  4. [gelöst] ical Adapter, Owncloud Kalender und Widget
    5.6k
37 Beiträge 8 Kommentatoren 9.5k Aufrufe
  • wendy2702W Offline
    wendy2702W Offline
    So,
    es läuft.
    Bei Events gar nichts eingetragen und alles wird angezeigt.
    Funktioniert jetzt wie gewollt.
    Mirko
    • R Offline
      rascal
      ich hänge mich mal hier an. Ich habe heute den ical Adapter installiert und bin beeindruckt.. 3 meiner 4 Owncloud Kalender funktionieren super.. nur der 4. macht mich verrückt.
      Vielleicht sagt einem von euch das .log was:
      host-cubietruck	2016-01-21 20:49:20	error	instance system.adapter.ical.1 terminated with code 6 (uncaught exception)
      TypeError:	2016-01-21 20:49:20	error	at process._tickCallback (node.js:355:11)
      TypeError:	2016-01-21 20:49:20	error	at _stream_readable.js:908:16
      TypeError:	2016-01-21 20:49:20	error	at IncomingMessage.emit (events.js:129:20)
      TypeError:	2016-01-21 20:49:20	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:962:12)
      TypeError:	2016-01-21 20:49:20	error	at Request.emit (events.js:129:20)
      TypeError:	2016-01-21 20:49:20	error	at Request. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1035:10)
      TypeError:	2016-01-21 20:49:20	error	at Request.emit (events.js:110:17)
      TypeError:	2016-01-21 20:49:20	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:198:22)
      TypeError:	2016-01-21 20:49:20	error	at Request._callback (/opt/iobroker/node_modules/iobroker.ical/main.js:193:39)
      TypeError:	2016-01-21 20:49:20	error	Cannot read property 'setDate' of undefined
      uncaught	2016-01-21 20:49:20	error	exception: Cannot read property 'setDate' of undefined
      ical-1	2016-01-21 20:49:20	info	processing URL: Alexander https://192.168.1.10/index.php/apps/calendar/export.php?calid=3
      ical-1	2016-01-21 20:49:17	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
      host-cubietruck	2016-01-21 20:49:10	info	instance system.adapter.ical.1 started with pid 18095
      host-cubietruck	2016-01-21 20:49:10	info	instance scheduled system.adapter.ical.1 0,30 * * * *
      Danke für die Hilfe im Voraus
      Martin
        wendy2702W Offline
        ich hatte diese Einträge im Log:
        > exception: Cannot read property 'getHours' of undefined
        Das lag daran das nach dem Import des Ical in Owncloud Anfang und End Datum vertauscht waren.
        Vielleicht überprüfst du mal die Einträge von dem Kalender der nicht funktioniert ob alles stimmig ist und Sinn ergibt.
        • R Offline
          rascal
          danke für den Hinweis.. habe bei diesem einen Kalender alle Einträge vor Heute gelöscht und siehe da… es funkt
          ich wünsche ein schönes Wochenende
          • V Offline
            V Offline
            von Rothensteyn
            @wendy2702
            Hi bitte entschuldige aber ich würde gerne wissen wie du mit den widget Daten abrufst.
            Ich suche jetz schon eine ganze weile und das Handbuch ist grad nicht verfügbar.
            Was muss ich da im vis eintragen damit die daten abgeholt werden.
            Danke im voruas
            PS.
            Mit der PN Funktion wird man schon etwas ausgebremst wen man neu ist.
              wendy2702W Offline
              @von Rothensteyn:
              @wendy2702
              Danke im voruas
              PS.
