  4. KNX Adapter - Nicht alle Objekte lassen sich schreiben
8 Beiträge 5 Kommentatoren 790 Aufrufe 4 Beobachtet
    klee
    schrieb am zuletzt editiert von klee
    Ich habe meine ETS Datei im KNX Adapter importiert.
    Einige Werte lassen sich über den KNX Adapter schreiben, andere nicht.
    Ich verstehe allerdings nicht warum.
    Hier mal 2 Objekte (Büro geht nicht, Schlafzimmer Süden geht schon)
    Schlafzimmer Süden
      "_id": "knx.0.OG_Eltern.Jalousie.Eltern_Süd_Position_%",
      "type": "state",
      "common": {
        "name": "Eltern Süd Position %",
        "type": "number",
        "role": "value",
        "read": true,
        "write": true,
        "unit": "%",
        "max": 100,
        "min": 0
      "native": {
        "dpt": "DPT5.001",
        "address": "11/1/9",
        "addressRefId": "P-05DD-0_GA-225",
        "statusGARefId": "",
        "actGARefId": "",
        "update": true,
        "objRef": "O-13_R-2070",
        "devName": "M-0083_A-008A-25-6CE4",
        "devInst": "P-05DD-0_DI-21",
        "objectSize": ""
      "from": "system.adapter.knx.0",
      "user": "system.user.admin",
      "ts": 1625087649012,
      "acl": {
        "object": 1636,
        "state": 1636
    Büro
      "_id": "knx.0.EG_Büro.Jalousie.Büro_Position_Höhe",
      "type": "state",
      "common": {
        "name": "Büro Position Höhe",
        "type": "number",
        "role": "value",
        "read": true,
        "write": true,
        "unit": "%",
        "max": 100,
        "min": 0
      "native": {
        "dpt": "DPT5.001",
        "address": "4/1/2",
        "addressRefId": "P-05DD-0_GA-30",
        "actGARefId": "",
        "update": true,
        "objRef": "O-110_R-31202",
        "devName": "M-0009_A-500F-01-936F",
        "devInst": "P-05DD-0_DI-4",
        "objectSize": ""
      "ts": 1625087648245,
      "acl": {
        "object": 1638,
        "state": 1638
    frankthegreatF 1 Antwort Letzte Antwort
    • K klee
      Schlafzimmer Süden
        "type": "state",
        "common": {
          "type": "number",
          "role": "value",
          "read": true,
          "write": true,
          "unit": "%",
          "max": 100,
          "min": 0
        "native": {
          "dpt": "DPT5.001",
          "actGARefId": "",
          "update": true,
          "objectSize": ""
        "acl": {
          "object": 1636,
          "state": 1636
      Büro
        "type": "state",
        "common": {
          "type": "number",
          "role": "value",
          "read": true,
          "write": true,
          "unit": "%",
          "max": 100,
          "min": 0
        "native": {
          "dpt": "DPT5.001",
          "address": "4/1/2",
          "actGARefId": "",
          "update": true,
          "objectSize": ""
        "acl": {
          "object": 1638,
          "state": 1638
      frankthegreatF Offline
      frankthegreat
      @klee Hast du einen Linienkoppler oder einen IP Router im System?
      • frankthegreatF frankthegreat
        klee
        @frankthegreat Nein nur eine simple linie
        • K klee
          klee
          Hier mal eine Log ausgabe, die entsteht wenn man Versucht eine Adresse zu schreiben, die nicht funktioniert:
          knx.0	2021-07-04 19:04:20.695	info	(8747) ( 4.b ) return to STATE_READY, processing : false
          knx.0	2021-07-04 19:04:20.694	info	(8747) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 10 3f 00 ChID : 16 SeqCntIN : 63 SeqCntOUT : 23 queue length : 0
          knx.0	2021-07-04 19:04:20.689	info	(8747) =====> STATE_TUNNELING_ACK
          knx.0	2021-07-04 19:04:20.687	info	(8747) RESPONSE single-array value : 20 auf knx.0.OG_Eltern.Jalousie.Eltern_Süd_Position_%
          knx.0	2021-07-04 19:04:20.686	info	(8747) RESPONSE : mappedName : Eltern Süd Position % dest : 11/1/9 val: 20 (DPT5.001) Eltern_Süd_Position_%
          knx.0	2021-07-04 19:04:20.684	info	(8747) main.js: onGroupValue_Response from 11/1/9
          knx.0	2021-07-04 19:04:20.682	info	(8747) ( 3.3 ) Received TUNNEL_REQUEST (RESPONSE - send ACK) : 06 10 04 20 00 16 04 10 3f 00 29 00 bc e0 11 04 59 09 02 00 40 33 16
          knx.0	2021-07-04 19:04:20.660	info	(8747) ( 4.b ) return to STATE_READY, processing : false
          knx.0	2021-07-04 19:04:20.659	info	(8747) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 10 3e 00 ChID : 16 SeqCntIN : 62 SeqCntOUT : 23 queue length : 0
          knx.0	2021-07-04 19:04:20.657	info	(8747) =====> STATE_TUNNELING_ACK
          knx.0	2021-07-04 19:04:20.655	info	(8747) ( 3.6a ) Received L_DATA.con 06 10 04 20 00 15 04 10 3e 00 2e 00 bc e0 11 63 59 09 01 00 00 was successfully processed by receiver.
