:17.568	error	Caught by controller[0]: [25686:0x540bc00] 179765 ms: Scavenge (reduce) 3971.8 (4100.8) -> 3971.9 (4100.8) MB, 12.2 / 0.0 ms (average mu = 0.130, current mu = 0.060) allocation failure
    host.9e4f3ab9a04d 2022-02-03 17:00:17.568	error	Caught by controller[0]: <--- Last few GCs --->
    history.0 2022-02-03 16:57:12.575	error	Cannot find search "custom" in "system"
    history.0 2022-02-03 16:57:12.518	info	starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.0, js-controller: 3.3.22
    @scheddy sagte in History Adapter speichert keine Werte mehr:
    Vielleicht fangen wir erst einmal mit den Grundinformationen an:
    history 1.10.5
    ist nicht stable
    @sigi234 sagte in History Adapter speichert keine Werte mehr:
    ioBroker 5.2.3
    gibbet nicht, das geht höchstens bis 3.3.22
    Hast du außer dem history Pfad (original: /opt/iobroker/iobroker-data/history) sonst noch etwas geändert?
    Hostname z.B.? war es immer host.9e4f3ab9a04d?
    Was hast du da überhaupt zusammengebraut?
    • S Scheddy
      ReportOOMFailure
      Was hast du als Basis?
      iobroker list instances und iobroker update -i
        Scheddy
        @homoran so ich versuche hier mal alle Daten übersichtlich zu zeigen
        Erstmal zu den Grundinformationen. Läuft im docker auf meinem Synology NAS.
        Daten von der alten Installation:
        iobroker 2.2.9
        Admin 4.0.10
        Node.js v10.19.0
        NPM 6.13.4
        History 1.9.10
        Name "iobrokerneu"
        Aktuelle Daten der Installation (nach erstem Start wurde der iobroker-data Ordner rüberkopiert):
        iobroker 3.3.22
        Admin 5.2.3
        Node.js v14.19.0
        NPM 6.14.16
        History 1.10.5
        Name "9e4f3ab9a04d"
        History Pfad mit alten Daten:
        /docker/iobroker_data/iobroker-data/iobroker-data
        Wenn ich ohne die Daten starte dann:
        /docker/iobroker_data/iobroker-data/history
        root@9e4f3ab9a04d:/opt/iobroker# iobroker list instances
        + system.adapter.admin.0                  : admin                 : 9e4f3ab9a04d -  enabled, port: 8081, b
        ind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : 9e4f3ab9a04d - disabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: 9e4f3ab9a04d -  enabled
        + system.adapter.discovery.0              : discovery             : 9e4f3ab9a04d -  enabled
          system.adapter.dwd.0                    : dwd                   : 9e4f3ab9a04d - disabled
          system.adapter.flot.0                   : flot                  : 9e4f3ab9a04d -  enabled
        + system.adapter.history.0                : history               : 9e4f3ab9a04d -  enabled
          system.adapter.hm-rega.0                : hm-rega               : 9e4f3ab9a04d - disabled
          system.adapter.hm-rpc.0                 : hm-rpc                : 9e4f3ab9a04d - disabled, port: 8701
          system.adapter.hm-rpc.1                 : hm-rpc                : 9e4f3ab9a04d - disabled, port: 12001
          system.adapter.hm-rpc.2                 : hm-rpc                : 9e4f3ab9a04d - disabled, port: 12010
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: 9e4f3ab9a04d -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : 9e4f3ab9a04d -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : 9e4f3ab9a04d -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : 9e4f3ab9a04d -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : 9e4f3ab9a04d -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : 9e4f3ab9a04d -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : 9e4f3ab9a04d -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: 9e4f3ab9a04d -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : 9e4f3ab9a04d -  enabled
        + system.adapter.info.0                   : info                  : 9e4f3ab9a04d -  enabled
        + system.adapter.javascript.0             : javascript            : 9e4f3ab9a04d -  enabled
        + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : 9e4f3ab9a04d -  enabled, port: 16021
        + system.adapter.parser.0                 : parser                : 9e4f3ab9a04d -  enabled
          system.adapter.ping.0                   : ping                  : 9e4f3ab9a04d - disabled
        + system.adapter.scenes.0                 : scenes                : 9e4f3ab9a04d -  enabled
        + system.adapter.simple-api.0             : simple-api            : 9e4f3ab9a04d -  enabled, port: 8087, b
        + system.adapter.tr-064.0                 : tr-064                : 9e4f3ab9a04d -  enabled
        + system.adapter.upnp.0                   : upnp                  : 9e4f3ab9a04d -  enabled
          system.adapter.vis-bars.0               : vis-bars              : 9e4f3ab9a04d -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : 9e4f3ab9a04d -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : 9e4f3ab9a04d -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : 9e4f3ab9a04d -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : 9e4f3ab9a04d -  enabled
          system.adapter.vis-history.0            : vis-history           : 9e4f3ab9a04d -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : 9e4f3ab9a04d -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : 9e4f3ab9a04d -  enabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : 9e4f3ab9a04d -  enabled
          system.adapter.vis-map.0                : vis-map               : 9e4f3ab9a04d -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : 9e4f3ab9a04d -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : 9e4f3ab9a04d -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : 9e4f3ab9a04d -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : 9e4f3ab9a04d -  enabled
          system.adapter.vis-weather.0            : vis-weather           : 9e4f3ab9a04d -  enabled
          system.adapter.vis.0                    : vis                   : 9e4f3ab9a04d -  enabled
        + system.adapter.web.0                    : web                   : 9e4f3ab9a04d -  enabled, port: 8082, b
        + system.adapter.yahka.0                  : yahka                 : 9e4f3ab9a04d -  enabled
        + instance is alive
