  4. [gelöst] Brauche hilfe json Array verschachtelung zu parsen
    5.6k
blocklyjavascript
24 Beiträge 5 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • F fastfoot
    @newpicsel sagte in Brauche hilfe json Array verschachtelung zu parsen:
    das kann doch nicht wahr sein, ich werde noch bekloppt!
    ich glaube da stimmt was nicht mit Blockly, bin aber nicht ganz sicher. So gehts aber
     <variables>
       <variable id="/vB;1BX-M-`@P2gBXZC;">json</variable>
       <variable id="D_M}auPlg#tJNK56ANMT">ListElem</variable>
       <variable id="9jxj.k~ts;=BDSFxGEzF">homes</variable>
     </variables>
     <block type="variables_set" id="|o?viYz(YZ#CAw+}Z|3K" x="-163" y="-112">
       <field name="VAR" id="/vB;1BX-M-`@P2gBXZC;">json</field>
       <value name="VALUE">
         <block type="convert_json2object" id="aieJ~X.TrK9_At(m$P:.">
             <block type="text" id="9m5.@`_eUqd|i6hWLx.(">
               <field name="TEXT">{"body":{"homes":[{"id":"xy","name":"Home","altitude":8,"coordinates":["xy","xy"],"country":"DE","timezone":"Europe\/Berlin","rooms":[{"id":"xy","name":"Schlafzimmer","type":"bedroom","module_ids":["xy"]},{"id":"xy","name":"Kinderzimmer","type":"custom","module_ids":["xy"]},{"id":"xy","name":"K\u00fcche","type":"kitchen","module_ids":["xy"]},{"id":"xy","name":"Wohnzimmer","type":"custom","module_ids":["xy"]},{"id":"xy","name":"Badezimmer","type":"bathroom","module_ids":["xy"]}],"modules":[{"id":"xy","type":"NAPlug","name":"Relais","setup_date":1512123665,"modules_bridged":["xy","xy","xy","xy","xy"]},{"id":"xy","type":"NRV","name":"K\u00fcche","setup_date":1514020470,"room_id":"xy","bridge":"xy"},{"id":"xy","type":"NRV","name":"Badezimmer","setup_date":1514023382,"room_id":"xy","bridge":"xy"},{"id":"xy","type":"NRV","name":"Kinderzimmer","setup_date":1514032377,"room_id":"xy","bridge":"xy"},{"id":"xy","type":"NRV","name":"Schlafzimmer","setup_date":1512123670,"room_id":"xy","bridge":"xy"},{"id":"xy","type":"NRV","name":"Wohnzimmer","setup_date":1512123670,"room_id":"xy","bridge":"xy"}],"therm_schedules":[{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":3,"m_offset":180},{"zone_id":1,"m_offset":240},{"zone_id":3,"m_offset":300},{"zone_id":9373,"m_offset":360},{"zone_id":0,"m_offset":480},{"zone_id":7690,"m_offset":1200},{"zone_id":6622,"m_offset":1320},{"zone_id":1,"m_offset":1380},{"zone_id":3,"m_offset":1620},{"zone_id":1,"m_offset":1680},{"zone_id":3,"m_offset":1740},{"zone_id":9373,"m_offset":1800},{"zone_id":0,"m_offset":1920},{"zone_id":7690,"m_offset":2640},{"zone_id":6622,"m_offset":2760},{"zone_id":1,"m_offset":2820},{"zone_id":3,"m_offset":3060},{"zone_id":1,"m_offset":3120},{"zone_id":3,"m_offset":3180},{"zone_id":9373,"m_offset":3240},{"zone_id":0,"m_offset":3360},{"zone_id":7690,"m_offset":4080},{"zone_id":6622,"m_offset":4200},{"zone_id":1,"m_offset":4260},{"zone_id":3,"m_offset":4500},{"zone_id":1,"m_offset":4560},{"zone_id":3,"m_offset":4620},{"zone_id":9373,"m_offset":4680},{"zone_id":0,"m_offset":4800},{"zone_id":7690,"m_offset":5520},{"zone_id":6622,"m_offset":5640},{"zone_id":1,"m_offset":5700},{"zone_id":3,"m_offset":5940},{"zone_id":1,"m_offset":6000},{"zone_id":3,"m_offset":6060},{"zone_id":9373,"m_offset":6120},{"zone_id":0,"m_offset":6240},{"zone_id":7690,"m_offset":6960},{"zone_id":6622,"m_offset":7140},{"zone_id":1,"m_offset":7200},{"zone_id":9373,"m_offset":7620},{"zone_id":3,"m_offset":7680},{"zone_id":0,"m_offset":7740},{"zone_id":7690,"m_offset":8400},{"zone_id":6622,"m_offset":8580},{"zone_id":1,"m_offset":8640},{"zone_id":9373,"m_offset":9060},{"zone_id":3,"m_offset":9120},{"zone_id":0,"m_offset":9180},{"zone_id":7690,"m_offset":9840},{"zone_id":6622,"m_offset":9960},{"zone_id":1,"m_offset":10020}],"zones":[{"name":"Komfort","id":0,"type":0,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":18},{"room_id":"xy","temp":20}]},{"name":"Nacht","id":1,"type":1,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":17},{"room_id":"xy","temp":18}]},{"name":"Eco","id":4,"type":5,"rooms_temp":[{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18}]},{"name":"Aufstehen","id":9373,"type":4,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19}]},{"name":"Schlafen","id":6622,"type":4,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19}]},{"name":"Schlarfzimmer