  4. Kreisdiagramme für VIS
    2.3k
    4.2k
35 Beiträge 5 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • C Cosmicchaos
    @liv-in-sky Ja, danke. Damit probiere ich ein bisschen rum. Alternativ ginge es vielleicht doch auch mit 2 zusammengebauten circle knob widgets.
    Das wären die beiden die ich übereinander legen würde wenn man bei einem die background color irgendwie auf opacity 0 setzen könnte.
    [{"tpl":"tplHqCircle","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"0_userdata.0.Eigen_Daten.Anteil_Grid_Tag","min":"0","max":"100","digits":"1","step":"1","is_comma":"true","displayPrevious":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"Anteil_PV_Tag","readOnly":true,"anticlockwise":true,"linecap":false,"angleOffset":"","hideNumber":true,"color":"#5e5e5e","bgcolor":"#1C7BB5","angleArc":"","cursor":"","thickness":"0.15"},"style":{"left":"879px","top":"403px","z-index":"45","width":"100px","height":"100px"},"widgetSet":"hqwidgets"}]
    [{"tpl":"tplHqCircle","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"0_userdata.0.Eigen_Daten.Anteil_PV_Tag","min":"0","max":"100","digits":"1","step":"1","is_comma":"true","displayPrevious":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"Anteil_PV_Tag","readOnly":true,"anticlockwise":false,"linecap":false,"angleOffset":"","hideNumber":true,"color":"#B4CD34","thickness":"0.15","bgcolor":"#ffffff"},"style":{"left":"1164px","top":"400px","z-index":"50","width":"100px","height":"100px","background-color":""},"widgetSet":"hqwidgets"}]
    liv-in-skyL Offline
    liv-in-skyL Offline
    @cosmicchaos wirst du nur mit jquery hinbekommen - teil von jvascript :-(
    • C Cosmicchaos
      liv-in-skyL Offline
      liv-in-skyL Offline
      @cosmicchaos
      habe das schon selbst versucht gehabt - daher habe ich das tortendiagram
      C 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        @cosmicchaos
        Cosmicchaos
        @liv-in-sky schade, das sah dem ursprünglichen Ziel schon verdammt ähnlich...
        • C Cosmicchaos
          liv-in-skyL Offline
          liv-in-skyL Offline
          @cosmicchaos
          hast du mal versucht, mit transparent als farbe zu arbeiten ?
          dann musst du aber 3 widgets übereinander legen und alle müssen ja an einer anderen stelle anfangen - also mit winkeloffset - dazu musst du aber den winkeloffset abhängig von deinen werten in den datenpunkten machen
            @cosmicchaos
            Cosmicchaos
            schrieb am zuletzt editiert von Cosmicchaos
            @liv-in-sky ich werde blöd, damit geht's... manchmal ist es zu einfach.
            man kann das zweite widget invertieren, fängt also oben auf 12 Uhr an, geht aber nach links (Grid). Der Rest ist Batterie. Das zweite Widget leigt drüber und geht nach rechts und zeigt den PV-Anteil.
            liv-in-skyL GlasfaserG 2 Antworten Letzte Antwort
            • C Cosmicchaos
              liv-in-skyL Offline
              liv-in-skyL Offline
              @cosmicchaos poste mal das ergebnis - also das widget - würd ich gerne mal sehen
              • C Cosmicchaos
                @liv-in-sky
                Wahnsinn, was alles geht. Riesen Dank für die Anleitung für Dummies ;)
                Wenn ich das richtig sehe liegt jetzt ein Tortendiagramm darunter, korrekt? Ich habe in meiner Vis da noch ein Bild drunter, das geht dann wohl nicht, oder?
                @cosmicchaos sagte in Kreisdiagramme für VIS:
                was für ein Bild?
                Hat das eine icon-Funktion?
                Oder was geht nicht?
                  Cosmicchaos
                  @liv-in-sky
                  [{"tpl":"tplHqCircle","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"oid":"0_userdata.0.Eigen_Daten.Anteil_PV_Tag","min":"0","max":"100","digits":"1","step":"1","is_comma":"true","displayPrevious":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"Anteil_PV_Tag","readOnly":true,"anticlockwise":false,"linecap":false,"angleOffset":"","hideNumber":true,"color":"#B4CD34","thickness":"0.15","bgcolor":"transparent","cursor":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"1026px","top":"821px","z-index":"50","width":"100px","height":"100px"},"widgetSet":"hqwidgets"}]
                  [{"tpl":"tplHqCircle","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"0_userdata.0.Eigen_Daten.Anteil_Grid_Tag","min":"0","max":"100","digits":"1","step":"1","is_comma":"true","displayPrevious":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"Anteil_PV_Tag","readOnly":true,"anticlockwise":true,"linecap":false,"angleOffset":"","hideNumber":true,"color":"#5e5e5e","bgcolor":"#1C7BB5","angleArc":"","cursor":"","thickness":"0.15"},"style":{"left":"1138px","top":"826px","z-index":"45","width":"100px","height":"100px"},"widgetSet":"hqwidgets"}]
                    was für ein Bild?
                    Cosmicchaos
                    @homoran Das Icon hat keine Funktion. Es ging mit der Lösung von liv-in-sky nicht, die Mitte des Widgets transparent zu halten. Mit den beiden knob widgets funzt das jedoch.
