  4. Flot Diagramm
    2.3k
    4.2k
Flot Diagramm
26 Beiträge 3 Kommentatoren 1.1k Aufrufe 1 Beobachtet
    @andibr sagte in Flot Diagramm:
    Das finde ich hässlich, was kann man da machen?
    was erwartest du, wenn der Wert 0 ist?
    Welche Einstellungen hast du denn?
    andibr
    schrieb am zuletzt editiert von andibr
    Welche möchtest du wissen? Es gibt da so viele?
    http://192.168.168.5:8082/flot/index.html?l%5B0%5D%5Bid%5D=0_userdata.0.Daten.Verbrauch.Holz&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bcolor%5D=%23ff9700&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=1&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=0&l%5B0%5D%5BspaceLength%5D=0&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Bpoints%5D=false&l%5B0%5D%5Byaxe%5D=rightColor&l%5B0%5D%5Bname%5D=Holz&l%5B0%5D%5Bxticks%5D=0&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bunit%5D=kg&l%5B1%5D%5Bid%5D=alias.0.Heizung.Witterung&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300ff5c&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=AT+S%C3%BCd&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BafterComma%5D=1&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5Bfill%5D=0.1&l%5B1%5D%5Bsmoothing%5D=1&l%5B1%5D%5Byaxe%5D=leftColor&l%5B1%5D%5BignoreNull%5D=false&l%5B2%5D%5Bid%5D=0_userdata.0.Daten.Verbrauch.Wasser&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=average&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=0&l%5B2%5D%5Bname%5D=Wasser&l%5B2%5D%5Bxmove%5D=0&l%5B2%5D%5BchartType%5D=line&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BafterComma%5D=1&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B2%5D%5Bmultiplicator%5D=1&l%5B2%5D%5Bpoints%5D=false&l%5B2%5D%5ByOffset%5D=0&l%5B2%5D%5Bxticks%5D=0&l%5B2%5D%5Byticks%5D=0&l%5B2%5D%5Byaxe%5D=rightColor&l%5B2%5D%5Bsmoothing%5D=1&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5BignoreNull%5D=false&l%5B2%5D%5Bunit%5D=m3&timeType=relative&relativeEnd=1minute&range=4320&aggregateType=count&aggregateSpan=24&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=300&live=3600&start=2021-10-30&end=2021-10-31&title=Energieverbrauch&barColor=%23ffffff&barWidth=0.2&legend=nw&legBgOpacity=1&timeFormat=%25H%3A%25M+%25d.%25m.&m%5B0%5D%5Bl%5D=1&m%5B0%5D%5Bv%5D=0&m%5B0%5D%5Bf%5D=false&m%5B0%5D%5Bc%5D=%23f8a2a2&m%5B0%5D%5Bt%5D=1&m%5B0%5D%5Bs%5D=0&m%5B0%5D%5Bd%5D=&m%5B0%5D%5Bp%5D=r&m%5B0%5D%5Bpy%5D=0&m%5B0%5D%5Bfc%5D=%23FF0000&m%5B0%5D%5Bfs%5D=&m%5B0%5D%5Bvl%5D=0&_refts=1641219266988
    eigentlich denke ich wäre es am besten, wenn die Linie nach dem letzten Datenpunkt einfach aufhören würde.
    • A andibr
      was hast du denn bei den Einstellungen zur Behandlung von NULL drin?
      • A andibr
        @andibr
        Nimm mal Chart Type "Schritte". Dann sieht man besser, zu welchem Zeitpunkt welcher Wert vorliegt.
          @andibr
          @paul53 sagte in Flot Diagramm:
          @andibr
          das ist eine gute Idee. Immerhin hat er bei Art mittel und nicht minmax.
            @andibr
            andibr
            Also ich habe sowohl mit alle 3 Einstellung probiert und die Linie geht immer zu 0.
            mit dem "Schritte" macht er das entweder nicht oder im unsichtbaren Bereich.
            jetzt steht es auf ignorieren.
            • A andibr
              @andibr
              Was ist das für ein Temperatursensor, der nur alle 3 Stunden aktualisiert?
                @andibr
                andibr
                Das ist ein EnOcean Thermokon SR65
                Edit: nee stimmt nicht, das ist ein js das mir mit JSON die Daten aus der Heizkesselsteuerung liest. Gem. History kommt da alle 1min ein Wert an und wir eingetragen.
