  4. Border in 3D Optik
    2.6k
    4.5k
Border in 3D Optik
vis
37 Beiträge 3 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • AlmixxA Almixx
    @Glasfaser dankeschön.
    GlasfaserG Offline
    GlasfaserG Offline
    @Almixx
    hier mit Zustand ... wie auf deinem Bild
    hier dein Datenpunkt eintragen :
    [{"tpl":"tplJquiButtonNav","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttontext":"WGR ein ","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":"{wert:0_userdata.0.Test123; wert==\"true\" ? \"UiStyle\" : \" \" }"},"style":{"left":"283px","top":"351px","width":"171px","height":"54px","border-color":"silver","border-style":"outset","border-radius":"1px","border-width":"8px"},"widgetSet":"jqui"}]
    .UiStyle .ui-button {
    background: green !important;
    AlmixxA 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @Almixx
      AlmixxA Offline
      AlmixxA Offline
      Almixx
      @Glasfaser
      Ich bekomme das irgendwie nicht hin... Im Reiter CSS 2 Buttons angelegt, normalen und aktiven, aber verfärben tut sich in der vis gar nichts... unter CSS Klasse habe ich "button_test" eingegeben. 😖 🤔
      .button_test
              height:50px;
          	width:100px;
          	line-height:20px;
              text-align:center;
              vertical-align:middle;
          	border:silver solid 3px;
              border-radius: 5px;
          	font-size:22px;
          	background: silver;
              color:white;
      .button_test :active
              height:50px;
          	width:100px;
          	line-height:20px;
              text-align:center;
          	border:#47aaff solid 3px;
              border-radius: 5px;
          	font-size:22px;
          	background: silver;
              color:white;
      • AlmixxA Almixx
        @Glasfaser
        .button_test
                height:50px;
            	width:100px;
            	line-height:20px;
                text-align:center;
                border-radius: 5px;
            	font-size:22px;
            	background: silver;
                color:white;
                height:50px;
            	width:100px;
            	line-height:20px;
                text-align:center;
                border-radius: 5px;
            	font-size:22px;
            	background: silver;
                color:white;
        GlasfaserG Offline
        GlasfaserG Offline
        @Almixx
        keine Ahnung was du machen willst ..
        aber setze mal dahinter
        !important;
        .button_test
                height:50px !important;
            	width:100px !important;
          @Almixx
          !important;
          .button_test
          AlmixxA Offline
          AlmixxA Offline
          Almixx
          @Glasfaser
          möchte das der Rahmen bei Betätigung des Buttons die Farbe ändert
          • AlmixxA Almixx
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @Almixx
            hier eintragen (Datenpunkt anpassen ) :
            {wert:0_userdata.0.Test123; wert=="true" ? "green" : "silver" }
            P 1 Antwort Letzte Antwort
              @Almixx
              pix
              @Almixx Denke bitte daran, das Bindings ("{}") nicht im Edit-Modus von VIS funktionieren. Also zum Testen immer die Runtime-Version laden (Playknopf oben rechts).
              @Glasfaser hat dir zwei Möglichkeiten der Formatierung angeboten. Du kannst das Aussehen des Buttons über die CSS Ränder Einstellungen des Widgets einstellen. Mit Hilfe eines Bindings kann das abhängig vom Zustand des Datenpunkts "0_userdata.0.Test123" gemacht werden. Ist der Datenpunkt true, wird's grün, sonst silber.
              Für die erste Lösung von @Glasfaser musst du den CSS-Code in den Reiter CSS packen und per Klasse aufrufen. Wenn das Element (hier das Widget mit dem Rand) die Klasse "UiStyle" hat, wird es - wie im CSS-Code hinterlegt - formatiert. Damit es diese Klasse bekommt, hat @Glasfaser wieder ein Binding genutzt. Wenn der Datenpunkt wahr ist, heißt die Klasse "UiStyle" und das Widget wird entsprechend formatiert. Ist er falsch, wird keine Klasse gesetzt, es passiert nix.
              Das ist aber keine Reaktion auf den Klick/Touch, sonder auf den Zustand des Datenpunkts. Für Klick/touch kannst du "active" nehmen. Dann sollte eine extra CSS-Klasse (im Reiter "Generell") dauerhaft gesetzt werden. ZB. "aktiv_bei_touch". Im CSS-Reiter formatierst du dann so
              .aktiv_bei_touch:active {
                 border: 5px dotted red;
              .aktiv_bei_touch {
                border: 5px solid green;
              Wenn das Widget dann aktiv ist (geklickt oder touched), sollte es kurz die Erscheinung ändern. Das geht mit jedem Widget.
