  3. Entwicklung
  4. IoBroker.cec
IoBroker.cec
23 Beiträge 8 Kommentatoren 4.8k Aufrufe 6 Beobachtet
    SuperElmi
    Hallo Garfonso,
    ich habe heute auf den js-controller 3.1.4 aktualisiert, seitdem startet der CEC-Adapter permanent neu. Knnst du bitte mal danach schauen? Danke dir!
    cec2.1	2020-05-20 20:21:10.869	warn	(2478) No state definition for state
    cec2.1	2020-05-20 20:21:10.500	info	(2478) Terminated (NO_ERROR): Without reason
    cec2.1	2020-05-20 20:21:10.498	info	(2478) terminating
    cec2.1	2020-05-20 20:21:10.446	warn	(2478) Already had device with name TV copy new stuff in old device.
    cec2.1	2020-05-20 20:21:10.432	error	(2478) Error: undefined is not a valid state value at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at CEC2.setStateChanged (/opt/iobroker/node_modules/iobroker.js-con
    cec2.1	2020-05-20 20:21:10.419	error	(2478) unhandled promise rejection: undefined is not a valid state value
    cec2.1	2020-05-20 20:21:10.417	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    cec2.1	2020-05-20 20:21:10.382	info	(2478) Device with logicalAddress 0 seen. Has name TV
    cec2.1	2020-05-20 20:21:07.944	info	(2478) config type: r
    cec2.1	2020-05-20 20:21:07.942	info	(2478) config osdName: ioBroker
    cec2.1	2020-05-20 20:21:07.898	info	(2478) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.cec2, node: v10.19.0, js-controller: 3.1.4
    cec2.1	2020-05-20 20:20:34.603	warn	(2455) No state definition for state
    cec2.1	2020-05-20 20:20:34.246	info	(2455) Terminated (NO_ERROR): Without reason
    cec2.1	2020-05-20 20:20:34.243	info	(2455) terminating
    cec2.1	2020-05-20 20:20:34.233	warn	(2455) Already had device with name TV copy new stuff in old device.
    cec2.1	2020-05-20 20:20:34.219	error	(2455) Error: undefined is not a valid state value at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at CEC2.setStateChanged (/opt/iobroker/node_modules/iobroker.js-con
    cec2.1	2020-05-20 20:20:34.206	error	(2455) unhandled promise rejection: undefined is not a valid state value
    cec2.1	2020-05-20 20:20:34.204	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    cec2.1	2020-05-20 20:20:34.167	info	(2455) Device with logicalAddress 0 seen. Has name TV
    GarfonsoG 1 Antwort Letzte Antwort
    • S SuperElmi
      Hallo Garfonso,
      GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      TL;DR: Versuch mal die 0.0.3 zu installieren und guck, ob es damit einfach weg ist. Für 'state' sollte kein State gesetzt werden... hm... vielleicht auch mal alle Objekte löschen und neu erzeugen lassen (also Adapter neustarten).
      @SuperElmi
      hm... warum ist da ein state undefined? grübel
      -> ist kein Problem mit 3.1.4, würde ich vermuten. Das sollte auch vorher schon einen Fehler gegeben haben.
      Irgendwie finde ich auch die Ausgaben gerade nicht im Code... hm... ich glaube deine Version ist schon etwas älter. (Ich war etwas unsauber mit Versionsnummern, bin halt noch mitten in der Entwicklung -> wird aber jetzt besser, nutzte jetzt das Skript :-) was sich automatisiert darum kümmert die Versionsnummern zu erhöhen, danke @AlCalzone ).
      Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
      Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
      • GarfonsoG Garfonso
        @SuperElmi
        SuperElmi
        @Garfonso
        Danke für den Hinweis auf die neue Version, schaut besser aus:
        cec2.1	2020-05-21 15:26:23.055	info	(5254) Creation of device TX-NR626__ finished.
        cec2.1	2020-05-21 15:26:22.437	warn	(5254) No state definition for ignored
        cec2.1	2020-05-21 15:26:22.434	info	(5254) Already knew device TX-NR626__. Update values.
        cec2.1	2020-05-21 15:26:22.306	info	(5254) Device with logicalAddress 5 seen. Has name TX-NR626__
        cec2.1	2020-05-21 15:26:15.768	info	(5254) Device for 5 already created.