                • A andibr
                  @andibr zeig mal die Tabelle der geloggten Daten
                    andibr
                    Temperatur.csv
                    Also da sind halt schon sehr wenige Veränderungen drin.
                    • A andibr
                      Temperatur.csv
                      @andibr sagte: Also da sind halt schon sehr wenige Veränderungen drin.
                      Aber im Minutenbereich mit 0,1 Grad Auflösung und nicht nur alle 3 Stunden.
                        andibr
                        @paul53 said in Flot Diagramm:
                        Das sind die Einstellung beim erweitert
                        • A andibr
                          @andibr sagte: Das sind die Einstellung beim erweitert
                          Zeige mal die Einstellungen im Tab "Zeit".
                            andibr
                            könnte es an dem "24" liegen?
                            Edit: ok, jetzt habe ich auf 200 erhöht und die Linie macht jetzt mehr Kurven
                            aber der rechte Rand ist immer noch doof
                            paul53P HomoranH 2 Antworten Letzte Antwort
                            • A andibr
                              @andibr
                              So sehen typisch meine Einstellungen aus:
                                @andibr
                                andibr
                                so jetzt mit deinen Werten und mit "null ignorieren"
                                So sieht das ganze doch schon viel besser aus. Jetzt muss ich mal noch mit den anderen beiden Werten testen.
                                Ich interpretiere mal das es mit dem "null ignorieren" gehen sollte, wenn man den Rest richtig macht. Zum Schluss möchte ich eigentlich einfach den Pellets verbrauch im Verhältnis zur Witterungstemperatur darstellen. Die blaue Kurve (die jetzt plötzlich nicht mehr geht) sollte für meine Familie eigentlich den Wasserverbrauch anzeigen.
                                PS: das ist mein erstes Diagramm mit Flot seit ich von fhem umgestiegen bin.
                                Danke für die Korrektur
                                • A andibr
                                  das bedeutet, dass eine Linie 24 Punkte hat, der Rest wird extrapoliert.
                                  Allerdings irritiert mich deine Anzeige der x-Achse mit "Minutenende" bei 3 Tagen.
                                  Ich hab da immer Tagesende, oder wie @paul53 jetzt
                                  • A andibr
                                    @andibr sagte: das ist mein erstes Diagramm mit Flot
                                    Man sollte zu jedem Wert "Min" und "Max" angeben, da dies die Skalierung bestimmt und man bei gut gewählter Skalierung den Wert anhand der Gitterlinien ablesen kann. Vorschlag:
                                    • Holz 0 - 60
                                    • Wasser 0 - 1.2
                                    • AT -20 - 40
                                      • Holz 0 - 60
                                      • Wasser 0 - 1.2
                                      • AT -20 - 40
                                      andibr
                                      So nun habe ich nochmals einen Versuch gemacht, ich denke jetzt sieht es doch schon ganz ansprechend aus?
                                      Die "Fehler mit dem Nullwert" sind mir erklärbar, weil ich die Berechnungen im Hintergrund angepasst habe. Jetzt mal schauen wie sich das über den Tag entwickelt.
                                      Jetzt wäre es noch schön wenn man in der Legende den "AT Süd" noch nach oben schieben könnte. Ist mir schon klar, man kann das im ganzen Code von Hand machen, aber ob es dann noch passt?
                                      Edit: Was natürlich auch noch schön wäre, wenn man das eingebetete Diagram auch via den Cloud-Zugriff sehen würde. Irgendwo habe ich da mal einen Forumseintrag gesehen, aber wo?
                                      • A andibr
                                        Dazu musst du die Reihenfolge der Linien ändern.
                                        Da das Ganze bei Flot nicht so einfach geht musst du alle anderen Linien nach unten kopieren
                                        Ob du das allerdings wirklich willst ist fraglich.
                                        Die räumliche Darstellung der Kurven ist ebenfalls von der Reihenfolge der Linien abhängig.
                                        Die oberste Linie liegt am weitesten hinten, die untersten ganz oben auf allen anderen Linien.
                                        Es ergibt daher keinen Sinn eine gefüllte Fläche ganz oben auf zu legen die dann die dünnen Linien verdeckt
                                          andibr
                                          Wie geht das mit dem kopieren? Sehe da irgendwie keine Funktion.
                                          Dann bin ich aber mit der Fläche vom AT Nord ja schon mal ganz gut unterwegs.
