  4. Parser Adapter
    6.5k
Parser Adapter
49 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
  • Q Qlink
    @homoran said in Parser Adapter:
    @qlink wo ist der richtige Quelltext als code?
    Wenn ich Rechtsklick und Seitenquelltext anzeigen klicke kommt Folgendes:
    # HELP hwi_bus_clock_mhz Bus Clock MHz - CPU [#0]: Intel Xeon E3-1225 v3
    hwi_bus_clock_mhz{unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Bus Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 97.61008134825474
    # HELP hwi_core_clock_mhz Core Clock MHz - CPU [#0]: Intel Xeon E3-1225 v3
    hwi_core_clock_mhz{coreno="0",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 0 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 780.8806507860379
    hwi_core_clock_mhz{coreno="1",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 1 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 780.8806507860379
    hwi_core_clock_mhz{coreno="2",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 2 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 780.8806507860379
    hwi_core_clock_mhz{coreno="3",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 3 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 780.8806507860379
    # HELP hwi_core_ratio_x Core Ratio x - CPU [#0]: Intel Xeon E3-1225 v3
    hwi_core_ratio_x{coreno="0",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 0 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 8
    hwi_core_ratio_x{coreno="1",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 1 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 8
    hwi_core_ratio_x{coreno="2",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 2 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 8
    hwi_core_ratio_x{coreno="3",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 3 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 8
    # HELP hwi_core_residency Core Residency % - CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency
    hwi_core_residency{coreno="0",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 0 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 88.20606221645437
    hwi_core_residency{coreno="1",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 1 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 88.30354808811423
    hwi_core_residency{coreno="2",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 2 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 88.37638068112336
    hwi_core_residency{coreno="3",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 3 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 92.46319157455508
    # HELP hwi_core_vid_v Core VID V - CPU [#0]: Intel Xeon E3-1225 v3
    hwi_core_vid_v{coreno="0",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 0 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.7230224609375
    hwi_core_vid_v{coreno="1",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 1 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.71875
    hwi_core_vid_v{coreno="2",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 2 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.7236328125
    hwi_core_vid_v{coreno="3",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 3 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.7252197265625
    # HELP hwi_drive_failure_yesno Drive Failure Yes/No - (multiple sources)
    hwi_drive_failure_yesno{unit="Yes/No",sensor_type="SENSOR_TYPE_OTHER",sensor="Drive Failure",source="S.M.A.R.T.: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0
    hwi_drive_failure_yesno{unit="Yes/No",sensor_type="SENSOR_TYPE_OTHER",sensor="Drive Failure",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0
    hwi_drive_failure_yesno{unit="Yes/No",sensor_type="SENSOR_TYPE_OTHER",sensor="Drive Failure",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0
    # HELP hwi_drive_host_reads_gb Drive Host Reads GB - (multiple sources)
    hwi_drive_host_reads_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Reads",source="S.M.A.R.T.: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 13388
    hwi_drive_host_reads_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Reads",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 554278
    hwi_drive_host_reads_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Reads",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 4873
    # HELP hwi_drive_host_writes_gb Drive Host Writes GB - (multiple sources)
    hwi_drive_host_writes_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Writes",source="S.M.A.R.T.: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 9971
    hwi_drive_host_writes_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Writes",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 103590
    hwi_drive_host_writes_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Writes",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 1822
    # HELP hwi_drive_read_activity Drive Read Activity % - (multiple sources)
    hwi_drive_read_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Read Activity",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.231
    hwi_drive_read_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Read Activity",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0
    hwi_drive_read_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Read Activity",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0
    # HELP hwi_drive_read_rate_mbs Drive Read Rate MB/s - (multiple sources)
    hwi_drive_read_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Read Rate",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.078
