  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ModBus
Драйвер ModBus
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
174 Beiträge 25 Kommentatoren 70.3k Aufrufe 2 Beobachtet
    MSapogov
    #66
    @Bluefox:
    @MSapogov:
    @Bluefox:
    А драйвер запущен? В логе есть что нибудь при уровне Debug? `
    Уж не помню где дебаг включается в новой админке…
    modbus-0 2016-10-19 14:27:50.315 info terminating
    RangeError: 2016-10-19 14:27:50.302 error at Socket.Readable.push (_stream_readable.js:111:10)
    RangeError: 2016-10-19 14:27:50.302 error at readableAddChunk (_stream_readable.js:153:18)
    RangeError: 2016-10-19 14:27:50.302 error at Socket.emit (events.js:169:7)
    RangeError: 2016-10-19 14:27:50.302 error at emitOne (events.js:77:13)
    RangeError: 2016-10-19 14:27:50.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-tcp-client.js:129:22)
    RangeError: 2016-10-19 14:27:50.302 error at Object.emit (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit-event-bus/src/stampit-event-bus.js:20:38)
    RangeError: 2016-10-19 14:27:50.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-client-core.js:135:17)
    RangeError: 2016-10-19 14:27:50.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-client-core.js:91:33)
    RangeError: 2016-10-19 14:27:50.302 error at Buffer.readUInt8 (buffer.js:718:5)
    RangeError: 2016-10-19 14:27:50.302 error at checkOffset (buffer.js:680:11)
    RangeError: 2016-10-19 14:27:50.302 error index out of range
    uncaught 2016-10-19 14:27:50.301 error exception: index out of range
    modbus-0 2016-10-19 14:27:50.292 info Connected to slave 192.168.11.205
    modbus-0 2016-10-19 14:27:50.239 warn Serial is not available
    modbus-0 2016-10-19 14:27:50.235 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
    host-Bee-IoT 2016-10-19 14:27:49.803 info instance system.adapter.modbus.0 started with pid 4679
    host-Bee-IoT 2016-10-19 14:27:47.318 info instance system.adapter.modbus.0 terminated with code 0 (OK)
    modbus-0 2016-10-19 14:27:47.307 info terminating
    host-Bee-IoT 2016-10-19 14:27:47.298 info stopInstance system.adapter.modbus.0 killing pid 4668
    host-Bee-IoT 2016-10-19 14:27:47.298 info object change system.adapter.modbus.0
    modbus-0 2016-10-19 14:27:39.556 warn Module serialport is not available
    modbus-0 2016-10-19 14:27:12.621 info Connected to slave 192.168.11.205
    modbus-0 2016-10-19 14:27:12.571 warn Serial is not available
    modbus-0 2016-10-19 14:27:12.567 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
    host-Bee-IoT 2016-10-19 14:27:12.129 info instance system.adapter.modbus.0 started with pid 4668
    host-Bee-IoT 2016-10-19 14:27:12.126 info object change system.adapter.modbus.0
    host-Bee-IoT 2016-10-19 14:27:09.269 info object change system.adapter.modbus.0
    host-Bee-IoT 2016-10-19 14:26:36.974 info object change system.adapter.modbus.0
    host-Bee-IoT 2016-10-19 14:16:51.782 info Do not restart adapter system.adapter.modbus.0 because disabled or deleted
    host-Bee-IoT 2016-10-19 14:16:51.782 error instance system.adapter.modbus.0 terminated with code 3 (Adapter disabled or invalid config)
    host-Bee-IoT 2016-10-19 14:16:38.916 info object change system.adapter.modbus.0
    host-Bee-IoT 2016-10-19 14:16:21.327 info Restart adapter system.adapter.modbus.0 because enabled
    host-Bee-IoT 2016-10-19 14:16:21.327 error instance system.adapter.modbus.0 terminated with code 0 (OK)
    Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:773:21
    Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:1150:13
    Error: 2016-10-19 14:16:21.302 error at clear (/opt/iobroker/node_modules/iobroker.modbus/main.js:1147:22)
    Error: 2016-10-19 14:16:21.302 error at Object.main.start (/opt/iobroker/node_modules/iobroker.modbus/main.js:1631:53)
    Error: 2016-10-19 14:16:21.302 error at Object.Factory [as complete] (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:177:48)
    Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/createForEach.js:15:9
    Error: 2016-10-19 14:16:21.302 error at arrayEach (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/arrayEach.js:15:9)
    Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:185:31
    Error: 2016-10-19 14:16:21.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:119:9)
    Error: 2016-10-19 14:16:21.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:19:23)
    Error: 2016-10-19 14:16:21.302 error No portname.
