  4. Synology-Adapter: unknown error
    6.7k
synology kamerasynology diskstation
16 Beiträge 2 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • A al10b
    @Glasfaser
    Welche Zeiten hast du im Adapter :
    Parameterabrufzeit
    Abfragezeit für zusätzliche Parameter
    Ähh - wo stehen die doch gleich noch mal?
    Hier mal so die ersten 500 Zeilen des Debug-Outputs beim Starten. Bitte beachte: entgegen meiner Behauptung von oben ist doch ein Fehler aufgetreten (Zeilen 472ff).
    synology.0  2021-01-11 15:16:55.610 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:55.609 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:55.609 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:55.608 debug   (16857) InfoSystem - Response: {"hdd_info":[{"capacity":"10000831348736","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"ST10000VN0004-1ZD101 ","order":1,"overvie
    synology.0  2021-01-11 15:16:55.608 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:55.193 debug   (16857) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    synology.0  2021-01-11 15:16:55.193 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    synology.0  2021-01-11 15:16:55.193 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:55.192 debug   (16857) TempInfo - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:16:55 2021","uptime":1566076,"versio
    synology.0  2021-01-11 15:16:55.192 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:55.105 debug   (16857) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:16:55.105 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:16:55.104 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:55.104 debug   (16857) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    synology.0  2021-01-11 15:16:55.103 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:54.926 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    synology.0  2021-01-11 15:16:54.926 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    synology.0  2021-01-11 15:16:54.925 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:54.924 debug   (16857) SystemUtilization - Response: {"cpu":{"15min_load":104,"1min_load":47,"5min_load":67,"device":"System","other_load":3,"system_load":4,"user_load":15},"disk":{"disk":[{"device":"nvme0n1","displ
    synology.0  2021-01-11 15:16:54.923 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:53.724 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    synology.0  2021-01-11 15:16:53.724 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    synology.0  2021-01-11 15:16:53.723 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:53.620 debug   (16857) setObject "DiskStationManager.info.cpu_load"
    synology.0  2021-01-11 15:16:53.618 debug   (16857) setObject "DiskStationManager.info.time"
    synology.0  2021-01-11 15:16:53.617 debug   (16857) setStates
    synology.0  2021-01-11 15:16:53.617 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:53.616 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:53.615 debug   (16857) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    synology.0  2021-01-11 15:16:53.614 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:53.268 debug   (16857) * Get info from (fastPoll) api: FS method: listSharings params: {}
    synology.0  2021-01-11 15:16:53.267 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    synology.0  2021-01-11 15:16:53.266 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:53.266 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:16:53.265 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    synology.0  2021-01-11 15:16:53.264 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:53.262 debug   (16857) listCameras - Response: {"cameras":[{"ADCap":0,"AppList":[],"DINum":0,"DONum":0,"MDCap":21,"MDModeList":[0,1],"PDCap":0,"PDDepend":0,"TDCap":21,"advLiveMinDuration":10,"advLiveProfile":1,"advL
    synology.0  2021-01-11 15:16:53.260 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:53.036 debug   (16857) * Get info from (fastPoll) api: SS method: listCameras params: {"basic":true,"version":7}
    synology.0  2021-01-11 15:16:53.035 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    synology.0  2021-01-11 15:16:53.035 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:53.034 debug   (16857) InfoHomeMode - Response: {"actrule_on":false,"actrules":"-1","cameras":"-1","custom1_det":1,"custom1_di":1,"custom2_det":1,"custom2_di":1,"geo_delay_time":60,"geo_lat":0,"geo_lng":0,"geo_mobil
    synology.0  2021-01-11 15:16:53.032 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:52.853 debug   (16857) * Get info from (fastPoll) api: SS method: getInfoHomeMode params: {"need_mobiles":true}
    synology.0  2021-01-11 15:16:52.852 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    synology.0  2021-01-11 15:16:52.851 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:52.851 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:52.850 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:52.849 debug   (16857) InfoSystem - Response: {"hdd_info":[{"capacity":"10000831348736","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"ST10000VN0004-1ZD101 ","order":1,"overvie
    synology.0  2021-01-11 15:16:52.848 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:52.421 debug   (16857) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    synology.0  2021-01-11 15:16:52.421 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    synology.0  2021-01-11 15:16:52.420 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:52.419 debug   (16857) TempInfo - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:16:52 2021","uptime":1566073,"versio
    synology.0  2021-01-11 15:16:52.418 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:52.336 debug   (16857) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:16:52.335 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:16:52.335 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:52.334 debug   (16857) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    synology.0  2021-01-11 15:16:52.333 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:52.177 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    synology.0  2021-01-11 15:16:52.177 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    synology.0  2021-01-11 15:16:52.176 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:52.175 debug   (16857) SystemUtilization - Response: {"cpu":{"15min_load":104,"1min_load":47,"5min_load":67,"device":"System","other_load":3,"system_load":4,"user_load":15},"disk":{"disk":[{"device":"nvme0n1","displ
    synology.0  2021-01-11 15:16:52.174 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:50.978 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    synology.0  2021-01-11 15:16:50.977 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    synology.0  2021-01-11 15:16:50.976 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:50.875 debug   (16857) setObject "DiskStationManager.info.time"
    synology.0  2021-01-11 15:16:50.874 debug   (16857) setStates
    synology.0  2021-01-11 15:16:50.873 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:50.873 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:50.872 debug   (16857) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    synology.0  2021-01-11 15:16:50.871 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:50.509 debug   (16857) * Get info from (fastPoll) api: FS method: listSharings params: {}
