  4. alte iobroker images
    6.1k
45 Beiträge 4 Kommentatoren 5.0k Aufrufe 2 Beobachtet
    @flinke-flasche sagte in alte iobroker images:
    zieht sich Daten
    tut er das?
    The id is empty! Please provide a valid id.
    Flinke Flasche
    ja, das sind die Daten aus dem ARCAM
    m.0
    2022-01-15 15:36:20.086	debug	State *** arcamAudio.DolbyLeveller.Level *** set with value *** 0 ***
    arcam.0
    2022-01-15 15:36:20.083	debug	Message Received: <<< Rx_Zn: 01 Cc: 39 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:20.038	debug	Gesendet wird: TxCc= 57 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:19.813	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    arcam.0
    2022-01-15 15:36:19.812	info	terminating
    arcam.0
    2022-01-15 15:36:19.680	debug	State *** arcamAudio.DolbyVolume.CalOffset.Level *** set with value *** 15 ***
    arcam.0
    2022-01-15 15:36:19.678	debug	Message Received: <<< Rx_Zn: 01 Cc: 3a Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 0f >>>
    arcam.0
    2022-01-15 15:36:19.634	debug	Gesendet wird: TxCc= 58 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:19.477	debug	State *** arcamAudio.DolbyVolume.Status *** set with value *** Dolby Volume off ***
    arcam.0
    2022-01-15 15:36:19.476	debug	Message Received: <<< Rx_Zn: 01 Cc: 38 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:19.431	debug	Gesendet wird: TxCc= 56 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:19.309	debug	<< ADAPTER UNLOAD >>
    arcam.0
    2022-01-15 15:36:19.298	error	The id is empty! Please provide a valid id.
    arcam.0
    2022-01-15 15:36:19.297	error	Error: The id is empty! Please provide a valid id. at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:501:19) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6081:17) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.arcam/arcam.js:438:14) at Socket.emit (events.js:314:20) at addChunk (_stream_readable.js:297:12) at readableAddChunk (_stream_readable.js:272:9) at Socket.Readable.push (_stream_readable.js:213:10) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
    arcam.0
    2022-01-15 15:36:19.285	error	unhandled promise rejection: The id is empty! Please provide a valid id.
    arcam.0
    2022-01-15 15:36:19.284	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    arcam.0
    2022-01-15 15:36:19.280	debug	State *** undefined *** set with value *** ***
    arcam.0
    2022-01-15 15:36:19.274	debug	Message Received: <<< Rx_Zn: 01 Cc: 4e Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:19.228	debug	Gesendet wird: TxCc= 78 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:19.075	debug	State *** arcamAudio.Mode.RoomEq *** set with value *** Room Eq On ***
    arcam.0
    2022-01-15 15:36:19.072	debug	Message Received: <<< Rx_Zn: 01 Cc: 37 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 01 >>>
    arcam.0
    2022-01-15 15:36:19.025	debug	Gesendet wird: TxCc= 55 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:18.671	debug	State *** arcamTuner.FM.Info.Genre *** set with value *** ***
    arcam.0
    2022-01-15 15:36:18.668	debug	Message Received: <<< Rx_Zn: 01 Cc: 03 Rx_Ac: 00 Rx_Dl: 00 Rx_Data: >>>
    arcam.0
    2022-01-15 15:36:18.619	debug	Gesendet wird: TxCc= 3 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:18.469	debug	State *** arcamInput.Video *** set with value *** BD ***
    arcam.0
    2022-01-15 15:36:18.466	debug	Message Received: <<< Rx_Zn: 01 Cc: 0a Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:18.415	debug	Gesendet wird: TxCc= 10 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:18.258	debug	State *** arcamAudio.Mode.DecodeMode.2Channel *** set with value *** DTS Neural:X ***
    arcam.0
    2022-01-15 15:36:18.255	debug	Message Received: <<< Rx_Zn: 01 Cc: 10 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 0a >>>
    arcam.0
    2022-01-15 15:36:18.210	debug	Gesendet wird: TxCc= 16 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:18.053	debug	State *** arcamAudio.Mode.DecodeMode.MultiChannel *** set with value *** DTS-ES / Neural:X ***
    arcam.0
    2022-01-15 15:36:18.051	debug	Message Received: <<< Rx_Zn: 01 Cc: 11 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 03 >>>
    arcam.0