Warm","id":7690,"type":4,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19}]},{"name":"Komfort+","id":3,"type":8,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19},{"room_id":"xy","temp":20}]}],"name":"Winter","default":false,"away_temp":16,"hg_temp":7,"id":"xy","selected":true,"type":"therm"},{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":360},{"zone_id":4,"m_offset":480},{"zone_id":0,"m_offset":1020},{"zone_id":1,"m_offset":1320},{"zone_id":0,"m_offset":1800},{"zone_id":4,"m_offset":1920},{"zone_id":0,"m_offset":2460},{"zone_id":1,"m_offset":2760},{"zone_id":0,"m_offset":3240},{"zone_id":4,"m_offset":3360},{"zone_id":0,"m_offset":3900},{"zone_id":1,"m_offset":4200},{"zone_id":0,"m_offset":4680},{"zone_id":4,"m_offset":4800},{"zone_id":0,"m_offset":5340},{"zone_id":1,"m_offset":5640},{"zone_id":0,"m_offset":6120},{"zone_id":4,"m_offset":6240},{"zone_id":3,"m_offset":6660},{"zone_id":0,"m_offset":6960},{"zone_id":1,"m_offset":7140},{"zone_id":0,"m_offset":7620},{"zone_id":3,"m_offset":7740},{"zone_id":0,"m_offset":8400},{"zone_id":1,"m_offset":8580},{"zone_id":0,"m_offset":9060},{"zone_id":3,"m_offset":9180},{"zone_id":0,"m_offset":9840},{"zone_id":1,"m_offset":9960}],"zones":[{"name":"","id":1,"type":1,"rooms_temp":[{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16}]},{"name":"Eco","id":4,"type":5,"rooms_temp":[{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16}]},{"name":"Komfort","id":0,"type":0,"rooms_temp":[{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18}]},{"name":"Komfort+","id":3,"type":8,"rooms_temp":[{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18}]}],"name":"Sommer","default":false,"away_temp":12,"hg_temp":7,"id":"xy","type":"therm"}],"therm_mode":"schedule","therm_setpoint_default_duration":60,"schedules":[{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":3,"m_offset":180},{"zone_id":1,"m_offset":240},{"zone_id":3,"m_offset":300},{"zone_id":9373,"m_offset":360},{"zone_id":0,"m_offset":480},{"zone_id":7690,"m_offset":1200},{"zone_id":6622,"m_offset":1320},{"zone_id":1,"m_offset":1380},{"zone_id":3,"m_offset":1620},{"zone_id":1,"m_offset":1680},{"zone_id":3,"m_offset":1740},{"zone_id":9373,"m_offset":1800},{"zone_id":0,"m_offset":1920},{"zone_id":7690,"m_offset":2640},{"zone_id":6622,"m_offset":2760},{"zone_id":1,"m_offset":2820},{"zone_id":3,"m_offset":3060},{"zone_id":1,"m_offset":3120},{"zone_id":3,"m_offset":3180},{"zone_id":9373,"m_offset":3240},{"zone_id":0,"m_offset":3360},{"zone_id":7690,"m_offset":4080},{"zone_id":6622,"m_offset":4200},{"zone_id":1,"m_offset":4260},{"zone_id":3,"m_offset":4500},{"zone_id":1,"m_offset":4560},{"zone_id":3,"m_offset":4620},{"zone_id":9373,"m_offset":4680},{"zone_id":0,"m_offset":4800},{"zone_id":7690,"m_offset":5520},{"zone_id":6622,"m_offset":5640},{"zone_id":1,"m_offset":5700},{"zone_id":3,"m_offset":5940},{"zone_id":1,"m_offset":6000},{"zone_id":3,"m_offset":6060},{"zone_id":9373,"m_offset":6120},{"zone_id":0,"m_offset":6240},{"zone_id":7690,"m_offset":6960},{"zone_id":6622,"m_offset":7140},{"zone_id":1,"m_offset":7200},{"zone_id":9373,"m_offset":7620},{"zone_id":3,"m_offset":7680},{"zone_id":0,"m_offset":7740},{"zone_id":7690,"m_offset":8400},{"zone_id":6622,"m_offset":8580},{"zone_id":1,"m_offset":8640},{"zone_id":9373,"m_offset":9060},{"zone_id":3,"m_offset":9120},{"zone_id":0,"m_offset":9180},{"zone_id":7690,"m_offset":9840},{"zone_id":6622,"m_offset":9960},{"zone_id":1,"m_offset":10020}],"zones":[{"name":"Komfort","id":0,"type":0,"rooms_temp":[{"room_id":"yx","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":18},{"room_id":"xy","temp":20}],"rooms":[{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":20}]},{"name":"Nacht","id":1,"type":1,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":17},{"room_id":"xy","temp":18}],"rooms":[{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":17},{"id":"xy","therm_setpoint_temperature":18}]},{"name":"Eco","id":4,"type":5,"rooms_temp":[{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18}],"rooms":[{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18}]},{"name":"Aufstehen","id":9373,"type":4,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19}],"rooms":[{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":19}]},{"name":"Schlafen","id":6622,"type":4,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19}],"rooms":[{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20},{"id":"xy","therm_setpoint_temperature":19}]},{"name":"Schlarfzimmer