    synology.0  2021-01-11 15:16:50.508 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    synology.0  2021-01-11 15:16:50.508 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:50.507 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:16:50.507 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    synology.0  2021-01-11 15:16:50.506 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:50.505 debug   (16857) listCameras - Response: {"cameras":[{"ADCap":0,"AppList":[],"DINum":0,"DONum":0,"MDCap":21,"MDModeList":[0,1],"PDCap":0,"PDDepend":0,"TDCap":21,"advLiveMinDuration":10,"advLiveProfile":1,"advL
    synology.0  2021-01-11 15:16:50.503 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:50.274 debug   (16857) * Get info from (fastPoll) api: SS method: listCameras params: {"basic":true,"version":7}
    synology.0  2021-01-11 15:16:50.274 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    synology.0  2021-01-11 15:16:50.273 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:50.272 debug   (16857) InfoHomeMode - Response: {"actrule_on":false,"actrules":"-1","cameras":"-1","custom1_det":1,"custom1_di":1,"custom2_det":1,"custom2_di":1,"geo_delay_time":60,"geo_lat":0,"geo_lng":0,"geo_mobil
    synology.0  2021-01-11 15:16:50.270 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:50.118 debug   (16857) * Get info from (fastPoll) api: SS method: getInfoHomeMode params: {"need_mobiles":true}
    synology.0  2021-01-11 15:16:50.117 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    synology.0  2021-01-11 15:16:50.117 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:50.116 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:50.115 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:50.114 debug   (16857) InfoSystem - Response: {"hdd_info":[{"capacity":"10000831348736","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"ST10000VN0004-1ZD101 ","order":1,"overvie
    synology.0  2021-01-11 15:16:50.113 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:49.681 debug   (16857) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    synology.0  2021-01-11 15:16:49.681 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    synology.0  2021-01-11 15:16:49.680 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:49.679 debug   (16857) TempInfo - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:16:49 2021","uptime":1566070,"versio
    synology.0  2021-01-11 15:16:49.678 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:49.588 debug   (16857) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:16:49.588 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:16:49.587 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:49.586 debug   (16857) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    synology.0  2021-01-11 15:16:49.585 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:49.398 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    synology.0  2021-01-11 15:16:49.398 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    synology.0  2021-01-11 15:16:49.397 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:49.396 debug   (16857) SystemUtilization - Response: {"cpu":{"15min_load":105,"1min_load":51,"5min_load":68,"device":"System","other_load":2,"system_load":4,"user_load":14},"disk":{"disk":[{"device":"nvme0n1","displ
    synology.0  2021-01-11 15:16:49.395 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:48.104 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    synology.0  2021-01-11 15:16:48.103 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    synology.0  2021-01-11 15:16:48.102 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:48.000 debug   (16857) setObject "DiskStationManager.info.cpu_load"
    synology.0  2021-01-11 15:16:47.999 debug   (16857) setObject "DiskStationManager.info.time"
    synology.0  2021-01-11 15:16:47.998 debug   (16857) setStates
    synology.0  2021-01-11 15:16:47.997 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:47.997 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:47.996 debug   (16857) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    synology.0  2021-01-11 15:16:47.995 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:47.634 debug   (16857) * Get info from (fastPoll) api: FS method: listSharings params: {}
    synology.0  2021-01-11 15:16:47.634 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    synology.0  2021-01-11 15:16:47.633 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:47.632 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:16:47.632 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    synology.0  2021-01-11 15:16:47.631 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:47.630 debug   (16857) listCameras - Response: {"cameras":[{"ADCap":0,"AppList":[],"DINum":0,"DONum":0,"MDCap":21,"MDModeList":[0,1],"PDCap":0,"PDDepend":0,"TDCap":21,"advLiveMinDuration":10,"advLiveProfile":1,"advL
    synology.0  2021-01-11 15:16:47.628 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:47.404 debug   (16857) * Get info from (fastPoll) api: SS method: listCameras params: {"basic":true,"version":7}
    synology.0  2021-01-11 15:16:47.403 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    synology.0  2021-01-11 15:16:47.403 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:47.401 debug   (16857) InfoHomeMode - Response: {"actrule_on":false,"actrules":"-1","cameras":"-1","custom1_det":1,"custom1_di":1,"custom2_det":1,"custom2_di":1,"geo_delay_time":60,"geo_lat":0,"geo_lng":0,"geo_mobil
    synology.0  2021-01-11 15:16:47.400 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:47.272 debug   (16857) * Get info from (fastPoll) api: SS method: getInfoHomeMode params: {"need_mobiles":true}
    synology.0  2021-01-11 15:16:47.271 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    synology.0  2021-01-11 15:16:47.270 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:47.270 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:47.269 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:47.268 debug   (16857) InfoSystem - Response: {"hdd_info":[{"capacity":"10000831348736","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"ST10000VN0004-1ZD101 ","order":1,"overvie
    synology.0  2021-01-11 15:16:47.267 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:46.840 debug   (16857) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    synology.0  2021-01-11 15:16:46.839 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    synology.0  2021-01-11 15:16:46.839 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:46.838 debug   (16857) TempInfo - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:16:46 2021","uptime":1566067,"versio
    synology.0  2021-01-11 15:16:46.837 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:46.749 debug   (16857) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:16:46.748 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:16:46.748 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:46.747 debug   (16857) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    synology.0  2021-01-11 15:16:46.746 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:46.552 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    synology.0  2021-01-11 15:16:46.552 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    synology.0  2021-01-11 15:16:46.551 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:46.550 debug   (16857) SystemUtilization - Response: {"cpu":{"15min_load":105,"1min_load":51,"5min_load":68,"device":"System","other_load":2,"system_load":4,"user_load":14},"disk":{"disk":[{"device":"nvme0n1","displ
