  4. Javascript Adapter rot
    5.5k
91 Beiträge 4 Kommentatoren 11.6k Aufrufe 3 Beobachtet
  • ChrisPrefectC ChrisPrefect
    @homoran Ich hatte immer beides zusammen ausgeführt:
    cd /opt/iobroker
    sudo -H -u iobroker npm cache clean --force
    pi@ioBrokerVM:/opt/iobroker$ cd /opt/iobroker
    pi@ioBrokerVM:/opt/iobroker$ sudo -H -u iobroker npm cache clean --force
    npm WARN using --force I sure hope you know what you are doing.
    pi@ioBrokerVM:/opt/iobroker$ iob update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
    Adapter    "backitup"      : 2.2.2    , installed 2.2.3
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "deconz"        : 1.3.19   , installed 1.3.19
    Adapter    "discovery"     : 2.7.3    , installed 2.7.5
    Adapter    "email"         : 1.0.10   , installed 1.0.10
    Adapter    "flot"          : 1.10.7   , installed 1.10.7
    Adapter    "geofency"      : 1.0.3    , installed 1.0.3
    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
    Adapter    "history"       : 1.9.14   , installed 1.10.5
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "influxdb"      : 1.9.5    , installed 2.4.0
    Adapter    "info"          : 1.9.8    , installed 1.9.16
    Adapter    "iot"           : 1.8.24   , installed 1.8.25
    Adapter    "iqontrol"      : 1.8.2    , installed 1.11.0
    Adapter    "jarvis"        : 2.2.1    , installed 3.0.7
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "lifx"          : 0.1.1    , installed 0.1.1
    Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
    Adapter    "material"      : 1.0.4    , installed 1.1.2
    Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
    Adapter    "mobile"        : 1.0.1    , installed 1.0.1
    Adapter    "modbus"        : 3.4.14   , installed 3.4.17
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.1
    Adapter    "node-red"      : 2.4.1    , installed 2.4.1
    Adapter    "octoprint"     : 2.1.0    , installed 2.1.1
    Adapter    "onvif"         : 0.4.4    , installed 0.4.4
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "proxy"         : 1.2.2    , installed 1.2.2
    Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
    Adapter    "samsung"       : 0.2.9    , installed 0.2.9
    Adapter    "scenes"        : 2.3.8    , installed 2.3.8
    Adapter    "shelly"        : 4.0.7    , installed 5.0.0
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
    Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.5
    Adapter    "sonoff"        : 2.4.5    , installed 2.4.7
    Adapter    "statistics"    : 1.0.9    , installed 1.0.10
    Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "tesla-motors"  : 0.5.2    , installed 1.0.7
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
    Adapter    "unifi"         : 0.5.10   , installed 0.5.10
    Adapter    "vis"           : 1.4.5    , installed 1.4.7
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.9
    Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
    Adapter    "web"           : 3.4.9    , installed 3.4.16
    Adapter    "windows-control": 0.1.5   , installed 0.1.5
    Adapter    "yahka"         : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"        : 1.6.6    , installed 1.6.12
    @chrisprefect sagte in Javascript Adapter rot:
    IMMER?
    sudo -u iobroker -H npm cache clean --force Error: EACCES: permission denied, scandir '/root'
    bist du da im Home des Root oder in /opt/iobroker?
    und davor hast du nie in der Konsole etwas mit npm macheirgendetwas gearbeitet?
    und auch nie mit root irgendwelche Rechte verbogen?
    Dann verstehe ich die Probleme überhaupt nicht
    ChrisPrefectC 1 Antwort Letzte Antwort
      IMMER?
      ChrisPrefectC Offline
      ChrisPrefect
      #66
      @homoran Das permission denied war mit root. Ich weiss aber nicht in welchem Verzeichnis.
      Rechte habe ich nie selbst geändert, ausser mit dem fixer.
      Mit npm habe ich vielleicht vor vielen Monaten mal etwas reparieren müssen. Wobei am Schluss habe ich meistens einen alten Virtualbox-Snapshot restaurieren müssen. Seit da lief das System aber zuverlässig. Wenn da Rechte falsch gewesen wären, hätte das schon früher einen Effekt gehabt, nicht?
        #67
        nee, das passiert durch die Nutzung von root.
        Alles was er anlegt bekommt auch er nur noch als Zugriff.
        Und wenn er irgendetwas sogar in seinem Home anlegt, kommst du/iobroker nicht mal mit sudo mehr dran.