              Pix
              • P pix
                .aktiv_bei_touch {
                Pix
                AlmixxA Offline
                AlmixxA Offline
                Almixx
                @pix @Glasfaser , vielen Dank an euch, hat jetzt endlich funktioniert, obwohl ich das gestern schonmal so probiert hatte..
                Mir ist aber aufgefallen, daß sich beim jqui-ctrl-Icon die Backgroundfarbe ändern lässt, beim state Button hingegen nicht. Auch nicht mit !important möglich. Ist das so? oder muß ich noch was beachten.
                Nicht verwirren lassen, experementiere mit verschiedenen Designs für Buttons 🙈 ☺
                • AlmixxA Almixx
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Almixx sagte in Border in 3D Optik:
                  die Backgroundfarbe ändern lässt , beim state Button hingegen nicht
                  funktioniert doch ..
                    AlmixxA Offline
                    AlmixxA Offline
                    Almixx
                    schrieb am zuletzt editiert von Almixx
                    @Glasfaser
                    Ich muß noch mal nerven 🙈
                    Die State Buttons funktionieren nicht, nur an den Ecken sieht man ganz leicht die Farbe durchschimmern. Nimmt auch Schriftgröße etc. so nicht an...
                    .button_rollo
                            height:40px !important;
                        	line-height: 22px !important;
                            text-align:center !important;
                            border-radius: 5px;
                            border-style: outset;
                            vertical-align:middle !important;
                        	border-radius: 5px !important;
                        	font-size: 20px !important;
                        	background: linear-gradient(0deg, red, yellow) !important;
                            color:white;
                    Farbe hab ich übrigens mal bewusst so gesetzt 😊
                    • AlmixxA Almixx
                      @Glasfaser
                      .button_rollo
                              border-radius: 5px;
                              color:white;
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Almixx
                      Stelle mir mal die gesamte Widget wie du es oben eingestellt hast mal zur Verfügung , damit ich es überprüfen kann .
                      Ich denke mal das ist ein Dialog View und du hast diese Rollo Büro in einem extra View.
                      ... oder das View , wäre natürlich auch besser .
                      setze es dann auch in ein Spoiler ( ist das Augensymbol )
                      hier dein View
                      • AlmixxA Almixx
                        @Glasfaser
                        .button_rollo
                                border-radius: 5px;
                                color:white;
                        GlasfaserG Offline
                        GlasfaserG Offline
                        nimm mal das :
                        .button_rollo .ui-button
                                border-radius: 5px;
                                color:white;
                          nimm mal das :
                                  border-radius: 5px;
                                  color:white;
                          AlmixxA Offline
                          AlmixxA Offline
                          Almixx
                          @Glasfaser probier ich später mal, bin noch auf schicht... danke
                            @Almixx
                            hier dein View
                            AlmixxA Offline
                            AlmixxA Offline
                            Almixx
                            @Glasfaser, hat zum Teil funktioniert. Die Hintergrundfarbe passte jetzt, dafür wurde der Button etwas kleiner. Die toggle Buttons änderten sich total in den Abmessungen. Was bewirkt dieses .ui-button?
                              "settings": {
                                "style": {
                                  "background": "",
                                  "background_class": ""
                                "theme": "dark-hive",
                                "sizex": "1381",
                                "sizey": "671",
                                "gridSize": "",
                                "useBackground": true,
                                "snapType": null,
                                "useAsDefault": true
                              "widgets": {
                                "e00001": {
                                  "tpl": "tplMfdShutter",
                                  "data": {
                                    "oid": "shelly.0.SHSW-25#69397C#1.Shutter.Position",
                                    "g_fixed": true,
                                    "g_visibility": true,
                                    "g_css_font_text": false,
                                    "g_css_background": false,
                                    "g_css_shadow_padding": false,
                                    "g_css_border": false,
                                    "g_gestures": false,
                                    "g_signals": false,
                                    "g_last_change": false,
                                    "visibility-cond": "==",
                                    "visibility-val": 1,
                                    "visibility-groups-action": "hide",
                                    "asButton": false,
                                    "signals-cond-0": "==",
                                    "signals-val-0": true,
                                    "signals-icon-0": "/vis/signals/lowbattery.png",
                                    "signals-icon-size-0": 0,
                                    "signals-blink-0": false,
                                    "signals-horz-0": 0,
                                    "signals-vert-0": 0,
                                    "signals-hide-edit-0": false,
                                    "signals-cond-1": "==",
                                    "signals-val-1": true,
                                    "signals-icon-1": "/vis/signals/lowbattery.png",
                                    "signals-icon-size-1": 0,
                                    "signals-blink-1": false,
                                    "signals-horz-1": 0,
                                    "signals-vert-1": 0,
                                    "signals-hide-edit-1": false,
                                    "signals-cond-2": "==",
                                    "signals-val-2": true,
                                    "signals-icon-2": "/vis/signals/lowbattery.png",
                                    "signals-icon-size-2": 0,
                                    "signals-blink-2": false,
                                    "signals-horz-2": 0,
                                    "signals-vert-2": 0,
                                    "signals-hide-edit-2": false,
                                    "lc-type": "last-change",
                                    "lc-is-interval": true,
                                    "lc-is-moment": false,
                                    "lc-format": "",
                                    "lc-position-vert": "top",
                                    "lc-position-horz": "right",