    synology.0  2021-01-11 15:16:46.549 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:45.255 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    synology.0  2021-01-11 15:16:45.254 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    synology.0  2021-01-11 15:16:45.253 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:45.152 debug   (16857) setObject "DiskStationManager.info.time"
    synology.0  2021-01-11 15:16:45.151 debug   (16857) setStates
    synology.0  2021-01-11 15:16:45.150 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:45.150 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:45.149 debug   (16857) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    synology.0  2021-01-11 15:16:45.148 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:44.791 debug   (16857) * Get info from (fastPoll) api: FS method: listSharings params: {}
    synology.0  2021-01-11 15:16:44.791 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    synology.0  2021-01-11 15:16:44.791 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:44.790 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:16:44.790 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    synology.0  2021-01-11 15:16:44.790 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:44.789 debug   (16857) listCameras - Response: {"cameras":[{"ADCap":0,"AppList":[],"DINum":0,"DONum":0,"MDCap":21,"MDModeList":[0,1],"PDCap":0,"PDDepend":0,"TDCap":21,"advLiveMinDuration":10,"advLiveProfile":1,"advL
    synology.0  2021-01-11 15:16:44.788 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:44.567 debug   (16857) * Get info from (fastPoll) api: SS method: listCameras params: {"basic":true,"version":7}
    synology.0  2021-01-11 15:16:44.567 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    synology.0  2021-01-11 15:16:44.567 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:44.566 debug   (16857) InfoHomeMode - Response: {"actrule_on":false,"actrules":"-1","cameras":"-1","custom1_det":1,"custom1_di":1,"custom2_det":1,"custom2_di":1,"geo_delay_time":60,"geo_lat":0,"geo_lng":0,"geo_mobil
    synology.0  2021-01-11 15:16:44.566 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:44.418 debug   (16857) * Get info from (fastPoll) api: SS method: getInfoHomeMode params: {"need_mobiles":true}
    synology.0  2021-01-11 15:16:44.417 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    synology.0  2021-01-11 15:16:44.417 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:44.417 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:44.416 debug   (16857) InfoSystem - Response: {"hdd_info":[{"capacity":"10000831348736","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"ST10000VN0004-1ZD101 ","order":1,"overvie
    synology.0  2021-01-11 15:16:44.415 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:43.990 debug   (16857) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    synology.0  2021-01-11 15:16:43.989 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    synology.0  2021-01-11 15:16:43.989 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:43.988 debug   (16857) TempInfo - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:16:43 2021","uptime":1566064,"versio
    synology.0  2021-01-11 15:16:43.987 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:43.902 debug   (16857) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:16:43.901 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:16:43.901 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:43.900 debug   (16857) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    synology.0  2021-01-11 15:16:43.900 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:43.730 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    synology.0  2021-01-11 15:16:43.729 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    synology.0  2021-01-11 15:16:43.729 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:43.728 debug   (16857) SystemUtilization - Response: {"cpu":{"15min_load":105,"1min_load":55,"5min_load":69,"device":"System","other_load":2,"system_load":3,"user_load":8},"disk":{"disk":[{"device":"nvme0n1","displa
    synology.0  2021-01-11 15:16:43.727 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:42.530 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    synology.0  2021-01-11 15:16:42.530 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    synology.0  2021-01-11 15:16:42.529 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:42.426 debug   (16857) setObject "DiskStationManager.info.cpu_load"
    synology.0  2021-01-11 15:16:42.425 debug   (16857) setObject "DiskStationManager.info.time"
    synology.0  2021-01-11 15:16:42.424 debug   (16857) setStates
    synology.0  2021-01-11 15:16:42.424 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:42.423 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:42.422 debug   (16857) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    synology.0  2021-01-11 15:16:42.421 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:42.066 debug   (16857) * Get info from (fastPoll) api: FS method: listSharings params: {}
    synology.0  2021-01-11 15:16:42.065 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    synology.0  2021-01-11 15:16:42.065 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:42.064 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:16:42.063 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    synology.0  2021-01-11 15:16:42.063 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:42.061 debug   (16857) listCameras - Response: {"cameras":[{"ADCap":0,"AppList":[],"DINum":0,"DONum":0,"MDCap":21,"MDModeList":[0,1],"PDCap":0,"PDDepend":0,"TDCap":21,"advLiveMinDuration":10,"advLiveProfile":1,"advL
    synology.0  2021-01-11 15:16:42.059 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:41.833 debug   (16857) * Get info from (fastPoll) api: SS method: listCameras params: {"basic":true,"version":7}
    synology.0  2021-01-11 15:16:41.833 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    synology.0  2021-01-11 15:16:41.832 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:41.831 debug   (16857) InfoHomeMode - Response: {"actrule_on":false,"actrules":"-1","cameras":"-1","custom1_det":1,"custom1_di":1,"custom2_det":1,"custom2_di":1,"geo_delay_time":60,"geo_lat":0,"geo_lng":0,"geo_mobil
    synology.0  2021-01-11 15:16:41.830 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:41.688 debug   (16857) * Get info from (fastPoll) api: SS method: getInfoHomeMode params: {"need_mobiles":true}
    synology.0  2021-01-11 15:16:41.687 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    synology.0  2021-01-11 15:16:41.686 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:41.686 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:41.685 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:41.684 debug   (16857) InfoSystem - Response: {"hdd_info":[{"capacity":"10000831348736","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"ST10000VN0004-1ZD101 ","order":1,"overvie
    synology.0  2021-01-11 15:16:41.683 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:41.258 debug   (16857) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    synology.0  2021-01-11 15:16:41.257 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    synology.0  2021-01-11 15:16:41.257 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:41.256 debug   (16857) TempInfo - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:16:41 2021","uptime":1566062,"versio
