  4. Phantom.js lässt sich nicht auf aktuellem System installieren…
    5.5k
4 Beiträge 3 Kommentatoren 1.1k Aufrufe
    Semenchkare
    habe folgendes Problem: Sowohl vom Admin aus als auch von der Konsole kann ich phantom.js nicht installieren.
    Hier mal ein paar Meldungen:
    root@bananapim2:~# sudo npm install iobroker.phantomjs-prebuilt –production
    npm ERR! Linux 4.6.3-sunxi
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.phantomjs-prebuilt" "--production"
    npm ERR! node v5.12.0
    npm ERR! npm v3.8.6
    npm ERR! code E404
    npm ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/iobroker.phantomjs-prebuilt
    npm ERR! 404
    npm ERR! 404 'iobroker.phantomjs-prebuilt' is not in the npm registry.
    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR! Please include the following file with any support request:
    npm ERR! /root/npm-debug.log
    root@bananapim2:~# sudo npm install iobroker.phantomjs --production
    phantomjs-prebuilt@2.1.12 install /root/node_modules/phantomjs-prebuilt
    node install.js
    PhantomJS not found on PATH
    Unexpected platform or architecture: linux/arm
    It seems there is no binary available for your platform/architecture
    Try to install PhantomJS globally
    npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
    npm WARN root No description
    npm WARN root No repository field.
    npm WARN root No README data
    npm WARN root No license field.
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.phantomjs" "--production"
    npm ERR! npm v3.8.6
    npm ERR! code ELIFECYCLE
    npm ERR! phantomjs-prebuilt@2.1.12 install: node install.js
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the phantomjs-prebuilt@2.1.12 install script 'node install.js'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the phantomjs-prebuilt package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node install.js
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs phantomjs-prebuilt
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR! npm owner ls phantomjs-prebuilt
    npm ERR! There is likely additional logging output above.
    Kann hier jemand was damit anfangen?
    ach ja, unter raspi2 und jessie das Gleiche.... liegt also nicht am armbian...
    PS alles andere läuft seit Wochen super. BS: Armbian, aktuellste Version.
    Viele Grüße
    Semenchkare
    raspberry 5 8GB mit iobroker,
    raspberry 5 8GB mit Raspberrymatic
      Du hast node v5.12 und npm 3.8.6
      Ob nodejs 5.xx problemlos läuft, weiss ich nicht, aber es wird 4.5 empfohlen.
      Auf jeden Fall macht npm v3.xx Probleme. Hier soll v2.xx verwendet werden.
        Semenchkare
        Hallo Hormoran,
        vielen Dank.
        Aber ich werde nicht downgraden. Da ist wohl der Entwickler am Zug…
        Ansonsten sehe ich mich nach Alternativen um.
        P.S.: Sinnvoll wäre, phantom hier aus dem Admin herauszunehmen, solange nicht aktuell...
        Viele Grüße
        Semenchkare
        • N Offline
          N Offline
          nobody
          Die Installation klappt nicht, weil es keine Binärversion für ARM gibt.
          http://phantomjs.org/download.html
          Wenn man sich die Hardwareanforderungen anschaut sollte dies verständlich sein, warum nicht
          [emoji6]
          http://phantomjs.org/build.html
          Gesendet von meinem GT-N8000 mit Tapatalk