                                    "lc-offset-vert": 0,
                                    "lc-offset-horz": 0,
                                    "lc-font-size": "12px",
                                    "lc-font-family": "",
                                    "lc-font-style": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-border-width": "0",
                                    "lc-border-style": "",
                                    "lc-border-color": "",
                                    "lc-border-radius": 10,
                                    "lc-zindex": 0,
                                    "min": "0",
                                    "max": "100",
                                    "show_active": false,
                                    "invert_icon": false,
                                    "iconColor": "#ffffff",
                                    "iconColor0": ""
                                  "style": {
                                    "left": "268px",
                                    "top": "110px",
                                    "width": "140px",
                                    "height": "156px",
                                    "z-index": "1"
                                  "widgetSet": "jqui-mfd"
                                "e00002": {
                                  "tpl": "tplFrame",
                                  "data": {
                                    "title": "Rollo Büro",
                                    "title_color": "black",
                                    "title_top": "5",
                                    "title_left": "5",
                                    "header_height": "30",
                                    "header_color": "#47aaff",
                                    "signals-icon-size-0": "1",
                                    "name": "Rollo Büro",
                                    "lc-format": "DD.MM.YYYY hh:mm:ss",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "title_font": "",
                                    "gestures-swipeRight-limit": "7",
                                    "gestures-swiping-minimum": "-3",
                                    "gestures-rotateRight-limit": "0",
                                    "gestures-rotating-delta": "2"
                                  "style": {
                                    "left": "50px",
                                    "top": "111px",
                                    "width": "351px",
                                    "height": "243px",
                                    "font-family": "Verdana, Geneva, sans-serif",
                                    "font-style": "normal",
                                    "font-variant": "normal",
                                    "font-weight": "bold",
                                    "font-size": "large",
                                    "z-index": "0",
                                    "background": "",
                                    "border-width": "5px",
                                    "border-style": "solid",
                                    "border-color": "#9f9d9d",
                                    "border-radius": "4px",
                                    "opacity": "",
                                    "background-color": "",
                                    "box-shadow": "4px 4px 4px rgba(4, 4, 4, 4)"
                                  "widgetSet": "basic"
                                "e00003": {
                                  "tpl": "tplValueFloatBar",
                                  "data": {
                                    "factor": "1",
                                    "color": "#47aaff",
                                    "min": "0",
                                    "max": "100",
                                    "orientation": "horizontal",
                                    "gestures-offsetX": 0,
                                    "gestures-offsetY": 0,
                                    "name": "",
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "comment": "",
                                    "reverse": false
                                  "style": {
                                    "left": "77px",
                                    "top": "192px",
                                    "width": "200px",
                                    "height": "16px",
                                    "border-color": "white",
                                    "border-radius": "5px",
                                    "border-width": "1px",
                                    "z-index": "1"
                                "e00004": {
                                  "tpl": "tplValueFloat",
                                  "data": {
                                    "is_comma": false,
                                    "factor": "1",
                                    "html_append_singular": " %",
                                    "html_append_plural": " %",
                                    "is_tdp": false,
                                    "digits": "0",
                                    "html_prepend": "Rollostand: ",
                                    "name": "",
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0
                                  "style": {
                                    "left": "107px",
                                    "top": "161px",
                                    "width": "151px",
                                    "height": "21px",
                                    "color": "white",
                                    "text-align": "center",
                                    "font-size": "small",
                                    "z-index": "1",
                                    "border-style": "none",
                                    "border-radius": "0px"
                                "e00005": {
                                  "tpl": "tplValueLastchange",
                                  "data": {
                                    "oid": "hm-rpc.1.PEQ0011956.1.LEVEL",
                                    "format_date": "DD.MM.YYYY um hh:mm:ss Uhr",
                                    "html_prepend": "<b>Letzte Einstellung: </b>",
                                    "name": "",
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0
                                  "style": {
                                    "left": "59px",
                                    "top": "336px",
                                    "width": "341px",
                                    "font-size": "x-small",
                                    "height": "9px",
                                    "color": "rgb(38, 179, 247)",
                                    "z-index": "1",
                                "e00006": {
                                  "tpl": "tplJquiButtonState",
                                  "data": {
                                    "oid": "shelly.0.SHSW-25#69397C#1.Shutter.Pause",
                                    "g_fixed": true,
                                    "g_visibility": false,
                                    "g_css_font_text": true,
                                    "g_css_border": true,
                                    "g_signals": false,