    uncaught 2016-10-19 14:16:21.301 error exception: No portname.
    modbus-0 2016-10-19 14:16:21.234 warn Serial is not available
    Если удаляю драйвер, а затем его ставлю вновь, то список с COM портами раскрывается (на выбор "Выбирите порт" и "Not available")
    Если сохранить изменения и снова зайти в настройки, то выбора уже никакого нет.
    А поддерживаются только ttyS* порты, или ttyUSB* тоже? `
    Я уже вижу
    А build-essential поставлены? `
    А как-же без нее
    build-essential is already the newest version (12.1ubuntu2).
    При дебаге есть не обльшие отличия…
    modbus-0	2016-10-19 15:06:44.372	debug	statesDB connected
    modbus-0	2016-10-19 15:06:44.366	debug	objectDB connected
    host-Bee-IoT	2016-10-19 15:06:44.036	info	instance system.adapter.modbus.0 started with pid 5312
    host-Bee-IoT	2016-10-19 15:06:44.032	info	object change system.adapter.modbus.0
    host-Bee-IoT	2016-10-19 15:06:36.076	info	Restart adapter system.adapter.modbus.0 because enabled
    host-Bee-IoT	2016-10-19 15:06:36.076	error	instance system.adapter.modbus.0 terminated with code 0 (OK)
    modbus-0	2016-10-19 15:06:36.067	info	terminating
    inMem	2016-10-19 15:06:36.062	debug	message modbus.0.* modbus.0.info.connection val=false, ack=true, ts=1476864396059, q=0, from=system.adapter.modbus.0, lc=1476864395998
    В npm install iobroker.modbus - старый!!!
    Ставлю с гита.
      MSapogov
      #67
      Переткнул USB-RS485 из ESXi в OrangePi PC.
      Там дает выбрать /dev/tyyS0 или /dev/ttyUSB0.
      Выбираю /dev/ttyUSB0.
      После сохранения больше выбрать не дает ничего из портов.
      host-orangepi-iot 2016-10-19 15:16:29.016 info Restart adapter system.adapter.modbus.0 because enabled
      host-orangepi-iot 2016-10-19 15:16:29.015 error instance system.adapter.modbus.0 terminated with code 0 (OK)
      inMem 2016-10-19 15:16:28.964 debug message modbus.0.* modbus.0.info.connection val=false, ack=true, ts=1476864988957, q=0, from=system.adapter.modbus.0, lc=1476864988781
      TypeError: 2016-10-19 15:16:28.938 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError: 2016-10-19 15:16:28.938 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError: 2016-10-19 15:16:28.938 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
      TypeError: 2016-10-19 15:16:28.938 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError: 2016-10-19 15:16:28.938 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:707:35)
      TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:773:21
      TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:1150:13
      TypeError: 2016-10-19 15:16:28.938 error at clear (/opt/iobroker/node_modules/iobroker.modbus/main.js:1147:22)
      TypeError: 2016-10-19 15:16:28.938 error at Object.main.start (/opt/iobroker/node_modules/iobroker.modbus/main.js:1631:53)
      TypeError: 2016-10-19 15:16:28.938 error at Object.Factory [as complete] (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:177:48)
      TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/createForEach.js:15:9
      TypeError: 2016-10-19 15:16:28.938 error at arrayEach (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/arrayEach.js:15:9)
      TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:185:31
      TypeError: 2016-10-19 15:16:28.938 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:119:9)
      TypeError: 2016-10-19 15:16:28.938 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:42:26)
      TypeError: 2016-10-19 15:16:28.938 error at new SerialPort (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/lib/serialport.js:101:11)
      TypeError: 2016-10-19 15:16:28.938 error Invalid "baudRate" must be a number got: 9600
      uncaught 2016-10-19 15:16:28.930 error exception: Invalid "baudRate" must be a number got: 9600
      modbus-0 2016-10-19 15:16:27.951 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
      modbus-0 2016-10-19 15:16:27.772 debug statesDB connected
