  4. Statistics Adapter "[STATE CHANGE] wrong value"
    2.1k
    4.0k
statisticsadapter fehler
4 Beiträge 2 Kommentatoren 604 Aufrufe 1 Beobachtet
  • W Offline
    W Offline
    watcherkb
    Der Statistics Adapter (v 1.0.2) berechnet nicht die Anzahl der sich ändernden States von einem Objekt. Weiß jemand was zu tun ist?
    statistics.0	2021-01-12 16:57:49.883	warn	(26236) [STATE CHANGE] wrong value => false on sonoff.0.Spuelmaschine.POWER => check the other adapter where value comes from
    statistics.0	2021-01-12 16:57:49.883	debug	(26236) [STATE CHANGE] stateChange => false [true]
      "from": "system.adapter.sonoff.0",
      "user": "system.user.admin",
      "ts": 1576948666312,
      "common": {
        "name": "Spuelmaschine POWER",
        "type": "boolean",
        "role": "switch",
        "read": true,
        "write": true,
        "storeMap": true,
        "custom": {
          "influxdb.0": {
            "enabled": true,
            "changesOnly": false,
            "debounce": 0,
            "maxLength": 10,
            "retention": 0,
            "changesRelogInterval": 0,
            "changesMinDelta": 0,
            "storageType": "",
            "aliasId": ""
          "statistics.0": {
            "enabled": true,
            "logName": "Spuelmaschine",
            "count": true,
            "sumCount": false,
            "timeCount": false,
            "fiveMin": false,
            "groupFactor": "",
            "impUnit": "",
            "impUnitPerImpulse": "",
            "sumIgnoreMinus": true,
            "sumDelta": false,
            "avg": false,
            "minmax": false,
            "sumGroup": ""
      "native": {},
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "sonoff.0.Spuelmaschine.POWER",
      "type": "state"
    CC2538+CC2592 PA-Zigbee-Funkmodul
    P 1 Antwort Letzte Antwort
    • W watcherkb
        "common": {
          "type": "boolean",
          "role": "switch",
          "read": true,
          "write": true,
          "storeMap": true,
          "custom": {
            "influxdb.0": {
              "enabled": true,
              "debounce": 0,
              "maxLength": 10,
              "retention": 0,
              "storageType": "",
              "aliasId": ""
            "statistics.0": {
              "enabled": true,
              "count": true,
              "sumCount": false,
              "timeCount": false,
              "fiveMin": false,
              "groupFactor": "",
              "impUnit": "",
              "sumDelta": false,
              "avg": false,
              "minmax": false,
              "sumGroup": ""
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636
        "type": "state"
      pianosenator
      ich habe zwar noch keine Lösung, aber ein ähnliches Problem.
      Ich nutze den adapter, um die On/Off Zeiten eines Heizungsventils zu überwachen.
      Wechsel auf true wird richtig erkannt, beim wechsel auf false bekomme ich eine ähnliche Meldung im Log:
      statistics.0	2021-01-22 14:48:04.866	warn	(2818) [STATE CHANGE] wrong value => false on hm-rpc.xxx.10.STATE => check the other adapter where value comes from
      statistics.0	2021-01-22 14:48:04.865	debug	(2818) [STATE CHANGE] stateChange => false [true]
      Letztes Jahr hat das noch funktioniert. Ist mir eben erst aufgefallen, dass es hakt.
      Sven
      • P pianosenator
        Sven
        pianosenator
        ich habe auch das hier gefunden, scheint als ein mehr oder weniger bekanntes Problem zu sein
        https://github.com/foxthefox/ioBroker.statistics/issues/52
        • P pianosenator
          pianosenator
          Meine Übergangslösung für das Problem: ich habe den Adapter auf Version 0.2.2 zurückgesetzt und werde GitHub ein bisschen im Auge behalten
