  4. SQL-History Adapter Update failed (1.3.2 auf 1.4.0)
    5.6k
46 Beiträge 7 Kommentatoren 7.4k Aufrufe
    und nochmal.
    Hier das log:
    ! root@ioBroker_Pine64:/opt/iobroker# iobroker add sql npm install iobroker.sql --production --prefix "/opt/iobroker" (System call) npm WARN deprecated node-uuid@1.4.7: use uuid module instead ../deps/libmagic/pcre/pcre_jit_compile.c:65:2: error: #error Unsupported architecture #error Unsupported architecture ^ make: *** [Release/obj.target/libpcre/deps/libmagic/pcre/pcre_jit_compile.o] Error 1 gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12) gyp ERR! System Linux 3.10.104-pine64 gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagic gyp ERR! node -v v4.6.1 gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v46-linux-arm64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp) ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’: ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’: ../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’: ../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’: ../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’: ../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), ^ In file included from ../src/statement.cc:6:0: ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Bind); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Get); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Run); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(All); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Each); ^ ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’: ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable] int status = uv_queue_work(uv_default_loop(), \ ^ ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’ STATEMENT_BEGIN(Reset); ^ npm ERR! Linux 3.10.104-pine64 npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.sql" "--production" "--prefix" "/opt/iobroker" npm ERR! node v4.6.1 npm ERR! npm v2.15.9 npm ERR! code ELIFECYCLE ! npm ERR! mmmagic@0.4.5 install: `node-gyp rebuild` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the mmmagic@0.4.5 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the mmmagic package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node-gyp rebuild npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs mmmagic npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls mmmagic npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request: npm ERR! /opt/iobroker/npm-debug.log host.ioBroker_Pine64 Cannot install iobroker.sql: 1 root@ioBroker_Pine64:/opt/iobroker# !
    Was mir direkt ins Auge sprang:
      Nachdem es hier so ruhig bleibt ;-) habe ich mich durchj Internet gequält.
      Dann habe ich festgestellt, dass mit mmmagic wahrscheinlich https://www.npmjs.com/package/mmmagic gemeint ist.
      Habe versucht das zu installieren, aber….
      root@ioBroker_Pine64:/opt/iobroker# npm install mmmagic
      mmmagic@0.4.5 install /opt/iobroker/node_modules/mmmagic
      node-gyp rebuild
      ! make: Entering directory '/opt/iobroker/node_modules/mmmagic/build'
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/apprentice.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/apptype.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/ascmagic.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf_time.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/compress.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/der.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/encoding.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/fsmagic.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/funcs.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/is_tar.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/magic.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/print.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/readcdf.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/readelf.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/softmagic.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/fmtcheck.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcat.o
      CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcpy.o
      AR(target) Release/obj.target/deps/libmagic/magic.a
      COPY Release/magic.a
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_byte_order.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_chartables.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_compile.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_config.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_dfa_exec.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_exec.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_fullinfo.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_get.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_globals.o
      CC(target) Release/obj.target/libpcre/deps/libmagic/pcre/pcre_jit_compile.o
      deps/libmagic/pcre/libpcre.target.mk:129: recipe for target 'Release/obj.target/libpcre/deps/libmagic/pcre/pcre_jit_compile.o' failed
      make: Leaving directory '/opt/iobroker/node_modules/mmmagic/build'
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! cwd /opt/iobroker/node_modules/mmmagic
      gyp ERR! not ok
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "mmmagic"
      ! npm ERR! mmmagic@0.4.5 install: node-gyp rebuild
      npm ERR!
      npm ERR!
      kann natürlich wieder an meiner 64Bit Umgebung auf dem Pine64 liegen.
      Werde da jetzt auch erst mal nicht weitermachen, da es meine Produktivumgebung ist.
      Wie bekomme ich es da jetzt wieder runter?
      So jedenfalls nicht:
      root@ioBroker_Pine64:/opt/iobroker# npm uninstall mmmagic
      npm WARN uninstall not installed in /opt/iobroker/node_modules: "mmmagic"
      oder heisst das, dass da wirklich nichts hängengeblieben ist?
      Mache jetzt auf dem Cubie weiter.
        So: Monolog die fünfte ;-)
        Auf dem Cubie läuft der Adapter.
        Installation im Admin hatte leider ein paar Hindernisse.
        Ich Depp habe das Installationsfenster geschlossen, daher habe ich keine durchgehende Doku über die Meldungen.