Warm","id":7690,"type":4,"rooms_temp":[{"room_id":"yx","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19}],"rooms":[{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":19}]},{"name":"Komfort+","id":3,"type":8,"rooms_temp":[{"room_id":"xy","temp":19},{"room_id":"xy","temp":20},{"room_id":"xy","temp":19},{"room_id":"xy","temp":19},{"room_id":"xy","temp":20}],"rooms":[{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":19},{"id":"xy","therm_setpoint_temperature":20}]}],"name":"Winter","default":false,"away_temp":16,"hg_temp":7,"id":"xy","selected":true,"type":"therm"},{"timetable":[{"zone_id":1,"m_offset":0},{"zone_id":0,"m_offset":360},{"zone_id":4,"m_offset":480},{"zone_id":0,"m_offset":1020},{"zone_id":1,"m_offset":1320},{"zone_id":0,"m_offset":1800},{"zone_id":4,"m_offset":1920},{"zone_id":0,"m_offset":2460},{"zone_id":1,"m_offset":2760},{"zone_id":0,"m_offset":3240},{"zone_id":4,"m_offset":3360},{"zone_id":0,"m_offset":3900},{"zone_id":1,"m_offset":4200},{"zone_id":0,"m_offset":4680},{"zone_id":4,"m_offset":4800},{"zone_id":0,"m_offset":5340},{"zone_id":1,"m_offset":5640},{"zone_id":0,"m_offset":6120},{"zone_id":4,"m_offset":6240},{"zone_id":3,"m_offset":6660},{"zone_id":0,"m_offset":6960},{"zone_id":1,"m_offset":7140},{"zone_id":0,"m_offset":7620},{"zone_id":3,"m_offset":7740},{"zone_id":0,"m_offset":8400},{"zone_id":1,"m_offset":8580},{"zone_id":0,"m_offset":9060},{"zone_id":3,"m_offset":9180},{"zone_id":0,"m_offset":9840},{"zone_id":1,"m_offset":9960}],"zones":[{"name":"","id":1,"type":1,"rooms_temp":[{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16}],"rooms":[{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16}]},{"name":"Eco","id":4,"type":5,"rooms_temp":[{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16},{"room_id":"xy","temp":16}],"rooms":[{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16},{"id":"xy","therm_setpoint_temperature":16}]},{"name":"Komfort","id":0,"type":0,"rooms_temp":[{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18}],"rooms":[{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18},{"id":"xy","therm_setpoint_temperature":18}]},{"name":"Komfort+","id":3,"type":8,"rooms_temp":[{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18},{"room_id":"xy","temp":18}],"rooms":[{"id":"yx","therm_setpoint_temperature":18},{"id":"yx","therm_setpoint_temperature":18},{"id":"yx","therm_setpoint_temperature":18},{"id":"yx","therm_setpoint_temperature":18},{"id":"yx","therm_setpoint_temperature":18}]}],"name":"Sommer","default":false,"away_temp":12,"hg_temp":7,"id":"xy","type":"therm"}]}],"user":{"email":"xy@web.de","language":"de-DE","locale":"de-DE","feel_like_algorithm":0,"unit_pressure":0,"unit_system":0,"unit_wind":0,"id":"xy"}},"status":"ok","time_exec":0.021591901779174805,"time_server":1611503100}</field>
             </block>
           </value>
         </block>
       </value>
       <next>
         <block type="variables_set" id="v^97j235UN(xelt4A+Q_">
           <field name="VAR" id="D_M}auPlg#tJNK56ANMT">ListElem</field>
             <block type="lists_getIndex" id="D4gT-+2l)bhIbGTnzRFs">
               <mutation statement="false" at="true"></mutation>
               <field name="MODE">GET</field>
               <field name="WHERE">FROM_START</field>
                 <block type="get_attr" id="y}}mHAa68~]}V|^4ConB">
                   <value name="PATH">
                     <shadow type="text" id="x^Lr@5`Kt63:[?*cS*1+">
                       <field name="TEXT">body.homes</field>
