  4. Modbus Adapter, Fehlermeldungen.
    5.6k
5 Beiträge 3 Kommentatoren 1.5k Aufrufe
    ThomasD
    ich habe am Raspberry einen USB RS-485 Adapter, zusätzlich nutze ich den mbusd als Software Gateway.
    Mbusd starte ich mit:
    mbusd -L/tmp/mbusd.log -p /dev/ttyUSB1 -s 1200 -P 502
    Einstellungen modbus Adapter:
    TCP
    127.0.0.1
    502
    Master
    und
    true
    false
    1000
    60000
    5000
    1000
    100
    Die Daten werden aktualisiert, aber trotzdem erhalte ich ständig Fehlermeldungen:
    ` > modbus.0 2016-11-25 20:45:26.106 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:45:26.101 warn Poll error count: 6 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:25.854 warn Poll error count: 5 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:25.520 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:24.541 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:23.623 warn Poll error count: 2 code: 'App Timeout'
    host.zentrale 2016-11-25 20:45:23.415 info 'system.adapter.modbus.0' disabled
    host.zentrale 2016-11-25 20:45:23.414 info object change system.adapter.modbus.0
    modbus.0 2016-11-25 20:45:22.863 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:16.648 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:16.300 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:14.416 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:13.660 warn Poll error count: 1 code: 'App Timeout'
    host.zentrale 2016-11-25 20:45:08.919 info Restart adapter system.adapter.modbus.0 because enabled
    host.zentrale 2016-11-25 20:45:08.918 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    modbus.0 2016-11-25 20:45:07.090 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:05.280 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:05.207 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:45:04.455 warn Poll error count: 1 code: 'App Timeout'
    host.zentrale 2016-11-25 20:45:04.397 info instance system.adapter.modbus.0 started with pid 30214
    mysensors.0 2016-11-25 20:44:57.731 info Time from 192.168.0.243 :
    modbus.0 2016-11-25 20:44:56.071 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:44:55.250 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:44:46.861 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:44:38.987 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:44:35.782 warn Error: {}
    modbus.0 2016-11-25 20:44:35.512 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:44:35.509 warn Poll error count: 10 code: 'App Timeout'
    host.zentrale 2016-11-25 20:44:34.377 info Restart adapter system.adapter.modbus.0 because enabled
    host.zentrale 2016-11-25 20:44:34.376 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    modbus.0 2016-11-25 20:44:33.475 info Connected to slave 127.0.0.1
    modbus.0 2016-11-25 20:44:33.306 info Connected to slave 127.0.0.1
    host.zentrale 2016-11-25 20:44:30.239 info instance system.adapter.modbus.0 started with pid 30176
    mysensors.0 2016-11-25 20:44:27.411 info Time from 192.168.0.243 :
    host.zentrale 2016-11-25 20:44:00.224 info Restart adapter system.adapter.modbus.0 because enabled
    host.zentrale 2016-11-25 20:44:00.223 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    host.zentrale 2016-11-25 20:43:56.034 info instance system.adapter.modbus.0 started with pid 30098
    modbus.0 2016-11-25 20:43:33.624 warn Error: {}
    modbus.0 2016-11-25 20:43:33.472 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:43:33.468 warn Poll error count: 12 code: 'App Timeout'
    modbus.0 2016-11-25 20:43:33.315 warn Error: {}
    modbus.0 2016-11-25 20:43:33.294 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:43:33.291 warn Poll error count: 9 code: 'App Timeout'
    modbus.0 2016-11-25 20:43:31.087 info Connected to slave 127.0.0.1
    modbus.0 2016-11-25 20:43:29.265 info Connected to slave 127.0.0.1
    host.zentrale 2016-11-25 20:43:26.012 info Restart adapter system.adapter.modbus.0 because enabled
    host.zentrale 2016-11-25 20:43:26.010 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    host.zentrale 2016-11-25 20:43:21.641 info instance system.adapter.modbus.0 started with pid 30011
    host.zentrale 2016-11-25 20:42:51.620 info Restart adapter system.adapter.modbus.0 because enabled
    host.zentrale 2016-11-25 20:42:51.619 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    host.zentrale 2016-11-25 20:42:46.985 info instance system.adapter.modbus.0 started with pid 29974
    host.zentrale 2016-11-25 20:42:46.965 info 'system.adapter.modbus.0' enabled
    host.zentrale 2016-11-25 20:42:46.964 info object change system.adapter.modbus.0
    host.zentrale 2016-11-25 20:42:42.561 info object change system.adapter.modbus.0
    modbus.0 2016-11-25 20:42:38.137 warn Poll error count: 11 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:31.947 warn Poll error count: 10 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:31.690 warn Poll error count: 9 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:31.405 warn Error: {}