        Habe mal versucht dies aus dem Log noch zu extrahieren, hoffentlich nicht zuviel gelöscht:
        sql.0 2016-12-21 19:02:25.092 info Connected to sqlite
        sql.0 2016-12-21 19:02:22.724 info starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.sql, node: v6.9.2
        host. 2016-12-21 19:02:22.466 info States connected to redis 127.0.0.1:6379
        iobroker 2016-12-21 19:02:13.079 info exit 0
        iobroker 2016-12-21 19:02:12.909 info host.ioBroker_Cubie object system.adapter.sql.0 created
        host.ioBroker_Cubie 2016-12-21 19:02:12.862 info instance system.adapter.sql.0 started with pid 13487
        host.ioBroker_Cubie 2016-12-21 19:02:12.736 info object change system.adapter.sql.0
        iobroker 2016-12-21 19:02:12.681 info host.ioBroker_Cubie object system.adapter.sql.0.alive created
        iobroker 2016-12-21 19:02:12.639 info host.ioBroker_Cubie object system.adapter.sql.0.connected created
        iobroker 2016-12-21 19:02:12.595 info host.ioBroker_Cubie object system.adapter.sql.0.memHeapUsed created
        iobroker 2016-12-21 19:02:12.552 info host.ioBroker_Cubie object system.adapter.sql.0.memHeapTotal created
        iobroker 2016-12-21 19:02:12.508 info host.ioBroker_Cubie object system.adapter.sql.0.memRss created
        iobroker 2016-12-21 19:02:12.462 info host.ioBroker_Cubie object system.adapter.sql.0.uptime created
        iobroker 2016-12-21 19:02:12.426 info host.ioBroker_Cubie create instance sql
        iobroker 2016-12-21 19:02:12.251 info host.ioBroker_Cubie object _design/custom created
        iobroker 2016-12-21 19:02:12.182 info host.ioBroker_Cubie object system.adapter.sql created
        iobroker 2016-12-21 19:02:11.672 info upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
        iobroker 2016-12-21 19:02:11.444 info upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
        iobroker 2016-12-21 19:02:11.162 info upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
        iobroker 2016-12-21 19:02:11.122 info got /opt/iobroker/node_modules/iobroker.sql/admin
        iobroker 2016-12-21 19:01:37.459 info ^
        iobroker 2016-12-21 19:01:37.459 info STATEMENT_BEGIN(Reset);
        iobroker 2016-12-21 19:01:37.459 info ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 19:01:37.459 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:37.459 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:37.379 info ^
        iobroker 2016-12-21 19:01:37.379 info STATEMENT_BEGIN(Each);
        iobroker 2016-12-21 19:01:37.379 info ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 19:01:37.379 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:37.379 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:37.305 info ^
        iobroker 2016-12-21 19:01:37.305 info STATEMENT_BEGIN(All);
        iobroker 2016-12-21 19:01:37.305 info ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 19:01:37.305 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:37.305 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:37.219 info ^
        iobroker 2016-12-21 19:01:37.219 info STATEMENT_BEGIN(Run);
        iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 19:01:37.219 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:37.219 info ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
        iobroker 2016-12-21 19:01:37.219 info STATEMENT_BEGIN(Get);
        iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 19:01:37.219 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:37.193 info ^
        iobroker 2016-12-21 19:01:37.193 info STATEMENT_BEGIN(Bind);
        iobroker 2016-12-21 19:01:37.193 info ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 19:01:37.193 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:37.193 info ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:37.193 info In file included from ../src/statement.cc:6:0:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
        iobroker 2016-12-21 19:01:37.132 info ^
        iobroker 2016-12-21 19:01:37.132 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:37.132 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:37.106 info ^
        iobroker 2016-12-21 19:01:37.106 info info.This()->ForceSet(Nan::New('sql').ToLocalChecked(), sql, ReadOnly);
        iobroker 2016-12-21 19:01:37.106 info ../src/statement.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Statement::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/statement.cc:103:74: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
        iobroker 2016-12-21 19:01:07.102 info ^
        iobroker 2016-12-21 19:01:07.102 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:07.102 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:07.060 info ^
        iobroker 2016-12-21 19:01:07.060 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:07.060 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:06.805 info ^
        iobroker 2016-12-21 19:01:06.805 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:06.805 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:06.761 info ^
        iobroker 2016-12-21 19:01:06.761 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 19:01:06.761 info ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 19:01:06.761 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
        iobroker 2016-12-21 19:01:06.761 info ../src/database.cc:134:86: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations] info.This()->ForceSet(Nan::New('mode').ToLocalChecked(), Nan::New(mode), ReadOnly);
        iobroker 2016-12-21 19:01:06.745 info ^
        iobroker 2016-12-21 19:01:06.745 info info.This()->ForceSet(Nan::New('filename').ToLocalChecked(), info[0].As(), ReadOnly);
        iobroker 2016-12-21 19:01:06.745 info ../src/database.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Database::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/database.cc:133:96: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
        iobroker 2016-12-21 18:52:16.538 info ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@6.9.2 (node-v48 ABI) (falling back to source compile with node-gyp)
        iobroker 2016-12-21 18:52:16.527 info node-pre-gyp
        iobroker 2016-12-21 18:50:50.883 info ^
        iobroker 2016-12-21 18:50:50.883 info static sljit_si getput_arg(struct sljit_compiler compiler, sljit_si flags, sljit_si reg, sljit_si arg, sljit_sw argw, sljit_si next_arg, sljit_sw next_argw)
        iobroker 2016-12-21 18:50:50.883 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1019:148: warning: parameter ‘next_argw’ set but not used [-Wunused-but-set-parameter]
        iobroker 2016-12-21 18:50:50.883 info sljit_si tmp_r;
        iobroker 2016-12-21 18:50:50.883 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘getput_arg’:../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1021:11: warning: variable ‘tmp_r’ set but not used [-Wunused-but-set-variable]
        iobroker 2016-12-21 18:50:50.867 info ^
        iobroker 2016-12-21 18:50:50.867 info if (value != INVALID_IMM)
        iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:905:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:897:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_set_delta’:
        iobroker 2016-12-21 18:50:50.867 info if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
        iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:800:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:796:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.867 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:792:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
        iobroker 2016-12-21 18:50:50.833 info ^
        iobroker 2016-12-21 18:50:50.833 info if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
        iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:788:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:784:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.833 info if (dst == arg1 && IS_2_LO_REGS(dst, arg2))
        iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:777:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:765:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:757:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:50:50.833 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:753:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (dst == arg1 && !(flags & SET_FLAGS))
        iobroker 2016-12-21 18:50:50.815 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_op_imm’:
        iobroker 2016-12-21 18:50:50.815 info In file included from ../deps/libmagic/pcre/sljit/sljitLir.c:1333:0, from ../deps/libmagic/pcre/pcre_jit_compile.c:62:
        iobroker 2016-12-21 18:43:46.296 info node-uuid@1.4.7: use uuid module instead
        iobroker 2016-12-21 18:43:46.290 info npm WARN deprecated
        iobroker 2016-12-21 18:42:35.521 info host.ioBroker_Cubie install adapter sqlnpm install --production --prefix '/opt/iobroker/node_modules/iobroker.sql' (System call)
        iobroker 2016-12-21 18:41:27.018 info ^
        iobroker 2016-12-21 18:41:27.018 info STATEMENT_BEGIN(Reset);
        iobroker 2016-12-21 18:41:27.018 info ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 18:41:27.018 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:41:27.018 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton
        iobroker 2016-12-21 18:41:26.925 info ^
        iobroker 2016-12-21 18:41:26.925 info STATEMENT_BEGIN(Each);
        iobroker 2016-12-21 18:41:26.925 info ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 18:41:26.925 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:41:26.925 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:41:26.853 info ^
        iobroker 2016-12-21 18:41:26.853 info STATEMENT_BEGIN(All);
        iobroker 2016-12-21 18:41:26.853 info ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 18:41:26.853 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:41:26.853 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:41:26.810 info ^
        iobroker 2016-12-21 18:41:26.810 info STATEMENT_BEGIN(Run);
        iobroker 2016-12-21 18:41:26.810 info ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 18:41:26.810 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:41:26.810 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:41:26.774 info ^
        iobroker 2016-12-21 18:41:26.774 info STATEMENT_BEGIN(Get);
        iobroker 2016-12-21 18:41:26.774 info ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 18:41:26.774 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:41:26.774 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:41:26.752 info ^
        iobroker 2016-12-21 18:41:26.752 info STATEMENT_BEGIN(Bind);
        iobroker 2016-12-21 18:41:26.752 info ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
        iobroker 2016-12-21 18:41:26.752 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:41:26.752 info ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:41:26.752 info In file included from ../src/statement.cc:6:0:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
        iobroker 2016-12-21 18:41:26.699 info ^
        iobroker 2016-12-21 18:41:26.699 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:41:26.699 info ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:41:26.665 info ^
        iobroker 2016-12-21 18:41:26.665 info info.This()->ForceSet(Nan::New('sql').ToLocalChecked(), sql, ReadOnly);
        iobroker 2016-12-21 18:41:26.665 info ../src/statement.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Statement::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/statement.cc:103:74: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
        iobroker 2016-12-21 18:40:56.740 info ^
        iobroker 2016-12-21 18:40:56.740 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:40:56.740 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:40:56.694 info ^
        iobroker 2016-12-21 18:40:56.694 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:40:56.694 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:40:56.424 info ^
        iobroker 2016-12-21 18:40:56.424 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:40:56.424 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:40:56.381 info ^
        iobroker 2016-12-21 18:40:56.381 info int status = uv_queue_work(uv_default_loop(),
        iobroker 2016-12-21 18:40:56.381 info ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
        iobroker 2016-12-21 18:40:56.381 info ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
        iobroker 2016-12-21 18:40:56.381 info ../src/database.cc:134:86: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations] info.This()->ForceSet(Nan::New('mode').ToLocalChecked(), Nan::New(mode), ReadOnly);
        iobroker 2016-12-21 18:40:56.368 info ^
        iobroker 2016-12-21 18:40:56.368 info info.This()->ForceSet(Nan::New('filename').ToLocalChecked(), info[0].As(), ReadOnly);
        iobroker 2016-12-21 18:40:56.368 info ../src/database.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Database::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/database.cc:133:96: warning: ‘bool v8::Object::ForceSet(v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.9.2/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
        iobroker 2016-12-21 18:32:05.398 info Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@6.9.2 (node-v48 ABI) (falling back to source compile with node-gyp)
        iobroker 2016-12-21 18:32:05.379 info ERR!
        iobroker 2016-12-21 18:32:05.368 info node-pre-gyp
        iobroker 2016-12-21 18:30:40.378 info ^
        iobroker 2016-12-21 18:30:40.378 info static sljit_si getput_arg(struct sljit_compiler *compiler, sljit_si flags, sljit_si reg, sljit_si arg, sljit_sw argw, sljit_si next_arg, sljit_sw next_argw)
        iobroker 2016-12-21 18:30:40.378 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1019:148: warning: parameter ‘next_argw’ set but not used [-Wunused-but-set-parameter]
        iobroker 2016-12-21 18:30:40.378 info sljit_si tmp_r;
        iobroker 2016-12-21 18:30:40.378 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘getput_arg’:../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:1021:11: warning: variable ‘tmp_r’ set but not used [-Wunused-but-set-variable]
        iobroker 2016-12-21 18:30:40.346 info ^
        iobroker 2016-12-21 18:30:40.346 info if (value != INVALID_IMM)
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:905:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:897:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_set_delta’:
        iobroker 2016-12-21 18:30:40.346 info if (dst == arg1 && !(flags & KEEP_FLAGS) && IS_2_LO_REGS(dst, arg2))
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:800:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:796:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:792:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:788:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:784:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info if (dst == arg1 && IS_2_LO_REGS(dst, arg2))
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:777:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:765:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:757:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        iobroker 2016-12-21 18:30:40.346 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c:753:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (dst == arg1 && !(flags & SET_FLAGS))
        iobroker 2016-12-21 18:30:40.256 info ../deps/libmagic/pcre/sljit/sljitNativeARM_Thumb2.c: In function ‘emit_op_imm’:
        iobroker 2016-12-21 18:30:40.256 info In file included from ../deps/libmagic/pcre/sljit/sljitLir.c:1333:0, from ../deps/libmagic/pcre/pcre_jit_compile.c:62:
        …und natürlich rückwärts.
