  4. Netatmo?
    6.6k
Netatmo?
140 Beiträge 52 Kommentatoren 46.9k Aufrufe 12 Beobachtet
    Smokey
    Leider konnte mir vor einiger Zeit schon niemand helfen… auch mit der neuesten Version des adapters habe ich noch folgende Fehlermeldung im Log. Wirklich niemand, der auch nur einen kleinen Hinweis hat?
    TypeError: 2016-08-31 20:10:18.800 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
    TypeError: 2016-08-31 20:10:18.800 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError: 2016-08-31 20:10:18.800 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
    TypeError: 2016-08-31 20:10:18.800 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
    TypeError: 2016-08-31 20:10:18.800 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:392:29)
    TypeError: 2016-08-31 20:10:18.800 error at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2998:14)
    TypeError: 2016-08-31 20:10:18.800 error at Adapter.emit (events.js:104:17)
    TypeError: 2016-08-31 20:10:18.800 error at Adapter. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:69:15)
    TypeError: 2016-08-31 20:10:18.800 error at new netatmo (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:15:10)
    TypeError: 2016-08-31 20:10:18.800 error at netatmo.authenticate (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:125:12)
    TypeError: 2016-08-31 20:10:18.800 error undefined is not a function
    uncaught 2016-08-31 20:10:18.772 error exception: undefined is not a function
    netatmo-0 2016-08-31 20:10:18.718 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.netatmo
    host-raspberrypi 2016-08-31 20:10:14.286 info instance system.adapter.netatmo.0 started with pid 14581
    host-raspberrypi 2016-08-31 20:10:08.311 info Restart adapter system.adapter.netatmo.0 because enabled
      steinwedel
      bei mir läuft der netatmo-Adapter. Das ist natürlich kein Trost für Dich, aber damit weißt Du, dass der Adapter grundsätzlich funktioniert.
      Ich würde den Adapter mal ganz deinstallieren (also nicht nur Instanzen) und dann direkt von Github neu installieren. Mache dies am Besten von der Konsole, damit wirklich alles ersetzt werden kann.
      Gruß Gerhard
        Smokey
        Hallo Gerhard,
        hab ich jetzt gemacht. Ändert leider nichts an der Fehlermeldung. Trotzdem Danke für den Tipp!
        Markus
          Smokey
          Hallo wep4you2,
          sagt dir vielleicht der Auszug aus dem Log irgendwas, was mir einen Hinweis auf den Fehler geben könnte? Wäre ganz klasse. Ich hab meine Netatmo zwar schon in iobroker verbunden, aber eben über den aufwändigen Weg und der Adapter wäre ne coole Sache.
          Danke schon mal
          Markus
            MattiHamburg
            Hallo erst mal aus dem schönen Norden.
            Ich bin auch eine begeisterter ccuio und jetzt ioBroker Nutzer. Ich taste mich da von Adapter zu Adapter heran.
            Mein System läuft auf einer Cubox sehr stabil. Alles gerade platt gemacht und auf den neusten Stand.
            Meine CCU umfasst bis jetzt 54 Komponenten und wächst stetig
            Meine neueste Errungenschaft ist die Netatmo Wetterstation komplett mit Wind und Regensensor.
            Nun habe ich diverse Versuche unternommen euren Adapter zum laufen zu bringen.
            Wie schon gesagt gesamte System neu aufgesetzt. Alles hat nicht geholfen.
