  3. Off Topic
  4. Stundenplan als JSON
    6.3k
6 Beiträge 4 Kommentatoren 828 Aufrufe 5 Beobachtet
    mark77
    Moin,
    mal ne Frage an die (JSON-)Profis:
    Wie könnte ein Schul-Stundenplan im JSON Format aufgebaut werden, damit ich ihn in IoB gut weiterverarbeiten kann.
    Darstellung der ganzen Woche auf z.B. einen 22" Monitor und Datrestellung des aktuellen Tages auf nem 7".
    Highlighten des aktuellen Tages/Blocks...
    Gibt es irgendetwas, was zu beachten wäre?
    So:
    	{ "Day": "Mon" {
    		{	"Block": 1, "TimeStart": "08:00", "TimeEnd":	"09:35", "Class":	"Mathe"	},
    		{	"Block": 2, "TimeStart": "09:55", "TimeEnd":	"10:55", "Class":	"Deutsch"	},
    		{	"Block": 3, "TimeStart": "11:15", "TimeEnd":	"12:00", "Class":	"Musik"	},
    		{	"Block": 4, "TimeStart": "12:20", "TimeEnd":	"13:05", "Class":	"Sachunterricht"	}
    	{ "Day": "Tue" {
    		{	"Block": 1, "TimeStart": "08:00", "TimeEnd":	"09:35", "Class":	"Sachunterricht"	},
    		{	"Block": 2, "TimeStart": "09:55", "TimeEnd":	"10:55", "Class":	"Englisch"	},
    		{	"Block": 3, "TimeStart": "11:15", "TimeEnd":	"12:00", "Class":	"Sport"	},
    		{	"Block": 4, "TimeStart": "12:20", "TimeEnd":	"13:05", "Class":	"Mathe"	}
    oder so:
    		{	"Day": "Mon", "Block": 1, "TimeStart": "08:00", "TimeEnd":	"09:35", "Class":	"Mathe"	},
    		{	"Day": "Mon", "Block": 2, "TimeStart": "09:55", "TimeEnd":	"10:55", "Class":	"Deutsch"	},
    		{	"Day": "Mon", "Block": 3, "TimeStart": "11:15", "TimeEnd":	"12:00", "Class":	"Musik"	},
    		{	"Day": "Mon", "Block": 4, "TimeStart": "12:20", "TimeEnd":	"13:05", "Class":	"Sachunterricht"	},
    		{	"Day": "Mon", "Block": 1, "TimeStart": "08:00", "TimeEnd":	"09:35", "Class":	"Sachunterricht"	},
    		{	"Day": "Mon", "Block": 2, "TimeStart": "09:55", "TimeEnd":	"10:55", "Class":	"Englisch"	},
    		{	"Day": "Mon", "Block": 3, "TimeStart": "11:15", "TimeEnd":	"12:00", "Class":	"Sport"	},
    		{	"Day": "Mon", "Block": 4, "TimeStart": "12:20", "TimeEnd":	"13:05", "Class":	"Mathe"	}
    Gibt es irgendwo Vor-/Nachteile?
    Bin für jeden Tipp dankbar.
    Gruß,
    Mark
    • M mark77
      Moin,
      So:
      	{ "Day": "Mon" {
      	{ "Day": "Tue" {
      oder so:
      Gruß,
      Mark
      M Online
      M Online
      MCU
      @mark77 Kannst du direkt probieren: In einen DP die JSON eintragen und dann in der VIS die JSONtable nutzen.
      Sollte allerdings eine JSON Tabelle sein also->
      [{ "Day": "Mon" {
      	{ "Day": "Tue" {
      • M MCU
        [{ "Day": "Mon" {
        	{ "Day": "Tue" {
        mark77
        @mcu Danke für deine Rückmeldung.
        Leider wird die Tabelle so nicht von Widget dargestellt, gibt es einen Trick?
        Die Variante funktioniert:
        die nicht:
        [{ "Day": "Mon" {
        	{ "Day": "Tue" {
        Gruß,
        Mark
        • M mark77
          die nicht:
          [{ "Day": "Mon" {
          	{ "Day": "Tue" {
          Gruß,
          Mark
          mark77
          Ich werde jetzt einen anderen Weg gehen.
          Ich bastel mir gerade, mit Hilfe der Seite https://codebeautify.org/jsonviewer/ eine für mich sinnvolle Struktur zusammen,
          um dann, per Skript Adapter, ganze Stundenpläne oder Tageweise Ausschnitte zu erhalten.
          Gruß,
          Mark
          • M mark77
            Gruß,
            Mark
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @mark77
            Damit kannst du dir dann aus einer beliebigen Json Datenstrukture eine Anzeige bauen.
            https://forum.iobroker.net/topic/31521/test-widget-json-template?_=1614678327007
            Meine Adapter und Widgets
            Links im Profil
            • OliverIOO OliverIO
              @mark77
              mark77
              @oliverio Danke!
              Das schau ich mir mal an.