        Weiterhin habe ich nichts vorher auf den neuesten Stand gebracht, vielleicht ist das aber von Vorteil:
        Controller: 0.13.2
        Admin: 1.6.7
        Cubietruck mit Ambian auf jessie mit Kernel 4.8.4
          ` > ____ _ _ _ _
        > / ___| _| |__ (_) ___| |_ _ __ _ _ ___| | __
        > | | | | | | '_ \| |/ _ \ __| '__| | | |/ __| |/ /
        > | |__| |_| | |_) | | __/ |_| | | |_| | (__| <
        > \____\__,_|_.__/|_|\___|\__|_| \__,_|\___|_|\_\
        > Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.8.4-sunxi
        > System load: 0.13 Up time: 16 days
        > Memory usage: 27 % of 2006Mb IP: 192.168.xxx.yyy
        > CPU temp: 38°C HDD temp: 40°C
        > Usage of /: 14% of 15G `
        • apollon77A Online
          apollon77A Online
          Hey Rainer,
          Danke!!!
          Also das mit der mmageic fürchte liegt an deinem 64bit ARM Ding … kannst versucen manuell (siehe ein Post von mir oben) "libmagic1" per apg-get install zu installieren, danach tuts vielleicht.
          Aber das es dem cubie geht ist schonmal cool. Ja da kommen eine melnge warnungen - scheinbar nicht ganz sauber programmiert, sind aber nur Warnungen.
          Jetzt müssen die anderen mal was sagen!
            @apollon77:
            "libmagic1" per apg-get install zu installieren, `
            libmagic1 heisst das Teil????
            ohne 1 hatte ich nichts installieren können, deswegen der Versuch über npm :(
            @apollon77:
            Aber das es dem cubie geht ist schonmal cool. Ja da kommen eine melnge warnungen - scheinbar nicht ganz sauber programmiert, sind aber nur Warnungen. ` eben, irgendwelche 404 dann geht er zum build und alles ist gut
            läuft auch und ich könnte Datenpunkte dafür aktivieren, aber ohne SQL(ite) ergibt das keinen Sinn.
            Ich könnte höchstens noch auf dem NUC testen, da ist auch natives Debian Jessie drauf und ich glaube auch sql.
            Merke gerade der NUC ist tot 😢 😢 😢
            • apollon77A Online
              apollon77A Online
              Ich denke sqlite ist drauf!
              Der versucht zuerst ein fertig kompiliertes Paket von SQLite runterzuladen für dein system. 404 heisst das er es nicht gefunden hat. Dann sagt er sich "Mist, naja dann kompilier ichs halt selber" und dann kommen die ganzen Compiler-Warnungen.
              AM Ende stand bei DIr ja "SQLite connected" … also das sollte geklappt haben!
                @apollon77:
                AM Ende stand bei DIr ja "SQLite connected" `
                Das hatte mich ja irritiert, aber wenn das sqlite bei armbian drauf ist (oder ich hatte es mal selber draufgespielt, oder….
                Ist ja gut.
                Mein NUC sagt nichts mehr 😢
                er ist noch warm, der Speicher auch, und im innern leuchtet etwas grün.
                Kein Bild, kein BIOS, keine Festplattenzugriffe.....
                Kennt sich da jemand aus??
                NUC5PPYH
                Jede Hilfe dankend angenommen
                • apollon77A Online
                  apollon77A Online
                  Hallo an die anderen User mit Problemen … hbt Ihr weitere Details? Sonnst kann ich Euch nicht helfen!
                  • R Offline
                    RizoliBS
                    @apollon77:
                    Hallo an die anderen User mit Problemen … hbt Ihr weitere Details? Sonnst kann ich Euch nicht helfen! `
                    Hallo Apollon77,
                    frohe Weihnachten vorab.
                    Auf meinem Windows-System will das SQL-History Adapter leider noch nicht.
                    Welche Daten benötigst Du?
                    Danke & schöne Feiertage
                    Sven aka RizoliBS
                    • apollon77A Online
                      apollon77A Online
                      Hey Sven,
                      siehe http://forum.iobroker.net/viewtopic.php … 508#p43698
                      • F Offline
                        Fitti
                        @apollon77:
                        Habe IOB auf Synology DS716+II drauf. Bei mir auch nach Update von 1.3x auf 1.4 SQl "halb" Probleme 😢
                        Während des Updates kamen viele Meldungen (konnte sie leider nicht sichern). Update via WebGUI angestoßen.
                        => In den Instanzen war noch SQL.0 da, bei den Adaptern weg (kein 1/1 Anzeige). Kann aber SQL.0 nicht starten, wird rot und fällt dann wieder runter.
                        Dann noch mal in "Adapter" neu installiert. Es kam dann ein SQL.1 dazu.
                        Wenn ich dann eine Instanz starten möchte, kommen die Fehlermeldungen aus dem Log weiter unten.
                        g++ -v oder gcc - v gibt es nicht. Hatte auch ein 'find' darauf gemacht.
                        Habe auch noch die npm-debug.log beigepackt.
                        Kann ich irgendwie die alte Version wieder installieren?
                        Bis dahin,
                        Fitti
                        Meine IOB Logfiles:
                        ! WORKNAS3 2016-12-26 14:15:21.479 error host.WORKNAS3 Cannot download adapter 'sql'. To restart it disable/enable it or restart host.
