  4. Fehler beim Upgrade des js-controllers
    5.5k
3 Beiträge 1 Kommentatoren 919 Aufrufe
  • C Offline
    ChristianF
    folgenden Fehler hat es bei mir beim Upgrade des js-controllers gegeben:
    root@HWR-Raspi:/opt/iobroker# npm install iobroker.js-controller --production
    > iobroker.js-controller@0.11.3 install /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/setup.js setup first
    fs.js:549
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
        at Error (native)
        at Object.fs.openSync (fs.js:549:18)
        at Object.fs.writeFileSync (fs.js:1156:15)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:538:23
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:559:11)
        at Module._compile (module.js:409:26)
        at Object.Module._extensions..js (module.js:416:10)
        at Module.load (module.js:343:32)
        at Function.Module._load (module.js:300:12)
    npm ERR! Linux 4.4.13-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "--production"
    npm ERR! node v4.4.7
    npm ERR! npm  v2.15.8
    npm ERR! code ELIFECYCLE
    npm ERR! iobroker.js-controller@0.11.3 install: `node lib/setup.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@0.11.3 install script 'node lib/setup.js setup first'.
    npm ERR! This is most likely a problem with the iobroker.js-controller package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node lib/setup.js setup first
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs iobroker.js-controller
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR!     npm owner ls iobroker.js-controller
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log</anonymous>
    Einen Fehler bezüglich des Killall Scripts habe ich noch an anderer Stelle: beim Aufruf von ./iobroker stop kommt ein Exitcode 127 für killall.sh . Ich habe kurz nachgelesen und herausgefunden dass 127 der Exitcode ist für "File not found". Vielleicht ist irgendwo ein relativer Pfad falsch oder so?
    Viele grüße
    Christian
    • C Offline
      ChristianF
      Hmm, niemand ne Idee?
      Viele Grüße
      Christian
      • C Offline
        ChristianF
        Hab die Installation plattgemacht und neu installiert -> läuft.
