  4. Amazon dash
    5.5k
Amazon dash
6 Beiträge 2 Kommentatoren 960 Aufrufe
  • DirkKD Offline
    DirkKD Offline
    DirkK
    Hallo Zusammen,
    Ich hab gestern meinen dash bekommen und hab diesen aktiviert. Nun wollte ich den Adapter installieren und bekam eine Fehlermeldung,
    sowohl auf dem Raspi II mit node 6.7.0, wie auch auf dem Raspi III mit node 4.4.2
    Hier die Fehlermeldung:
    $ ./iobroker add amazon-dash
    npm install iobroker.amazon-dash –production --prefix "/opt/iobroker" (System call)
    ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">^
    compilation terminated.
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
    gyp
    ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack at emitTwo (events.js:106:13)gyp ERR! stack
    at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
    gyp ERR! System Linux 4.1.19-v7+
    gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/pcap
    gyp ERR! node -v v6.7.0
    gyp ERR! node-gyp -v v3.3.1
    gyp ERR! not ok
    npm
    WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/authenticate-pam/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/package.json'
    npm
    ERR! Linux 4.1.19-v7+
    npm
    ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"npm
    ERR!
    node v6.7.0npm ERR!
    npm v3.10.3npm ERR! code ELIFECYCLE
    npm ERR! pcap@2.0.0 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the pcap package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs pcap
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm owner ls pcap
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm
    ERR! /npm-debug.log
    ERROR: host.RPi2 Cannot install iobroker.amazon-dash: 1
    Hat vieleicht schon jemand Erfahrung und eine Idee?</pcap>
    Gruß Dirk
    Raspi3 CCU
      Da gibt es schon einigesczu.
      Node 6 läuft nicht immer und npm 3 schon gar nicht.
      Empfohlen ist node 4.5 und npm 2.x
      • DirkKD Offline
        DirkKD Offline
        DirkK
        Na das war fix,
        was ist~~@Homoran:~~
        Empfohlen ist node 4.5 und npm 2.x `
        npm ?
        Gruß Dirk
        Raspi3 CCU
          Steht beivdir im error log
          @DirkK:
          node v6.7.0npm ERR!
          npm v3.10.3npm ERR `
          Benutzt du zum installieren: " npm install iobroker…. "
          Node package manager, wird auch bei Debian mit node installiert.
          • DirkKD Offline
            DirkKD Offline
            DirkK
            OK, Danke, jetzt muß ich "erst mal in mich gehen", kann man andere Versionen drüberbügeln? Mein Ahne hat gerade das selbe Problem, aber irgendwie kriegt der keine
            Vorgängerversion drauf.
            Gruß Dirk
            Raspi3 CCU
              Node steht auf der Website unter Jessie schnellstart.
              Npm hat Bluefox hier im forum schon öfter geschrieben.