              Mit der PN Funktion wird man schon etwas ausgebremst wen man neu ist. `
              wenn du einen Ical Adapter installiert und konfiguriert hast kannst du es z.B. mit diesem Widget machen:
              [{"tpl":"tplValueStringRaw","data":{"oid":"ical.1.data.html","visibility-cond":"==","visibility-val":1,"test_html":""},"style":{"left":"341px","top":"45px","width":"318px","height":"187px"},"widgetSet":"basic"}]
              ical.1.data.html –> muss natürlich deinem ical.X.data.html entsprechen
              • R Offline
                rascal
                Hey,
                ich hab's in vis so gemacht:
                widget: basic - String (unescaped))
                im Object ID: steht der Datenpunkt vom ical Adapter drin: ical.0.data.html
                sieht dann so aus: (wobei die Widgets teilweise verschoben sind im edit modus :(
                  wendy2702W Offline
                  Frohes neues Jahr zusammen,
                  ich muss dieses Thema mal wieder aktivieren. Habe heute ein Update von Owncloud 8.x auf 9.0.6 gemacht.
                  Seitdem funktioniert das Einlesen der Kalender mit den iCal Adaptern nicht mehr :-(
                  Zum Einlesen des Geburtstagskalender hatte ich bisher immer diesen Link aus Owncloud verwendet:
                  https://192.168.178.18:8443/index.php/apps/calendar/export.php?calid=21
                  Das ist der Download link für den Kalender gewesen und damit scheint es nicht mehr zu funktionieren.
                  Wenn ich in der neuen Version von Owncloud jetzt auf "Herunterladen" des Kalenders klicke wird dieser direkt geladen und ich weiß nicht wie ich an den aktuellen Download link kommen kann oder muss in iCal jetzt etwas anderes eingetragen werden?
                  Danke für eure Hilfe
                  Mirko
                    wendy2702W Offline
                    konnte mir selber helfen :-)
                    Hier mal meine Lösung falls wer dasselbe Problem bekommt.
                    Ich habe mich mit Google Chrome in meinen Owncloud Kalender eingeloggt. Im Beispiel Bild der Abfall Kalender.
                    Dann mit F12 die Console gestartet und dann in der Console auf 1. Timeline gewechselt.
                    Dann eine Aufzeichnung 2. gestartet, 3. Herunterladen des Kalenders gestartet, Aufzeichnung gestoppt, 4. Event gesucht "Receive Response", wenn man den dann anklickt erscheint unten 5. ein Teil des download link.
                    Der Komplette Link sieht dann bei mir z.B. so aus:
                    https://192.168.178.18:8443/remote.php/dav/calendars/Abfall/abfall?export
                    Damit funktioniert die Abfrage wieder, ich weiß aber nicht ob das jetzt der "richtige" weg ist oder ob es noch eine andere Möglichkeit gibt.
                    Schönen Sonntag
                    Mirko
                      DiLa
                      ich habe ebenfalls eine Owncloud in der Version 9.1 und bekomme es einfach nicht hin, das der ioBroker den Kalender ausliest.
                      Den Link habe ich wie oben beschrieben ausgelesen, dieser lautet bei mir wie folgt:
                      https://192.168.1.10/owncloud/remote.ph … ics?export
                      Den Namen habe ich "Dirk" genannt und Zertifikat steht auf "ignore".
                      Benutzername und Passwort sind ebenfalls hinterlegt.
                      Wenn ich den Link in eine Browser URL kopiere, fragt er nach dem Benutzer und Passwort, dann lädt er die Datei sauber runter.
                      Der Export Link funktioniert also.
                      Folgende Fehler bekomme ich immer im Log. Leider kann ich damit so gar nichts anfangen.
                      Kann mir da bitte jemand weiterhelfen?
