  4. [Vorstellung] Meine dritte VIS
    6.6k
visvis projekte
640 Beiträge 83 Kommentatoren 244.3k Aufrufe 117 Beobachtet
  • K Kuddel
    @marhal das ist meine aktuelle Version:
    // Liest die ioBroker Adapter aus und legt verschiedenen State's an.
    //on({id:"system.adapter.admin.0.uptime",change:'any'}, function (obj) {
       createState('Adapter.Anzahl', 0, { name: 'Anzahl', desc: 'Anzahl der Adapter', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
       createState('Adapter.AdapterNummer', 0, { name: 'Adapter zum schalten', desc: 'Adapter zum schalten', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
       //var counterAlt = getState("javascript.0.Adapter.Anzahl").val;
       var counter =0;
       var on = 0
       var manuell=0
       var cacheSelector = $('[id=system.adapter.*.alive]');
       cacheSelector.each(function(id, i) {
           var devicename = getObject(id).common.name;
       	//Instanzen ausklammern
       	instanz0 = devicename.indexOf('daswetter');
       	instanz1 = devicename.indexOf('dwd');
           instanz2 = devicename.indexOf('ical');
       	instanz3 = devicename.indexOf('feiertage');
       	instanz4 = devicename.indexOf('snmp.1');
           instanz5 = devicename.indexOf('vis.0');
           instanz6 = devicename.indexOf('yamaha.0');
       	if(instanz0 !=0 && instanz1 != 0 && instanz2 !=0 && instanz3 != 0 && instanz4 != 0 && instanz5 !=0 && instanz6 !=0){
       		var devicenameName=devicename;
       		var instanzname=getObject(id).common.name;
       		var test = devicenameName;
       		var devicename_array = devicenameName.split(' ');
       		devicenameName = devicename_array[0];
       		counter = counter+1;
       		var strStatePath = "system.adapter." + devicenameName + ".alive";
       		if (isState(strStatePath, true)) {
       			var uptime = getState("system.adapter." + devicenameName + ".uptime").val;
       			var tage = Math.floor(uptime / (24*3600));
       			var stunden = Math.floor((uptime % (24*3600))/3600);
       			var minuten = Math.floor((uptime % (3600))/60);
       			//var sekunden = Math.floor(uptime % 60);
       			if (stunden < 10) {stunden = "0"+stunden};
                   if (minuten < 10) {minuten = "0"+minuten};
       			if (tage == 1) {uptime = tage.toString()+" Tag, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";};
       			if (tage != 1) {uptime = tage.toString()+" Tage, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";}
       			//var total = getState("system.adapter." + devicenameName + ".memHeapTotal").val;
       			//var used = getState("system.adapter." + devicenameName + ".memHeapUsed").val;
       			//var rss = getState("system.adapter." + devicenameName + ".memRss").val;
       			var connect = getState("system.adapter." + devicenameName + ".alive").val;
       			if(connect == false){var con = 0;}
       			else {
       				var con = 1;
       				var strStatePath = devicenameName + ".info.connection";
       					var connectS = getState(devicenameName + ".info.connection").val;
       					if (connectS == false) {
       						con = 2;
       			if(con==1) {on = on + 1}
       		devicename="Adapter.Adapter"+counter.toString()+".KompletterNameAdapter";
       		createState(devicename, 'empty', { name: 'Kompletter Name des Adapters', desc: '', type: 'string', role: '',read: true, write: true });
       		setStateDelayed(devicename, devicenameName, 800);
       		var contentstring = devicenameName;
       		var suchstring = /(ical)/g;
       		var suchergebnis = suchstring.test( contentstring );
       		if (suchergebnis != true) {
       			var devicename_array = devicenameName.split('.');
