  4. Homematic Adapter Sensoren
4 Beiträge 2 Kommentatoren 442 Aufrufe 1 Beobachtet
    Blackeye
    ich habe ein paar Probleme mit meinen Sensoren und dem Adapter. Die Schalterfunktionieren perfekt , die Sensoren übermitteln irgendwie keine Daten:
    hm-rpc.0	2021-04-26 09:12:23.312	info	(18425) Connected
    hm-rpc.0	2021-04-26 09:12:23.253	info	(18425) xmlrpc client is trying to connect to 192.168.0.50:2001/ with ["http://http://192.168.0.36:2001","raspberrypi:hm-rpc.0"]
    hm-rpc.0	2021-04-26 09:12:23.252	info	(18425) xmlrpc server is trying to listen on 0.0.0.0:2001
    hm-rpc.0	2021-04-26 09:12:23.069	info	(18425) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.19.1, js-controller: 3.1.6
    hm-rpc.0	2021-04-26 09:12:17.943	info	(18388) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    hm-rpc.0	2021-04-26 09:12:17.925	info	(18388) Disconnected
    hm-rpc.0	2021-04-26 09:12:17.901	info	(18388) xmlrpc -> 192.168.0.50:2001/ init ["http://http://192.168.0.36:2001",""]
    hm-rpc.0	2021-04-26 09:10:56.908	info	(18388) Connected
    hm-rpc.0	2021-04-26 09:10:56.851	info	(18388) xmlrpc client is trying to connect to 192.168.0.50:2001/ with ["http://http://192.168.0.36:2001","raspberrypi:hm-rpc.0"]
    hm-rpc.0	2021-04-26 09:10:56.850	info	(18388) xmlrpc server is trying to listen on 192.168.0.36:2001
    hm-rpc.0	2021-04-26 09:10:56.603	info	(18388) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.19.1, js-controller: 3.1.6
    hm-rpc.0	2021-04-26 09:10:51.356	info	(18349) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    hm-rpc.0	2021-04-26 09:10:51.336	info	(18349) Disconnected
    hm-rpc.0	2021-04-26 09:10:51.322	info	(18349) xmlrpc -> 192.168.0.50:2001/ init ["http://http://192.168.0.36:2001",""]
    Bei der x.x.x.36 handelt es sich um den ioBroker und bei der x.x.x50 um die Homematic....
    Habe ich etwas vergessen?
    Danke!
    • B Blackeye
      Danke!
      @blackeye sagte in Homematic Adapter Sensoren:
      Leider nur wenig Informationen :-(
      Die Glaskugel meint:
      was hast du als callback-Adresse eingetragen?
        Blackeye
        @homoran +Hi,
        ich dachte im LOG würde Alles stehen, sorry...
        Es ist die http://192.168.0.36 da bin ich mir wirklich nicht ganz sicher, aber die Lampen funktionieren ja...
        • B Blackeye
          Danke!
          aber da fehlt was:
          ich weiß nur nicht was in die letzten Anführungszeichen gehört.
          und zweimal http:// ist wohl auch nicht korrekt