                      ical.0 2017-03-08 20:45:01.006 info terminating
                      ical.0 2017-03-08 20:45:00.485 error at emitOne (events.js:77:13)
                      ical.0 2017-03-08 20:45:00.485 error at Request. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1126:10)
                      ical.0 2017-03-08 20:45:00.485 error at Request.emit (events.js:172:7)
                      ical.0 2017-03-08 20:45:00.485 error at emitTwo (events.js:87:13)
                      ical.0 2017-03-08 20:45:00.485 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:187:22)
                      ical.0 2017-03-08 20:45:00.485 error at Request._callback (/opt/iobroker/node_modules/iobroker.ical/main.js:170:23)
                      ical.0 2017-03-08 20:45:00.485 error at /opt/iobroker/node_modules/iobroker.ical/main.js:186:25
                      ical.0 2017-03-08 20:45:00.485 error at Object.parseICS (/opt/iobroker/node_modules/iobroker.ical/node_modules/node-ical/ical.js:408:20)
                      ical.0 2017-03-08 20:45:00.485 error at Object.handleObject (/opt/iobroker/node_modules/iobroker.ical/node_modules/node-ical/ical.js:369:41)
                      ical.0 2017-03-08 20:45:00.485 error at Object.EXDATE (/opt/iobroker/node_modules/iobroker.ical/node_modules/node-ical/ical.js:192:35)
                      ical.0 2017-03-08 20:45:00.485 error TypeError: exdate[name].toISOString is not a function
                      ical.0 2017-03-08 20:45:00.468 error uncaught exception: exdate[name].toISOString is not a function
                      ical.0 2017-03-08 20:44:51.412 info starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ical, node: v4.4.7
                      Vielen Dank,
                      Gruß,
                      Dirk
                        wendy2702W Offline
                        @DiLa:
                        Vielen Dank,
                        Gruß,
                        Dirk `
                        hast du Kalender Einträge bei denen Eventuell der Start hinter dem Ende liegt. Ich weiß, klingt komisch hatte ich aber auch schon.
                        Desweiteren durften bei OC keine Bilder oder Emoticons in den Kalender Eintragen drin sein damit der Richtig mit dem Ical Adapter funktioniert.
                        Bist du sicher das es der Richtige Link ist? ich wundere mich das er am Ende ein Datum und eine Zeit enthält.
                        Meiner sieht da ein wenig anders aus.
                        Mirko
                          DiLa
                          Hallo Mirko,
                          vielen Dank für deine Antwort.
                          Das ich im OC Kalender keine Icons haben darf war mir neu.
                          Ich habe mal einen neuen Kalender angelegt, mit nur einem Eintrag. Dieser hat sofort funktioniert. :D :(
                          Da ich in meinem Kalender mega viele Termine drin habe, bedeutet das jetzt Fleißarbeit und "falsche" Einträge suchen.
                          Ich benutze ein Android Smartphone und habe natürlich auch alle schicken Funktionen genutzt, was sich dann wohl jetzt rächt.
                          OK, also auf zur Suche.
                          Vielen Dank für deine Hilfe.
                          Gruß,
                          Dirk
                            wendy2702W Offline
                            Musst mal Google bemühen. Es gibt, wenn ich mich richtig erinnere, eine relativ einfache Möglichkeit die Fehlerhaften Einträge in der Datenbank zu finden und zu löschen.
                            Wenn ich den Rechner wieder anhabe kann ich auch mal suchen.
                              DiLa
                              ich bin leider erst heute wieder dazu gekommen mich dem Problem anzunehmen.
                              Per Google habe ich immer folgenden Befehl gefunden um in der MySQL Datenbank die fehlerhaften Einträge zu finden.
                              SELECT * FROM oc_clndr_objects WHERE calendardata NOT LIKE '%END:VCALENDAR%';
                              Leider heisst meine Tabelle schonmal anders, nämlich oc_calendarobjects.
                              Der Umgebaute Befehl: SELECT * FROM oc_calendarobjects WHERE calendardata NOT LIKE '%END:VCALENDAR%'
                              liefert mir folgendes Ergebnis:
                              MySQL lieferte ein leeres Resultat zurück (d.h. null Datensätze). (Die Abfrage dauerte 0.0099 Sekunden.)
                              Heisst das jetzt, ich habe kein Problem innerhalb der Datensätze und das Problem liegt doch woanders?
                              Oder suche ich mal wieder einfach nur falsch?
                              Wäre schön, wenn man mir nochmal helfen könnte.
                              Vielen Dank schonmal,
                              Viele Grüße,
                              Dirk
                              • schuppermanS Offline
                                schupperman
                                habe genau das gleiche Problem. Gibt es dafür inzwischen eine Lösung. Meine SQL Abfrage liefert auch keine Ergebnisse.