                                    "buttontext": "Stop",
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "value": "true",
                                    "class": "button_rollo"
                                  "style": {
                                    "left": "180px",
                                    "top": "231px",
                                    "width": "",
                                    "height": "",
                                    "z-index": "1",
                                    "border-width": "3px",
                                    "border-style": "outset",
                                    "border-color": "{wert:shelly.0.SHSW-25#69397C#1.Shutter.Pause; wert==\"true\" ? \"#47aaff\" : \"silver\" }",
                                  "widgetSet": "jqui"
                                "e00007": {
                                  "tpl": "tplJquiRadioList",
                                  "data": {
                                    "g_fixed": true,
                                    "g_signals": false,
                                    "values": "25;50;75",
                                    "texts": " 25%; 50%; 75%",
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "class": ""
                                  "style": {
                                    "left": "116px",
                                    "top": "289px",
                                    "font-family": "",
                                    "font-variant": "",
                                    "font-weight": "",
                                    "z-index": "1",
                                    "height": "",
                                    "width": "225px",
                                    "border-width": "2px",
                                    "border-color": "silver",
                                    "position": ""
                                  "widgetSet": "jqui"
                                "e00008": {
                                  "tpl": "tplJquiToogle",
                                  "data": {
                                    "oid": "shelly.0.SHSW-25#69397C#1.Shutter.Close",
                                    "g_fixed": true,
                                    "g_css_background": true,
                                    "g_signals": false,
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "class": "button_rollo",
                                    "label": "Zu"
                                  "style": {
                                    "left": "66px",
                                    "top": "231px",
                                    "width": "",
                                    "height": "",
                                    "border-color": "{wert:shelly.0.SHSW-25#69397C#1.Shutter.Close; wert==\"true\" ? \"#47aaff\" : \"silver\" }",
                                    "text-align": "",
                                    "font-weight": "",
                                    "font-family": "",
                                    "z-index": "1"
                                  "widgetSet": "jqui"
                                "e00009": {
                                  "data": {
                                    "oid": "shelly.0.SHSW-25#69397C#1.Shutter.Open",
                                    "g_fixed": true,
                                    "g_signals": false,
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "label": "Auf"
                                  "style": {
                                    "left": "293px",
                                    "top": "231px",
                                    "border-color": "{wert:shelly.0.SHSW-25#69397C#1.Shutter.Open; wert==\"true\" ? \"#47aaff\" : \"silver\" }",
                                    "z-index": "1"
                                  "widgetSet": "jqui"
                                "e00010": {
                                  "tpl": "tplContainerView",
                                  "data": {
                                    "g_fixed": true,
                                    "g_css_shadow_padding": true,
                                    "g_signals": false,
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "contains_view": "Navigation",
                                    "views": [
                                      "EG",
                                      "Heiz_EG",
                                      "Heiz_OG",
                                      "Heiz_UG",
                                      "Heizung",
                                      "Netzwerk",
                                      "OG",
                                      "Rollos",
                                      "Start",
                                      "Tankstellen",
                                      "UG"
                                  "style": {
                                    "left": "128px",
                                    "top": "-8px",
                                    "width": "958px",
                                    "height": "94px",
                                    "z-index": "1"
                              "name": "Rollos",
                              "filterList": []
                            • AlmixxA Almixx
                                "settings": {
                                  "style": {
                                    "background": "",
                                  "sizex": "1381",
                                  "sizey": "671",
                                  "gridSize": "",
                                  "snapType": null,
                                "widgets": {
                                  "e00001": {
                                    "data": {
                                      "g_fixed": true,
                                      "g_signals": false,
                                      "asButton": false,
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "min": "0",
                                      "max": "100",
                                      "iconColor0": ""
                                    "style": {
                                      "left": "268px",
                                      "top": "110px",
                                      "width": "140px",
                                      "height": "156px",
                                      "z-index": "1"
                                  "e00002": {
                                    "tpl": "tplFrame",
                                    "data": {
                                      "title_top": "5",
                                      "title_left": "5",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "title_font": "",
                                    "style": {
                                      "left": "50px",
                                      "top": "111px",
                                      "width": "351px",
                                      "height": "243px",
                                      "z-index": "0",
                                      "background": "",
                                      "opacity": "",
                                  "e00003": {
                                    "data": {
                                      "factor": "1",