    hwi_drive_read_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Read Rate",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0
    hwi_drive_read_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Read Rate",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0
    # HELP hwi_drive_remaining_life Drive Remaining Life % - (multiple sources)
    hwi_drive_remaining_life{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Drive Remaining Life",source="S.M.A.R.T.: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 97
    hwi_drive_remaining_life{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Drive Remaining Life",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 59
    hwi_drive_remaining_life{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Drive Remaining Life",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 99
    # HELP hwi_drive_temperature_c Drive Temperature °C - (multiple sources)
    hwi_drive_temperature_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="Drive Airflow Temperature",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 28
    hwi_drive_temperature_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="Drive Airflow Temperature",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 25
    # HELP hwi_drive_total_activity Drive Total Activity % - (multiple sources)
    hwi_drive_total_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Total Activity",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.253
    hwi_drive_total_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Total Activity",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0.102
    hwi_drive_total_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Total Activity",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0.101
    # HELP hwi_drive_warning_yesno Drive Warning Yes/No - (multiple sources)
    hwi_drive_warning_yesno{unit="Yes/No",sensor_type="SENSOR_TYPE_OTHER",sensor="Drive Warning",source="S.M.A.R.T.: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0
    hwi_drive_warning_yesno{unit="Yes/No",sensor_type="SENSOR_TYPE_OTHER",sensor="Drive Warning",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0
    hwi_drive_warning_yesno{unit="Yes/No",sensor_type="SENSOR_TYPE_OTHER",sensor="Drive Warning",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0
    # HELP hwi_drive_write_activity Drive Write Activity % - (multiple sources)
    hwi_drive_write_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Write Activity",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.022
    hwi_drive_write_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Write Activity",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0.102
    hwi_drive_write_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Write Activity",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0.101
    # HELP hwi_drive_write_rate_mbs Drive Write Rate MB/s - (multiple sources)
    hwi_drive_write_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Write Rate",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.009
    hwi_drive_write_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Write Rate",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0.031
    hwi_drive_write_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Write Rate",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0.031
    # HELP hwi_effective_clock_mhz Effective Clock MHz - CPU [#0]: Intel Xeon E3-1225 v3
    hwi_effective_clock_mhz{aggregationtype="Average",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Average Effective Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 113.21687342191372
    # HELP hwi_gpu_clock_mhz GPU Clock MHz - CPU [#0]: Intel Xeon E3-1225 v3: Enhanced
    hwi_gpu_clock_mhz{unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="GPU Clock",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 585.6604880895284
    # HELP hwi_gpu_d3d_memory_dedicated_mb GPU D3D Memory Dedicated MB - CPU [#0]: Intel Xeon E3-1225 v3: Enhanced
    hwi_gpu_d3d_memory_dedicated_mb{unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="GPU D3D Memory Dedicated",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 6
    # HELP hwi_gpu_d3d_memory_dynamic_mb GPU D3D Memory Dynamic MB - CPU [#0]: Intel Xeon E3-1225 v3: Enhanced
    hwi_gpu_d3d_memory_dynamic_mb{unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="GPU D3D Memory Dynamic",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 163.37109375
    # HELP hwi_gpu_d3d_usage GPU D3D Usage % - CPU [#0]: Intel Xeon E3-1225 v3: Enhanced
    hwi_gpu_d3d_usage{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="GPU D3D Usage",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 4.723036573628488
    # HELP hwi_mb_cpu_c MB CPU °C - (multiple sources)
    hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU (PECI)",source="ASRock C226 WS (Nuvoton NCT6776F)",host="ASROCK"} 31
    hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU GT Cores (Graphics)",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 27
    hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU IA Cores",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 29
    hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU Package",source="CPU [#0]: Intel Xeon E3-1225 v3: DTS",host="ASROCK"} 31
    hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU Package",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 29
    hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU",source="ASRock C226 WS (Nuvoton NCT6776F)",host="ASROCK"} 37.5