      modbus-0 2016-10-19 15:16:27.732 debug objectDB connected
      host-orangepi-iot 2016-10-19 15:16:25.456 info instance system.adapter.modbus.0 started with pid 26218
      host-orangepi-iot 2016-10-19 15:16:22.948 info instance system.adapter.modbus.0 terminated with code null ()
      host-orangepi-iot 2016-10-19 15:16:22.947 warn instance system.adapter.modbus.0 terminated due to SIGTERM
      Меня пугает строчка - Invalid "baudRate" must be a number got: 9600
      root@orangepi-iot:~# ls -l /dev/ttyS* /dev/ttyUSB*
      crw--w---- 1 root tty 251, 0 Oct 12 17:17 /dev/ttyS0
      crw-rw---- 1 root dialout 188, 0 Oct 19 15:12 /dev/ttyUSB0
      Может права на порт задать другие?
      • H Offline
        Haus
        #68
        @MSapogov:
        ! host-orangepi-iot 2016-10-19 15:16:29.016 info Restart adapter system.adapter.modbus.0 because enabled host-orangepi-iot 2016-10-19 15:16:29.015 error instance system.adapter.modbus.0 terminated with code 0 (OK) inMem 2016-10-19 15:16:28.964 debug message modbus.0.* modbus.0.info.connection val=false, ack=true, ts=1476864988957, q=0, from=system.adapter.modbus.0, lc=1476864988781 TypeError: 2016-10-19 15:16:28.938 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) TypeError: 2016-10-19 15:16:28.938 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) TypeError: 2016-10-19 15:16:28.938 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12) TypeError: 2016-10-19 15:16:28.938 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9) TypeError: 2016-10-19 15:16:28.938 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:707:35) TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:773:21 TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:1150:13 TypeError: 2016-10-19 15:16:28.938 error at clear (/opt/iobroker/node_modules/iobroker.modbus/main.js:1147:22) TypeError: 2016-10-19 15:16:28.938 error at Object.main.start (/opt/iobroker/node_modules/iobroker.modbus/main.js:1631:53) TypeError: 2016-10-19 15:16:28.938 error at Object.Factory [as complete] (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:177:48) TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/createForEach.js:15:9 TypeError: 2016-10-19 15:16:28.938 error at arrayEach (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/arrayEach.js:15:9) TypeError: 2016-10-19 15:16:28.938 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:185:31 TypeError: 2016-10-19 15:16:28.938 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:119:9) TypeError: 2016-10-19 15:16:28.938 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:42:26) TypeError: 2016-10-19 15:16:28.938 error at new SerialPort (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/lib/serialport.js:101:11) TypeError: 2016-10-19 15:16:28.938 error Invalid "baudRate" must be a number got: 9600 uncaught 2016-10-19 15:16:28.930 error exception: Invalid "baudRate" must be a number got: 9600 modbus-0 2016-10-19 15:16:27.951 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus modbus-0 2016-10-19 15:16:27.772 debug statesDB connected modbus-0 2016-10-19 15:16:27.732 debug objectDB connected host-orangepi-iot 2016-10-19 15:16:25.456 info instance system.adapter.modbus.0 started with pid 26218 host-orangepi-iot 2016-10-19 15:16:22.948 info instance system.adapter.modbus.0 terminated with code null () host-orangepi-iot 2016-10-19 15:16:22.947 warn instance system.adapter.modbus.0 terminated due to SIGTERM `
        У меня всё также
        js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
        admin: 3.6.0
        javascript: 4.1.10
        web: 2.4.1 vis: 1.1.10
        cloud: 2.6.2
        Server: DELL FX170 / linux: Debian 9.5 Stretch
        Adapter: MegaD-2561, Mega-ES…
          MSapogov
          #69
          @Haus:
          @MSapogov:
          После сохранения больше выбрать не дает ничего из портов. У меня всё также
          Проверил, права 666 на /dev/ttyUSB0, не помогают.