                        ! WORKNAS3 2016-12-26 14:15:21.479 info iobroker exit 25
                        ! WORKNAS3 2016-12-26 14:15:21.466 error iobroker host.WORKNAS3 Cannot install iobroker.sql: 1
                        ! WORKNAS3 2016-12-26 14:15:21.430 info iobroker /volume1/npm-debug.log
                        ! WORKNAS3 2016-12-26 14:15:21.430 info iobroker npm ERR!
                        ! WORKNAS3 2016-12-26 14:15:21.430 info iobroker npm ERR! Please include the following file with any support request:
                        ! WORKNAS3 2016-12-26 14:15:21.429 info iobroker
                        ! WORKNAS3 2016-12-26 14:15:18.573 info iobroker node-gyp rebuildnpm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs mmmagic npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls mmmagic npm ERR! There is likely additional logging output above.
                        ! WORKNAS3 2016-12-26 14:15:18.571 info iobroker Tell the author that this fails on your system:npm ERR!
                        ! WORKNAS3 2016-12-26 14:15:18.563 info iobroker ERR! mmmagic@0.4.5 install: node-gyp rebuildnpm ERR! Exit status 1 npm ERR! npm ERR! Failed at the mmmagic@0.4.5 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the mmmagic package, npm ERR! not with npm itself. npm ERR!
                        ! WORKNAS3 2016-12-26 14:15:18.559 info iobroker ELIFECYCLE npm
                        ! WORKNAS3 2016-12-26 14:15:18.559 info iobroker npm ERR! npm v2.15.0npm ERR! code
                        ! WORKNAS3 2016-12-26 14:15:18.559 info iobroker '/volume1/@appstore/Node.js_v4/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'iobroker.sql' '–production' '--prefix' '/volume1/iobroker'npm ERR! node v4.4.2
                        ! WORKNAS3 2016-12-26 14:15:18.559 info iobroker ERR! Linux 3.10.77npm ERR! argv
                        ! WORKNAS3 2016-12-26 14:15:18.557 info iobroker
                        ! WORKNAS3 2016-12-26 14:15:18.552 info iobroker npm
                        ! WORKNAS3 2016-12-26 14:15:13.438 info iobroker ERR! not ok
                        ! WORKNAS3 2016-12-26 14:15:13.437 info iobroker
                        ! WORKNAS3 2016-12-26 14:15:13.437 info iobroker gyp
                        ! WORKNAS3 2016-12-26 14:15:13.437 info iobroker v3.3.1
                        ! WORKNAS3 2016-12-26 14:15:13.436 info iobroker node-gyp -v
                        ! WORKNAS3 2016-12-26 14:15:13.436 info iobroker ERR!
                        ! WORKNAS3 2016-12-26 14:15:13.436 info iobroker gyp
                        ! WORKNAS3 2016-12-26 14:15:13.436 info iobroker cwd /volume1/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagicgyp ERR! node -v v4.4.2
                        ! WORKNAS3 2016-12-26 14:15:13.435 info iobroker gyp ERR! System Linux 3.10.77gyp ERR! command '/volume1/@appstore/Node.js_v4/usr/local/bin/node' '/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild' gyp ERR!
                        ! WORKNAS3 2016-12-26 14:15:13.426 info iobroker stack at FSReqWrap.oncomplete (fs.js:82:15)
                        ! WORKNAS3 2016-12-26 14:15:13.426 info iobroker ERR!
                        ! WORKNAS3 2016-12-26 14:15:13.426 info iobroker gyp
                        ! WORKNAS3 2016-12-26 14:15:13.426 info iobroker at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                        ! WORKNAS3 2016-12-26 14:15:13.426 info iobroker ERR! stack
                        ! WORKNAS3 2016-12-26 14:15:13.425 info iobroker gyp
                        ! WORKNAS3 2016-12-26 14:15:13.424 info iobroker stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                        ! WORKNAS3 2016-12-26 14:15:13.424 info iobroker ERR!
                        ! WORKNAS3 2016-12-26 14:15:13.423 info iobroker at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16gyp
                        ! WORKNAS3 2016-12-26 14:15:13.423 info iobroker ERR! stack
                        ! WORKNAS3 2016-12-26 14:15:13.423 info iobroker gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp
                        ! WORKNAS3 2016-12-26 14:15:13.413 info iobroker stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
                        ! WORKNAS3 2016-12-26 14:15:13.412 info iobroker ERR!
                        ! WORKNAS3 2016-12-26 14:15:13.412 info iobroker gyp
                        ! WORKNAS3 2016-12-26 14:15:13.412 info iobroker stack Error: not found: make
                        ! WORKNAS3 2016-12-26 14:15:13.411 info iobroker ERR!
