  4. Iobroker, Wert von mysensors an CCU übergeben
2 Beiträge 2 Kommentatoren 719 Aufrufe
  • I Offline
    I Offline
    iobroker-6043
    Hallo Community
    Kriege meine Temperaturwerde von mysensors/nodeMCU TempSensor.
    Möchte diesen Wert in eine CCU Systemvariable schreiben.
    setState('hm-rega.0.5237', '"mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP"/192_168_1_103.0.0_TEMP.V_TEMP/');
    "common": {
    "name": "192_168_1_103.0.0_TEMP.V_TEMP",
    "type": "string",
    "role": "value.temperature",
    "min": 0,
    "def": 0,
    "read": true,
    "write": false
    "native": {
    "ip": "192.168.1.103",
    "id": "0",
    "childId": "0",
    "subType": "S_TEMP",
    "varType": "V_TEMP",
    "subTypeNum": 6,
    "varTypeNum": 0
    "acl": {
    "object": 1638,
    "owner": "system.user.admin",
    "state": 1638
    "_id": "mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP",
    "type": "state"
    • paul53P Offline
      Das Datenpunktobjekt hat eine falschen "type": "string"; es sollte "type": "number" sein. Außerdem fehlt "unit": "°C".
      "common": {
      "type": "number",
      "min": 0,
      "def": 0,
      "read": true,
      "write": false,
      "unit": "°C"
      "native": {
      "id": "0",
      "childId": "0",
      "subTypeNum": 6,
      "varTypeNum": 0
      "acl": {
      "object": 1638,
      "state": 1638
      "type": "state"
      Wenn die Werte vom Typ "number" sind:
      setState('hm-rega.0.5237', getState('mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP').val);
      Wenn die Werte aber vom Typ "string" sind, dann:
      setState('hm-rega.0.5237', parseFloat(getState('mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP').val));
      Den Typ kann man testen:
      log('Typ: ' + typeof getState('mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP').val);