          • BluefoxB Offline
            BluefoxB Offline
            #70
            @MSapogov:
            Может права на порт задать другие? `
            Обновись с гита.
              dito85
              #71
              @Bluefox:
              Обновись с гита. `
              Обновился с гита. Не знаю как на serial (нет возможности проверить). А вот у TCP в запросе, ID устройства не меняется, всегда 00.
              • BluefoxB Offline
                BluefoxB Offline
                #72
                @dito85:
                @Bluefox:
                Обновись с гита. Обновился с гита. Не знаю как на serial (нет возможности проверить). А вот у TCP в запросе, ID устройства не меняется, всегда 00.
                Да действительно. Обновись с гита. :)
                  dito85
                  #73
                  @Bluefox:
                  @dito85:
                  @Bluefox:
                  Да действительно. Обновись с гита. :) `
                  Спасибо! Заработало )
                  • BluefoxB Offline
                    BluefoxB Offline
                    #74
                    @dito85:
                    @Bluefox:
                    @dito85:
                    Обновился с гита. Не знаю как на serial (нет возможности проверить). А вот у TCP в запросе, ID устройства не меняется, всегда 00. Да действительно. Обновись с гита. :)
                    Спасибо! Заработало ) `
                    Интересно. Что конкретно заработало? TCP? Master? с кем общается?
                      MSapogov
                      #75
                      @Bluefox:
                      Интересно. Что конкретно заработало? TCP? Master? с кем общается? `
                      TCP заработал как и 0.3.11 (пока одно устройство ID 5 на arduino и 9 Holding регистров)
                      На виртуалке ни вкакую не хочет в IOB видеть COM порты через USB.
                      Что странно, то USB GSM модемы отлично работают в asterisk на этoм-же сервере.
                      PS: RTU на OrangePi PC так-же не дает выбрать порт после сохранения…
                      Но в логах уже есть обнадеживающие записи, касательно USB переходника
                      host-orangepi-iot 2016-10-19 20:58:37.473 info Restart adapter system.adapter.modbus.0 because enabled
                      host-orangepi-iot 2016-10-19 20:58:37.472 error instance system.adapter.modbus.0 terminated with code 0 (OK)
                      modbus-0 2016-10-19 20:58:37.433 info terminating
                      TypeError: 2016-10-19 20:58:37.344 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                      TypeError: 2016-10-19 20:58:37.344 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                      TypeError: 2016-10-19 20:58:37.344 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
                      TypeError: 2016-10-19 20:58:37.344 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                      TypeError: 2016-10-19 20:58:37.344 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                      TypeError: 2016-10-19 20:58:37.344 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                      TypeError: 2016-10-19 20:58:37.344 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                      TypeError: 2016-10-19 20:58:37.344 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                      TypeError: 2016-10-19 20:58:37.344 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                      TypeError: 2016-10-19 20:58:37.344 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                      TypeError: 2016-10-19 20:58:37.344 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                      TypeError: 2016-10-19 20:58:37.344 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:707:35)
                      TypeError: 2016-10-19 20:58:37.344 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:773:21
                      TypeError: 2016-10-19 20:58:37.344 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:1258:13