    synology.0  2021-01-11 15:16:41.255 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:41.170 debug   (16857) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:16:41.170 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:16:41.169 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:41.169 debug   (16857) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    synology.0  2021-01-11 15:16:41.168 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:40.983 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    synology.0  2021-01-11 15:16:40.983 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    synology.0  2021-01-11 15:16:40.982 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:40.981 debug   (16857) SystemUtilization - Response: {"cpu":{"15min_load":105,"1min_load":55,"5min_load":69,"device":"System","other_load":2,"system_load":3,"user_load":8},"disk":{"disk":[{"device":"nvme0n1","displa
    synology.0  2021-01-11 15:16:40.980 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:39.684 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    synology.0  2021-01-11 15:16:39.683 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    synology.0  2021-01-11 15:16:39.683 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:39.583 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.linkRtspPath"
    synology.0  2021-01-11 15:16:39.582 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.linkRtspOverHttpPath"
    synology.0  2021-01-11 15:16:39.581 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.linkMxpegHttpPath"
    synology.0  2021-01-11 15:16:39.581 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.linkMulticstPath"
    synology.0  2021-01-11 15:16:39.580 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.linkMjpegHttpPath"
    synology.0  2021-01-11 15:16:39.579 debug   (16857) setObject "FileStation.sharing.list"
    synology.0  2021-01-11 15:16:39.578 debug   (16857) setObject "DiskStationManager.vol_info.volume_1.desc"
    synology.0  2021-01-11 15:16:39.578 debug   (16857) setObject "DiskStationManager.vol_info.volume_1.used"
    synology.0  2021-01-11 15:16:39.569 debug   (16857) setObject "DiskStationManager.vol_info.volume_1.used_size"
    synology.0  2021-01-11 15:16:39.568 debug   (16857) setObject "DiskStationManager.vol_info.volume_1.total_size"
    synology.0  2021-01-11 15:16:39.567 debug   (16857) setObject "DiskStationManager.vol_info.volume_1.status"
    synology.0  2021-01-11 15:16:39.565 debug   (16857) setObject "DiskStationManager.vol_info.volume_1.name"
    synology.0  2021-01-11 15:16:39.564 debug   (16857) setObject "DiskStationManager.hdd_info.drive_4.capacity"
    synology.0  2021-01-11 15:16:39.563 debug   (16857) setObject "DiskStationManager.hdd_info.drive_4.storage_pool"
    synology.0  2021-01-11 15:16:39.562 debug   (16857) setObject "DiskStationManager.hdd_info.drive_4.temperature"
    synology.0  2021-01-11 15:16:39.560 debug   (16857) setObject "DiskStationManager.hdd_info.drive_4.ebox_order"
    synology.0  2021-01-11 15:16:39.559 debug   (16857) setObject "DiskStationManager.hdd_info.drive_4.overview_status"
    synology.0  2021-01-11 15:16:39.558 debug   (16857) setObject "DiskStationManager.hdd_info.drive_4.model"
    synology.0  2021-01-11 15:16:39.557 debug   (16857) setObject "DiskStationManager.hdd_info.drive_4.diskno"
    synology.0  2021-01-11 15:16:39.555 debug   (16857) setObject "DiskStationManager.hdd_info.drive_3.capacity"
    synology.0  2021-01-11 15:16:39.554 debug   (16857) setObject "DiskStationManager.hdd_info.drive_3.storage_pool"
    synology.0  2021-01-11 15:16:39.553 debug   (16857) setObject "DiskStationManager.hdd_info.drive_3.temperature"
    synology.0  2021-01-11 15:16:39.552 debug   (16857) setObject "DiskStationManager.hdd_info.drive_3.ebox_order"
    synology.0  2021-01-11 15:16:39.550 debug   (16857) setObject "DiskStationManager.hdd_info.drive_3.overview_status"
    synology.0  2021-01-11 15:16:39.549 debug   (16857) setObject "DiskStationManager.hdd_info.drive_3.model"
    synology.0  2021-01-11 15:16:39.548 debug   (16857) setObject "DiskStationManager.hdd_info.drive_3.diskno"
    synology.0  2021-01-11 15:16:39.547 debug   (16857) setObject "DiskStationManager.hdd_info.drive_2.capacity"
    synology.0  2021-01-11 15:16:39.545 debug   (16857) setObject "DiskStationManager.hdd_info.drive_2.storage_pool"
    synology.0  2021-01-11 15:16:39.544 debug   (16857) setObject "DiskStationManager.hdd_info.drive_2.temperature"
    synology.0  2021-01-11 15:16:39.543 debug   (16857) setObject "DiskStationManager.hdd_info.drive_2.ebox_order"
    synology.0  2021-01-11 15:16:39.542 debug   (16857) setObject "DiskStationManager.hdd_info.drive_2.overview_status"
    synology.0  2021-01-11 15:16:39.540 debug   (16857) setObject "DiskStationManager.hdd_info.drive_2.model"
    synology.0  2021-01-11 15:16:39.539 debug   (16857) setObject "DiskStationManager.hdd_info.drive_2.diskno"
    synology.0  2021-01-11 15:16:39.538 debug   (16857) setObject "DiskStationManager.hdd_info.drive_1.capacity"
    synology.0  2021-01-11 15:16:39.537 debug   (16857) setObject "DiskStationManager.hdd_info.drive_1.storage_pool"
    synology.0  2021-01-11 15:16:39.535 debug   (16857) setObject "DiskStationManager.hdd_info.drive_1.temperature"
    synology.0  2021-01-11 15:16:39.534 debug   (16857) setObject "DiskStationManager.hdd_info.drive_1.ebox_order"
    synology.0  2021-01-11 15:16:39.533 debug   (16857) setObject "DiskStationManager.hdd_info.drive_1.overview_status"
    synology.0  2021-01-11 15:16:39.531 debug   (16857) setObject "DiskStationManager.hdd_info.drive_1.model"
    synology.0  2021-01-11 15:16:39.530 debug   (16857) setObject "DiskStationManager.hdd_info.drive_1.diskno"
    synology.0  2021-01-11 15:16:39.529 debug   (16857) setObject "DiskStationManager.info.upgrade_ready"
    synology.0  2021-01-11 15:16:39.527 debug   (16857) setObject "DiskStationManager.info.is_system_crashed"
    synology.0  2021-01-11 15:16:39.526 debug   (16857) setObject "DiskStationManager.info.memory_size"
    synology.0  2021-01-11 15:16:39.525 debug   (16857) setObject "DiskStationManager.info.memory_usage"
    synology.0  2021-01-11 15:16:39.523 debug   (16857) setObject "DiskStationManager.info.cpu_load"
    synology.0  2021-01-11 15:16:39.522 debug   (16857) setObject "DiskStationManager.info.time"
    synology.0  2021-01-11 15:16:39.521 debug   (16857) setStates
    synology.0  2021-01-11 15:16:39.521 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:39.520 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:39.519 debug   (16857) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    synology.0  2021-01-11 15:16:39.518 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:39.156 debug   (16857) * Get info from (fastPoll) api: FS method: listSharings params: {}
    synology.0  2021-01-11 15:16:39.156 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    synology.0  2021-01-11 15:16:39.155 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:39.154 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:16:39.154 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    synology.0  2021-01-11 15:16:39.153 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:39.151 debug   (16857) listCameras - Response: {"cameras":[{"ADCap":0,"AppList":[],"DINum":0,"DONum":0,"MDCap":21,"MDModeList":[0,1],"PDCap":0,"PDDepend":0,"TDCap":21,"advLiveMinDuration":10,"advLiveProfile":1,"advL