                                      "color": "#47aaff",
                                      "min": "0",
                                      "max": "100",
                                      "name": "",
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "comment": "",
                                      "reverse": false
                                    "style": {
                                      "left": "77px",
                                      "top": "192px",
                                      "width": "200px",
                                      "height": "16px",
                                      "z-index": "1"
                                  "e00004": {
                                    "data": {
                                      "is_comma": false,
                                      "factor": "1",
                                      "is_tdp": false,
                                      "digits": "0",
                                      "name": "",
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0
                                    "style": {
                                      "left": "107px",
                                      "top": "161px",
                                      "width": "151px",
                                      "height": "21px",
                                      "color": "white",
                                      "z-index": "1",
                                  "e00005": {
                                    "data": {
                                      "name": "",
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0
                                    "style": {
                                      "left": "59px",
                                      "top": "336px",
                                      "width": "341px",
                                      "height": "9px",
                                      "z-index": "1",
                                  "e00006": {
                                    "data": {
                                      "g_fixed": true,
                                      "g_signals": false,
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "value": "true",
                                    "style": {
                                      "left": "180px",
                                      "top": "231px",
                                      "width": "",
                                      "height": "",
                                      "z-index": "1",
                                    "widgetSet": "jqui"
                                  "e00007": {
                                    "data": {
                                      "g_fixed": true,
                                      "g_signals": false,
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "class": ""
                                    "style": {
                                      "left": "116px",
                                      "top": "289px",
                                      "font-family": "",
                                      "font-variant": "",
                                      "font-weight": "",
                                      "z-index": "1",
                                      "height": "",
                                      "width": "225px",
                                      "position": ""
                                    "widgetSet": "jqui"
                                  "e00008": {
                                    "data": {
                                      "g_fixed": true,
                                      "g_signals": false,
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "label": "Zu"
                                    "style": {
                                      "left": "66px",
                                      "top": "231px",
                                      "width": "",
                                      "height": "",
                                      "text-align": "",
                                      "font-weight": "",
                                      "font-family": "",
                                      "z-index": "1"
                                    "widgetSet": "jqui"
                                  "e00009": {
                                    "data": {
                                      "g_fixed": true,
                                      "g_signals": false,
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "label": "Auf"
                                    "style": {
                                      "left": "293px",
                                      "top": "231px",
                                      "z-index": "1"
                                    "widgetSet": "jqui"
                                  "e00010": {
                                    "data": {
                                      "g_fixed": true,
                                      "g_signals": false,
                                      "lc-format": "",
                                      "lc-bkg-color": "",
                                      "lc-color": "",
                                      "lc-zindex": 0,
                                      "views": [
                                        "EG",
                                        "Heiz_EG",
                                        "Heiz_OG",
                                        "Heiz_UG",
                                        "Heizung",
                                        "Netzwerk",
                                        "OG",
                                        "Rollos",
                                        "Start",
                                        "Tankstellen",
                                        "UG"
                                    "style": {
                                      "left": "128px",
                                      "top": "-8px",
                                      "width": "958px",
                                      "height": "94px",
                                      "z-index": "1"
                                "name": "Rollos",
                                "filterList": []
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Zuweisung zu diesem Widget Typ !
                                AlmixxA Offline
                                AlmixxA Offline
                                Almixx
                                @Glasfaser
                                das heißt also ich muß es für alle widget typen seperat machen?
                                Weil wenn ich die anderen ebenfalls mit der Klasse zuweise stimmen die nicht mehr,s.o.
                                Bin noch sehr unerfahren mit CSS, versuche aber zu lernen...
                                • AlmixxA Almixx
                                  @Glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @Almixx
                                  ausschlagebend ist
                                  im Widget eingetragen unter CSS button_rollo ist dann nur dieses Widget gemeint .
                                  die CSS verändert ... sagen wir mal Hintergrund grün
                                  .button_rollo1 .ui-button
                                  im Widget eingetragen unter CSS button_rollo1 ist dann nur dieses Widget gemeint .