                      TypeError: 2016-10-19 20:58:37.344 error at clear (/opt/iobroker/node_modules/iobroker.modbus/main.js:1255:22)
                      TypeError: 2016-10-19 20:58:37.344 error at Object.main.start (/opt/iobroker/node_modules/iobroker.modbus/main.js:1583:26)
                      TypeError: 2016-10-19 20:58:37.344 error modbusClient.connect is not a function
                      uncaught 2016-10-19 20:58:37.334 error exception: modbusClient.connect is not a function
                      modbus-0 2016-10-19 20:58:36.299 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
                      host-orangepi-iot 2016-10-19 20:58:33.737 info instance system.adapter.modbus.0 started with pid 31857
                      host-orangepi-iot 2016-10-19 20:58:31.239 info instance system.adapter.modbus.0 terminated with code 0 (OK)
                      modbus-0 2016-10-19 20:58:31.204 info terminating
                      host-orangepi-iot 2016-10-19 20:58:31.157 info stopInstance system.adapter.modbus.0 killing pid 31773
                      host-orangepi-iot 2016-10-19 20:58:31.155 info stopInstance system.adapter.modbus.0
                      host-orangepi-iot 2016-10-19 20:58:31.145 info object change system.adapter.modbus.0
                      modbus-0 2016-10-19 20:58:06.901 info List of port: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86","serialNumber":"1a86_USB2.0-Serial","pnpId":"usb-1a86_USB2.0-Serial-if00-port0","vendorId":"0x1a86","productId"
                      modbus-0 2016-10-19 20:57:53.650 warn Error: connect ECONNREFUSED 127.0.0.1:502
                      modbus-0 2016-10-19 20:57:52.541 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
                      iobroker 2016-10-19 20:57:49.956 info exit 0
                      iobroker 2016-10-19 20:57:49.936 info host.orangepi-iot object system.adapter.modbus.0 created
                      • BluefoxB Offline
                        BluefoxB Offline
                        #76
                        Мы достаточно близко подошли к решению.
                        Попробуй ещё раз обновиться
                        • H Offline
                          Haus
                          #77
                          @MSapogov:
                          @Bluefox:
                          ! host-orangepi-iot 2016-10-19 20:58:37.473 info Restart adapter system.adapter.modbus.0 because enabled host-orangepi-iot 2016-10-19 20:58:37.472 error instance system.adapter.modbus.0 terminated with code 0 (OK) modbus-0 2016-10-19 20:58:37.433 info terminating TypeError: 2016-10-19 20:58:37.344 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) TypeError: 2016-10-19 20:58:37.344 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) TypeError: 2016-10-19 20:58:37.344 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16) TypeError: 2016-10-19 20:58:37.344 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12) TypeError: 2016-10-19 20:58:37.344 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) TypeError: 2016-10-19 20:58:37.344 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) TypeError: 2016-10-19 20:58:37.344 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8) TypeError: 2016-10-19 20:58:37.344 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) TypeError: 2016-10-19 20:58:37.344 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) TypeError: 2016-10-19 20:58:37.344 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12) TypeError: 2016-10-19 20:58:37.344 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9) TypeError: 2016-10-19 20:58:37.344 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:707:35) TypeError: 2016-10-19 20:58:37.344 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:773:21 TypeError: 2016-10-19 20:58:37.344 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:1258:13 TypeError: 2016-10-19 20:58:37.344 error at clear (/opt/iobroker/node_modules/iobroker.modbus/main.js:1255:22) TypeError: 2016-10-19 20:58:37.344 error at Object.main.start (/opt/iobroker/node_modules/iobroker.modbus/main.js:1583:26) TypeError: 2016-10-19 20:58:37.344 error modbusClient.connect is not a function