    # HELP hwi_mb_cpu_rpm MB CPU RPM - ASRock C226 WS (Nuvoton NCT6776F)
    hwi_mb_cpu_rpm{unit="RPM",sensor_type="SENSOR_TYPE_NONE",sensor="CPUFANIN0",source="ASRock C226 WS (Nuvoton NCT6776F)",host="ASROCK"} 1124
    # HELP hwi_mb_cpu_w MB CPU W - CPU [#0]: Intel Xeon E3-1225 v3: Enhanced
    hwi_mb_cpu_w{unit="W",sensor_type="SENSOR_TYPE_POWER",sensor="CPU Package Power",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 4.102112850552842
    # HELP hwi_mb_motherboard_c MB Motherboard °C - ASRock C226 WS (Nuvoton NCT6776F)
    hwi_mb_motherboard_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="Motherboard",source="ASRock C226 WS (Nuvoton NCT6776F)",host="ASROCK"} 28
    # HELP hwi_memory_available_mb Memory Available MB - System
    hwi_memory_available_mb{category="Physical",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Physical Memory Available",source="System",host="ASROCK"} 13345
    hwi_memory_available_mb{category="Virtual",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Virtual Memory Available",source="System",host="ASROCK"} 19853
    # HELP hwi_memory_clock_mhz Memory Clock MHz - Memory Timings
    hwi_memory_clock_mhz{unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Memory Clock",source="Memory Timings",host="ASROCK"} 780.8806507860379
    # HELP hwi_memory_clock_ratio_x Memory Clock Ratio x - Memory Timings
    hwi_memory_clock_ratio_x{unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Memory Clock Ratio",source="Memory Timings",host="ASROCK"} 8
    # HELP hwi_memory_command_rate_t Memory Command Rate T - Memory Timings
    hwi_memory_command_rate_t{unit="T",sensor_type="SENSOR_TYPE_OTHER",sensor="Command Rate",source="Memory Timings",host="ASROCK"} 2
    # HELP hwi_memory_commited_mb Memory Commited MB - System
    hwi_memory_commited_mb{category="Virtual",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Virtual Memory Commited",source="System",host="ASROCK"} 17484
    # HELP hwi_memory_load Memory Load % - System
    hwi_memory_load{category="Physical",unit="%",sensor_type="SENSOR_TYPE_OTHER",sensor="Physical Memory Load",source="System",host="ASROCK"} 58.9
    hwi_memory_load{category="Virtual",unit="%",sensor_type="SENSOR_TYPE_OTHER",sensor="Virtual Memory Load",source="System",host="ASROCK"} 46.8
    # HELP hwi_memory_page_file_usage Memory Page File Usage % - System
    hwi_memory_page_file_usage{unit="%",sensor_type="SENSOR_TYPE_OTHER",sensor="Page File Usage",source="System",host="ASROCK"} 3.5301610043174345
    # HELP hwi_memory_tcas_t Memory Tcas T - Memory Timings
    hwi_memory_tcas_t{unit="T",sensor_type="SENSOR_TYPE_OTHER",sensor="Tcas",source="Memory Timings",host="ASROCK"} 11
    # HELP hwi_memory_tras_t Memory Tras T - Memory Timings
    hwi_memory_tras_t{unit="T",sensor_type="SENSOR_TYPE_OTHER",sensor="Tras",source="Memory Timings",host="ASROCK"} 28
    # HELP hwi_memory_trcd_t Memory Trcd T - Memory Timings
    hwi_memory_trcd_t{unit="T",sensor_type="SENSOR_TYPE_OTHER",sensor="Trcd",source="Memory Timings",host="ASROCK"} 11
    # HELP hwi_memory_trfc_t Memory Trfc T - Memory Timings
    hwi_memory_trfc_t{unit="T",sensor_type="SENSOR_TYPE_OTHER",sensor="Trfc",source="Memory Timings",host="ASROCK"} 208
    # HELP hwi_memory_trp_t Memory Trp T - Memory Timings
    hwi_memory_trp_t{unit="T",sensor_type="SENSOR_TYPE_OTHER",sensor="Trp",source="Memory Timings",host="ASROCK"} 11
    # HELP hwi_memory_used_mb Memory Used MB - System
    hwi_memory_used_mb{category="Physical",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Physical Memory Used",source="System",host="ASROCK"} 19127
    # HELP hwi_network_dl_rate_kbs Network DL rate KB/s - Network: Intel I210AT Copper (Springville) Network Adapter
    hwi_network_dl_rate_kbs{unit="KB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Current DL rate",source="Network: Intel I210AT Copper (Springville) Network Adapter",host="ASROCK"} 0
    hwi_network_dl_rate_kbs{unit="KB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Current DL rate",source="Network: Intel I210AT Copper (Springville) Network Adapter",host="ASROCK"} 5.986752717391304
    # HELP hwi_network_up_rate_kbs Network UP rate KB/s - Network: Intel I210AT Copper (Springville) Network Adapter
    hwi_network_up_rate_kbs{unit="KB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Current UP rate",source="Network: Intel I210AT Copper (Springville) Network Adapter",host="ASROCK"} 0
    hwi_network_up_rate_kbs{unit="KB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Current UP rate",source="Network: Intel I210AT Copper (Springville) Network Adapter",host="ASROCK"} 15.143017648112755
    # HELP hwi_usage Usage % - CPU [#0]: Intel Xeon E3-1225 v3
    hwi_usage{aggregationtype="Max",category="CPU/Thread",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Max CPU/Thread Usage",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 10.5
    hwi_usage{aggregationtype="Total",category="CPU",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Total CPU Usage",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 6.175
    @qlink sagte in Parser Adapter:
    Spoiler
    und welchen Wert willst du haben?
    EDIT:
    3 Platten von NUM 0-2 \"Drive Warning\"[^\}]+[^\d]+(\d+)
    Typ number! nicht Zahl mit Komma
    Q 1 Antwort Letzte Antwort
      Spoiler
      EDIT:
      Q Offline
      Q Offline
      Qlink
      "Drive Warning"[^}]+[^\d]+(\d+)
      Ich will den Wert im grünen Kreis, bekomme aber den Wert im roten Kreis:
      Also die Zahl am Ende dieser Zeile:
      ob ich bei Typ number(,) oder number(.) im Parser Adapter auswähle macht scheinbar keinen Unterschied...