        Aber es ist ja egal wenn man mit root arbeitet
        oder erst beim nächsten versuchten Zugriff, so wie jetzt
          cd /opt/iobroker
          update done
          GlasfaserG Offline
          GlasfaserG Offline
          #68
          @chrisprefect
          iobroker del javascript
          danach zeige
          iob update -i
          • GlasfaserG Glasfaser
            @chrisprefect
            danach zeige
            iob update -i
            ChrisPrefect
            #69
            @glasfaser
            Werden da meine Skripte gelöscht? Ich habe recht viele...
            pi@ioBrokerVM:~$ cd /opt/iobroker
            pi@ioBrokerVM:/opt/iobroker$ iobroker del javascript
            Delete adapter "javascript"
            host.ioBrokerVM Counted 1 instances of javascript
            host.ioBrokerVM Counted 1 meta of javascript
            host.ioBrokerVM Counted 1 adapter for javascript
            host.ioBrokerVM Counted 3 channels of javascript
            host.ioBrokerVM Counted 147 states of javascript
            host.ioBrokerVM Counted 16 states of system.adapter.javascript
            host.ioBrokerVM Counted 89 states (io.javascript.*) from states
            host.ioBrokerVM Counted 16 states (system.adapter.javascript.*) from states
            host.ioBrokerVM Counted 1 objects of javascript
            host.ioBrokerVM file javascript.admin deleted
            host.ioBrokerVM object javascript deleted
            host.ioBrokerVM object javascript.admin deleted
            host.ioBrokerVM Deleting 170 object(s).
            host.ioBrokerVM Deleting 105 state(s).
            Error deleting adapter javascript from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
            You might have to delete it yourself!
            hash changed or no sources cached => force download of new sources
            update done
              @glasfaser
              update done
              GlasfaserG Offline
              GlasfaserG Offline
              #70
              @chrisprefect
              Hast du wie oben von mir mal angegeben , die VM neu gestartet !?
                @glasfaser Das kam am ende nach iobroker u all
                upload [1] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/index_m.html index_m.html text/html
                upload [0] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/admin.d.ts admin.d.ts video/mp2t
                internal/modules/cjs/loader.js:1131
                    throw err;
                    at parse (<anonymous>)
                    at Object.Module._extensions..json (internal/modules/cjs/loader.js:1128:22)
                    at Module.load (internal/modules/cjs/loader.js:950:32)
                    at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                    at Module.require (internal/modules/cjs/loader.js:974:19)
                    at require (internal/modules/cjs/helpers.js:93:18)
                    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19)
                    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:245:26
                    at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2303:9)
                    at processImmediate (internal/timers.js:466:21)
                Und der Javascript-Adapter ist noch immer rot nach dem Neustart. Und das Update sehe ich auch nicht.
                #71
                @Glasfaser
                War ich von ausgegangen
                sonst können wir nochmal ganz von vorne beginnen
                  @chrisprefect
                  ChrisPrefect
                  #72
                  @glasfaser ja, VM ist neu gestartet.
                    @Glasfaser
                    ChrisPrefect
                    #73
                    @homoran Wie installiere ich den Javascript-Adapter wieder? Und sehe ich dann meine Skripte auch wieder?
                      #74
                      dann exportiere sie doch erst einmal sicherheitshalber
                        ChrisPrefect
                        #75
                        @homoran Ich habe deinen Befehl ja schon ausgeführt.
                          #76
                          welchen?
                          Skripte werden über die Instanz exportiert
                            welchen?
                            ChrisPrefect
                            #77
                            @homoran Den von @Glasfaser :
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #78
                              @chrisprefect
                              Da hast aber ganz schön was .........
                              Auf hard ...
                              cd /opt/iobroker
                              npm uninstall javascript
                              npm uninstall js-controller
                              Ausgabe
                              iob update -i
                              ChrisPrefectC HomoranH 2 Antworten Letzte Antwort
                                @chrisprefect
                                Auf hard ...
                                cd /opt/iobroker
                                Ausgabe
                                iob update -i
                                ChrisPrefect
                                #79
                                @glasfaser sagte in Javascript Adapter rot:
                                iob update -i
                                pi@ioBrokerVM:/opt/iobroker$ npm uninstall javascript
                                [sudo] Passwort für pi:
                                Das hat nicht funktioniert, bitte nochmal probieren.
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                                up to date in 22.931s
                                155 packages are looking for funding
                                  run `npm fund` for details
                                pi@ioBrokerVM:/opt/iobroker$ npm uninstall js-controller
                                [..................] / rollbackFailedOptional: verb npm-session 29b8658558937b5f
                                up to date in 20.442s
                                update done
                                  @chrisprefect
                                  Auf hard ...
                                  cd /opt/iobroker
                                  Ausgabe
                                  iob update -i
                                  #80
                                  Auf hard ...
                                  shure?
                                  ohne -u iobroker -H ?
                                    iob update -i
                                    update done
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #81
                                    @chrisprefect
                                    Erlich ......
                                    nimm ein Backup .... installiere ioBroker neu
                                    und lass die Finger von root
                                    HomoranH ChrisPrefectC 2 Antworten Letzte Antwort
                                      Auf hard ...
                                      shure?
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #82
                                      @homoran sagte in Javascript Adapter rot:
                                      shure?
                                      Ja ... wollte sehen was passiert
                                        @chrisprefect
                                        Erlich ......
                                        #83
                                        nimm ein Backup
                                        da sind dann auch deine Skripte drin
                                          @chrisprefect
                                          Erlich ......
                                          ChrisPrefect
                                          #84
                                          @glasfaser Das Backup das ich habe ist von vorgestern. Das war wohl noch vor dem Update der Admin-Instanz. Aber wenn ich das wieder zurückspiele und wieder update bin ich gleich weit.
                                          HomoranH GlasfaserG 2 Antworten Letzte Antwort