                                  Dein View funktioniert nicht , setze es in Code-Tags </>
                                  AlmixxA 2 Antworten Letzte Antwort
                                    @Almixx
                                    ausschlagebend ist
                                    AlmixxA Offline
                                    AlmixxA Offline
                                    Almixx
                                    @Glasfaser , View funktioniert nicht, hier mal das komplette Widget
                                    [{"tpl":"tplMfdShutter","data":{"oid":"shelly.0.SHSW-25#69397C#1.Shutter.Position","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"min":"0","max":"100","show_active":false,"invert_icon":false,"iconColor":"#ffffff","iconColor0":""},"style":{"left":"268px","top":"110px","width":"140px","height":"156px","z-index":"1"},"widgetSet":"jqui-mfd"},{"tpl":"tplFrame","data":{"visibility-cond":"==","visibility-val":1,"title":"Rollo Büro","title_color":"black","title_top":"5","title_left":"5","header_height":"30","header_color":"#47aaff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":"1","signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","name":"Rollo Büro","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"DD.MM.YYYY hh:mm:ss","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title_font":"","gestures-swipeRight-limit":"7","gestures-swiping-minimum":"-3","gestures-rotateRight-limit":"0","gestures-rotating-delta":"2"},"style":{"left":"50px","top":"111px","width":"351px","height":"243px","font-family":"Verdana, Geneva, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"large","z-index":"0","background":"","border-width":"5px","border-style":"solid","border-color":"#9f9d9d","border-radius":"4px","opacity":"","background-color":"","box-shadow":"4px 4px 4px rgba(4, 4, 4, 4)"},"widgetSet":"basic"},{"tpl":"tplValueFloatBar","data":{"oid":"shelly.0.SHSW-25#69397C#1.Shutter.Position","visibility-cond":"==","visibility-val":1,"factor":"1","color":"#47aaff","min":"0","max":"100","orientation":"horizontal","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","name":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"comment":"","reverse":false},"style":{"left":"77px","top":"192px","width":"200px","height":"16px","border-color":"white","border-radius":"5px","border-width":"1px","border-style":"solid","z-index":"1"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"shelly.0.SHSW-25#69397C#1.Shutter.Position","visibility-cond":"==","visibility-val":1,"is_comma":false,"factor":"1","html_append_singular":" %","html_append_plural":" %","is_tdp":false,"gestures-offsetX":0,"gestures-offsetY":0,"digits":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","html_prepend":"Rollostand: ","name":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"107px","top":"161px","width":"151px","height":"21px","color":"white","text-align":"center","font-family":"Verdana, Geneva, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"small","z-index":"1","border-width":"1px","border-style":"none","border-color":"white","border-radius":"0px"},"widgetSet":"basic"},{"tpl":"tplValueLastchange","data":{"oid":"hm-rpc.1.PEQ0011956.1.LEVEL","visibility-cond":"==","visibility-val":1,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"format_date":"DD.MM.YYYY um hh:mm:ss Uhr","html_prepend":"<b>Letzte Einstellung: </b>","visibility-groups-action":"hide","name":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"59px","top":"336px","width":"341px","font-style":"normal","font-variant":"normal","font-size":"x-small","height":"9px","color":"rgb(38, 179, 247)","z-index":"1","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplJquiButtonState","data":{"oid":"shelly.0.SHSW-25#69397C#1.Shutter.Pause","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttontext":"Stop","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"true","class":"button_rollo2"},"style":{"left":"180px","top":"231px","width":"98","height":"40","z-index":"1","font-family":"Verdana, Geneva, sans-serif","border-width":"3px","border-style":"outset","border-color":"{wert:shelly.0.SHSW-25#69397C#1.Shutter.Pause; wert==\"true\" ? \"#47aaff\" : \"silver\" }","border-radius":"5px"},"widgetSet":"jqui"},{"tpl":"tplJquiRadioList","data":{"oid":"shelly.0.SHSW-25#69397C#1.Shutter.Position","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"25;50;75","texts":" 25%; 50%; 75%","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":""},"style":{"left":"116px","top":"289px","font-family":"","font-variant":"","font-weight":"","z-index":"1","height":"","width":"225px","border-width":"2px","border-style":"outset","border-color":"silver","border-radius":"5px","position":""},"widgetSet":"jqui"},{"tpl":"tplJquiToogle","data":{"oid":"shelly.0.SHSW-25#69397C#1.Shutter.Close","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":"button_rollo1","label":"Zu"},"style":{"left":"66px","top":"231px","width":"","height":"","background-color":"","border-color":"{wert:shelly.0.SHSW-25#69397C#1.Shutter.Close; wert==\"true\" ? \"#47aaff\" : \"silver\" }","text-align":"","font-weight":"","font-family":"","border-width":"3px","border-radius":"5px","border-style":"outset","z-index":"1"},"widgetSet":"jqui"},{"tpl":"tplJquiToogle","data":{"oid":"shelly.0.SHSW-25#69397C#1.Shutter.Open","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":"button_rollo1","label":"Auf"},"style":{"left":"292px","top":"232px","border-color":"{wert:shelly.0.SHSW-25#69397C#1.Shutter.Open; wert==\"true\" ? \"#47aaff\" : \"silver\" }","border-width":"3px","border-style":"outset","border-radius":"5px","z-index":"1"},"widgetSet":"jqui"}]
                                      @Almixx
                                      ausschlagebend ist
                                      AlmixxA Offline
                                      AlmixxA Offline
                                      Almixx
                                      @Glasfaser
                                        "settings": {
                                          "style": {
                                            "background": "",
                                          "sizex": "1381",
                                          "sizey": "671",
                                          "gridSize": "",
                                          "snapType": null,
                                          "useAsDefault": true,
                                          "class": ""
                                        "widgets": {
                                          "e00001": {
                                            "data": {
                                              "g_fixed": true,
                                              "g_signals": false,
                                              "asButton": false,
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "min": "0",
                                              "max": "100",
                                              "iconColor0": ""
                                            "style": {
                                              "left": "268px",
                                              "top": "110px",
                                              "width": "140px",
                                              "height": "156px",
                                              "z-index": "1"
                                          "e00002": {
                                            "tpl": "tplFrame",
                                            "data": {
                                              "title_top": "5",
                                              "title_left": "5",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "title_font": "",
                                            "style": {
                                              "left": "50px",
                                              "top": "111px",
                                              "width": "351px",
                                              "height": "243px",
                                              "z-index": "0",
                                              "background": "",
                                              "opacity": "",
                                          "e00003": {
                                            "data": {
                                              "factor": "1",
                                              "color": "#47aaff",
                                              "min": "0",