    2022-01-15 15:36:18.007	debug	Gesendet wird: TxCc= 17 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:17.867	debug	State *** arcamTuner.DAB.Info.DLS_PDT_Info *** set with value ***  ***
    arcam.0
    2022-01-15 15:36:17.863	debug	Message Received: <<< Rx_Zn: 01 Cc: 1a Rx_Ac: 00 Rx_Dl: 81 Rx_Data: 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 >>>
    arcam.0
    2022-01-15 15:36:17.804	debug	Gesendet wird: TxCc= 26 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:17.649	debug	State *** arcamAudio.Info.IncomingAudioSampleRate *** set with value *** 48 kHz ***
    arcam.0
    2022-01-15 15:36:17.647	debug	Message Received: <<< Rx_Zn: 01 Cc: 44 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 02 >>>
    arcam.0
    2022-01-15 15:36:17.602	debug	Gesendet wird: TxCc= 68 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:17.459	debug	State *** arcamAudio.Info.IncomingAudioFormat *** set with value *** Undetected / Undetected ***
    arcam.0
    2022-01-15 15:36:17.446	debug	Message Received: <<< Rx_Zn: 01 Cc: 43 Rx_Ac: 00 Rx_Dl: 02 Rx_Data: 1521 >>>
    arcam.0
    2022-01-15 15:36:17.398	debug	Gesendet wird: TxCc= 67 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:17.219	debug	State *** arcamDisplay.FrontDisplay.InfoType *** set with value *** Processing Mode ***
    arcam.0
    2022-01-15 15:36:17.215	debug	Message Received: <<< Rx_Zn: 01 Cc: 09 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:17.170	debug	Gesendet wird: TxCc= 9 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:17.014	debug	State *** arcamVideo.Info.IncomingVideoMode *** set with value *** 1x15120 153Hz undefinedundefined ***
    arcam.0
    2022-01-15 15:36:17.012	debug	Message Received: <<< Rx_Zn: 01 Cc: 42 Rx_Ac: 00 Rx_Dl: 07 Rx_Data: 00013b10997400 >>>
    arcam.0
    2022-01-15 15:36:16.964	debug	Gesendet wird: TxCc= 66 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:16.811	debug	State *** arcamInput.Input2 *** set with value *** Follow Zone 1 ***
    arcam.0
    2022-01-15 15:36:16.809	debug	Message Received: <<< Rx_Zn: 02 Cc: 1d Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:16.760	debug	Gesendet wird: TxCc= 29 TxZn: 02 TxData: 240
    arcam.0
    2022-01-15 15:36:16.609	debug	State *** arcamInput.Input *** set with value *** BD ***
    arcam.0
    2022-01-15 15:36:16.607	debug	Message Received: <<< Rx_Zn: 01 Cc: 1d Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 02 >>>
    arcam.0
    2022-01-15 15:36:16.557	debug	Gesendet wird: TxCc= 29 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:16.207	debug	State *** arcamSystem.Power2 *** set with value *** 00 ***
    arcam.0
    2022-01-15 15:36:16.203	debug	Message Received: <<< Rx_Zn: 02 Cc: 00 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:16.152	debug	Gesendet wird: TxCc= 0 TxZn: 02 TxData: 240
    arcam.0
    2022-01-15 15:36:15.996	debug	State *** arcamSystem.Power *** set with value *** 00 ***
    arcam.0
    2022-01-15 15:36:15.993	debug	Message Received: <<< Rx_Zn: 01 Cc: 00 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:15.948	debug	Gesendet wird: TxCc= 0 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:15.793	debug	State *** arcamAudio.Mode.Compression *** set with value *** Off ***
    arcam.0
    2022-01-15 15:36:15.791	debug	Message Received: <<< Rx_Zn: 01 Cc: 41 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:15.744	debug	Gesendet wird: TxCc= 65 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:15.590	debug	State *** arcamDisplay.FrontDisplay.Brightness *** set with value *** Off ***
    arcam.0
    2022-01-15 15:36:15.587	debug	Message Received: <<< Rx_Zn: 01 Cc: 01 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:15.539	debug	Gesendet wird: TxCc= 1 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:15.379	debug	State *** arcamAudio.Info.Headphones.Status *** set with value *** Headphones Not Connected ***
    arcam.0
    2022-01-15 15:36:15.375	debug	Message Received: <<< Rx_Zn: 01 Cc: 02 Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:15.330	debug	Gesendet wird: TxCc= 2 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:15.177	debug	State *** arcamAudio.Volume.Mute2 *** set with value *** 1 ***
    arcam.0
    2022-01-15 15:36:15.173	debug	Message Received: <<< Rx_Zn: 02 Cc: 0e Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 00 >>>