          knx.0	2021-07-04 19:04:20.643	info	(8747) ==> easy-knx.js: signal runtime : 0s 10.203541ms
          knx.0	2021-07-04 19:04:20.642	info	(8747) ==> successful acknowledged previous package... processing next of 0
          knx.0	2021-07-04 19:04:20.640	info	(8747) ( 2 ) Received TUNNEL_ACK : 06 10 04 21 00 0a 04 10 16 00 from 172.16.2.3:3671 SeqCntIN : 61 SeqCntOUT : 23 GA : 0/0/0
          knx.0	2021-07-04 19:04:20.636	info	(8747) easy-knx: task.data : 06 10 04 20 00 15 04 10 16 00 11 00 bc e0 11 63 59 09 01 00 00 byteLen : 21
          knx.0	2021-07-04 19:04:20.633	info	(8747) ( 1 ) Sending : GroupValueRead : 06 10 04 20 00 15 04 10 16 00 11 00 bc e0 11 63 59 09 01 00 00 sent to 172.16.2.3:3671 ChID: 16 SeqCntIN : 61 SeqCntOUT : 22 GA : 11/1/9 conCheck.conected
          knx.0	2021-07-04 19:04:20.473	info	(8747) Has todo still 1 tasks, just processing : false
          knx.0	2021-07-04 19:04:20.472	info	(8747) ( 4.b ) return to STATE_READY, processing : false
          knx.0	2021-07-04 19:04:20.467	info	(8747) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 10 3d 00 ChID : 16 SeqCntIN : 61 SeqCntOUT : 22 queue length : 1
          knx.0	2021-07-04 19:04:20.464	info	(8747) =====> STATE_TUNNELING_ACK
          knx.0	2021-07-04 19:04:20.461	info	(8747) RESPONSE single-array value : 20 auf knx.0.OG_Eltern.Jalousie.Eltern_Süd_Position_%
          knx.0	2021-07-04 19:04:20.459	info	(8747) RESPONSE : mappedName : Eltern Süd Position % dest : 11/1/9 val: 20 (DPT5.001) Eltern_Süd_Position_%
          knx.0	2021-07-04 19:04:20.457	info	(8747) main.js: onGroupValue_Response from 11/1/9
          knx.0	2021-07-04 19:04:20.455	info	(8747) ( 3.3 ) Received TUNNEL_REQUEST (RESPONSE - send ACK) : 06 10 04 20 00 16 04 10 3d 00 29 00 bc e0 11 04 59 09 02 00 40 33 16
          knx.0	2021-07-04 19:04:20.439	info	(8747) Has todo still 1 tasks, just processing : false
          knx.0	2021-07-04 19:04:20.438	info	(8747) ( 4.b ) return to STATE_READY, processing : false
          knx.0	2021-07-04 19:04:20.437	info	(8747) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 10 3c 00 ChID : 16 SeqCntIN : 60 SeqCntOUT : 22 queue length : 1
          knx.0	2021-07-04 19:04:20.434	info	(8747) =====> STATE_TUNNELING_ACK
          knx.0	2021-07-04 19:04:20.433	info	(8747) ( 3.6a ) Received L_DATA.con 06 10 04 20 00 15 04 10 3c 00 2e 00 bc e0 11 63 59 09 01 00 00 was successfully processed by receiver.
          knx.0	2021-07-04 19:04:20.425	info	(8747) main.js : tGA.write on Statechange : 11/1/9 P-05DD-0_GA-225 typeof val: number 50 DPT5.001
          knx.0	2021-07-04 19:04:20.419	info	(8747) ==> easy-knx.js: signal runtime : 0s 11.091339ms
          knx.0	2021-07-04 19:04:20.417	info	(8747) ==> successful acknowledged previous package... processing next of 0
          knx.0	2021-07-04 19:04:20.416	info	(8747) ( 2 ) Received TUNNEL_ACK : 06 10 04 21 00 0a 04 10 15 00 from 172.16.2.3:3671 SeqCntIN : 59 SeqCntOUT : 22 GA : 0/0/0
          knx.0	2021-07-04 19:04:20.411	info	(8747) easy-knx: task.data : 06 10 04 20 00 15 04 10 15 00 11 00 bc e0 11 63 59 09 01 00 00 byteLen : 21
          knx.0	2021-07-04 19:04:20.408	info	(8747) ( 1 ) Sending : GroupValueRead : 06 10 04 20 00 15 04 10 15 00 11 00 bc e0 11 63 59 09 01 00 00 sent to 172.16.2.3:3671 ChID: 16 SeqCntIN : 59 SeqCntOUT : 21 GA : 11/1/9 conCheck.conected
          knx.0	2021-07-04 19:04:20.404	info	(8747) main.js : tGA.write on Statechange : 11/1/9 P-05DD-0_GA-225 typeof val: number 50 DPT5.001
          TheBamT 1 Antwort Letzte Antwort
          • K klee
            TheBamT Offline
            TheBamT Offline
            TheBam
            @klee
            Bist du dir sicher das die datenpunkte die richtigen sind? Das sieht für mich so aus als ob das eine ein Status ist und das andere ein Wert den er haben will. Dann ist es auch klar warum es nicht geht.