    modbus.0 2016-11-25 20:42:31.084 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:42:31.083 warn Poll error count: 8 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:30.208 warn Poll error count: 8 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:29.830 warn Error: {}
    modbus.0 2016-11-25 20:42:29.637 warn Poll error count: 7 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:29.257 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:42:29.253 warn Poll error count: 6 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:29.044 warn Poll error count: 5 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:28.931 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:28.874 info Connected to slave 127.0.0.1
    modbus.0 2016-11-25 20:42:23.023 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:22.739 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:22.472 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:20.426 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:20.045 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:19.836 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:13.816 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:13.519 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:13.263 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:11.219 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:10.626 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:04.940 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:04.610 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:04.312 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:04.057 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:42:01.421 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:56.439 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:55.733 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:55.107 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:54.850 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:47.233 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:45.645 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:43.326 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:34.120 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:31.713 warn Poll error count: 7 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:31.667 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:30.366 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:28.877 warn Error: {}
    modbus.0 2016-11-25 20:41:28.867 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:41:28.864 warn Poll error count: 6 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:28.533 warn Poll error count: 5 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:28.508 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:25.659 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:25.325 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:25.305 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:24.912 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:22.120 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:22.103 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:18.914 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:18.899 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:16.571 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:15.757 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:15.695 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:10.592 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:08.133 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:07.389 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:07.362 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:06.548 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:04.185 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:41:00.758 info Connected to slave 127.0.0.1
    modbus.0 2016-11-25 20:40:58.152 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:40:46.159 info Connected to slave 127.0.0.1
    modbus.0 2016-11-25 20:40:03.326 warn Poll error count: 7 code: 'App Timeout'
    modbus.0 2016-11-25 20:40:00.947 warn Error: {}
    modbus.0 2016-11-25 20:40:00.754 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:40:00.751 warn Poll error count: 6 code: 'App Timeout'
    modbus.0 2016-11-25 20:40:00.120 warn Poll error count: 5 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:57.714 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:57.546 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:56.915 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:54.507 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:52.207 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:51.303 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:48.098 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:47.758 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:46.170 warn Error: {}
    modbus.0 2016-11-25 20:39:46.148 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:39:46.146 warn Poll error count: 13 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:44.554 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:39:41.942 info Connected to slave 127.0.0.1