            Sonst konnte ich mir immer selber weiter helfen indem ich in eure Beiträge gelesen hab
            Folgen Fehler erscheinen im Log
            host-cubox-i	2016-10-16 14:18:15.530	info	Restart adapter system.adapter.netatmo.0 because enabled
            host-cubox-i	2016-10-16 14:18:15.530	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
            netatmo-0	2016-10-16 14:18:15.484	info	terminating
            TypeError:	2016-10-16 14:18:14.959	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
            TypeError:	2016-10-16 14:18:14.959	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            TypeError:	2016-10-16 14:18:14.959	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
            TypeError:	2016-10-16 14:18:14.959	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
            TypeError:	2016-10-16 14:18:14.959	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:394:29)
            TypeError:	2016-10-16 14:18:14.959	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3004:14)
            TypeError:	2016-10-16 14:18:14.959	error	at Adapter.emit (events.js:104:17)
            TypeError:	2016-10-16 14:18:14.959	error	at Adapter. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:69:15)
            TypeError:	2016-10-16 14:18:14.959	error	at new netatmo (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:15:10)
            TypeError:	2016-10-16 14:18:14.959	error	at netatmo.authenticate (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:125:12)
            TypeError:	2016-10-16 14:18:14.959	error	undefined is not a function
            uncaught	2016-10-16 14:18:14.937	error	exception: undefined is not a function
            netatmo-0	2016-10-16 14:18:14.901	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.netatmo
            Habt ihr eine Ahnung was ich falsch mache
            Danke für die Hilfe
            Geändert Homoran Code in codetags
              tgirard
              Guten Morgen
              Der Adapter sieht vielversprechend aus. Wenn ich ihn starte, dann beendet er leider gleich wieder mit:
              host-bananapi	2016-12-09 06:51:37.844	error	instance system.adapter.netatmo.0 terminated with code 6 (uncaught exception)
              TypeError:	2016-12-09 06:51:36.686	error	at Request.emit (events.js:172:7)
              TypeError:	2016-12-09 06:51:36.686	error	at emitTwo (events.js:87:13)
              TypeError:	2016-12-09 06:51:36.686	error	at Request.self.callback (/root/node_modules/iobroker.netatmo/node_modules/netatmo-homey/node_modules/request/request.js:186:22)
              TypeError:	2016-12-09 06:51:36.686	error	at null. (/root/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:388:14)
              TypeError:	2016-12-09 06:51:36.686	error	at /root/node_modules/iobroker.netatmo/netatmoStation.js:14:26
              TypeError:	2016-12-09 06:51:36.686	error	at Array.forEach (native)
              TypeError:	2016-12-09 06:51:36.686	error	at /root/node_modules/iobroker.netatmo/netatmoStation.js:15:25
              TypeError:	2016-12-09 06:51:36.686	error	at handleDevice (/root/node_modules/iobroker.netatmo/netatmoStation.js:32:13)
              TypeError:	2016-12-09 06:51:36.686	error	at handleDevice (/root/node_modules/iobroker.netatmo/netatmoStation.js:34:30)
              TypeError:	2016-12-09 06:51:36.686	error	at getDeviceName (/root/node_modules/iobroker.netatmo/netatmoStation.js:25:27)
              TypeError:	2016-12-09 06:51:36.686	error	Cannot read property 'replaceAll' of undefined
              uncaught	2016-12-09 06:51:36.665	error	exception: Cannot read property 'replaceAll' of undefined
              netatmo-0	2016-12-09 06:51:33.674	info	starting. Version 0.4.1 in /root/node_modules/iobroker.netatmo
              kann mir hier jemand helfen?
              vielen Dank!
              Thierry
              • P Offline
                PArt
                Nach langem Warten gibt es noch einmal ein Update für den Adapter.
                Beachtet bitte, das ihr eine aktuelle Node-Version verwendet (>= 4)!
                Neu ist, das die Welcome & Presence jetzt realtime updates versenden…
                Wenn ihr Probleme habt, so gebt mir bitte kurz bescheid. An meine 2 Vorredner: Checkt bitte einmal eure Node-Version! Ich habe das original Repo des homey-netatmo Projekt aber gerade geforkt und hier bereits einige Fehler behoben....
                • G Offline
                  gst666
                  Version 1.0.0 des netatmo Adapters hat bei mir Probleme mit der Welcome Kamera. Anscheinend kann sich der Treiber nicht authentisieren. Nutze ich nur die Wetterstation, ist alles OK.
                  Nutze node 4.7.2
                  Hier das Fehlerlog
                  Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                  automation	2017-01-29 09:49:34.198	info	host.automation Restart adapter system.adapter.netatmo.0 because enabled
                  automation	2017-01-29 09:49:34.197	error	host.automation instance system.adapter.netatmo.0 terminated with code 0 (OK)
                  netatmo.0	2017-01-29 09:49:33.684	info	netatmo.0 Registering realtime events with https://iobroker.herokuapp.com/netatmo/
                  netatmo.0	2017-01-29 09:49:33.684	info	netatmo.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v4.7.2
                  host.automation	2017-01-29 09:49:33.101	info	instance system.adapter.netatmo.0 started with pid 20122
                  host.automation	2017-01-29 09:49:29.528	info	Restart adapter system.adapter.netatmo.0 because enabled
                  host.automation	2017-01-29 09:49:29.528	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
                  netatmo.0	2017-01-29 09:49:29.511	info	terminating
                  netatmo.0	2017-01-29 09:49:29.508	info	cleaned everything up...