                                              "max": "100",
                                              "name": "",
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "comment": "",
                                              "reverse": false
                                            "style": {
                                              "left": "77px",
                                              "top": "192px",
                                              "width": "200px",
                                              "height": "16px",
                                              "z-index": "1"
                                          "e00004": {
                                            "data": {
                                              "is_comma": false,
                                              "factor": "1",
                                              "is_tdp": false,
                                              "digits": "0",
                                              "name": "",
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0
                                            "style": {
                                              "left": "107px",
                                              "top": "161px",
                                              "width": "151px",
                                              "height": "21px",
                                              "color": "white",
                                              "z-index": "1",
                                          "e00005": {
                                            "data": {
                                              "name": "",
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0
                                            "style": {
                                              "left": "59px",
                                              "top": "336px",
                                              "width": "341px",
                                              "height": "9px",
                                              "z-index": "1",
                                          "e00006": {
                                            "data": {
                                              "g_fixed": true,
                                              "g_signals": false,
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "value": "true",
                                            "style": {
                                              "left": "180px",
                                              "top": "231px",
                                              "width": "98px",
                                              "height": "40px",
                                              "z-index": "1",
                                            "widgetSet": "jqui"
                                          "e00007": {
                                            "data": {
                                              "g_fixed": true,
                                              "g_signals": false,
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "class": ""
                                            "style": {
                                              "left": "116px",
                                              "top": "289px",
                                              "font-family": "",
                                              "font-variant": "",
                                              "font-weight": "",
                                              "z-index": "1",
                                              "height": "",
                                              "width": "225px",
                                              "position": ""
                                            "widgetSet": "jqui"
                                          "e00008": {
                                            "data": {
                                              "g_fixed": true,
                                              "g_signals": false,
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "label": "Zu"
                                            "style": {
                                              "left": "66px",
                                              "top": "231px",
                                              "width": "",
                                              "height": "",
                                              "text-align": "",
                                              "font-weight": "",
                                              "font-family": "",
                                              "z-index": "1"
                                            "widgetSet": "jqui"
                                          "e00009": {
                                            "data": {
                                              "g_fixed": true,
                                              "g_signals": false,
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "label": "Auf"
                                            "style": {
                                              "left": "292px",
                                              "top": "232px",
                                              "z-index": "1"
                                            "widgetSet": "jqui"
                                          "e00010": {
                                            "data": {
                                              "g_fixed": true,
                                              "g_signals": false,
                                              "lc-format": "",
                                              "lc-bkg-color": "",
                                              "lc-color": "",
                                              "lc-zindex": 0,
                                              "views": [
                                                "EG",
                                                "Heiz_EG",
                                                "Heiz_OG",
                                                "Heiz_UG",
                                                "Heizung",
                                                "Netzwerk",
                                                "OG",
                                                "Rollos",
                                                "Start",
                                                "Tankstellen",
                                                "UG"
                                            "style": {
                                              "left": "128px",
                                              "top": "-8px",
                                              "width": "958px",
                                              "height": "94px",
                                              "z-index": "1"
                                        "name": "Rollos",
                                        "filterList": []
                                      • AlmixxA Almixx
                                        @Glasfaser
                                          "settings": {
                                            "style": {
                                              "background": "",
                                            "sizex": "1381",
                                            "sizey": "671",
                                            "gridSize": "",
                                            "snapType": null,
                                            "class": ""
                                          "widgets": {
                                            "e00001": {
                                              "data": {
                                                "g_fixed": true,
                                                "g_signals": false,
                                                "asButton": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "min": "0",
                                                "max": "100",
                                                "iconColor0": ""
                                              "style": {
                                                "left": "268px",
                                                "top": "110px",
                                                "width": "140px",
                                                "height": "156px",
                                                "z-index": "1"
                                            "e00002": {