                     </shadow>
                   </value>
                   <value name="OBJECT">
                     <block type="variables_get" id="Z:Q/oC),ci+VB|/C_=#e">
                     </block>
                   </value>
                 </block>
               </value>
               <value name="AT">
                 <block type="math_number" id="i,v$65]{,wBqiepB3Y5e">
                   <field name="NUM">1</field>
                 </block>
               </value>
             </block>
           </value>
           <next>
             <block type="debug" id="Z(eB|rR|`AfFhT5}AG0y" inline="true">
               <value name="TEXT">
                 <shadow type="text" id="wI)4cgwH_(t,m8{fgY{4">
                 </shadow>
                 <block type="get_attr" id="l]pga[gC-;TR^3%PvfWZ">
                   <value name="PATH">
                     <shadow type="text" id="D7Awsg^#;YZa4B:@.@C?">
                       <field name="TEXT">name</field>
                     </shadow>
                   </value>
                     <block type="variables_get" id="`MS,$BaS~1d/v3libv/Z">
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="l9u`8W$*CE;MU(=%WCAs">
                   <field name="VAR" id="9jxj.k~ts;=BDSFxGEzF">homes</field>
                     <block type="get_attr" id="|Xu34tHXLM~i*[P_tt*n">
                       <value name="PATH">
                         <shadow type="text" id="8hUTTD8Rv.:}$Cpud$yl">
                           <field name="TEXT">body.homes.0</field>
                         </shadow>
                       </value>
                         <block type="variables_get" id="-Bo!!LxO1=83y!6$F{g_">
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="debug" id="j8`b,;;Zi5R5Ms_6b$8e" inline="true">
                       <value name="TEXT">
                         <shadow type="text" id=";6hQuQHA?LmE{#O;ffa^">
                         </shadow>
                         <block type="get_attr" id="BF_{C9s+tw2skqe.(r9y">
                           <value name="PATH">
                             <shadow type="text" id="t0mkzS?1R+ZUR(6Zv-kc">
                             </shadow>
                           </value>
                             <block type="variables_get" id="2pbvCH0vG;J(MtyZDMiI">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    fastfoot
    @fastfoot sagte in Brauche hilfe json Array verschachtelung zu parsen:
    Also, auch ältere Versionen arbeiten nicht anders, bin bis auf die 4.7.4 zurück. Mich kommt aber body.homes.0 als Attribut seltsam vor. @paul53 was meinst Du dazu? In JS jedenfalls wäre das ungültig, wird in Blockly ja allerdings mit getAttr() gemacht
    NewpicselN 1 Antwort Letzte Antwort
    • F fastfoot
       <variables>
       </variables>
               </block>
             </value>
           </block>
         </value>
         <next>
                     <value name="PATH">
                       </shadow>
                     </value>
                       </block>
                     </value>
                   </block>
                 </value>
                 <value name="AT">
                   </block>
                 </value>
               </block>
             </value>
             <next>
                 <value name="TEXT">
                   </shadow>
                     <value name="PATH">
                       </shadow>
                     </value>
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                         <value name="PATH">
                           </shadow>
                         </value>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                         <value name="TEXT">
                           </shadow>
                             <value name="PATH">
                               </shadow>
                             </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      NewpicselN Offline
      NewpicselN Offline
      Newpicsel
      @fastfoot
      Unglaublich es funktioniert, sobald einmal die array "[]homes" selektiert ist, kannst danach alle werte auslesen!
