  4. (Syno/Docker) wie spielt man das Backup ein ?
69 Beiträge 3 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • HumidorH Humidor
    @glasfaser ja, keine Änderung
    GlasfaserG Offline
    GlasfaserG Offline
    @humidor
    in der Konsole
    influx
    show database
    Werden dann deine database angezeigt
    HumidorH 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @humidor
      in der Konsole
      influx
      show database
      HumidorH Offline
      HumidorH Offline
      Humidor
      schrieb am zuletzt editiert von Humidor
      @glasfaser
      root@a8c9f63dab85:/# influx
      Connected to http://localhost:8086 version 1.7.11
      InfluxDB shell version: 1.7.11
      > show database
      ERR: error parsing query: found DATABASE, expected CONTINUOUS, DATABASES, DIAGNO
      STICS, FIELD, GRANTS, MEASUREMENT, MEASUREMENTS, QUERIES, RETENTION, SERIES, SHA
      RD, SHARDS, STATS, SUBSCRIPTIONS, TAG, USERS at line 1, char 6
      Warning: It is possible this error is due to not setting a database.
      Please set a database with the command "use <database>".
      > use iobroker
      Using database iobroker
      > show iobroker
      ERR: error parsing query: found iobroker, expected CONTINUOUS, DATABASES, DIAGNO
      BG
      • HumidorH Humidor
        @glasfaser
        > show database
        > use iobroker
        > show iobroker
        GlasfaserG Offline
        GlasfaserG Offline
        @humidor
        show series
        EDIT :
        Nix da vom Backup .
          @humidor
          show series
          EDIT :
          Nix da vom Backup .
          HumidorH Offline
          HumidorH Offline
          Humidor
          @glasfaser
          show databases
          name
          _internal
          iobroker
          show series
          0_userdata.0.AMISFronius.PowerFronius
          key
          0_userdata.0.AMIS.170
          0_userdata.0.AMIS.270
          0_userdata.0.AMIS.PVPower
          0_userdata.0.AMIS.PVÜberschuss
          0_userdata.0.AMIS.Power
          0_userdata.0.AMISFronius.170
          0_userdata.0.AMISFronius.270
          0_userdata.0.AMISFronius.PVPowerFronius
          0_userdata.0.AMISFronius.PVÜberschussFronius
          fritzdect.0.DECT_087610456373.celsius
          fritzdect.0.DECT_087610456373.power
          fritzdect.0.DECT_087610456373.state
          fritzdect.0.DECT_087610456373.voltage
          fritzdect.0.DECT_116300118701.celsius
          fritzdect.0.DECT_116300118701.power
          fritzdect.0.DECT_116300118701.state
          fritzdect.0.DECT_116300118701.voltage
          fuelpricemonitor.0.0_Home_Diesel.0.prices.0.amount
          fuelpricemonitor.0.0_Home_Diesel.2.prices.0.amount
          fuelpricemonitor.0.zuHome_Diesel.0.prices.0.amount
          javascript.0.Pool.RL
          javascript.0.Pool.TimerPumpe
          javascript.0.Pool.TimerWB
          BG
          • HumidorH Humidor
            @glasfaser
            show databases
            name
            _internal
            iobroker
            show series
            key
            GlasfaserG Offline
            GlasfaserG Offline
            @humidor
            select * from "0_userdata.0.AMISFronius.PowerFronius"
              @humidor
              HumidorH Offline
              HumidorH Offline
              Humidor
              @glasfaser ja, da ist nichts da..?
              time                ack  from                      q value
              1621958869486000000 true system.adapter.influxdb.0 0 -4414
              1621959547507000000 true system.adapter.influxdb.0 0 -4414
              BG
              • HumidorH Humidor
                GlasfaserG Offline
                GlasfaserG Offline
                @humidor
                und bei den anderen :
                Beispiel:
                select * from "0_userdata.0.AMISFronius.PVÜberschussFronius"
                War Influx ganz ohne Daten , vor dem einspiele des Backup ?
                Sind das alte Werte .
                  @humidor
                  Beispiel:
                  HumidorH Offline
                  HumidorH Offline
                  Humidor
                  @glasfaser das VMM System hat die Daten, im ioBackup ist influx aktiviert
                  die influx-Backup datei wird erzeugt (MB)
                  diese Werte die da stehen, war der letzte beim erstellen vom ioBackup, nehme ich an. diese 2 Werte sehe ich auch im ioBroker
                  sind bei allen 2 Werte drin.
                  BG
                  • HumidorH Humidor
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @humidor
                    Zum verstehen , komme gerade nicht mit .... wo was ist 🤔
                    Influx ist im VMM mit ioBroker und funktioniert.
                    Du hast ein Backup vom VMM Influx und spielst es im Docker Influx ein , hast aber dann keine Daten im ioBroker im Docker oder in der VMM mit ioBroker .
                    Das VMM und Docker bringt mich gerade durcheinander .😭
                      @humidor
                      HumidorH Offline
                      HumidorH Offline
                      Humidor
                      #66
                      @glasfaser alles ganz easy, VMM läuft ohne Probleme, alles da.
                      nun der neue Versuche, Umzug auf Docker (da endlich influxdb läuft).
                      aber die influx-Daten kommen nicht mit
                      das manuelle einspielen von den Daten hat dann auch nicht geklappt
                      aktuell ist der ioBroker Docker noch im Ruhezustand, nur influxdb ist aktiv, dh er bekommt keine neue Daten geliefert.
                      BG
                      • HumidorH Humidor
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #67
                        @humidor
                        Also nutzt du zum testen die VMM ioBroker und hast Influx im Docker aktiv mit dem Backup verbunden .
                        Hast du mal ohne dem Backup getestet , ob Influx im Docker überhaupt funktioniert und die Datenpunkte anlegt.
                          @humidor
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          #68
                          @glasfaser den Satz verstehe ich nicht, löse dich vom VMM.
                          ich habe ein Influx Backup, das will ich im Docker - Influx einspielen, fkt. nicht
                          das Docker - Influx läuft, ioBroker sagt verbunden, Datenpunkte im Grafana auswählbar.
                          die History-Daten von Influx sollen wieder hergestellt werden, aus dem Backup.
                          BG
                          • HumidorH Humidor
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #69
                            @humidor
                            Ok,
                            wie gesagt habe ich mich mit dem Influx Backup einspielen noch nicht befasst ,
                            ich würde mich hier im angegeben Thread einklinken , vielleicht kann dir simatec dort weiterhelfen.
                            https://forum.iobroker.net/topic/33603/backitup-für-influxdb/99