        cec2.1	2020-05-21 15:26:13.191	info	(5254) Device for 5 already created.
        cec2.1	2020-05-21 15:26:12.299	info	(5254) No name for logicalAddress 5, requesting it.
        cec2.1	2020-05-21 15:26:02.398	error	(5254) Setting activeSource to 0.0.0.0
        cec2.1	2020-05-21 15:25:58.378	info	(5254) Device for 0 already created.
        cec2.1	2020-05-21 15:25:57.377	info	(5254) config type: r
        cec2.1	2020-05-21 15:25:57.376	info	(5254) config osdName: ioBroker
        cec2.1	2020-05-21 15:25:57.327	info	(5254) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.cec2, node: v10.19.0, js-controller: 3.1.4
        SuperElmi
        • GarfonsoG Offline
          GarfonsoG Offline
          Garfonso
          Danke für die Rückmeldung. Sieht gut aus. Direkt noch eine Kleinigkeit gefixt (die "Error" Ausgabe da ist Quatsch und ist eher debug oder kann ganz weg).
          Ich hoffe, ich finde bald Zeit mal weiter zu machen. :-)
          R 1 Antwort Letzte Antwort
            RkcCorian
            @garfonso
            Hallo Zusammen,
            ich habe folgendes Setup:
            A) LG Smart TV CEC fähig
            B) Hue Sync Box CEC fähig
            C) Fire TV Cube CEC fähig
            D) Xbox One X, bislang nicht CEC fähig, ließe sich aber durch Tausch auf Xbox Series X ändern :-)
            Nun möchte ich gezielt die Kombination A+B+C ein-/ausschalten, bzw. A+B+D. Das ist nicht ganz so trivial bislang. Die Kombination A+B+C klappt mehr oder weniger mit ein paar Tricks in ioBroker, sobald D dazu kommt wird es schwierig, da sich die Geräte gegenseitig beeinflussen. Nun bin ich auf diesen Adapter aufmerksam geworden.
            Meine Fragen:
            1. Hilft dieser Adapter bei meinem Problem?
            2. Falls ja: Wie greift dieser Adapter auf HDMI-CEC zu? Über ein drittes Gerät, welches dazwischen geschaltet wird?
            Vielen Dank im Voraus und einen guten Start in die neue Woche! :-)
            • R RkcCorian
              @garfonso
              Hallo Zusammen,
              Meine Fragen:
              GarfonsoG Offline
              GarfonsoG Offline
              Garfonso
              schrieb am zuletzt editiert von Garfonso
              @markus-2
              Zu 2.: Der Zugriff auf HDMI-CEC ist bisher nur getestet mit einem raspberry Pi der per HDMI Kabel mit HDMI-Setup verbunden ist. Theoretisch gehen auch andere Adapter, die von libpulseeight bzw. cec-client unterstützt werden, siehe hier (als Startpunkt): https://github.com/Pulse-Eight/libcec
              Aber es muss grundsätzlich ein Gerät mit dem HDMI-Setup verbunden sein. Wenn auf der Konsole (ggf. nach installation) der cec-client funktioniert, sollte der Adapter auch funktionieren (oder funktionierend gemacht werden können).
              Zu 1:
              Wenn die XBox gar kein CEC kann, dann kommst du mit CEC nur zu dem Punkt, dass A+B an sind und auf die richtigen Eingänge geschaltet sind (für A+B+C geht alles an + richtige Eingänge). Wenn du die XBox dann irgendwie anders anbekommst, wärst du ja dann da.
              Das "gegenseitig beeinflussen", was du siehst, wird vermutlich auch mit CEC zusammen hängen. Grundsätzlich melden sich Geräte, die angehen im CEC-Bus und fragen auch ob was läuft und wenn nicht, melden sie sich als aktive Quelle und alle schalten die Eingänge entsprechend (macht z.B. das FireTV, wenn man es anschaltet). Das würde der Adapter auch beheben, weil der dann anstelle der XBox sagen würde, dass die gerade aktive Quelle ist (was dazu führt, dass TV und ggf. Sync Box die Eingänge entsprechend schalten und andere Geräte wissen, dass was läuft und nicht dazwischen funken -> den letzten Punkt müsste man nochmal testen, klappt aber auch mit "echten" Geräten nicht immer).