uncaught 2016-10-19 20:58:37.334 error exception: modbusClient.connect is not a function modbus-0 2016-10-19 20:58:36.299 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus host-orangepi-iot 2016-10-19 20:58:33.737 info instance system.adapter.modbus.0 started with pid 31857 host-orangepi-iot 2016-10-19 20:58:31.239 info instance system.adapter.modbus.0 terminated with code 0 (OK) modbus-0 2016-10-19 20:58:31.204 info terminating host-orangepi-iot 2016-10-19 20:58:31.157 info stopInstance system.adapter.modbus.0 killing pid 31773 host-orangepi-iot 2016-10-19 20:58:31.155 info stopInstance system.adapter.modbus.0 host-orangepi-iot 2016-10-19 20:58:31.145 info object change system.adapter.modbus.0 modbus-0 2016-10-19 20:58:06.901 info List of port: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86","serialNumber":"1a86_USB2.0-Serial","pnpId":"usb-1a86_USB2.0-Serial-if00-port0","vendorId":"0x1a86","productId" modbus-0 2016-10-19 20:57:53.650 warn Error: connect ECONNREFUSED 127.0.0.1:502 modbus-0 2016-10-19 20:57:52.541 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus iobroker 2016-10-19 20:57:49.956 info exit 0 iobroker 2016-10-19 20:57:49.936 info host.orangepi-iot object system.adapter.modbus.0 created `
                          iobroker upload modbus
                          у тебя версия старая
                          У меня свисток зацепило с 0.4.1, пока нечем упровлять
                          log
                          inMem	2016-10-19 18:21:16.512	debug	message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1476890476494, q=0, from=system.adapter.admin.0, lc=1476890476494
                          modbus-0	2016-10-19 18:21:11.815	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.modbus.0
                          modbus-0	2016-10-19 18:21:11.813	info	List of port: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86","serialNumber":"1a86_USB2.0-Ser_","p
                          inMem	2016-10-19 18:21:11.637	debug	message messagebox.system.adapter.modbus.0 messagebox.system.adapter.modbus.0 command=listUart, message=null, from=system.adapter.admin.0, message=null, id=244, ack=false, time=1476890471631, _id=75
                          inMem	2016-10-19 18:21:10.952	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1476890470933, q=0, from=system.adapter.admin.0, lc=1476890470933
                          inMem	2016-10-19 18:20:26.355	debug	message modbus.0.* modbus.0.info.pollTime val=8, ack=true, ts=1476890426342, q=0, from=system.adapter.modbus.0, lc=1476890426342
                          inMem	2016-10-19 18:20:26.346	debug	message modbus.0.* modbus.0.info.connection val=true, ack=true, ts=1476890426332, q=0, from=system.adapter.modbus.0, lc=1476890426332
                          modbus-0	2016-10-19 18:20:26.330	info	Connected to slave
                          modbus-0	2016-10-19 18:20:25.459	info	starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.modbus
                          modbus-0	2016-10-19 18:20:25.349	debug	statesDB connected
                          modbus-0	2016-10-19 18:20:25.320	debug	objectDB connected
                          host-Server-PC	2016-10-19 18:20:23.522	info	instance system.adapter.modbus.0 started with pid 17789
                          host-Server-PC	2016-10-19 18:20:23.480	info	object change system.adapter.modbus.0
                          host-Server-PC	2016-10-19 18:19:55.221	info	object change system.adapter.modbus.0
                          admin: 3.6.0
                          javascript: 4.1.10
                          cloud: 2.6.2
                            MSapogov
                            #78
                            @Bluefox:
                            Попробуй ещё раз обновиться `
                            0.4.1
                            Теперь COM порт запоминает!
                            Я вижу появился бонус "RTU over TCP".
                            Проверить работу RTU смогу только завтра (это часов через 12)
                            PS: Как можно виртуалку на ESXi с USB-COM портом победить? При выборе Not available.