      • Q Qlink
        @qlink hast du mein Regex versucht?
        Wenn es damit auch nicht klappt musst du die Regel löschen! und mit Number neu anlegen.
        Eine Änderung des Typs kann zu einem Hänger führen
        • Q Qlink
          @qlink Wenn das hier nicht hilft: \"Drive Warning\"[^\}]+[^\d]+(\d+)$ kopier mal bitte den Quelltext aus dem Parser Editor hier rein.
          ggf. ist der anders formatiert als im Browser
            Q Offline
            Q Offline
            Qlink
            Ja, der Screenshot aus meinem letzten Post ist mit deinem Regex.
            Hätte jetzt auch nochmal probiert die komplette Regel zu löschen und neu anzulegen.
            Bekomme immer dasselbe Ergebnis bzw. den falschen Wert wie oben gepostet zurück ... 😞
              Q Offline
              Q Offline
              Qlink
              mit diesem Regex nimmt er die Zahl zwei Stellen vorher:
              seltsamerweise zeigt er aber bei Ergebnis nichts an....
              Hier der Code direkt aus dem Parser Editor:
              hwi_core_clock_mhz{coreno="0",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 0 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 3123.5226031441516
              hwi_core_clock_mhz{coreno="1",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 1 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 3123.5226031441516
              hwi_core_clock_mhz{coreno="2",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 2 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 3123.5226031441516
              hwi_core_clock_mhz{coreno="3",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Core 3 Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 3123.5226031441516
              hwi_core_ratio_x{coreno="0",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 0 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 32
              hwi_core_ratio_x{coreno="1",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 1 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 32
              hwi_core_ratio_x{coreno="2",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 2 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 32
              hwi_core_ratio_x{coreno="3",unit="x",sensor_type="SENSOR_TYPE_OTHER",sensor="Core 3 Ratio",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 32
              hwi_core_residency{coreno="0",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 0 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 80.15015365152505
              hwi_core_residency{coreno="1",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 1 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 65.78857951491227
              hwi_core_residency{coreno="2",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 2 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 74.38991256541709
              hwi_core_residency{coreno="3",category="C3",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Core 3 C3 Residency",source="CPU [#0]: Intel Xeon E3-1225 v3: C-State Residency",host="ASROCK"} 71.01332961211648
              hwi_core_vid_v{coreno="0",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 0 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.9827880859375
              hwi_core_vid_v{coreno="1",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 1 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.9827880859375
              hwi_core_vid_v{coreno="2",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 2 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.9827880859375
              hwi_core_vid_v{coreno="3",unit="V",sensor_type="SENSOR_TYPE_VOLT",sensor="Core 3 VID",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 0.9825439453125
              hwi_drive_host_reads_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Reads",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 554298
              hwi_drive_host_reads_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Reads",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 4893
              hwi_drive_host_writes_gb{aggregationtype="Total",unit="GB",sensor_type="SENSOR_TYPE_OTHER",sensor="Total Host Writes",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 1823
              hwi_drive_read_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Read Activity",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 6.915
              hwi_drive_read_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Read Activity",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 2.71
              hwi_drive_read_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Read Rate",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 12.036
              hwi_drive_read_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Read Rate",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 4.533
              hwi_drive_temperature_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="Drive Airflow Temperature",source="S.M.A.R.T.: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 34
              hwi_drive_temperature_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="Drive Airflow Temperature",source="S.M.A.R.T.: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 33
              hwi_drive_total_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Total Activity",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.004
              hwi_drive_total_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Total Activity",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 7.077
              hwi_drive_total_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Total Activity",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 2.861
              hwi_drive_write_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Write Activity",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.004