                  netatmo.0	2017-01-29 09:49:29.507	info	Unregistering realtime events
                  netatmo.0	2017-01-29 09:49:29.506	error	at IncomingMessage.g (events.js:260:16)
                  netatmo.0	2017-01-29 09:49:29.506	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/node_modules/request/request.js:1001:12)
                  netatmo.0	2017-01-29 09:49:29.506	error	at Request.emit (events.js:169:7)
                  netatmo.0	2017-01-29 09:49:29.506	error	at emitOne (events.js:77:13)
                  netatmo.0	2017-01-29 09:49:29.506	error	at Request. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/node_modules/request/request.js:1081:10)
                  netatmo.0	2017-01-29 09:49:29.506	error	at Request.emit (events.js:172:7)
                  netatmo.0	2017-01-29 09:49:29.506	error	at emitTwo (events.js:87:13)
                  netatmo.0	2017-01-29 09:49:29.506	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/node_modules/request/request.js:186:22)
                  netatmo.0	2017-01-29 09:49:29.506	error	at null. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/netatmo.js:156:25)
                  netatmo.0	2017-01-29 09:49:29.506	error	at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/netatmo.js:46:17)
                  netatmo.0	2017-01-29 09:49:29.506	error	Error: Authenticate error: invalid_request
                  netatmo.0	2017-01-29 09:49:29.504	error	uncaught exception: Authenticate error: invalid_request
                  netatmo.0	2017-01-29 09:49:29.311	info	Registering realtime events with https://iobroker.herokuapp.com/netatmo/
                  netatmo.0	2017-01-29 09:49:29.235	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v4.7.2
                  host.	2017-01-29 09:49:29.221	info	States connected to redis 127.0.0.1:6379
                  host.automation	2017-01-29 09:49:28.743	info	instance system.adapter.netatmo.0 started with pid 20112
                  • P Offline
                    PArt
                    Ok, mist, habe das Problem gefunden … Netatmo erlaubt den Zugriff auf diese Daten nur aus einem speziellen Scope, der NUR für den eigenen Account funktioniert :( Ich werde gleich einen Workaround veröffentlichen
                    Danke für die Meldung
                    • P Offline
                      PArt
                      Habe direkt bei Netatmo einen Request gestellt, das der Scope mit der aktuellen AppID abgerufen werden darf … Warte noch auf Antwort
                      • G Offline
                        gst666
                        Danke für Dein Update. Mit dem eigenen App-Key scheint es jetzt auch mit der Welcome-Kamera zu gehen. Jetzt habe ich aber leider doch noch eine Frage: Wie kann ich den Live-Stream mir in iobroker anzeigen lassen. Die URL für das Bild funktioniert. Bei dem Live-Stream bekomme ich eine m3u8-Datei. Soweit schön. In dieser sind dann Streams mit verschiedenen Auflösungen enthalten. Wie kann ich diesen mit den Widgets von iobroker verwenden?
                        Wie sähe die URL aus? Muss ich erst mit einer Javascript-App eine passende erzeugen?
                        • P Offline
                          PArt
                          Die m3u8 Datei ist der Stream, normalerweise sollte diese von jedem Mediaplayer/Browser wiedergegeben werden können. Wie man diese in VIS anbindet, da bin ich leider etwas überfragt, da können dir hier die VIS-Profis sicherlich besser helfen …
                          Du kannst die m3u8 aber auch in einem Texteditor öffnen. Diese beinhaltet die URLs für die einzelnen Auflösungen und Qualitäten (m3u Files)
                            Bradock
                            Habe heute die erste Presence montiert.
                            Werde sie in Verbindung mit dem neuen Adapter testen.
                            An dieser Stelle großen Dank an PArt
                            Hoffe für die Stream-Einbindung in VIS findet sich auch noch ein Weg ;)
                            Gruß Sascha
                              Dinosky
                              bisher lief dein Adapter perfekt bis zur Version 0.41, ab da ließ er sich nicht mehr Updaten.