       		if (devicenameName == "daswetter") {
       			var bild = "/" + devicenameName + ".admin/" + devicenameName + "com.png";
       		} else if (suchergebnis != false) {
       			var icalName = devicename_array[0];
       			var bild = "/" + icalName + ".admin/" + icalName + ".png";
       		} else {
       			var bild = "/" + devicenameName + ".admin/" + devicenameName + ".png";
       		//Alexa2
       		if (devicenameName == 'alexa2') {var bild = "/" + devicenameName + ".admin/" + "alexa.png";}
       		//FritzDECT
       		if (devicenameName == 'fritzdect') {var bild = "/" + devicenameName + ".admin/" + "fritzdect_logo.png";}
       		//FullyBrowser
       		if (devicenameName == 'fullybrowser') {var bild = "/" + devicenameName + ".admin/" + "fully.png";}
       		//HM-Rega
       		//if (devicenameName == 'hm-rega') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
       		if (devicenameName == 'hm-rega') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
       		//HomeMatic
       		//if (instanzname == 'hm-rpc.0 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
       		if (instanzname == 'hm-rpc.0 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
       		//HomeMatic-IP
       		//if (instanzname == 'hm-rpc.1 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
       		if (instanzname == 'hm-rpc.1 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic_ip.jpg";}
       		//UPNP
       		if (devicenameName == 'upnp') {var bild = "/" + devicenameName + ".admin/" + "upnp-discovery.png";}
               //Pushover.1
       		if (instanzname == 'pushover.1 alive') {var bild = "/mihome-vacuum.admin/mihome-vacuum.png";}
               //Pushover.2
       		if (instanzname == 'pushover.2 alive') {var bild = "/daswetter.admin/daswettercom.png";}
       		//AdapterName anpassen
               //DasWetter
       		if (instanzname == 'daswetter.0 alive') {devicenameName='DasWetter'; manuell=1}
       		//DWD
       		if (instanzname == 'dwd.0 alive') {devicenameName='DWD'; manuell=1}
       		//HM-REGA
       		if (instanzname == 'hm-rega.0 alive') {devicenameName='HM-Rega'; manuell=1}
       		//HM-RPC.0
       		if (instanzname == 'hm-rpc.0 alive') {devicenameName='HomeMatic'; manuell=1}
       		//HM-RPC.1
       		if (instanzname == 'hm-rpc.1 alive') {devicenameName='HM-IP'; manuell=1}
       		//MiHome-Vacuum
       		if (instanzname == 'mihome-vacuum.0 alive') {devicenameName='Nono'; manuell=1}
       		//Pushover
       		if (instanzname == 'pushover.0 alive') {devicenameName='Pushover.0'; manuell=1}
       		if (instanzname == 'pushover.1 alive') {devicenameName='Pushover.1'; manuell=1}
       		if (instanzname == 'pushover.2 alive') {devicenameName='Pushover.2'; manuell=1}
       		//Simple-API
       		if (instanzname == 'simple-api.0 alive') {devicenameName='Simple-API'; manuell=1}
       		//SNMP.0
       		if (instanzname == 'snmp.0 alive') {devicenameName='SNMP.0'; manuell=1}
       		//SNMP.1
       		if (instanzname == 'snmp.1 alive') {devicenameName='SNMP.1'; manuell=1}
               //Spotify
               if (instanzname == 'spotify-premium.0 alive') {devicenameName='Spotify'; manuell=1}
               //TR-064.0
       		if (instanzname == 'tr-064.0 alive') {devicenameName='TR-064.0'; manuell=1}
       		//TR-064.1
       		if (instanzname == 'tr-064.1 alive') {devicenameName='TR-064.1'; manuell=1}
               //XPEnology
               if (instanzname == 'synology.1 alive') {devicenameName='XPEnology'; manuell=1}
       		//Instanz-Namen setzen
       		if(manuell!=1) {devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();}