                                              "tpl": "tplFrame",
                                              "data": {
                                                "title_top": "5",
                                                "title_left": "5",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "title_font": "",
                                              "style": {
                                                "left": "50px",
                                                "top": "111px",
                                                "width": "351px",
                                                "height": "243px",
                                                "z-index": "0",
                                                "background": "",
                                                "opacity": "",
                                            "e00003": {
                                              "data": {
                                                "factor": "1",
                                                "color": "#47aaff",
                                                "min": "0",
                                                "max": "100",
                                                "name": "",
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "comment": "",
                                                "reverse": false
                                              "style": {
                                                "left": "77px",
                                                "top": "192px",
                                                "width": "200px",
                                                "height": "16px",
                                                "z-index": "1"
                                            "e00004": {
                                              "data": {
                                                "is_comma": false,
                                                "factor": "1",
                                                "is_tdp": false,
                                                "digits": "0",
                                                "name": "",
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0
                                              "style": {
                                                "left": "107px",
                                                "top": "161px",
                                                "width": "151px",
                                                "height": "21px",
                                                "color": "white",
                                                "z-index": "1",
                                            "e00005": {
                                              "data": {
                                                "name": "",
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0
                                              "style": {
                                                "left": "59px",
                                                "top": "336px",
                                                "width": "341px",
                                                "height": "9px",
                                                "z-index": "1",
                                            "e00006": {
                                              "data": {
                                                "g_fixed": true,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "value": "true",
                                              "style": {
                                                "left": "180px",
                                                "top": "231px",
                                                "width": "98px",
                                                "height": "40px",
                                                "z-index": "1",
                                              "widgetSet": "jqui"
                                            "e00007": {
                                              "data": {
                                                "g_fixed": true,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "class": ""
                                              "style": {
                                                "left": "116px",
                                                "top": "289px",
                                                "font-family": "",
                                                "font-variant": "",
                                                "font-weight": "",
                                                "z-index": "1",
                                                "height": "",
                                                "width": "225px",
                                                "position": ""
                                              "widgetSet": "jqui"
                                            "e00008": {
                                              "data": {
                                                "g_fixed": true,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "label": "Zu"
                                              "style": {
                                                "left": "66px",
                                                "top": "231px",
                                                "width": "",
                                                "height": "",
                                                "text-align": "",
                                                "font-weight": "",
                                                "font-family": "",
                                                "z-index": "1"
                                              "widgetSet": "jqui"
                                            "e00009": {
                                              "data": {
                                                "g_fixed": true,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "label": "Auf"
                                              "style": {
                                                "left": "292px",
                                                "top": "232px",
                                                "z-index": "1"
                                              "widgetSet": "jqui"
                                            "e00010": {
                                              "data": {
                                                "g_fixed": true,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "views": [
                                                  "EG",
                                                  "Heiz_EG",
                                                  "Heiz_OG",
                                                  "Heiz_UG",
                                                  "Heizung",
                                                  "Netzwerk",
                                                  "OG",
                                                  "Rollos",
                                                  "Start",
                                                  "Tankstellen",
                                                  "UG"
                                              "style": {
                                                "left": "128px",
                                                "top": "-8px",
                                                "width": "958px",
                                                "height": "94px",
                                                "z-index": "1"
                                          "name": "Rollos",
                                          "filterList": []
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @Almixx
                                        Dein Widget sehen so bei mir aus .
                                        Lösche die defekten und füge neue hinzu
                                          @Almixx
                                          AlmixxA Offline
                                          AlmixxA Offline
                                          Almixx
                                          @Glasfaser
                                          bringt nichts. sobald das .ui-button setze, verändern sich diese toggle button, ohne Eintrag funktioniert es.
                                          Nur der state button reagiert zumindest bei der background Farbe
                                          Ist das denn so kompliziert? 😕