                              Habe Testhalber auf einer Synology iobroker installiert mit node.js 4.4.2
                              Selbst auf der neu installation bekomme ich deinen Adapter nicht mehr zum laufen.
                              Anbei der Log vielleicht kannst du mir einen Tip geben.
                              Gruß Dinosky
                              Log:
                              $ ./iobroker add netatmo
                              npm install iobroker.netatmo –production --prefix "/volume1/homes/admin/opt/iobroker" (System call)
                              npm
                              WARN
                              addRemoteGit Error: not found: gitnpm
                              WARN addRemoteGit at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)npm
                              WARN addRemoteGit at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
                              npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                              npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                              npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
                              npm
                              WARN addRemoteGit git+https://github.com/PArns/netatmo.git resetting remote /var/services/homes/admin/.npm/_git-remotes/https-github-com-PArns-netatmo-git-64c84a8d because of error: { [Error: not found: git] code: 'ENOGIT' }
                              npm
                              ERR! git clone –template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/PArns/netatmo.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-PArns-netatmo-git-64c84a8d: undefinednpm ERR! git clone --template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/PArns/netatmo.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-PArns-netatmo-git-64c84a8d:
                              undefined
                              npm
                              ERR!
                              Linux 3.10.77npm ERR!
                              argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.netatmo" "--production" "--prefix" "/volume1/homes/admin/opt/iobroker"npm ERR! node v4.4.2
                              npm ERR! npm
                              v2.15.0npm
                              ERR! code ENOGIT
                              npm ERR!
                              not found: gitnpm ERR!
                              npm ERR! Failed using git.
                              npm ERR! This is most likely not a problem with npm itself.
                              npm ERR!
                              Please check if you have git installed and in your PATH.
                              npm ERR! Please include the following file with any support request:npm ERR!
                              /volume1/homes/admin/opt/npm-debug.log
                              ERROR: host.DiskStation Cannot install iobroker.netatmo: 1
                                bb61
                                Gleicher Fehler auch bei mir.
                                Komplett neue iobroker-Installation, alle anderen Adapter (inzw. ca. 15) laufen problemlos durch, hier aber (nach "+" im Admin) nur Fehlermeldungen, wie beim Vorredner.
                                Trägersystem iobroker: Win2k8R2
                                Browser (iobroker.admin): Firefox auf Win10 (auf Win2k8R2 gleicher Fehler)
                                alles aktuell gepatcht
                                Falls Bedarf zum Testen: Habe Voll-System im eigenen Zugriff (Basis innen / aussen, ein Zusatz-Raummodul, +Wind, +Regen)
                                …und auch schon selber für andere Systeme NA-Abruf-Module gebaut (per NA-API, Status und Historie, alle Werte aller Geräte)
                                ...bin neu auf dieses System gestossen (über Alexa), würde gerne ioBroker weiter testen. Ihr habt da offenbar was ganz ganz Tolles gebaut. Übergreifend usw. und wirklich durchdacht. Hab sofort so etliche Ideen! Und sicher nicht nur "nehmend", wenns passt ;-) ...doof, das ausgerechnet der NA-Adapter nicht installierbar ist! Der hat so schnucklige und seltene Werte in gut verpackten preiswerten Sensoren..... ;-)
                                Gruss bb61
                                  Windows Installationen ???
                                  Der Fehler liegt in einem fehlenden Paket, hier:
                                  @Dinosky:
                                  ERR! code ENOGIT `
                                  unter Linux:
                                  apt-get install git
                                  Unter Windows wurde es hier im Forum schon öfter beschrieben.
                                    bb61
                                    Kaum macht man's richtig, klappts auch!
                                    …und wieder was gelernt!
                                    Nun bleibt natürlich (unterschwellig) die Frage, ob sich das System wirklich nur ausschließlich an die Zielgruppe von Ropsitory-Tools installiert habender oder zumindest kennender Entwickler wendet, oder nicht wenigstens eine deutliche eindeutige Fehlermeldung erscheinen sollte, die auf die nächste nötige Aktion hinweist (wenn schon nicht selbst systemspezifisch vom Installer Fehlendes nachinstalliert wird). Aber aus Sicht rein ehrenamtlicher Entw.-Tätigkeit ist das natürlich voll ok, so wie es ist!