              hwi_drive_write_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Write Activity",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0.162
              hwi_drive_write_activity{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Write Activity",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0.15
              hwi_drive_write_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Write Rate",source="Drive: INTEL SSDSA2CW120G3 (CVPR344400F1120LGN)",host="ASROCK"} 0.001
              hwi_drive_write_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Write Rate",source="Drive: Samsung SSD 860 EVO 500GB (S3Z2NB0M460334M)",host="ASROCK"} 0.2
              hwi_drive_write_rate_mbs{unit="MB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Write Rate",source="Drive: Samsung SSD 860 PRO 512GB (S42YNX0N507289T)",host="ASROCK"} 0.2
              hwi_effective_clock_mhz{aggregationtype="Average",unit="MHz",sensor_type="SENSOR_TYPE_CLOCK",sensor="Average Effective Clock",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 884.3905456148119
              hwi_gpu_d3d_memory_dynamic_mb{unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="GPU D3D Memory Dynamic",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 252.05078125
              hwi_gpu_d3d_usage{unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="GPU D3D Usage",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 0.15913690476190476
              hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU (PECI)",source="ASRock C226 WS (Nuvoton NCT6776F)",host="ASROCK"} 35
              hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU GT Cores (Graphics)",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 30
              hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU IA Cores",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 35
              hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU Package",source="CPU [#0]: Intel Xeon E3-1225 v3: DTS",host="ASROCK"} 34
              hwi_mb_cpu_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="CPU Package",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 35
              hwi_mb_cpu_w{unit="W",sensor_type="SENSOR_TYPE_POWER",sensor="CPU Package Power",source="CPU [#0]: Intel Xeon E3-1225 v3: Enhanced",host="ASROCK"} 13.322686269124457
              hwi_mb_motherboard_c{unit="°C",sensor_type="SENSOR_TYPE_TEMP",sensor="Motherboard",source="ASRock C226 WS (Nuvoton NCT6776F)",host="ASROCK"} 29
              hwi_memory_available_mb{category="Physical",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Physical Memory Available",source="System",host="ASROCK"} 12274
              hwi_memory_available_mb{category="Virtual",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Virtual Memory Available",source="System",host="ASROCK"} 18789
              hwi_memory_commited_mb{category="Virtual",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Virtual Memory Commited",source="System",host="ASROCK"} 18547
              hwi_memory_load{category="Physical",unit="%",sensor_type="SENSOR_TYPE_OTHER",sensor="Physical Memory Load",source="System",host="ASROCK"} 62.2
              hwi_memory_load{category="Virtual",unit="%",sensor_type="SENSOR_TYPE_OTHER",sensor="Virtual Memory Load",source="System",host="ASROCK"} 49.6
              hwi_memory_page_file_usage{unit="%",sensor_type="SENSOR_TYPE_OTHER",sensor="Page File Usage",source="System",host="ASROCK"} 3.4275255705180916
              hwi_memory_used_mb{category="Physical",unit="MB",sensor_type="SENSOR_TYPE_OTHER",sensor="Physical Memory Used",source="System",host="ASROCK"} 20198
              hwi_network_dl_rate_kbs{unit="KB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Current DL rate",source="Network: Intel I210AT Copper (Springville) Network Adapter",host="ASROCK"} 1.522758995037221
              hwi_network_up_rate_kbs{unit="KB/s",sensor_type="SENSOR_TYPE_OTHER",sensor="Current UP rate",source="Network: Intel I210AT Copper (Springville) Network Adapter",host="ASROCK"} 0.11486119727047146
              hwi_usage{aggregationtype="Max",K"} 2.1
              category="CPU/Thread",unit="%",sensor_type="SENSOR_TYPE_USAGE",sensor="Max CPU/Thread Usage",source="CPU [#0]: Intel Xeon E3-1225 v3",host="ASROCK"} 3.1
              [/s]
              HomoranH 3 Antworten Letzte Antwort
              • Q Qlink
                so was kann man auf dem Handy schlecht entziffern, der zitierte sieht anders aus
                • Q Qlink
                  [/s]
                  und was steht im Datenpunkt?
                  Das sehe ich mir mal an
                  • Q Qlink
                    [/s]
                    @qlink klappt bei mir einwandfrei.
                    Habe auch mal mit anderen Parametern probiert, bei denen ich Nachkommastellen brauche: \"Drive Warning\"[^\}]+[^\d]+([\d\.]+)
                    • Q Qlink
                      [/s]
                      @qlink Habe ein wenig weiter gespielt:
                      nehme ich die Ergebnisgruppe raus findet der Parser alles nach Vorschrift:
                      füge ich dann die Gruppe hinzu, kommt auch das richtige Ergebnis
                      Klicke ich dann auf den Start-Button wird die falsche Stelle markiert, es bleibt das richtige Ergebnis:
                      Das sieht man, wenn man einen anderen Parameter wählt:
                      und nach klick auf Play
                        Q Offline
                        Q Offline
                        Qlink
                        Vielen Dank für deine Tests.
                        Verstehe ich es richtig, dass der Regex somit stimmt und eigentlich die Ziffer 0 am Ende der Zeile als Ergebnis kommt, der Parser Adapter aber auf Grund eines Bugs o.ä. die falsche 0 markiert ?
                        kurz: der Regex stimmt, der Parser Adapter zeigts nur falsch an ?
                          so sieht es für mich aus