        root@9e4f3ab9a04d:/opt/iobroker# iobroker update -i
        Used repository: default
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 5.2.3    , installed 5.2.3
        Adapter    "backitup"      : 2.2.3    , installed 2.2.4
        Adapter    "coronavirus-statistics": 0.8.7   , installed 0.8.7
        Adapter    "discovery"     : 2.7.3    , installed 2.7.5
        Adapter    "dwd"           : 2.7.7    , installed 2.7.7
        Adapter    "flot"          : 1.10.7   , installed 1.10.7
        Adapter    "history"       : 1.9.14   , installed 1.10.5
        Adapter    "hm-rega"       : 3.0.33   , installed 3.0.35
        Adapter    "hm-rpc"        : 1.15.0   , installed 1.15.0
        Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
        Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
        Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
        Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
        Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
        Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
        Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
        Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
        Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
        Adapter    "info"          : 1.9.8    , installed 1.9.18
        Adapter    "javascript"    : 5.2.13   , installed 5.2.21
        Controller "js-controller" : 3.3.22   , installed 3.3.22
        Adapter    "nanoleaf-lightpanels": 1.3.1   , installed 1.3.1
        Adapter    "parser"        : 1.0.7    , installed 1.0.7
        Adapter    "ping"          : 1.5.0    , installed 1.5.2
        Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
        Adapter    "scenes"        : 2.3.8    , installed 2.3.8
        Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
        Adapter    "socketio"      : 3.1.5    , installed 4.1.0
        Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
        Adapter    "upnp"          : 1.0.19   , installed 1.0.20
        Adapter    "vis"           : 1.4.5    , installed 1.4.8
        Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
        Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
        Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
        Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
        Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
        Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.9
        Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
        Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
        Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
        Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
        Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
        Adapter    "web"           : 3.4.16   , installed 3.4.16
        Adapter    "yahka"         : 0.13.1   , installed 0.13.1
        • S Scheddy
          iobroker 2.2.9
          Admin 4.0.10
          Node.js v10.19.0
          NPM 6.13.4
          History 1.9.10
          Name "iobrokerneu"
          iobroker 3.3.22
          Admin 5.2.3
          Node.js v14.19.0
          NPM 6.14.16
          History 1.10.5
          Name "9e4f3ab9a04d"
          + instance is alive
          update done
          So etwas gehört immer direkt an den Anfang!
          Mit Docker kenne ich mich überhaupt nicht aus.
          Auch wenn das Problem mit History wahrscheinlich nicht direkt Dockerspezifisch ist.
          Allerdings könnte ich mir vorstellen, dass die Basis ggf. schon krumm ist.
          Unter dem Vorbehalt, dass es bei Docker nicht sowieso ganz anders läuft:
          von einer ganz anderen Installation???
          das geht schief!
          anschließend einen npm rebuild durchgezogen?
          Alleine schon wegen der anderen node-Versionen?
          Hast du ioBroker mitgeteilt, dass du jetzt einen anderen Hostnamen benutzst?
          in "normalen" Installationen geht das mit iobroker host this
          was ist denn "mein Synology NAS" mit Namen und Zahlen (z.B. RAM)??
            Scheddy
            @homoran es ist eine DS1815+ mit 16GB RAM.
            So ganz schief kann es ja nicht laufen da nur die history gerade muckt.
            NPM rebuild habe ich nicht durchgeführt und auch iobroker host this nicht.
            Habe gerade mal iobroker host this probiert, aber iobroker lässt sich nicht über den Stop command stoppen.
            Das kopieren wurde hier im Forum empfohlen. Ich glaube auch nicht das es jetzt die Katastrophe ist.
            • S Scheddy
              Naja, ein FatalProcessOutOfMemory sieht nicht nach ausreichend RAM aus
              • wann war das?
              • Galt das für Docker?
              • Galt das für ein dazwischenliegendes Node-Update?
                • Die Daten werden nämlich für die Hardware und die node-version kompiliert
              Dann glaube und hoffe
              weil es für Docker eigene Befehle gibt
                • wann war das?
                Scheddy
                @homoran so History läuft jetzt. Habe ein downgrade gemacht auf die stable Version. Danach sind die Fehler immer noch gekommen. Deswegen habe ich auf ein leeres Verzeichnis gewechselt. Danach ohne Probleme zeigt er alles an und zeichnet brav auf. Ich denke ReportOOMFailure(v8::internal::Isolate*, char const*, bool) der Fehler kommt weil er auf alte Daten zugreifen will die kein bool verwenden sondern int. Ist für mich die einzige logische Erklärung.
                • S Scheddy
                  OOM ist OutOfMemory
                  da passt deine Logik dann nicht mehr so ganz
                    OOM ist OutOfMemory
                    Scheddy
                    @homoran said in History Adapter speichert keine Werte mehr:
                    OOM ist OutOfMemory
                    Das ist mir schon klar. Aber wenn er 25GB an Daten anpackt und in jedem Fehler sind passiert genau sowas.
                    • S Scheddy
                      OOM ist OutOfMemory
                      dann kommt das aber vom kopieren des iobroker data verzeichnisses.
                      Aber wenn das bei Docker funktioniert, ist das wohl so