                            ! log
                            host-Bee-IoT	2016-10-19 22:57:09.443	info	stopInstance system.adapter.modbus.0 killing pid 3868
                            host-Bee-IoT	2016-10-19 22:57:09.443	info	object change system.adapter.modbus.0
                            modbus-0	2016-10-19 22:56:50.658	warn	Module serialport is not available
                            modbus-0	2016-10-19 22:56:44.854	error	IP address is not defined
                            modbus-0	2016-10-19 22:56:44.815	warn	Serial is not available
                            modbus-0	2016-10-19 22:56:44.811	info	starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.modbus
                            host-Bee-IoT	2016-10-19 22:56:44.368	info	instance system.adapter.modbus.0 started with pid 3868
                            IOB Ubuntu
                            root@Bee-IoT:~# lsusb
                            Bus 002 Device 005: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
                            Bus 002 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
                            Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
                            Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
                            Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                            root@Bee-IoT:~# ls -l /dev/ttyS* /dev/ttyUSB*
                            crw-rw---- 1 root dialout 4, 64 окт 19 20:57 /dev/ttyS0
                            crw-rw---- 1 root dialout 4, 65 окт 19 20:57 /dev/ttyS1
                            crw-rw---- 1 root dialout 4, 74 окт 19 20:57 /dev/ttyS10
                            crw-rw---- 1 root dialout 4, 75 окт 19 20:57 /dev/ttyS11
                            crw-rw---- 1 root dialout 4, 76 окт 19 20:57 /dev/ttyS12
                            crw-rw---- 1 root dialout 4, 77 окт 19 20:57 /dev/ttyS13
                            crw-rw---- 1 root dialout 4, 78 окт 19 20:57 /dev/ttyS14
                            crw-rw---- 1 root dialout 4, 79 окт 19 20:57 /dev/ttyS15
                            crw-rw---- 1 root dialout 4, 80 окт 19 20:57 /dev/ttyS16
                            crw-rw---- 1 root dialout 4, 81 окт 19 20:57 /dev/ttyS17
                            crw-rw---- 1 root dialout 4, 82 окт 19 20:57 /dev/ttyS18
                            crw-rw---- 1 root dialout 4, 83 окт 19 20:57 /dev/ttyS19
                            crw-rw---- 1 root dialout 4, 66 окт 19 20:57 /dev/ttyS2
                            crw-rw---- 1 root dialout 4, 84 окт 19 20:57 /dev/ttyS20
                            crw-rw---- 1 root dialout 4, 85 окт 19 20:57 /dev/ttyS21
                            crw-rw---- 1 root dialout 4, 86 окт 19 20:57 /dev/ttyS22
                            crw-rw---- 1 root dialout 4, 87 окт 19 20:57 /dev/ttyS23
                            crw-rw---- 1 root dialout 4, 88 окт 19 20:57 /dev/ttyS24
                            crw-rw---- 1 root dialout 4, 89 окт 19 20:57 /dev/ttyS25
                            crw-rw---- 1 root dialout 4, 90 окт 19 20:57 /dev/ttyS26
                            crw-rw---- 1 root dialout 4, 91 окт 19 20:57 /dev/ttyS27
                            crw-rw---- 1 root dialout 4, 92 окт 19 20:57 /dev/ttyS28
                            crw-rw---- 1 root dialout 4, 93 окт 19 20:57 /dev/ttyS29
                            crw-rw---- 1 root dialout 4, 67 окт 19 20:57 /dev/ttyS3
                            crw-rw---- 1 root dialout 4, 94 окт 19 20:57 /dev/ttyS30
                            crw-rw---- 1 root dialout 4, 95 окт 19 20:57 /dev/ttyS31
                            crw-rw---- 1 root dialout 4, 68 окт 19 20:57 /dev/ttyS4
                            crw-rw---- 1 root dialout 4, 69 окт 19 20:57 /dev/ttyS5
                            crw-rw---- 1 root dialout 4, 70 окт 19 20:57 /dev/ttyS6
                            crw-rw---- 1 root dialout 4, 71 окт 19 20:57 /dev/ttyS7
                            crw-rw---- 1 root dialout 4, 72 окт 19 20:57 /dev/ttyS8
                            crw-rw---- 1 root dialout 4, 73 окт 19 20:57 /dev/ttyS9
                            crw-rw---- 1 root dialout 188, 0 окт 19 22:55 /dev/ttyUSB0
                            crw-rw---- 1 root dialout 188, 1 окт 19 22:55 /dev/ttyUSB1
                            root@Bee-IoT:~#
                              MSapogov
                              #79
                              @Haus:
                              У меня свисток зацепило с 0.4.1, пока нечем упровлять `
                              На тот момент была только 0.4.0 (с доработками)
                              А у тебя IOB локально работает или на виртуалке?
                              И как свисток свисток подключен к IOB?