                        ! WORKNAS3 2016-12-26 14:15:13.411 info iobroker gyp
                        ! WORKNAS3 2016-12-26 14:15:13.403 info iobroker ERR! build error
                        ! WORKNAS3 2016-12-26 14:15:13.398 info iobroker gyp
                        ! fritzbox.0 2016-12-26 14:15:10.410 info fritzbox.0 data from 192.168.1.199: 26.12.16 14:15:10;CONNECT;1;11;03603813750;
                        ! fritzbox.0 2016-12-26 14:15:05.316 info fritzbox.0 data from 192.168.1.199: 26.12.16 14:15:05;CALL;1;11;80154;03603813750;SIP0;
                        ! tankerkoenig.0 2016-12-26 14:15:02.259 info tankerkoenig.0 objects written
                        ! tankerkoenig.0 2016-12-26 14:15:02.258 info tankerkoenig.0 starting. Version 1.0.0 in /volume1/iobroker/node_modules/iobroker.tankerkoenig, node: v4.4.2
                        ! WORKNAS3 2016-12-26 14:15:00.823 info host.WORKNAS3 instance system.adapter.tankerkoenig.0 started with pid 13853
                        ! WORKNAS3 2016-12-26 14:14:58.669 info iobroker WARN deprecated node-uuid@1.4.7: use uuid module instead
                        ! WORKNAS3 2016-12-26 14:14:58.665 info iobroker npm
                        ! WORKNAS3 2016-12-26 14:14:52.561 info iobroker npm install iobroker.sql --production --prefix '/volume1/iobroker' (System call)
                        ! WORKNAS3 2016-12-26 14:14:51.372 info iobroker install sql
                        ! WORKNAS3 2016-12-26 14:14:51.370 warn host.WORKNAS3 startInstance cannot find start file for adapter 'sql'. Try to install it... 3 attempt
                        ! WORKNAS3 2016-12-26 14:14:51.357 info iobroker exit 25
                        ! WORKNAS3 2016-12-26 14:14:51.349 error iobroker host.WORKNAS3 Cannot install iobroker.sql: 1
                        ! WORKNAS3 2016-12-26 14:14:51.308 info iobroker npm ERR! /volume1/npm-debug.log
                        ! WORKNAS3 2016-12-26 14:14:51.308 info iobroker ERR! Please include the following file with any support request:
                        ! WORKNAS3 2016-12-26 14:14:51.306 info iobroker
                        ! WORKNAS3 2016-12-26 14:14:51.303 info iobroker npm
                        ! WORKNAS3 2016-12-26 14:14:51.300 info iobroker
                        ! WORKNAS3 2016-12-26 14:14:48.603 info iobroker ERR! There is likely additional logging output above.
                        ! WORKNAS3 2016-12-26 14:14:48.601 info iobroker ERR! Tell the author that this fails on your system:npm ERR! node-gyp rebuild npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs mmmagic npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls mmmagic npm
                        ! WORKNAS3 2016-12-26 14:14:48.592 info iobroker npm ERR! Failed at the mmmagic@0.4.5 install script 'node-gyp rebuild'.npm ERR! This is most likely a problem with the mmmagic package, npm ERR! not with npm itself. npm
                        ! WORKNAS3 2016-12-26 14:14:48.591 info iobroker npm v2.15.0npm ERR! code ELIFECYCLE npm ERR! mmmagic@0.4.5 install: node-gyp rebuild npm ERR! Exit status 1 npm ERR!
                        ! WORKNAS3 2016-12-26 14:14:48.588 info iobroker v4.4.2npm ERR!
                        ! WORKNAS3 2016-12-26 14:14:48.588 info iobroker argv '/volume1/@appstore/Node.js_v4/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'iobroker.sql' '--production' '--prefix' '/volume1/iobroker'npm ERR! node
                        ! WORKNAS3 2016-12-26 14:14:48.587 info iobroker ERR!
                        ! WORKNAS3 2016-12-26 14:14:48.587 info iobroker ERR! Linux 3.10.77npm
                        ! WORKNAS3 2016-12-26 14:14:48.583 info iobroker npm
                        ! WORKNAS3 2016-12-26 14:14:43.100 info iobroker gyp ERR! command '/volume1/@appstore/Node.js_v4/usr/local/bin/node' '/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagic gyp ERR! node -v v4.4.2 gyp ERR! node-gyp -v v3.3.1 gyp ERR! not ok
                        ! WORKNAS3 2016-12-26 14:14:43.098 info iobroker gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16 gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5 gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15) gyp ERR! System Linux 3.10.77
                        ! WORKNAS3 2016-12-26 14:14:43.096 info iobroker gyp ERR! stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
                        ! WORKNAS3 2016-12-26 14:14:43.092 info iobroker gyp ERR! stack Error: not found: make
                        ! WORKNAS3 2016-12-26 14:14:43.090 info iobroker ERR! build error
                        ! WORKNAS3 2016-12-26 14:14:43.084 info iobroker gyp
                        ! WORKNAS3 2016-12-26 14:14:28.682 info iobroker WARN deprecated node-uuid@1.4.7: use uuid module instead
                        ! WORKNAS3 2016-12-26 14:14:28.678 info iobroker npm
                        ! WORKNAS3 2016-12-26 14:14:22.697 info iobroker npm install iobroker.sql --production --prefix '/volume1/iobroker' (System call)
                        ! WORKNAS3 2016-12-26 14:14:21.505 info iobroker install sql
                        ! WORKNAS3 2016-12-26 14:14:21.504 warn host.WORKNAS3 startInstance cannot find start file for adapter 'sql'. Try to install it... 2 attempt
                        ! WORKNAS3 2016-12-26 14:14:21.488 info iobroker exit 25
                        ! WORKNAS3 2016-12-26 14:14:21.476 error iobroker host.WORKNAS3 Cannot install iobroker.sql: 1
                        ! WORKNAS3 2016-12-26 14:14:21.447 info iobroker npm ERR! Please include the following file with any support request:npm ERR! /volume1/npm-debug.log
                        ! WORKNAS3 2016-12-26 14:14:18.781 info iobroker npm ERR! npm ERR! Failed at the mmmagic@0.4.5 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the mmmagic package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node-gyp rebuild npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs mmmagic npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls mmmagic npm ERR! There is likely additional logging output above.
                        ! WORKNAS3 2016-12-26 14:14:18.774 info iobroker mmmagic@0.4.5 install: node-gyp rebuildnpm ERR! Exit status 1
                        ! WORKNAS3 2016-12-26 14:14:18.769 info iobroker code ELIFECYCLE npm ERR!
                        ! WORKNAS3 2016-12-26 14:14:18.766 info iobroker ERR! npm v2.15.0npm ERR!