              //Edit: Die ganzen Ausführungen natürlich unter dem Vorbehalt, dass sich die Geräte auch alle CEC-konform Verhalten, was wohl nicht immer 100%ig so ist. Aber ich habe da bisher ganz gute Erfahrungen gemacht.
                @markus-2
                Zu 1:
                RkcCorian
                @garfonso
                Vielen Dank! Mein ioBroker läuft auf einem Docker auf meiner NAS und die steht weit weg von meinem Fernseher. D.h. ich sehe folgende Möglichkeiten:
                A) Direkt vor Ort ein Gerät unterbringen welches auf den HDMI-Bus Zugriff hat (bspw. so wie Du beschreibst
                B) Wenn die Xbox CEC kann (durch vermutlich Tausch auf die Xbox Serie X) sollte es ebenfalls, ohne die Notwendigkeit von A) gehen, da dann die Xbox beim Einschalten sagt, "ich bin die aktive Quelle" und der Fire TV Cube sollte dann (korrektes Verhalten vorausgesetzt) nicht auch noch mit angehen
                Ist das korrekt? Vielen Dank im Voraus!!
                • R RkcCorian
                  @garfonso
                  GarfonsoG Offline
                  GarfonsoG Offline
                  Garfonso
                  @markus-2
                  Ja.
                  zu a) hab ich hier ein iobroker-slave auf einem raspberry am TV
                  zu b) genau, wenn die XBox CEC kann, könnte sie sagen, sie geht an und TV usw. geht mit an und stellt sich ein. Hier geht das ganz ok mit FireTV <-> Blu-Ray Player (hier würde der cec Adapter dann ggf. den Vorteil bringen die Geräte von extern, z.B. Alexa, schalten zu können bzw. den Zustand überwachen zu können, also Vis zeigt an, dass XBox gespielt wird oder irgendwas anderes schaltet entsprechend noch :-) Aber das ist natürlich ein Stück weit Spielerei).
                    @markus-2
                    Ja.
                    RkcCorian
                    @garfonso
                    Super, dann habe ich jetzt ein Bild, vielen Dank!
                    Langfristig: Neue Xbox (Series X) :-)
                    Kurzfristig: Ich nutze den LG Adapter, curl (GET und PUT) Befehle für die Hue Sync Box, adb für den Fire TV Cube und den Xbox Adapter für die Xbox One X (kann kein CEC). Das habe ich seit gestern so am Laufen
                    Kurzfristig (Alternative falls es nicht zuverlässig läuft): Deine Lösung. Die klingt ebenfalls vielversprechend, allerdings habe ich meine jetzige Lösung "fast fertig" (ein paar Zeilen muss ich noch schreiben, inzw. konnte ich mit TestScripts aber alle notwendigen Ansteuerungen umsetzen :-)
                    Vielen lieben Dank für den Austausch und die mögliche Backup-Lösung!!!! Vor einer Woche habe ich noch gar keine Lösung gesehen.
                    • theip4ndaT Offline
                      theip4ndaT Offline
                      theip4nda
                      Kann es sein das keiner der Buttons bei einem Samsung H Serie Tv funktioniert?
                      Die Verbindung steht, anynet+ hat auch eine Verbindung zum pi aber egal welchen Button ich drücke es passiert leider nichts.
                      • theip4ndaT theip4nda
                        GarfonsoG Offline
                        GarfonsoG Offline
                        Garfonso
                        @theip4nda
                        mit den Buttons hab ich noch recht wenig Erfahrung... :-/ Bei meinem TV geht es auch nicht oder es ist noch was kaputt... da bin ich noch nicht ganz hinter gekommen. Ich hatte mal einen TV da musste man das Gerät, was fernsteuern darf, auch als "aktives Gerät" auswählen, was aber auch den Eingang entsprechend geschaltet hat... kann sein, dass das generell so ist. Konnte ich aber auch noch nicht testen, weil mein TV das bei meinen letzten versuchen mit dem PI nicht machen wollte, also den "aktiv" zu setzen.