    synology.0  2021-01-11 15:16:39.150 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:38.926 debug   (16857) * Get info from (fastPoll) api: SS method: listCameras params: {"basic":true,"version":7}
    synology.0  2021-01-11 15:16:38.926 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    synology.0  2021-01-11 15:16:38.925 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:38.924 debug   (16857) InfoHomeMode - Response: {"actrule_on":false,"actrules":"-1","cameras":"-1","custom1_det":1,"custom1_di":1,"custom2_det":1,"custom2_di":1,"geo_delay_time":60,"geo_lat":0,"geo_lng":0,"geo_mobil
    synology.0  2021-01-11 15:16:38.923 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:38.787 debug   (16857) * Get info from (fastPoll) api: SS method: getInfoHomeMode params: {"need_mobiles":true}
    synology.0  2021-01-11 15:16:38.786 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    synology.0  2021-01-11 15:16:38.785 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:38.784 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:38.783 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:38.780 debug   (16857) InfoSystem - Response: {"hdd_info":[{"capacity":"10000831348736","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"ST10000VN0004-1ZD101 ","order":1,"overvie
    synology.0  2021-01-11 15:16:38.778 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:38.349 debug   (16857) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    synology.0  2021-01-11 15:16:38.349 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    synology.0  2021-01-11 15:16:38.348 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:38.348 debug   (16857) TempInfo - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:16:38 2021","uptime":1566059,"versio
    synology.0  2021-01-11 15:16:38.347 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:38.258 debug   (16857) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:16:38.257 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:16:38.256 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:38.255 debug   (16857) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    synology.0  2021-01-11 15:16:38.254 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:38.065 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    synology.0  2021-01-11 15:16:38.064 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    synology.0  2021-01-11 15:16:38.064 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:38.062 debug   (16857) SystemUtilization - Response: {"cpu":{"15min_load":105,"1min_load":42,"5min_load":67,"device":"System","other_load":1,"system_load":2,"user_load":5},"disk":{"disk":[{"device":"nvme0n1","displa
    synology.0  2021-01-11 15:16:38.061 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:36.862 debug   (16857) Send [SS] [getLiveViewPathCamera] Error: [no error] Response: [object]
    synology.0  2021-01-11 15:16:36.759 debug   (16857) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    synology.0  2021-01-11 15:16:36.759 debug   (16857) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    synology.0  2021-01-11 15:16:36.758 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:36.658 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.linkSnapshot"
    synology.0  2021-01-11 15:16:36.657 debug   (16857) setStates
    synology.0  2021-01-11 15:16:36.657 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:36.657 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:36.655 debug   (16857) getLiveViewPathCamera
    synology.0  2021-01-11 15:16:36.654 debug   (16857) * sendPolling. namePolling = slowPoll | iteration = 4 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:36.654 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:36.654 debug   (16857) addLinkSnapShot
    synology.0  2021-01-11 15:16:36.653 debug   (16857) * sendPolling. namePolling = slowPoll | iteration = 3 | typeof poll = function | poll = undefined
    synology.0  2021-01-11 15:16:36.653 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:36.652 debug   (16857) listRadios - Response: {"offset":0,"radios":[],"total":0}
    synology.0  2021-01-11 15:16:36.652 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:36.504 debug   (16857) * Get info from (slowPoll) api: AS method: listRadios params: {"container":"Favorite","limit":1000,"library":"shared","sort_direction":"ASC"}
    synology.0  2021-01-11 15:16:36.504 debug   (16857) * sendPolling. namePolling = slowPoll | iteration = 2 | typeof poll = object | poll = {"api":"as","method":"listRadios","params":{"container":"Favorite","limit":1000,"library":"shared","sort_d
    synology.0  2021-01-11 15:16:36.504 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:36.503 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:16:36.503 debug   (16857) * sendPolling. namePolling = slowPoll | iteration = 1 | typeof poll = object | poll = {"api":"dl","method":"listTasks","params":{}}
    synology.0  2021-01-11 15:16:36.503 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:36.503 debug   (16857) ListRemotePlayers - Response: {"players":[]}
    synology.0  2021-01-11 15:16:36.502 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:36.305 debug   (16857) * Get info from (slowPoll) api: AS method: listRemotePlayers params: {"type":"all","additional":"subplayer_list"}
    synology.0  2021-01-11 15:16:36.305 debug   (16857) * sendPolling. namePolling = slowPoll | iteration = 0 | typeof poll = object | poll = {"api":"as","method":"listRemotePlayers","params":{"type":"all","additional":"subplayer_list"}}
    synology.0  2021-01-11 15:16:36.304 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:36.203 debug   (16857) setObject "SurveillanceStation.HomeMode.wifi_ssid"
    synology.0  2021-01-11 15:16:36.202 debug   (16857) setObject "SurveillanceStation.HomeMode.geo_radius"
    synology.0  2021-01-11 15:16:36.201 debug   (16857) setObject "SurveillanceStation.HomeMode.geo_lng"
    synology.0  2021-01-11 15:16:36.201 debug   (16857) setObject "SurveillanceStation.HomeMode.geo_lat"
    synology.0  2021-01-11 15:16:36.200 debug   (16857) setObject "SurveillanceStation.HomeMode.onetime_enable_time"
    synology.0  2021-01-11 15:16:36.199 debug   (16857) setObject "SurveillanceStation.HomeMode.onetime_enable_on"
    synology.0  2021-01-11 15:16:36.199 debug   (16857) setObject "SurveillanceStation.HomeMode.onetime_disable_time"
    synology.0  2021-01-11 15:16:36.198 debug   (16857) setObject "SurveillanceStation.HomeMode.onetime_disable_on"
    synology.0  2021-01-11 15:16:36.197 debug   (16857) setObject "SurveillanceStation.HomeMode.notify_on"
    synology.0  2021-01-11 15:16:36.196 debug   (16857) setObject "SurveillanceStation.HomeMode.status_on"
    synology.0  2021-01-11 15:16:36.196 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.motionDetected"
    synology.0  2021-01-11 15:16:36.195 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.enabled"
    synology.0  2021-01-11 15:16:36.194 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.recStatus"
    synology.0  2021-01-11 15:16:36.193 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.vendor"
    synology.0  2021-01-11 15:16:36.193 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.model"
    synology.0  2021-01-11 15:16:36.192 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.port"