      vielen Dank!
      dann muss ich nur noch eine liste aus allen id´s von "modules.modules_bridged" erstellen, wie kann ich dann die zugehörigen namen der id´s ermitteln?
      kann ich eine aktion in eine schleife packen, die genau so oft durchläuft wie id´s in der liste sind und jedesmal die variable mit der nächsten id gefüllt wird?
      geht darum, dass die objekte der räume automatisch angelegt werden, die ja bei jedem user anders heißen und unterschiedlich viele sind...
      für mich könnte ich alles manuel anlegen aber es soll ja am besten ohne weiteres für alle anwendbar sein.
              "modules": [
                  "id": "xy",
                  "type": "NAPlug",
                  "name": "Relais",
                  "setup_date": 1512123665,
                  "modules_bridged": [
                    "123","456","789","987","654"
                  "id": "123",
                  "name": "Wohnzimmer",
                  "type": "custom",
                  "module_ids": [
                    "123"
                  "id": "456",
                  "name": "Badezimmer",
                  "type": "bathroom",
                  "module_ids": [
                    "456"
      • F fastfoot
        NewpicselN Offline
        NewpicselN Offline
        Newpicsel
        @fastfoot said in Brauche hilfe json Array verschachtelung zu parsen:
        Also ich hab den schritt body.homes.0 nicht getestet, da ich in der liste "ListElem" auf die werte schon zugreifen kann, ich finds auch seltsam aber ich kenne mich auch nicht damit aus...
        F 2 Antworten Letzte Antwort
        • NewpicselN Newpicsel
          fastfoot
          @newpicsel Auf modules kannst du so zugreifen
            fastfoot
            für ListElem so
            • F fastfoot
              NewpicselN Offline
              NewpicselN Offline
              Newpicsel
              @fastfoot
              Ja stimmt, jetzt wo ich den block gesehen habe, ist es mir auch wieder eingefallen.
              Danke dir und auch den anderen, ich bin fast verzweifelt!
              • NewpicselN Offline
                NewpicselN Offline
                Newpicsel
                @fastfoot
                Abend,
                eine frage habe ich noch, vielleicht kannst du oder jemand helfen?
                Wie kann ich etwas nach einem Wert aus der Liste "modules" filtern?
                Ich möchte zb. nur den block ausgeben, wo "name: "Relais"" enthalten ist.
                So klappt es nicht, wobei wenn ich nach den ersten block frage alles klappt, liegt also nur an dem filter, ich weiß nicht wie der hier aussehen müsste...
                Ich kann nicht sicher sagen ob mein gewünschter Inhalt immer der erste block in der liste ist.
                F 1 Antwort Letzte Antwort
                  @fastfoot
                  Abend,
                  fastfoot
                  @fastfoot
                  Abend,
                  den Filter musst du selbst bauen, indem du bei jedem Durchlauf prüfst und dann die Schleife abbrichst
                  • F fastfoot
                    @fastfoot
                    Abend,
                    NewpicselN Offline
                    NewpicselN Offline
                    Newpicsel
                    schrieb am zuletzt editiert von Newpicsel
                    😑 ok danke
                    kriege ich aber hin 😛
                    hab nur gehofft es fürde auch so gehen...
                    machs-smart.deM 1 Antwort Letzte Antwort
                      😑 ok danke
                      machs-smart.deM Offline
                      machs-smart.de
                      @newpicsel ich habe dazu eine Anleitung geschrieben, vielleicht hilft es dir ja: https://www.machs-smart.de/json-blockly-einlesen-parsen-verarbeiten/
                      www.machs-smart.de
                      Anleitungen und Tutorials rund um ioBroker