               //devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();
       		devicename="Adapter.Adapter"+counter.toString()+".NameInstanz";
       		createState(devicename, 'empty', { name: 'Name des Geräts', desc: '', type: 'string', role: '',read: true, write: true });
       		//Bild Pfad setzen
       		devicename="Adapter.Adapter"+counter.toString()+".Bild";
       		createState(devicename, 'empty', { name: 'Speicherort Bild', desc: '', type: 'string', role: '',read: true, write: true });
       		setStateDelayed(devicename, bild, 800);
       		//Uptime setzen
       		devicename="Adapter.Adapter"+counter.toString()+".Uptime";
       		createState(devicename, 'empty', { name: 'Uptime', desc: '', type: 'string', role: '',read: true, write: true });
       		setStateDelayed(devicename, uptime, 800);
       		//MemUsed setzen
       		//devicename="Adapter.Adapter"+counter.toString()+".MemUsed";
       		//createState(devicename, 0, { name: 'Link MemUsed', desc: '', type: 'number', role: '',read: true, write: true });
       		//setStateDelayed(devicename, used, 800);
       		//MemToal setzen
       		//devicename="Adapter.Adapter"+counter.toString()+".MemTotal";
       		//createState(devicename, 0, { name: 'Link MemTotal', desc: '', type: 'number', role: '',read: true, write: true });
       		//setStateDelayed(devicename, total, 800);
       		//MemRSS setzen
       		//devicename="Adapter.Adapter"+counter.toString()+".MemRSS";
       		//createState(devicename, 0, { name: 'Link MemRSS', desc: '', type: 'number', role: '',read: true, write: true });
       		//setStateDelayed(devicename, rss, 800);
       		//Connected setzen
       		devicename="Adapter.Adapter"+counter.toString()+".Connected";
       		createState(devicename, 0, { name: 'Status Adapter', desc: '', type: 'number', role: '',read: true, write: true });
       		setStateDelayed(devicename, con, 800);
               //Wert zurücksetzen
               var manuell=0
       //Adaptet Icon Übersicht
       visstatus="javascript.0.VIS-Status.alle_adapter_gestartet";
       if(on == counter){setState(visstatus, true);}
       if(on == counter -1){setState(visstatus, true);}
       if(on < counter -1){setState(visstatus, false);}
       setStateDelayed('Adapter.Anzahl', counter, 800);
       function isState(strStatePath, strict) {
           let mSelector;
           if (strict) {
               mSelector = $('state[id=' + strStatePath + '$]');
           } else {
               mSelector = $('state[id=' + strStatePath + ']');
           if (mSelector.length > 0) {
               return true;
           } else {
               return false;
    on({id:"javascript.0.Adapter.AdapterNummer", change: 'any'}, function (dpobj) {
       if (getState("javascript.0.Adapter.AdapterNummer").val != 0) {
           const instanz = "javascript." + instance;
           var adapterNummer = getState(instanz + ".Adapter.AdapterNummer").val;
           var adapter = getState(instanz + ".Adapter.Adapter" + adapterNummer + ".KompletterNameAdapter").val; // Name und Instanz des Adapters
           var idAdapter = "system.adapter." + adapter;
           var obj = getObject(idAdapter);
           if (dpobj.state.val == false) {
               obj.common.enabled = true;  // Adapter einschalten
           } else if (dpobj.state.val == true) {
               obj.common.enabled = false;  // Adapter ausschalten
           setObject(idAdapter, obj);
           setStateDelayed('javascript.0.Adapter.AdapterNummer', 0, 800);
    marhal
    #404
    @Kuddel
    Das ist ja mal eine schnelle Antwort :) und guten Morgen dir Kuddel.