    synology.0  2021-01-11 15:16:36.191 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.id"
    synology.0  2021-01-11 15:16:36.191 debug   (16857) setObject "SurveillanceStation.cameras.CamTerrasse.host"
    synology.0  2021-01-11 15:16:36.190 debug   (16857) setObject "SurveillanceStation.info.remindQuickconnectTunnel"
    synology.0  2021-01-11 15:16:36.189 debug   (16857) setObject "SurveillanceStation.info.enableVideoRelay"
    synology.0  2021-01-11 15:16:36.188 debug   (16857) setObject "SurveillanceStation.info.maxCameraSupport"
    synology.0  2021-01-11 15:16:36.188 debug   (16857) setObject "SurveillanceStation.info.liscenseNumber"
    synology.0  2021-01-11 15:16:36.187 debug   (16857) setObject "SurveillanceStation.info.isLicenseEnough"
    synology.0  2021-01-11 15:16:36.186 debug   (16857) setObject "SurveillanceStation.info.cameraNumber"
    synology.0  2021-01-11 15:16:36.186 debug   (16857) setObject "SurveillanceStation.info.CMSMinVersion"
    synology.0  2021-01-11 15:16:36.185 debug   (16857) setObject "AudioStation.info.version_string"
    synology.0  2021-01-11 15:16:36.184 debug   (16857) setObject "AudioStation.info.version"
    synology.0  2021-01-11 15:16:36.183 debug   (16857) setObject "AudioStation.info.transcode_capability.1"
    synology.0  2021-01-11 15:16:36.183 debug   (16857) setObject "AudioStation.info.transcode_capability.0"
    synology.0  2021-01-11 15:16:36.180 debug   (16857) setObject "AudioStation.info.support_virtual_library"
    synology.0  2021-01-11 15:16:36.179 debug   (16857) setObject "AudioStation.info.support_usb"
    synology.0  2021-01-11 15:16:36.177 debug   (16857) setObject "AudioStation.info.support_bluetooth"
    synology.0  2021-01-11 15:16:36.176 debug   (16857) setObject "AudioStation.info.sid"
    synology.0  2021-01-11 15:16:36.174 debug   (16857) setObject "AudioStation.info.settings.transcode_to_mp3"
    synology.0  2021-01-11 15:16:36.172 debug   (16857) setObject "AudioStation.info.settings.prefer_using_html5"
    synology.0  2021-01-11 15:16:36.171 debug   (16857) setObject "AudioStation.info.settings.enable_download"
    synology.0  2021-01-11 15:16:36.169 debug   (16857) setObject "AudioStation.info.settings.disable_upnp"
    synology.0  2021-01-11 15:16:36.168 debug   (16857) setObject "AudioStation.info.settings.audio_show_virtual_library"
    synology.0  2021-01-11 15:16:36.166 debug   (16857) setObject "AudioStation.info.serial_number"
    synology.0  2021-01-11 15:16:36.164 debug   (16857) setObject "AudioStation.info.same_subnet"
    synology.0  2021-01-11 15:16:36.163 debug   (16857) setObject "AudioStation.info.remote_controller"
    synology.0  2021-01-11 15:16:36.161 debug   (16857) setObject "AudioStation.info.privilege.upnp_browse"
    synology.0  2021-01-11 15:16:36.160 debug   (16857) setObject "AudioStation.info.privilege.tag_edit"
    synology.0  2021-01-11 15:16:36.158 debug   (16857) setObject "AudioStation.info.privilege.sharing"
    synology.0  2021-01-11 15:16:36.157 debug   (16857) setObject "AudioStation.info.privilege.remote_player"
    synology.0  2021-01-11 15:16:36.155 debug   (16857) setObject "AudioStation.info.privilege.playlist_edit"
    synology.0  2021-01-11 15:16:36.154 debug   (16857) setObject "AudioStation.info.playing_queue_max"
    synology.0  2021-01-11 15:16:36.152 debug   (16857) setObject "AudioStation.info.is_manager"
    synology.0  2021-01-11 15:16:36.151 debug   (16857) setObject "AudioStation.info.has_music_share"
    synology.0  2021-01-11 15:16:36.149 debug   (16857) setObject "AudioStation.info.enable_user_home"
    synology.0  2021-01-11 15:16:36.148 debug   (16857) setObject "AudioStation.info.enable_personal_library"
    synology.0  2021-01-11 15:16:36.146 debug   (16857) setObject "AudioStation.info.enable_equalizer"
    synology.0  2021-01-11 15:16:36.145 debug   (16857) setObject "AudioStation.info.dsd_decode_capability"
    synology.0  2021-01-11 15:16:36.144 debug   (16857) setObject "AudioStation.info.browse_personal_library"
    synology.0  2021-01-11 15:16:36.142 debug   (16857) setObject "FileStation.info.uid"
    synology.0  2021-01-11 15:16:36.140 debug   (16857) setObject "FileStation.info.system_codepage"
    synology.0  2021-01-11 15:16:36.139 debug   (16857) setObject "FileStation.info.support_virtual_protocol.2"
    synology.0  2021-01-11 15:16:36.138 debug   (16857) setObject "FileStation.info.support_virtual_protocol.1"
    synology.0  2021-01-11 15:16:36.136 debug   (16857) setObject "FileStation.info.support_virtual_protocol.0"
    synology.0  2021-01-11 15:16:36.135 debug   (16857) setObject "FileStation.info.support_virtual.enable_remote_mount"
    synology.0  2021-01-11 15:16:36.133 debug   (16857) setObject "FileStation.info.support_virtual.enable_iso_mount"
    synology.0  2021-01-11 15:16:36.132 debug   (16857) setObject "FileStation.info.support_vfs"
    synology.0  2021-01-11 15:16:36.130 debug   (16857) setObject "FileStation.info.support_sharing"
    synology.0  2021-01-11 15:16:36.129 debug   (16857) setObject "FileStation.info.support_file_request"
    synology.0  2021-01-11 15:16:36.127 debug   (16857) setObject "FileStation.info.items.3"
    synology.0  2021-01-11 15:16:36.126 debug   (16857) setObject "FileStation.info.items.2"
    synology.0  2021-01-11 15:16:36.125 debug   (16857) setObject "FileStation.info.items.1"
    synology.0  2021-01-11 15:16:36.123 debug   (16857) setObject "FileStation.info.items.0"
    synology.0  2021-01-11 15:16:36.121 debug   (16857) setObject "FileStation.info.is_manager"
    synology.0  2021-01-11 15:16:36.120 debug   (16857) setObject "FileStation.info.hostname"
    synology.0  2021-01-11 15:16:36.118 debug   (16857) setObject "FileStation.info.enable_list_usergrp"
    synology.0  2021-01-11 15:16:36.117 debug   (16857) setObject "DiskStationManager.info.productName"
    synology.0  2021-01-11 15:16:36.115 debug   (16857) setObject "DiskStationManager.info.serviceVolSize"
    synology.0  2021-01-11 15:16:36.114 debug   (16857) setObject "DiskStationManager.info.unique"
    synology.0  2021-01-11 15:16:36.111 debug   (16857) setObject "DiskStationManager.info.timezone"
    synology.0  2021-01-11 15:16:36.109 debug   (16857) setObject "DiskStationManager.info.hostname"
    synology.0  2021-01-11 15:16:36.108 debug   (16857) setObject "DiskStationManager.info.version_string"
    synology.0  2021-01-11 15:16:36.107 debug   (16857) setObject "DiskStationManager.info.version"
    synology.0  2021-01-11 15:16:36.105 debug   (16857) setObject "DiskStationManager.info.uptime"
    synology.0  2021-01-11 15:16:36.104 debug   (16857) setObject "DiskStationManager.info.time"
    synology.0  2021-01-11 15:16:36.102 debug   (16857) setObject "DiskStationManager.info.temperature_warn"
    synology.0  2021-01-11 15:16:36.101 debug   (16857) setObject "DiskStationManager.info.temperature"
    synology.0  2021-01-11 15:16:36.099 debug   (16857) setObject "DiskStationManager.info.serial"
    synology.0  2021-01-11 15:16:36.098 debug   (16857) setObject "DiskStationManager.info.ram"
    synology.0  2021-01-11 15:16:36.096 debug   (16857) setObject "DiskStationManager.info.model"
    synology.0  2021-01-11 15:16:36.094 debug   (16857) setObject "DiskStationManager.info.codepage"
    synology.0  2021-01-11 15:16:36.092 debug   (16857) setStates
    synology.0  2021-01-11 15:16:36.091 debug   (16857) >>>>>>>>>>>>>>> Read all data, save received data.