                    • C Cosmicchaos
                      @liv-in-sky
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @cosmicchaos
                      du solltest auch den code in sog. code tags packen und das dann in den spoiler
                        @cosmicchaos
                        wie wäre es mit sowas und in der mitte einen kreis darüberlegen
                        ist html code - müßte nur umgebaut werden mit ein paar bindings zum steuern
                        evtl kann man den mittelpunkt auh noch in den html code einbinden
                        könnte morgen mal ein paar tests machen
                        [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<style>\n    \n  div.my2test { background: conic-gradient(yellowgreen 70%, gold 0 86%, #f06 0);\n            height: 150px;\n    width: 150px;\n     border-radius:50%;\n  }\n</style>\n\n<div class=\"my2test \">\n   \n</div>"},"style":{"left":"405px","top":"397px","width":"163px","height":"172px"},"widgetSet":"basic"}]
                        Enrico FischerE Offline
                        Enrico Fischer
                        schrieb am zuletzt editiert von Enrico Fischer
                        @liv-in-sky said in Kreisdiagramme für VIS:
                        @cosmicchaos
                        Ich denke auch das das der beste Ansatz ist.Einfach das Diagramm auf z-index 1 legen und einen Html mit einem Radius von 100 und einem Durchmesser der kleiner ist wie das Diagramm darüber legen.Hintergrund des html widgets muss dann die selbe Farbe haben wie dein Vis hintergrund.
                        Widget Code
                        [{"tpl":"tplVis-materialdesign-Chart-Pie","data":{"oid":"nothing_selected","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","chartDataMethod":"inputPerEditor","dataCount":"1","chartType":"doughnut","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background","chartAreaBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background_chart","titleLayout":"#mdwTheme:vis-materialdesign.0.fontSizes.card.title","titleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.card.title","colorBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background","colorTitleSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_title","colorTextSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_body","colorTitle":"#mdwTheme:vis-materialdesign.0.colors.card.title","globalColor":"","hoverColor":"","borderColor":"","hoverBorderColor":"","showValues":"showValuesOff","valuesFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.pie.value","valuesFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.value","valuesFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.value","valuesPositionAnchor":"center","valuesPositionAlign":"end","valuesTextAlign":"center","legendPosition":"right","legendFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.legend","legendFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.legend","legendFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.legend","legendPointStyle":"true","showTooltip":"true","tooltipBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_background","tooltipShowColorBox":"true","tooltipTitleFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_title","tooltipTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_title","tooltipTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.tooltip_title","tooltipBodyFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_text","tooltipBodyFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_text","tooltipBodyFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.tooltip_text","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid0":"proxmox.0.node_proxmox.memory.free","oid1":"proxmox.0.node_proxmox.memory.used","dataColor0":"#cede12","dataColor1":"#1958cc","borderWidth":"0","cardUse":false},"style":{"left":"97px","top":"32px","width":"300px","height":"300px","z-index":"1"},"widgetSet":"materialdesign"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"117px","top":"52px","z-index":"2","width":"260","height":"260","background-color":"#f0e0e0","border-radius":"100%"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"proxmox.0.node_proxmox.memory.free","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_plural":" MB free"},"style":{"left":"47px","top":"365px","color":"#cede12","width":"200","height":"30","font-size":"x-large"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"proxmox.0.node_proxmox.memory.used","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_plural":" MB used"},"style":{"left":"247px","top":"365px","color":"#1958cc","width":"200","height":"30","font-size":"x-large","text-align":"right"},"widgetSet":"basic"}]
                        • C Cosmicchaos
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Das Kreisdiagramm funktioniert auch nur mit einem Widget , :
                          hier die drei Datenpunkte eintragen :
                          Hier kannst du den inneren Kreisdurchmesser ( vom Kuchen ) einstellen :
                          [{"tpl":"tplVis-materialdesign-Chart-Pie","data":{"oid":"","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","chartDataMethod":"inputPerEditor","dataCount":"2","chartType":"doughnut","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background","chartAreaBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background_chart","titleLayout":"#mdwTheme:vis-materialdesign.0.fontSizes.card.title","titleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.card.title","colorBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background","colorTitleSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_title","colorTextSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_body","colorTitle":"#mdwTheme:vis-materialdesign.0.colors.card.title","globalColor":"","hoverColor":"","borderColor":"","hoverBorderColor":"","showTooltip":false,"tooltipBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_background","tooltipShowColorBox":"true","tooltipTitleFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_title","tooltipTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_title","tooltipTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.tooltip_title","tooltipBodyFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_text","tooltipBodyFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_text","tooltipBodyFontSize":"16","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid0":"0_userdata.0.1","oid1":"0_userdata.0.2","dataColor0":"#cede12","dataColor1":"#1958cc","borderWidth":"0","cardUse":false,"oid2":"0_userdata.0.3","label0":"","valueTextColor0":"","label1":"","valueTextColor1":"","chartPaddingTop":"","chartPaddingLeft":"","chartPaddingRight":"","chartPaddingBottom":"","doughnutCutOut":"85","dataColor2":"#d2d0d0","name":"PV Kreis","g_pieValuesLayout":true,"showValues":"showValuesOff","valuesFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.pie.value","valuesFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.value","valuesFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.value","valuesPositionAnchor":"center","valuesPositionAlign":"end","valuesTextAlign":"center","g_legendLayout":false,"legendPosition":"right","legendFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.legend","legendFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.legend","legendFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.legend","legendPointStyle":"true"},"style":{"left":"505px","top":"105px","width":"300px","height":"300px","z-index":"50"},"widgetSet":"materialdesign"}]