    modbus.0 2016-11-25 20:39:31.037 info Connected to slave 127.0.0.1
    host.zentrale 2016-11-25 20:38:46.442 info Do not restart adapter system.adapter.modbus.0 because disabled or deleted
    host.zentrale 2016-11-25 20:38:46.440 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    modbus.0 2016-11-25 20:38:42.051 warn Error: {}
    modbus.0 2016-11-25 20:38:41.938 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:38:41.936 warn Poll error count: 12 code: 'App Timeout'
    modbus.0 2016-11-25 20:38:37.732 info Connected to slave 127.0.0.1
    modbus.0 2016-11-25 20:38:31.262 warn Error: {}
    modbus.0 2016-11-25 20:38:31.033 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:38:31.029 warn Poll error count: 9 code: 'App Timeout'
    host.zentrale 2016-11-25 20:38:29.222 info Do not restart adapter system.adapter.modbus.0 because disabled or deleted
    host.zentrale 2016-11-25 20:38:29.221 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    modbus.0 2016-11-25 20:38:28.826 info Connected to slave 127.0.0.1
    host.zentrale 2016-11-25 20:38:23.484 info 'system.adapter.modbus.0' disabled
    host.zentrale 2016-11-25 20:38:23.483 info object change system.adapter.modbus.0
    mysensors.0 2016-11-25 20:38:19.570 info Time from 192.168.0.243 :
    host.zentrale 2016-11-25 20:38:12.219 info Restart adapter system.adapter.modbus.0 because enabled
    host.zentrale 2016-11-25 20:38:12.218 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    host.zentrale 2016-11-25 20:38:07.579 info instance system.adapter.modbus.0 started with pid 29466
    host.zentrale 2016-11-25 20:38:07.558 info object change system.adapter.modbus.0
    host.zentrale 2016-11-25 20:37:54.620 info Restart adapter system.adapter.modbus.0 because enabled
    host.zentrale 2016-11-25 20:37:54.619 error instance system.adapter.modbus.0 terminated with code 7 (Adapter already running)
    host.zentrale 2016-11-25 20:37:50.505 info instance system.adapter.modbus.0 started with pid 29447
    modbus.0 2016-11-25 20:37:46.243 warn Poll error count: 11 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:44.030 warn Poll error count: 10 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:43.581 warn Poll error count: 9 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:39.026 warn Poll error count: 8 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:37.989 warn Error: {}
    modbus.0 2016-11-25 20:37:37.758 warn Poll error count: 7 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:37.724 info Disconnected from slave 127.0.0.1
    modbus.0 2016-11-25 20:37:37.721 warn Poll error count: 6 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:37.658 warn Poll error count: 5 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:37.033 warn Poll error count: 4 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:34.822 warn Poll error count: 3 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:34.377 warn Poll error count: 2 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:31.052 warn Poll error count: 1 code: 'App Timeout'
    modbus.0 2016-11-25 20:37:29.189 warn Error: {} `
    Schöne Grüße
    ThomasD
      ThomasD
      ich bin mir noch nicht sicher, ich muss es noch etwas länger beobachte, aber irgend was stimmt nicht mit der Instanz modbus.0.
      Ich habe jetzt eine neue erstellt und diese scheint zu funktionieren.
      Das Merkwürdige die Instanz modbus.0 habe ich komplett entfernt, erhalte aber immer noch Fehlermeldungen.
      ` > modbus.0 2016-11-25 23:12:27.548 warn Poll error count: 2 code: 'App Timeout'
      modbus.0 2016-11-25 23:12:24.344 warn Poll error count: 1 code: 'App Timeout'
      modbus.0 2016-11-25 23:12:19.757 info Connected to slave 127.0.0.1
      modbus.0 2016-11-25 23:12:01.001 warn Error: {}
      modbus.0 2016-11-25 23:12:00.598 info Disconnected from slave 127.0.0.1
      modbus.0 2016-11-25 23:12:00.595 warn Poll error count: 12 code: 'App Timeout'
      modbus.0 2016-11-25 23:11:56.390 info Connected to slave 127.0.0.1 `
      Schöne Grüße
      ThomasD
      • E Offline
        enricoh831
        Hallo Thomas,
        Kannst du mir eine Frage zu mbusd beantworten?
        Ich habe per rtu ein Gerät mit id 2 und drei Holding Register angebunden. Ich kann es auch per Qmodbus ansprechen.
        Aber wie bekomme ich das Gerät in mbusd und dann per TCP in iobroker?
        Gruß Enrico
        Gesendet von meinem LG-D802 mit Tapatalk
        • E Offline
          enricoh831
          So komischerweise geht das jetzt. Hatte es erst nochmal über. Android modbus Monitor versucht und dann nochmal in iobroker.
          Aber wenn ich jetzt noch nen weiteren slave mit einer anderen id abfragen will muss ich ja eine neue Instanz starten die wieder 30mb RAM braucht. Wenn ich 32 slaves hab brauche ich ja ohne Ende RAM.
          Hat da einer noch Ne Idee
          • wendy2702W Offline
            wendy2702W Offline
            könnt ihr mir eventuell bei der Umsetzung mbusd <> iobroker weiterhelfen?
            http://forum.iobroker.net/viewtopic.php … 180#p47820
