  3. Cloud Dienste
  4. iot Adapter stürzt ab startet nicht mehr
    6.5k
12 Beiträge 4 Kommentatoren 425 Aufrufe 2 Beobachtet
  • F Offline
    Flubfee
    Nachdem mein iot Adapter mehrere Wochen problemlos mit GoogleHome zusammen lief, lässt er sich ein paar Tagen nicht mehr starten. Am Anfang waren es im wesentlichen, jetzt kommt sowas:
    host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/googleHome.js:10:5)
    host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.rotshio	2021-06-08 21:47:16.343	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
    host.rotshio	2021-06-08 21:47:16.342	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
    host.rotshio	2021-06-08 21:47:16.341	error	Caught by controller[0]: SyntaxError: Unexpected identifier
    host.rotshio	2021-06-08 21:47:16.341	error	Caught by controller[0]: ^^^^^^^^^^^^^^^^
    host.rotshio	2021-06-08 21:47:16.340	error	Caught by controller[0]: rar patternDirection = {role: /^indicatoR\.dirgction$/, indic�to2: true, " " ` ` name: 'DIRECUION',0 required: fal
    host.rotshio	2021-06-08 21:47:16.339	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.type-detector/index.js:103
    host.rotshio	2021-06-08 21:47:14.486	info	instance system.adapter.iot.0 started with pid 3296
    host.rotshio	2021-06-08 21:46:44.449	info	Restart adapter system.adapter.iot.0 because enabled
    host.rotshio	2021-06-08 21:46:44.449	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Habe alles auf den neuesten Stand gebarch und ein paar Adapter ausgeschaltet, um RAM Probelem auf dem Rasp3B auszuschliessen.
    Vielen Dank im voraus für Eure Hilfe.
    ioBroker on Raspi 3B
    • F Flubfee
      HomoranH Offline
      HomoranH Offline
      @flubfee sagte in iot Adapter stürzt ab startet nicht mehr:
      sind immer noch 15!
      da ist mit Sicherheit dein RAM aufgebraucht.
      F 1 Antwort Letzte Antwort
        sind immer noch 15!
        Flubfee
        Nun ja, bis vor 3 Tagen liefs ohne Probleme.
        Gut das Du sicher bist, aber wie kann ich es messen, um die gleiche Sicherheit zu gewinnen?
        • HomoranH Offline
          HomoranH Offline
          hast du doch gerade gemacht.
          im Moment ist zwar Ruhe, aber dein SWAP ist angeknabbert.
          Da gsb es also eine Zeit, als das RAM nicht mehr reichte.
          evtl. bei einem backup(??)
            Flubfee
            Dafür ist das Swap ja da.... Und Backup soll ja nicht das laufende System zerschiessen.
            • F Flubfee
              @flubfee
              100MB Swap ist für nix da, viel zu klein für irgendwas. Da kannst du nur schauen ob dir der Speicher mal ausgegangen ist.
              Ich würde jedenfalls sagen, das Ding geht in die Knie, wenn da was 'dickes' gestartet wird. Z.B. ein Backup.
                @flubfee
                Flubfee
                Schön, Backup Adapter ist wieder ausgeschaltet.
                Das ist nicht mein Problem, sondern iot....
                • F Flubfee
                  @flubfee
                  Vielleicht auch was anderes.
                  which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                  mal anschauen. Bitte in CodeTags, nicht als Screenshot.
                    @flubfee
                    Flubfee
                    Danke Thomas,
                    der Gedanke kam mir vor ein paar Tagen auch schon:
                    pi@rotshio:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.1
                    v12.22.1
                    6.14.12
                    nodejs:
                      Installiert:           12.22.1-1nodesource1
                      Installationskandidat: 12.22.1-1nodesource1
                      Versionstabelle:
                     *** 12.22.1-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                         10.24.0~dfsg-1~deb10u1 500
                    pi@rotshio:~ $
                    • F Flubfee
                      Danke Thomas,
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.1
                      v12.22.1
                      6.14.12
                      nodejs:
                        Versionstabelle:
                      pi@rotshio:~ $
                      @flubfee
                      Gut, das passt.
                      iobroker update --version
                        @flubfee
                        Gut, das passt.
                        Flubfee
                        Welch Wunder, die neueste iot Version 1.8.22 löst das Problem.
                        • F Flubfee
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @flubfee
                          Dann bitte ein (GELÖST) vor Deinen Threadtitel