    synology.0  2021-01-11 15:16:36.089 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:16:06.088 debug   (16857) ListRemotePlayers - Response: {"players":[]}
    synology.0  2021-01-11 15:16:06.086 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:16:05.886 debug   (16857) * Get info from (firstPoll) api: AS method: listRemotePlayers params: {"type":"all","additional":"subplayer_list"}
    synology.0  2021-01-11 15:16:05.886 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 10 | typeof poll = object | poll = {"api":"as","method":"listRemotePlayers","params":{"type":"all","additional":"subplayer_list"}}
    synology.0  2021-01-11 15:16:05.884 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:15:35.881 debug   (16857) listCameras - Response: {"cameras":[{"ADCap":0,"AppList":[],"DINum":0,"DONum":0,"MDCap":21,"MDModeList":[0,1],"PDCap":0,"PDDepend":0,"TDCap":21,"advLiveMinDuration":10,"advLiveProfile":1,"advL
    synology.0  2021-01-11 15:15:35.879 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:15:35.610 debug   (16857) * Get info from (firstPoll) api: SS method: listCameras params: {"basic":true,"version":7}
    synology.0  2021-01-11 15:15:35.609 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 9 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    synology.0  2021-01-11 15:15:35.608 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:15:05.605 debug   (16857) InfoHomeMode - Response: {"actrule_on":false,"actrules":"-1","cameras":"-1","custom1_det":1,"custom1_di":1,"custom2_det":1,"custom2_di":1,"geo_delay_time":60,"geo_lat":0,"geo_lng":0,"geo_mobil
    synology.0  2021-01-11 15:15:05.604 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:15:05.446 debug   (16857) * Get info from (firstPoll) api: SS method: getInfoHomeMode params: {"need_mobiles":true}
    synology.0  2021-01-11 15:15:05.446 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 8 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    synology.0  2021-01-11 15:15:05.444 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:14:35.441 debug   (16857) Info - Response: {"CMSMinVersion":"8.2.8-6335","DSModelName":"DS918+","SvsClientMinVersion":"1.2.9-1082","VS240HDMinVersion":"2.4.0-1508","VS360HDLoginMinVersion":"4.3.7-5091","VS360HDMinVersi
    synology.0  2021-01-11 15:14:35.440 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:14:34.672 debug   (16857) * Get info from (firstPoll) api: SS method: getInfo params: {}
    synology.0  2021-01-11 15:14:34.671 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 7 | typeof poll = object | poll = {"api":"ss","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:14:34.670 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:14:34.669 debug   (16857) * Packet DTV non installed, skipped
    synology.0  2021-01-11 15:14:34.668 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 6 | typeof poll = object | poll = {"api":"dtv","method":"GetInfoTuner","params":{}}
    synology.0  2021-01-11 15:14:34.666 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:14:04.665 error   (16857) *** ERROR : src: *sendPolling syno[vs][getInfo] code: 160 message: Unknown error
    synology.0  2021-01-11 15:14:04.663 debug   (16857) * No response, read next.