                                Danke und LG
                                Thomas
                                  wendy2702W Offline
                                  Welches Problem genau hast du denn?
                                  Ich nutze kein OC mehr sondern bin auf Nextcloud umgestiegen was aber Grundsätzlich das selbe ist.
                                  Gibt es irgendwelche Logfiles (iobroker, OC) die einen Fehler zeigen?
                                    schupperman
                                    Hallo, bin auch bei Nextcloud und bekomme im iobroker Log die folgenden Meldungen:
                                    ! broker 2017-12-16 20:14:18.042 info instance system.adapter.ical.0 terminated with code 0 (OK)
                                    ! ical.0 2017-12-16 20:14:17.949 info terminating
                                    ! ical.0 2017-12-16 20:14:17.439 error at emitOne (events.js:96:13)
                                    ! ical.0 2017-12-16 20:14:17.439 error at Request. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1163:10)
                                    ! ical.0 2017-12-16 20:14:17.439 error at Request.emit (events.js:191:7)
                                    ! ical.0 2017-12-16 20:14:17.439 error at emitTwo (events.js:106:13)
                                    ! ical.0 2017-12-16 20:14:17.439 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:186:22)
                                    ! ical.0 2017-12-16 20:14:17.439 error at Request._callback (/opt/iobroker/node_modules/iobroker.ical/main.js:170:23)
                                    ! ical.0 2017-12-16 20:14:17.439 error at /opt/iobroker/node_modules/iobroker.ical/main.js:186:25
                                    ! ical.0 2017-12-16 20:14:17.439 error at Object.parseICS (/opt/iobroker/node_modules/iobroker.ical/node_modules/node-ical/ical.js:408:20)
                                    ! ical.0 2017-12-16 20:14:17.439 error at Object.handleObject (/opt/iobroker/node_modules/iobroker.ical/node_modules/node-ical/ical.js:369:41)
                                    ! ical.0 2017-12-16 20:14:17.439 error at Object.EXDATE (/opt/iobroker/node_modules/iobroker.ical/node_modules/node-ical/ical.js:192:35)
                                    ! ical.0 2017-12-16 20:14:17.439 error TypeError: exdate[name].toISOString is not a function
                                    ! ical.0 2017-12-16 20:14:17.437 error uncaught exception: exdate[name].toISOString is not a function
                                    Habe, die Emoticions aus Nextcloud gelöscht und bin im Moment ziemlich ratlos.
                                    Vielen Dank
                                      wendy2702W Offline
                                      Hast du mal zum testen einen neuen Kalender angelegt und manuell einen Termin eingetragen?
                                      So kann man erstmal testen ob es grundsätzlich funktioniert.
                                      Ich kann leider, wegen neuem Rechner, meine Aufzeichnung von damals nicht finden.
                                      Sicher das keiner der Termine falsch ist was start und Endzeit betrifft?
                                      Mal ne SQL Datenbank analyze gemacht? Mal manuell in MySQL eingeloggt und geschaut wie die Datenbank aussieht?
                                      EDIT: Habe den Shortcut gefunden der mir damals etwas weitergeholfen hat, aber das hast du ja schon gemacht wenn ich das richtig gelesen habe, oder?
                                      https://got-tty.org/owncloud-kalendersy … rch-emojis
                                        schupperman
                                        Das mit dem neuen Kalender klappt.
                                        Das mit der Start und Endzeit zu checken ist schwierig, da viele viele Termine.
                                        Ja ich war in MySql und hab die Abfrage gemacht - O Datensätze.
                                        Danke und LG Thomas
                                          wendy2702W Offline
                                          Wie sind die Termine in NC gekommen? Manuell, Smartphone sync, etc?
                                          Ich würde mal ein backup des Kalenders machen, kannst ja einfach alle Einträge exportieren, und dann die Datenbank check machen. Also nicht nur das Kommando welches die Kalender Einträge prüft.
                                          Mirko