                        ! WORKNAS3 2016-12-26 14:14:18.766 info iobroker node v4.4.2npm
                        ! WORKNAS3 2016-12-26 14:14:18.766 info iobroker npm ERR!
                        ! WORKNAS3 2016-12-26 14:14:18.766 info iobroker '/volume1/@appstore/Node.js_v4/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'iobroker.sql' '--production' '--prefix' '/volume1/iobroker'
                        ! WORKNAS3 2016-12-26 14:14:18.765 info iobroker npm ERR! argv
                        ! WORKNAS3 2016-12-26 14:14:18.765 info iobroker ERR! Linux 3.10.77
                        ! iobroker 2016-12-26 14:14:13.560 info gyp ERR! not ok
                        ! iobroker 2016-12-26 14:14:13.560 info node -v v4.4.2gyp ERR! node-gyp -v v3.3.1
                        ! iobroker 2016-12-26 14:14:13.553 info
                        ! iobroker 2016-12-26 14:14:13.553 info ERR!
                        ! iobroker 2016-12-26 14:14:13.552 info gyp
                        ! iobroker 2016-12-26 14:14:13.552 info cwd /volume1/iobroker/node_modules/iobroker.sql/node_modules/sql-client/node_modules/inote-util/node_modules/mmmagic
                        ! iobroker 2016-12-26 14:14:13.551 info ERR!
                        ! iobroker 2016-12-26 14:14:13.551 info gyp
                        ! iobroker 2016-12-26 14:14:13.550 info command '/volume1/@appstore/Node.js_v4/usr/local/bin/node' '/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'
                        ! iobroker 2016-12-26 14:14:13.550 info gyp ERR!
                        ! iobroker 2016-12-26 14:14:13.548 info gyp ERR! System Linux 3.10.77
                        ! iobroker 2016-12-26 14:14:13.546 info stack at FSReqWrap.oncomplete (fs.js:82:15)
                        ! iobroker 2016-12-26 14:14:13.545 info ERR!
                        ! iobroker 2016-12-26 14:14:13.545 info stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp
                        ! iobroker 2016-12-26 14:14:13.544 info ERR!
                        ! iobroker 2016-12-26 14:14:13.543 info gyp
                        ! iobroker 2016-12-26 14:14:13.543 info at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                        ! iobroker 2016-12-26 14:14:13.542 info ERR! stack
                        ! iobroker 2016-12-26 14:14:13.540 info gyp
                        ! iobroker 2016-12-26 14:14:13.540 info gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
                        ! iobroker 2016-12-26 14:14:13.534 info at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
                        ! iobroker 2016-12-26 14:14:13.534 info ERR! stack
                        ! iobroker 2016-12-26 14:14:13.533 info gyp
                        ! iobroker 2016-12-26 14:14:13.532 info stack Error: not found: make
                        ! iobroker 2016-12-26 14:14:13.531 info ERR!
                        ! iobroker 2016-12-26 14:14:13.531 info gyp
                        ! iobroker 2016-12-26 14:14:13.529 info
                        ! iobroker 2016-12-26 14:14:13.523 info build error
                        ! iobroker 2016-12-26 14:14:13.522 info ERR!
                        ! iobroker 2016-12-26 14:14:13.521 info
                        ! iobroker 2016-12-26 14:14:13.518 info gyp
                        ! iobroker 2016-12-26 14:13:58.762 info WARN deprecated node-uuid@1.4.7: use uuid module instead
                        ! iobroker 2016-12-26 14:13:58.760 info
                        ! iobroker 2016-12-26 14:13:58.757 info npm
                        ! iobroker 2016-12-26 14:13:51.877 info npm install iobroker.sql --production --prefix '/volume1/iobroker' (System call)
                        ! host.WORKNAS3 2016-12-26 14:13:51.873 info 'system.adapter.sql.0' disabled
                        ! host.WORKNAS3 2016-12-26 14:13:51.872 info object change system.adapter.sql.0
                        ! iobroker 2016-12-26 14:13:51.839 info host.WORKNAS3 Adapter 'system.adapter.sql.0' is stopped.
                        ! iobroker 2016-12-26 14:13:50.641 info install sql
                        ! host.WORKNAS3 2016-12-26 14:13:50.640 warn startInstance cannot find start file for adapter 'sql'. Try to install it... 1 attempt
                        ! host.WORKNAS3 2016-12-26 14:13:50.637 info 'system.adapter.sql.0' enabled
                        ! host.WORKNAS3 2016-12-26 14:13:50.636 info object change system.adapter.sql.0
                        ! host.WORKNAS3 2016-12-26 14:13:31.202 info instance system.adapter.solarwetter.0 terminated with code 0 (OK)
                        578_npm-debug.zip
                        "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
                        Plural von Status ist auch Status!
                        • apollon77A Online
                          apollon77A Online
                          "make not found" … das sagt am Ende das keinerlei Build-Tools da sind und das geht dann hier schieff.
                          Ältere Versionen installieren geht mit neuerm js-controller und neuestem Adamin, da ist in der Adapterzeile ganz hinten die Spalte "Installieren" wo du eine Version auswählen kannst.
                          • apollon77A Online
                            apollon77A Online
                            Also ich habe in der neuen v1.4.1 die sql-client Library wieder auf die alte Version zurückgesetzt, Problem sollte damit gefixt sein.
                            Bitte testen!!
                            Ingo F
                            • F Offline
                              Fitti
                              Jup. Es gibt keine Build Tools hier. Hatte versucht mir ipkg auf Synology nachzuinstallieren um build-tools rauf zu bekommen, gibt ja unzählige Anleitungen dazu, war aber ein ganz ganz dumme Idee.