                                    Nochmals Danke für die schnelle Hilfe!
                                      @bb61:
                                      Nochmals Danke für die schnelle Hilfe! `
                                      Gerne!
                                      @bb61:
                                      oder zumindest kennender Entwickler wendet, oder nicht wenigstens eine deutliche eindeutige Fehlermeldung erscheinen sollte, die auf die nächste nötige Aktion hinweist `
                                      Ich bin auch kein Entwickler, sondern nur einfacher User. Aber ich liebe Logik-Rätsel ;-)
                                      Ich kann um Himmelswillen kein log vollständig entziffern. Aber wenn da etwas in Blockbuchstaben steht und davor noch ein Err, dann ist das schon ein eindeutiger Hinweis und den versuche ich zu entschlüsseln.
                                      das E steht für Error, bleibt NO GIT.
                                      oder ECONNREFUSED, ENOMEM usw. lassen sich relativ einfach zuordnen, zur Not gibt es noch die Tante G.
                                      Da das ganze aus der Linux Ecke kommt ist GIT dort in nahezu jedem Repo enthalten.
                                      Wenn ich das richtig interpretiere kommt dieses logging von npm, nicht von ioBroker.
                                      • E Offline
                                        Elitepain77
                                        Hallo!
                                        Bin neu hier im Forum. Ich habe vor ca. 2 Monaten den Umstieg von CCU.IO auf io-broker gewagt und bin absolut zufrieden. Habe momentan ca. 13 Adapter laufen. Aber am Netatmo Adapter scheitere ich gerade…
                                        • raspberrypi 2017-03-03 13:57:28.088 error host.raspberrypi instance system.adapter.netatmo.0 terminated with code 0 (OK)
                                        netatmo.0 2017-03-03 13:57:28.059 error netatmo.0 uncaught exception: Cannot read property 'replaceAll' of undefined
                                        netatmo.0 2017-03-03 13:57:27.576 info netatmo.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v4.7.2
                                        raspberrypi 2017-03-03 13:57:25.380 info host.raspberrypi instance system.adapter.netatmo.0 started with pid 23006
                                        host.raspberrypi 2017-03-03 12:56:55.342 info Restart adapter system.adapter.netatmo.0 because enabled
                                        host.raspberrypi 2017-03-03 12:56:55.340 error instance system.adapter.netatmo.0 terminated with code 0 (OK)
                                        netatmo.0 2017-03-03 12:56:55.314 info terminating
                                        netatmo.0 2017-03-03 12:56:55.305 info cleaned everything up…
                                        netatmo.0 2017-03-03 12:56:55.303 error at Request.emit (events.js:172:7)
                                        netatmo.0 2017-03-03 12:56:55.303 error at emitTwo (events.js:87:13)
                                        netatmo.0 2017-03-03 12:56:55.303 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/node_modules/request/request.js:186:22)
                                        netatmo.0 2017-03-03 12:56:55.303 error at null. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/netatmo.js:388:20)
                                        netatmo.0 2017-03-03 12:56:55.303 error at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:14:26
                                        netatmo.0 2017-03-03 12:56:55.303 error at Array.forEach (native)
                                        netatmo.0 2017-03-03 12:56:55.303 error at /opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:15:25
                                        netatmo.0 2017-03-03 12:56:55.303 error at handleDevice (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:32:13)
                                        netatmo.0 2017-03-03 12:56:55.303 error at handleDevice (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:34:30)
                                        netatmo.0 2017-03-03 12:56:55.303 error at getDeviceName (/opt/iobroker/node_modules/iobroker.netatmo/netatmoStation.js:25:27)
                                        netatmo.0 2017-03-03 12:56:55.303 error TypeError: Cannot read property 'replaceAll' of undefined
                                        netatmo.0 2017-03-03 12:56:55.293 error uncaught exception: Cannot read property 'replaceAll' of undefined
                                        netatmo.0 2017-03-03 12:56:53.646 info starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.netatmo, node: v4.7.2
                                        Hat jemand einen Tip für mich?
                                        Habe node 4.7.2. Sollte alles frisch sein..
                                        Vielen Dank vorab.
                                        Elitepain
                                        • P Offline
                                          PArt
                                          Wie schon per Mail geschrieben … Versuche bitte mal das aktuelle Update und poste noch einmal dein Log