    In den Zeilen steht folgendes
    25 var cacheSelector = $('[id=system.adapter.*.alive]');
    26
    27 cacheSelector.each(function(id, i) {
    28
    29 var devicename = getObject(id).common.name;
    • M marhal
      @Kuddel
      26
      28
      Kuddel
      #405
      @marhal das ist aktuell mein Skript
         var counter =0;
         var on = 0
         var manuell=0
             instanz4 = devicename.indexOf('kodi.0');
         	instanz5 = devicename.indexOf('snmp.1');
             instanz6 = devicename.indexOf('vis.0');
             instanz7 = devicename.indexOf('yamaha.0');
         	if(instanz0 !=0 && instanz1 != 0 && instanz2 !=0 && instanz3 != 0 && instanz4 != 0 && instanz5 !=0 && instanz6 !=0 && instanz7 !=0){
         			else {
         				var con = 1;
         						con = 2;
         		} else {
         		//Alexa2
         		//FritzDECT
         		//FullyBrowser
         		//HM-Rega
         		//HomeMatic
         		//HomeMatic-IP
         		//UPNP
                 //Pushover.1
                 //Pushover.2
                 //DasWetter
         		//DWD
         		//HM-REGA
         		//HM-RPC.0
         		//HM-RPC.1
         		//MiHome-Vacuum
         		//Pushover
         		//Simple-API
         		//SNMP.0
         		//SNMP.1
                 //Spotify
                 //TR-064.0
         		//TR-064.1
                 //XPEnology
         		//Bild Pfad setzen
         		//Uptime setzen
         		//MemUsed setzen
         		//MemToal setzen
         		//MemRSS setzen
         		//Connected setzen
                 //Wert zurücksetzen
                 var manuell=0
             let mSelector;
             if (strict) {
             } else {
                 return true;
             } else {
                 return false;
      Bevor wir jetzt groß rumprobieren, nimm einfach mal diese Version
      S K 2 Antworten Letzte Antwort
      • K KHK
        @Kuddel ok, dann werde ich mal den Weg gehen - danke
        V Offline
        V Offline
        volx3eet
        #406
        Hat mir auch geholfen 😊
        • K Kuddel
             var counter =0;
             var on = 0
             var manuell=0
             			else {
             				var con = 1;
             						con = 2;
             		} else {
             		//Alexa2
             		//FritzDECT
             		//FullyBrowser
             		//HM-Rega
             		//HomeMatic
             		//HomeMatic-IP
             		//UPNP
                     //Pushover.1
                     //Pushover.2
                     //DasWetter
             		//DWD
             		//HM-REGA
             		//HM-RPC.0
             		//HM-RPC.1
             		//MiHome-Vacuum
             		//Pushover
             		//Simple-API
             		//SNMP.0
             		//SNMP.1
                     //Spotify
                     //TR-064.0
             		//TR-064.1
                     //XPEnology
             		//Bild Pfad setzen
             		//Uptime setzen
             		//MemUsed setzen
             		//MemToal setzen
             		//MemRSS setzen
             		//Connected setzen
                     //Wert zurücksetzen
                     var manuell=0
                 let mSelector;
                 if (strict) {
                 } else {
                     return true;
                 } else {
                     return false;
          Sequal
          #407
          @Kuddel
          Hut ab vor Deiner Arbeit! Deine Visualisierung ist echt gut gelungen!
          Ich hab allerdings ein kleines Verständnisproblem mit den Wetter-Views. Es wird alles bestens angezeigt, Objekte sind alle da, auch die Scripte laufen....eigentlich. Es wird jedoch nichts aktualisiert außer Datum und Uhrzeit. Temperaturen, Icons etc. bleiben immer bei den eingestellten Datenpunkten zb. von Day1. Auch die 5-Tagesübersicht bleibt wie eingerichtet, aber ändert sich nicht mit dem Fortschreiten der Woche. Was für ein Script hab ich da übersehen oder hab ich den Wetter.com-Adapter nicht richtig eingerichtet? Welcher Pfad im Adapter soll benutzt werden? Ich suche gerad den Wald zwischen all den Bäumen.....
          Sequal
          • S Sequal
            @Kuddel
            Sequal
            Kuddel
            #408
            @Sequal die VIS stellt ja nur die Wetterdaten vom Adapter "DasWetter" dar.
            Ändern sich deine DPs unter "daswetter.0" denn korrekt ?
            Wenn der Adapter die Daten nicht korrekt aktualisiert, gibt es in der VIS natürlich auch keine Veränderungen.
            • K Kuddel
              Sequal
              schrieb am zuletzt editiert von Sequal
              #409
              @Kuddel
              Ich war eigentlich der Meinung, die Datenpunkte sind alle korrekt, bis mir auffiel, dass sich die Temperaturen nicht verändern auf der Startseite. Kann es daran liegen, dass ich den falschen API Pfad im Adapter ausgewählt habe? Welcher passt hier?
              • S Sequal
                @Kuddel
                Kuddel
                #410
                @Sequal poste mal bitte einen Screenshot von deinen Adapter Einstellungen, dann kann ich morgen früh mal vergleichen
                • K Kuddel
                  Sequal
                  #411
                  @Kuddel said in [Vorstellung] Meine dritte VIS:
                  Ich hab die Instanz vorhin testweise gelöscht, neu hinzugefügt aber noch nicht wieder konfiguriert.
