  4. Fehler beim installieren von Statistics auf dem Rpi
    6.7k
3 Beiträge 2 Kommentatoren 312 Aufrufe 1 Beobachtet
  • C Offline
    Cino
    Kann mir einer bei diesem Fehler helfen? Auf dem Rpi4
    $ ./iobroker add statistics  --host iobroker
    NPM version: 6.14.13
    npm install iobroker.statistics@1.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
    ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.2/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.2/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^
    In file included from /home/iobroker/.cache/node-gyp/12.22.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.22.2/include/node/node.h:67,
                     from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
    In file included from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.22.2/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.10.17-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.22.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    host.iobroker install adapter statistics
    upload [5] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/words.js words.js application/javascript
    upload [4] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/statistics.png statistics.png image/png
    upload [3] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/index_m.html index_m.html text/html
    upload [2] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/index.html index.html text/html
    upload [1] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/custom_m.html custom_m.html text/html
    upload [0] statistics.admin /opt/iobroker/node_modules/iobroker.statistics/admin/custom.html custom.html text/html
    host.iobroker object system.adapter.statistics created/updated
    host.iobroker object _design/custom created/updated
    host.iobroker create instance statistics
    host.iobroker object system.adapter.statistics.0.logLevel created
    host.iobroker object system.adapter.statistics.0.sigKill created
    host.iobroker object system.adapter.statistics.0.eventLoopLag created
    host.iobroker object system.adapter.statistics.0.outputCount created
    host.iobroker object system.adapter.statistics.0.inputCount created
    host.iobroker object system.adapter.statistics.0.uptime created
    host.iobroker object system.adapter.statistics.0.memRss created
    host.iobroker object system.adapter.statistics.0.memHeapTotal created
    host.iobroker object system.adapter.statistics.0.memHeapUsed created
    host.iobroker object system.adapter.statistics.0.cputime created
    host.iobroker object system.adapter.statistics.0.cpu created
    host.iobroker object system.adapter.statistics.0.compactMode created
    host.iobroker object system.adapter.statistics.0.connected created
    host.iobroker object system.adapter.statistics.0.alive created
    host.iobroker object system.adapter.statistics.0 created
    process exited with code 0
    IOB@RPI4
    Shelly, Zigbee, ebus
    • C Cino
      @cino sagte in Fehler beim installieren von Statistics auf dem Rpi:
      bei diesem Fehler
      welcher Fehler?
      also alles in Ordnung
      C 1 Antwort Letzte Antwort
        bei diesem Fehler
        welcher Fehler?
        Cino
        schrieb am zuletzt editiert von Cino
        @homoran wegen Zeile 16
        Kann ich den Betriebsstundenzähler überhaupt nutzen bei true und false?
        IOB@RPI4