            P 1 Antwort Letzte Antwort
            • TheBamT TheBam
              @klee
              plc
              @thebam
              bei mir ist ein ähnliches Problem.
              Nach dem Einlesen des KNX Projektes lassen sich die meisten Gruppenadressen unter den neu angelegten Objekten nicht steuern.
              Vor dem Update auf den neuen KNX Adapter hat auch nicht alles funktioniert.
              Die Kommunikation zwischen KNX Adapter und KNX Bus sollte funktionieren da ich die Änderung der Zustände unter den Objekten im IoBroker sehen kann. Unter den Objekten habe ich versucht die Rechte auf 666 zu setzen (Standard 000) keine Änderung.
              Beim Vergleichen der Objekte ist mir eine Sache aufgefallen siehe unten. Objekt bearbeiten->Objektdaten
              nicht funktionierendes Objekt
                "_id": "knx.0.Licht.Schalten.Büro_Deckenlicht_links_schalten",
                "type": "state",
                "common": {
                  "name": "Büro Deckenlicht links schalten",
                  "type": "boolean",
                  "read": true,
                  "write": true,
                  "role": "value",
                  "min": false,
                  "max": true
                "native": {
                  "dpt": "DPT1.001",
                  "address": "1/1/94",
                  "addressRefId": "P-0720-0_GA-107",
                  "actGARefId": ""
                "acl": {
                  "object": 0,
                  "owner": "system.user.admin",
                  "state": 0
                "ts": 1640775426051
              read/write habe ich händisch alles auf true gesetzt.
              funktionierendes Objekt:
                "_id": "knx.0.Licht.Schalten.Flur_Garderobe_schalten",
                "type": "state",
                "common": {
                  "name": "Flur Garderobe schalten",
                  "type": "boolean",
                  "read": true,
                  "write": true,
                  "role": "value",
                  "min": false,
                  "max": true
                "native": {
                  "dpt": "DPT1.001",
                  "address": "1/1/35",
                  "addressRefId": "P-0720-0_GA-45",
                  "actGARefId": ""
                "ts": 1640716862072
              der Unterschied ist in der Zeile "from": "system.adapter.knx.0",. Beim nicht funktionierenden Objekt steht system.adapter.admin.0. Wenn ich das händisch versuche zu korrigieren, bleibt es nicht gespeichert. Nach dem erneuten Öffnen steht wieder admin.0.
              KNX Projekt aus ETS5
              Admin Adapter v5.2.3
              KNX Adapter 2.0.5
              TheBamT T 2 Antworten Letzte Antwort
              • P plc
                @thebam
                  "type": "state",
                  "common": {
                    "type": "boolean",
                    "read": true,
                    "write": true,
                    "role": "value",
                    "min": false,
                    "max": true
                  "native": {
                    "dpt": "DPT1.001",
                    "actGARefId": ""
                  "acl": {
                    "object": 0,
                    "state": 0
                  "ts": 1640775426051
                  "type": "state",
                  "common": {
                    "type": "boolean",
                    "read": true,
                    "write": true,
                    "role": "value",
                    "min": false,
                    "max": true
                  "native": {
                    "dpt": "DPT1.001",
                    "actGARefId": ""
                  "ts": 1640716862072
                KNX Adapter 2.0.5
                TheBamT Offline
                TheBamT Offline
                TheBam
                @plc
                Kann ich so nichts zu sagen. Bitte den Entwickler direkt anschreiben in dem neuen knx adapter Post.
                Oder umsteigen und openknx bzw. Den mal probieren
                • P plc
                  @thebam
                    "type": "state",
                    "common": {
                      "type": "boolean",
                      "read": true,
                      "write": true,
                      "role": "value",
                      "min": false,
                      "max": true
                    "native": {
                      "dpt": "DPT1.001",
                      "actGARefId": ""
                    "acl": {
                      "object": 0,
                      "state": 0
                    "ts": 1640775426051
                    "type": "state",
                    "common": {
                      "type": "boolean",
                      "read": true,
                      "write": true,
                      "role": "value",
                      "min": false,
                      "max": true
                    "native": {
                      "dpt": "DPT1.001",
                      "actGARefId": ""
                    "ts": 1640716862072
                  KNX Adapter 2.0.5
                  tombox
                  @plc wenn es gar nicht geht kannst du auch jederzeit dem neuen openknx adapter eine Chance geben vielleicht geht es da einfacher