                  Erster Schritt wäre zu wissen, welchen Pfad Du gewählt hast, damit ich das schonmal ausschließen kann.
                  Gruß und Danke!
                  K V 2 Antworten Letzte Antwort
                  • S Sequal
                    Gruß und Danke!
                    Kuddel
                    #412
                    • S Sequal
                      Gruß und Danke!
                      V Offline
                      V Offline
                      volx3eet
                      #413
                      @Sequal Ich hab dir hier auch nochmal eine Anleitung angehängt. Ich gehe davon aus, daß du dir bereits einen Account erstellt hast bei daswetter. Wenn du dich dort einloggst findest du eigentlich alle Links die du im Adapter eintragen musst.
                      Anleitung
                      Volx
                      • K Kuddel
                        Sequal
                        #414
                        @Kuddel
                        Ok, Du hast 3 Pfade eingetragen......ich hatte mir einen ausgesucht. Vielleicht war das der Haken :) Ich beobachte.....Danke!
                        Euch schöne Feiertage!
                        • V volx3eet
                          Anleitung
                          Volx
                          Sequal
                          #415
                          @volx3eet
                          Jo, danke. War bereits alles eingerichtet, aber eben nur ein Pfad. Ich hatte die Erläuterung so verstanden.....
                          • S Sequal
                            @volx3eet
                            Sequal
                            #416
                            Nabend zusammen,
                            ich hab noch eine Kleinigkeit:
                            Kann mir jemand auf die Sprünge helfen wieso im Warnungsfeld anstatt dem Wert "warning begin" in korrekter Datums/Uhrzeitform lediglich eine 13stellige Zahl angezeigt wird? Ich finde den Fehler nicht.....
                            Sequal
                            • S Sequal
                              Nabend zusammen,
                              Sequal
                              Kuddel
                              #417
                              @Sequal das kam glaube ich mit dem letzten Update vom DWD Adapter.
                              Habe mich bei in meiner aktuelle VIS gefixt.
                              Widgets:
                              [{"tpl":"tplFrame","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"","title_color":"#FFFFFF","title_top":"-10","title_left":"30","header_height":"0","header_color":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title_back":"","title_font":"","name":"!_Hintergrund"},"style":{"left":"0px","top":"0px","width":"410px","height":"280px","color":"","z-index":"1","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","background":"#202020"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Wetterwarnungen","name":"!_Überschrift"},"style":{"left":"0px","top":"0px","height":"30px","width":"410px","z-index":"10","color":"white","text-align":"center","text-shadow":"","font-family":"Arial, Helvetica, sans-serif","font-style":"","font-variant":"","font-weight":"bolder","font-size":"20px","line-height":"30px","background":"grey"},"widgetSet":"basic"},{"tpl":"tplTimeValue","data":{"oid":"dwd.0.warning.begin","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"format_date":"DD.MM.YYYY - hh:mm","name":"Beginn","visibility-oid":"dwd.0.warning.severity","html_prepend":"Beginn: ","html_append":" Uhr"},"style":{"left":"20px","top":"90px","width":"250px","height":"20px","z-index":"20","font-weight":"bolder","line-height":"20px"},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Beschreibung","value2":"{dwd.0.warning.description}","value3":"{dwd.0.warning.description}","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","visibility-oid":"dwd.0.warning.severity","html_prepend":"","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: orange","value0":"dwd.0.warning.description}","value1":"{dwd.0.warning.description}","value4":"{dwd.0.warning.description}","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: yellow","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red"},"style":{"left":"20px","top":"145px","width":"370px","height":"120px","z-index":"10","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-weight":"bolder","font-size":"medium","line-height":"","background-color":"","border-radius":"","border-width":"","border-style":"","border-color":""},"widgetSet":"basic"},{"tpl":"tplTimeValue","data":{"oid":"dwd.0.warning.end","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"format_date":"DD.MM.YYYY - hh:mm","name":"Ende","visibility-oid":"dwd.0.warning.severity","html_prepend":"Ende: ","html_append":" Uhr"},"style":{"left":"20px","top":"110px","width":"250px","height":"20px","z-index":"20","font-weight":"bolder","line-height":"20px"},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Rahmen","value2":"","value3":"","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","html_prepend":"","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: red","value0":"Keine Meldung vorhanden","value1":"","value4":"","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"boder-color: #41f316","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: orange","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"5px","top":"40px","width":"400px","height":"235px","z-index":"10","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-weight":"bolder","font-size":"20px","line-height":"235px","background-color":"","border-radius":"10px","border-width":"1px","border-style":"solid","border-color":"{wert:dwd.0.warning.severity; wert==0? \"#41f316\": wert==1? \"yellow\": wert==2? \"orange\": wert==3? \"red\": wert==4? \"red\": \"#303030\"} "},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Severity","value2":"{dwd.0.warning.severity}","value3":"{dwd.0.warning.severity}","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","html_prepend":"Crit: ","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: orange","value0":"","value1":"{dwd.0.warning.severity}","value4":"{dwd.0.warning.severity}","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: yellow","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red","visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","visibility-oid":"dwd.0.warning.severity"},"style":{"left":"345px","top":"0px","width":"60px","height":"30px","z-index":"10","text-align":"right","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"medium","line-height":"30px","background-color":"","border-radius":"","border-width":"","border-style":"","border-color":""},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Überschrift","value2":"{dwd.0.warning.text}","value3":"{dwd.0.warning.text}","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","visibility-oid":"dwd.0.warning.severity","html_prepend":"","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: orange","value0":"{dwd.0.warning.text}","value1":"{dwd.0.warning.text}","value4":"{dwd.0.warning.text}","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: yellow","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red"},"style":{"left":"20px","top":"45px","width":"370px","height":"35px","z-index":"10","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"25px","line-height":"30px","background-color":"","border-radius":"","border-width":"","border-style":"","border-color":""},"widgetSet":"basic"}]
                              • K Kuddel
                                   var counter =0;
                                   var on = 0
                                   var manuell=0
                                   			else {
                                   				var con = 1;
                                   						con = 2;
                                   		} else {
                                   		//Alexa2
                                   		//FritzDECT
                                   		//FullyBrowser
                                   		//HM-Rega
                                   		//HomeMatic
                                   		//HomeMatic-IP
                                   		//UPNP
                                           //Pushover.1
                                           //Pushover.2
                                           //DasWetter
                                   		//DWD
                                   		//HM-REGA
                                   		//HM-RPC.0
                                   		//HM-RPC.1
                                   		//MiHome-Vacuum
                                   		//Pushover
                                   		//Simple-API
                                   		//SNMP.0
                                   		//SNMP.1
                                           //Spotify
                                           //TR-064.0
                                   		//TR-064.1
                                           //XPEnology
                                   		//Bild Pfad setzen
                                   		//Uptime setzen
                                   		//MemUsed setzen
                                   		//MemToal setzen
                                   		//MemRSS setzen
                                   		//Connected setzen
                                           //Wert zurücksetzen
                                           var manuell=0
                                       let mSelector;
                                       if (strict) {
                                       } else {
                                           return true;
                                       } else {
                                           return false;
                                KHK
                                #418
                                @Kuddel
                                Habe dein eingestellte Script mal probiert, aber irgenwie werden nicht alle Daten gelesen...oder ist der Eintrag "object.object" richtig?
                                • K KHK
                                  @Kuddel
                                  Kuddel
                                  #419
                                  @KHK ne da läuft was nicht richtig. Uptime und Connected werde nicht korrekt ausgelesen.
                                  Sieht das bei allen Adaptenr so aus?
                                  • K Kuddel
                                    KHK
                                    #420
                                    @Kuddel
                                    ja, deswegen war ich mir nicht ganz sicher...
                                    • K KHK
                                      @Kuddel
                                      Kuddel
                                      #421
                                      @KHK wie sehen deine Einstellungen von der Javascript Instanz aus ?
                                      • K Kuddel
                                        KHK
                                        #422
                                        @Kuddel Der Haken unter "Erlaube das Kommando "sendtohost" war nicht gesetzt. Habe das angepasst, aber keine Änderung.
                                        • K Kuddel
                                          KHK
                                          #423
                                          @Kuddel
                                          Habe im Log dies entdeckt:
                                          Wo könnte ich dies finden?