    synology.0  2021-01-11 15:14:04.038 debug   (16857) * Get info from (firstPoll) api: VS method: getInfo params: {}
    synology.0  2021-01-11 15:14:04.037 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 5 | typeof poll = object | poll = {"api":"vs","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:14:04.035 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:13:34.034 debug   (16857) Info - Response: {"browse_personal_library":"all","dsd_decode_capability":true,"enable_equalizer":false,"enable_personal_library":true,"enable_user_home":true,"has_music_share":true,"is_manage
    synology.0  2021-01-11 15:13:34.032 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:13:33.209 debug   (16857) * Get info from (firstPoll) api: AS method: getInfo params: {}
    synology.0  2021-01-11 15:13:33.208 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 4 | typeof poll = object | poll = {"api":"as","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:13:33.207 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:13:33.206 debug   (16857) * Packet DL non installed, skipped
    synology.0  2021-01-11 15:13:33.204 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 3 | typeof poll = object | poll = {"api":"dl","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:13:33.203 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:13:03.200 debug   (16857) Info - Response: {"enable_list_usergrp":false,"hostname":"Rigel","is_manager":true,"items":[{"gid":100},{"gid":101},{"gid":65536},{"gid":65537}],"support_file_request":true,"support_sharing":t
    synology.0  2021-01-11 15:13:03.199 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:13:02.340 debug   (16857) * Get info from (firstPoll) api: FS method: getInfo params: {}
    synology.0  2021-01-11 15:13:02.339 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 2 | typeof poll = object | poll = {"api":"fs","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:13:02.338 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:12:32.337 debug   (16857) Info - Response: {"codepage":"ger","model":"DS918+","ram":8192,"serial":"1960PDN172202","temperature":40,"temperature_warn":false,"time":"Mon Jan 11 15:12:32 2021","uptime":1565813,"version":"
    synology.0  2021-01-11 15:12:32.336 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:12:32.190 debug   (16857) * Get info from (firstPoll) api: DSM method: getInfo params: {}
    synology.0  2021-01-11 15:12:32.190 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    synology.0  2021-01-11 15:12:32.189 debug   (16857) -----------------------------------------------------------------------------------------------------
    synology.0  2021-01-11 15:12:02.187 debug   (16857) InstallingPackets - Response: {"diskList":"","packages":{"AntiVirus":true,"AudioStation":true,"Calendar":true,"CardDAVServer":true,"Docker":true,"Docker-GitLab":true,"DocumentViewer":true,"Dok
    synology.0  2021-01-11 15:12:02.184 debug   (16857) * The response is received, parse:
    synology.0  2021-01-11 15:12:01.227 debug   (16857) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    synology.0  2021-01-11 15:12:01.226 debug   (16857) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    synology.0  2021-01-11 15:11:59.027 info    (16857) starting. Version 0.1.18 in /opt/iobroker/node_modules/iobroker.synology, node: v14.15.2, js-controller: 3.1.6
    synology.0  2021-01-11 15:11:59.019 debug   (16857) Plugin sentry destroyed because not initialized correctly
    synology.0  2021-01-11 15:11:59.007 debug   (16857) Plugin sentry Do not initialize Plugin (enabled=false)
    GlasfaserG Offline
    GlasfaserG Offline
    @al10b sagte in Synology-Adapter: unknown error:
    Ähh - wo stehen die doch gleich noch mal?
    In der Instanz von den Adaptereinstellungen :
    https://forum.iobroker.net/topic/33224/iobroker-synology-adapter/25
    • GlasfaserG Glasfaser
      al10b
      @Glasfaser
      Ah, das, danke.
      Also:
      Parameterabrufzeit (ms): 100
      Abfragezeit für zusätzliche Parameter (ms): 60000
      Sollten die Default-Werte sein.
      • A al10b
        @Glasfaser
        Ah, das, danke.
        Also:
        GlasfaserG Offline
        GlasfaserG Offline
        Stelle den mal auf 5000
          al10b
          @Glasfaser
          Das war's leider noch nicht:
          aber:
          synology.0	2021-01-11 17:36:10.111	error	(26021) *** ERROR : src: *sendPolling syno[vs][getInfo] code: 160 message: Unknown error
          • A al10b
            @Glasfaser
            aber:
            GlasfaserG Offline
            GlasfaserG Offline
            @al10b
            Laut der neuen Meldung jetzt 160
            Insufficient application privilege
            Nutzt du HTTPS bzw. 2 stufige Überprüfung
            Schau mal im LOG von der Synology selber , ob du etwas verdächtiges findest !?
              @al10b
              al10b
              schrieb am zuletzt editiert von al10b
              @glasfaser
              Also, im Moment kommen da nur noch die 160-Fehler. Ich habe ein
              tail -f /var/log/messages
              mitlaufen lassen, aber da passiert zu dieser Zeit nichts Aufregendes. Gibt es noch andere Logs, die sich anzusehen lohnt?
              Ich nutze https und 2-Faktor-Authentifizierung. Da ich aber z.B. das Bild von der Synology Surveillance Station via ioBroker im HomeKit sehen kann, sollte da nichts Grundsätzliches falsch laufen.
              Nachtrag: Hier noch einmal das Log vom 160er im Debug-Modus:
              synology.0	2021-01-12 12:00:19.298	error	(2593) *** ERROR : src: *sendPolling syno[vs][getInfo] code: 160 message: Unknown error
              synology.0	2021-01-12 12:00:19.297	debug	(2593) * No response, read next.
              synology.0	2021-01-12 12:00:18.021	debug	(2593) * Get info from (firstPoll) api: VS method: getInfo params: {}
              synology.0	2021-01-12 12:00:18.020	debug	(2593) * sendPolling. namePolling = firstPoll | iteration = 5 | typeof poll = object | poll = {"api":"vs","method":"getInfo","params":{}}
              synology.0	2021-01-12 12:00:18.019	debug	(2593) -----------------------------------------------------------------------------------------------------
              Noch ein Nachtrag:
              Dieser Fehler tritt selten auf, aber immer im Zusammenhang mit der Abfrage
              ... poll = {"api":"vs","method":"getInfo","params":{}
              Und umgekehrt: diese Anfrage taucht sonst bis jetzt, d.h. in ca. 30 Minuten, nicht im Log auf. Ich lasse das noch ein wenig weiter laufen.
              • A al10b
                @glasfaser
                Noch ein Nachtrag:
                GlasfaserG Offline
                GlasfaserG Offline
                @al10b said in Synology-Adapter: unknown error:
                Ich weiß nicht ob es daran hängt .. das es gerade Probleme macht !?
                Kannst du es mal ohne bei dir testen !?
                  al10b
                  @glasfaser
                  Ich habe nun die TFA ausgeschaltet. Seit 2 Stunden sind keine Fehler aufgetreten. Ich beobachte das weiter und melde mich morgen noch einmal.
                  • A al10b
                    @glasfaser
                    al10b
                    @al10b
                    Der Fehler
                    synology.0	2021-01-13 09:23:23.058	error	(14786) *** ERROR : src: *sendPolling syno[dsm][getSystemUtilization] code: 1052 message: Unknown error
                    tritt leider immer noch auf.
                    TFA ist aus, https ist an.
                    Stundenlang ist Ruhe und dann kommen wieder ca. 40 Einträge auf einmal.
                    • A al10b
                      @al10b
                      Der Fehler
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @al10b
                      Ich selber habe leider keine Idee mehr was es sein kann ,da der Fehler sporalisch bei dir auftritt !
                      Du kannst ja ein Issues erstellen !
                      https://github.com/instalator/ioBroker.synology
                        @al10b
                        al10b
                        @glasfaser
                        Dann erst einmal vielen Dank für Deine Hilfe. Ich warte erst einmal noch. Es ist ja nur störend.