                              Kurzfristig war doch in der Tat der gesamte iobroker Ordner einfach weg.
                              Lösung war hier, das der Ordner auf einen anderen Bereich gemountet wurde. Ich hatte dann ein dismount /dev/volume1 durchgeführt und der Ordner war wieder da.
                              Sorgte für nette Momente - da das Backup auch nicht lief.
                              Hat aber nichts mit iobroker zu tun, sondern mit dem Skripten für ipkg. Und ja - ich hatte das richtige Installskript für meinen Prozessor genommen. Ist aber noch "untestet".
                              @apollon77:
                              Bitte testen!!
                              Ingo F `
                              Test erfolgreich :D Danke!
                              Muste den Adapte noch einmal installieren und hatte dann SQL.0, .1 und .2 drauf. .1 und .2 einfach gelöscht. Alles läuft.
                              So long,
                              Fitti
                                akamia
                                Ist bei mir gefixt. Danke.
                                NUC6i3 / ProxMox / HM/FHEM/WifiLight/HUE/Tradfri/KM200/InfluxDB/RFlink/Plex/Smartmeter
                                piVCCU, Arduinos, X4000, Z2000, Solo4K, SAMSUNG C & H, NAS OMV4/Win10Pro (JRMC/JRemote), 4x4 HDMImatrix, ...
                                • etvE Offline
                                  etvE Offline
                                  etv
                                  @apollon77:
                                  Bitte testen!!
                                  Ingo F `
                                  Servus Ingo,
                                  sorry für die lange Wartezeit…war rund um die Feiertage unterwegs.
                                  Ja, bei mir ist ioBroker auf einer Synology Diskstation drauf und da kann man wie oben schon von Fitti gesagt nicht ganz so ran wie auf einem eigenen Unix System.
                                  Mit deiner neuen Version 1.4.1 funzt der Update ohne Probleme und SQL-History tut wieder seinen Dienst - herzlichen Dank!!!
                                  Liebe Grüße
                                  tom
                                  …ist schon sehr lange begeisterter ioBroker Nutzer! 1x zu Hause und 1x auf der Alm. ioBroker ist das 'Hirn' des Smarthome und steuert HomeMatic und Shellys, loggt was so passiert, zeigt es auf Tabletts schön an und ermöglicht mir via Cloud Adapter den Fernzugriff...
                                  • apollon77A Online
                                    apollon77A Online
                                    Super das es wieder tut.
                                    Es wird halt für "Nicht aktuelle Systeme" zunehmend schwieriger werden weil viele Node-Libraries halt auf die "üblichen Systeme" ausgerichtet sind und ggf. damit einige der neueren Adapter Probleme machen werden …
                                    Also vllt für die Zukunft langsam Alternativen entwickeln ;-)
                                    • etvE Offline
                                      etvE Offline
                                      etv
                                      @apollon77:
                                      …Also vllt für die Zukunft langsam Alternativen entwickeln ;-) `
                                      …tut mir das nicht an - seit ioBroker auf der Syno rennt, hab ich eigentlich keine Brösel mehr ;)
                                      am Raspi waren von Memoryproblemen angefangen bis zu den berühmten SD-Card Fehlern alles dabei :D
                                      Liebe Grüße
                                      tom
                                      • apollon77A Online
                                        apollon77A Online
                                        @etv:
                                        …tut mir das nicht an `
                                        Also Absichtlich wird das keiner tun … Aber so wie es einige ioBroker-Adapter gibt die erst ab node 4.x laufen und die 0.10/0.12 ausschliessen weil Sie bestimmte Features verwenden die es vorher nicht gab wird das schleichend weitergehen.
                                        Ich denke das Du jetzt schon mit dem radar-Adapter, oder vllt modbus o.ä. heute schon Probleme auf deiner Synology haben wirst Sie ans laufen zu bekommen.
                                        Wenn es jetzt für den SQL-Adapter z.B. eine coole neue Feature-Idee gibt die DB-Transaktionen braucht, dann ist das jetzt zurückgenommene Library-Upgrade nötig und dann bleibst Du auf der Strecke weil dein System keinen C++11-Kompatiblen Compiler hat.
                                        Klar gehen dann ggf die alten Versionen auch noch,m aber Bugfixes sind da schwierig.
                                        Oder jemand baut nen coolen neuen Adapter den Du gern nutzen willst, aber verwendet halt (siehe oben) Sprachfeatures oder wieder abhängigge Libraries die bei dir nicht gehen ...
                                        Der "Druck" wird nicht absichtlich kommen, sondern sich einschleichen ... fürchte ich
                                        • etvE Offline
                                          etvE Offline
                                          etv
                                          @apollon77:
                                          …Also Absichtlich wird das keiner tun ... `
                                          …ja eh klar.. :D
                                          Wenn es denn eine g'scheite Hartware Alternative geben würde, aber alles unter 2 Gig RAM ist mal für meine Installation leider sinnlos. Ich hatte früher zwei Raspis als Multihost System am Laufen um alles irgendwie unter zu bekommen. Das ist einigermaßen gelaufen, aber wie gesagt immer wieder mit diversen Problemen. Wie ich dann von der Synology Möglichkeit gelesen hab, hab ich es da drauf installiert und da läuft's nun.....
                                          Naja - ich werd' mal im Netz suchen - hier im Forum ist ja auch das eine oder andere Board diskutiert....aber jedes Board mit schon bekannten Nachteilen :(
                                          Ein kleiner Windows-PC wär' noch einen Alternative wie z.B: der da https://www.amazon.de/Mini-PC-lautlose- ... B01LT46CVG