    arcam.0
    2022-01-15 15:36:15.126	debug	Gesendet wird: TxCc= 14 TxZn: 02 TxData: 240
    arcam.0
    2022-01-15 15:36:14.975	debug	State *** arcamAudio.Volume.Mute *** set with value *** 0 ***
    arcam.0
    2022-01-15 15:36:14.971	debug	Message Received: <<< Rx_Zn: 01 Cc: 0e Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 01 >>>
    arcam.0
    2022-01-15 15:36:14.922	debug	Gesendet wird: TxCc= 14 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:14.774	debug	State *** arcamAudio.Volume.Volume2 *** set with value *** 50 ***
    arcam.0
    2022-01-15 15:36:14.771	debug	Message Received: <<< Rx_Zn: 02 Cc: 0d Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 32 >>>
    arcam.0
    2022-01-15 15:36:14.717	debug	Gesendet wird: TxCc= 13 TxZn: 02 TxData: 240
    arcam.0
    2022-01-15 15:36:14.568	debug	State *** arcamAudio.Volume.Volume *** set with value *** 50 ***
    arcam.0
    2022-01-15 15:36:14.560	debug	Message Received: <<< Rx_Zn: 01 Cc: 0d Rx_Ac: 00 Rx_Dl: 01 Rx_Data: 32 >>>
    arcam.0
    2022-01-15 15:36:14.513	debug	Gesendet wird: TxCc= 13 TxZn: 01 TxData: 240
    arcam.0
    2022-01-15 15:36:14.488	debug	verification of states completed - starting autoRequest
    arcam.0
    2022-01-15 15:36:12.585	info	State value to set for "arcam.0.arcamSystem.Info.Connected" has to be type "bool" but received type "number"
    arcam.0
    2022-01-15 15:36:12.572	debug	adapter connected to ARCAM-AVR: 192.168.0.99:5000
    arcam.0
    2022-01-15 15:36:12.455	debug	<< ADAPTER MAIN BLOCK >>
    arcam.0
    2022-01-15 15:36:12.453	debug	<< ADAPTER READY >>
    • F Flinke Flasche
      m.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      arcam.0
      ja
      was für eine ID fehlt ihm denn?
      F 1 Antwort Letzte Antwort
        ja
        Flinke Flasche
        keine Ahnung
        • F Flinke Flasche
          keine Ahnung
          keine Ahnung
          aber ich????
          Ich kenne den Adapter nicht und weiß nicht wo da eine ID eingegeben werden muss.
          Ohne Screenshot der Instanzenkonfig bin ich im Blindflug
          Hast du dir die Konfig nach der Meldung wenigstens mal angesehen?
            keine Ahnung
            aber ich????
            Flinke Flasche
            es kann nirgends eine ID eingegeben werden.
            • F Flinke Flasche
              dann zeig mal die Objects
                Flinke Flasche
                da gibt es sehr viele Ordner
                  Ich habe keine Ahnung, das müsste sich ein Dev ansehen.
                  Eine angemeckerte Stelle ist:
                  					adapter.setState(stateName, {
                  					val: stateVal,
                  					ack: true
                  https://github.com/Schorsch99/ioBroker.arcam/blob/master/arcam.js#L438
                    					val: stateVal,
                    					ack: true
                    Flinke Flasche
                    ich auch nicht.
                    Trotzdem DANKE für deine Zeit und fürs helfen.
                    Muss mir evtl. doch mal ne neue Fernbedienung suchen.
                    • F Flinke Flasche
                      ich auch nicht.
                      Flinke Flasche
                      Ich habe es nun hinbekommen.
                      Ich habe eine altes Image im Netz gefunden und installiert.
                      Der Arcam Adapter funktionierte, allerdings brauchte ich noch den SimpleAPI Adapter. Dafür musste ich den js.Controller aktualisieren.
                      Mit der aktuellen Version 3.3 ging es wieder nicht.
                      Danach habe ich auf 2.2.10 downgegradet und nun funktioniert wieder alles.
                      Vermutlich funktioniert es auch wenn ich das aktuelle Image verwende und da versuche den js.controller downgrade.
                      • F Flinke Flasche
                        nein, weil dann einiges anderes (u.a. der admin) nicht mehr laufen.
                        denn mal viel Glück
                        man kann auch keine Aktuelle Software unter win 3.11 installieren
                          denn mal viel Glück
                          Flinke Flasche
                          Danke.
                          Werd mir jetzt das Image abspeichern als Sicherheit.
                          Da hast du natürlich recht.