                              • H Offline
                                Haus
                                #80
                                @MSapogov:
                                @Haus:
                                И как свисток свисток подключен к IOB? `
                                ioBroker локально работает, USB-RS485 настройка /dev/ttyUSB2. ttyUSB0 и ttyUSB1 мастера 1-wite.
                                admin: 3.6.0
                                javascript: 4.1.10
                                cloud: 2.6.2
                                  MSapogov
                                  #81
                                  Serial RTU - на сколько смог проверил. (пока одно устройство ID 5 на arduino и 9 Holding регистров)
                                  Работает…
                                  Странно, если разорвать RS-485, а потом обратно соединить, то опрос невзобновляется. (Recconect time - 60000 ms)
                                  В логах````
                                  modbus-0 2016-10-20 10:27:07.660 warn Poll error count: 1 code: {"err":"timeout"}
                                  Приходится перезапускать драйвер.
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #82
                                    @MSapogov:
                                    Работает…
                                    В логах````
                                    Приходится перезапускать драйвер. `
                                    Попробуй ещё раз обновиться.
                                      MSapogov
                                      #83
                                      @Bluefox:
                                      @MSapogov:
                                      В логах````
                                      Попробуй ещё раз обновиться. `
                                      0.4.2
                                      Ждал 5 минут, опросы не взобновились.
                                      Я только разрываю линию RS-485.
                                      Кажется когда эксперементировал с ModbusTCP то при разрыве WiFi было так-же.
                                      • V Offline
                                        V Offline
                                        VictorS
                                        #84
                                        Добрый день всем.
                                        Столкнулся со странной штукой - установлен драйвер 0.4.5, хочу затащить в IOB данные с контроллера datakom via Modbus RTU.
                                        Для чего через socat был поднят виртуальный serial порт в системе (виртуалка VurtualBox).
                                        Тестовая утилитка modpoll видит устройство через виртуальный порт и прекрасно получает данные:
                                        ./modpoll -m rtu -a 1 -t 4 -r 48 -b 9600 -p none /dev/ttyvir0
                                        ! modpoll 3.4 - FieldTalk™ Modbus(R) Master Simulator
                                        ! Copyright (c) 2002-2013 proconX Pty Ltd
                                        ! Visit http://www.modbusdriver.com for Modbus libraries and tools.
                                        ! Protocol configuration: Modbus RTU
                                        ! Slave configuration...: address = 1, start reference = 48, count = 1
                                        ! Communication.........: /dev/ttyvir0, 9600, 8, 1, none, t/o 1.00 s, poll rate 1000 ms
                                        ! Data type.............: 16-bit register, output (holding) register table
                                        ! -- Polling slave... (Ctrl-C to stop)
                                        ! [48]: 120
                                        ! – Polling slave... (Ctrl-C to stop)
                                        ! [48]: 120
                                        ! [48]: 120
                                        ! [48]: 120
                                        Но тут мое счастье и закончилось. Драйвер не видит этот порт в упор в списке. Права 666 не помогли.
                                        Решил немного обмануть драйвер, сделал виртуальный порт как ttyS33. Результат - драйвер не видит ничего вообще. В списке undefined.
                                        Как пофиксить, никто не знает?
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          #85
                                          Можешь создать в папке node_modules/iobroker.modbus файл port.js:
                                          var serialport = require('serialport');
                                          serialport.list(function (err, ports) {
                                          	console.log(JSON.stringify(ports, null, 2));
                                          	process.exit();
                                          Запустить его из консоли node port.js
                                          Вот что я вижу:
                                          C:\ioBroker\node_modules\ioBroker.modbus>node port.js
                                              "comName": "COM3",
                                              "manufacturer": "Intel",
                                              "pnpId": "PCI\\VEN_8086&DEV_1E3D&SUBSYS_ABCDED&REV_04\\3&11583666&0&B3"
                                              "comName": "COM1",
                                              "manufacturer": "(����������� �����)",
                                              "pnpId": "ACPI\\PNP0501\\1"
                                          А у тебя?
