  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Разные ошибки
Разные ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
192 Beiträge 27 Kommentatoren 80.1k Aufrufe
  • H Offline
    Haus
    #85
    @Bluefox:
    А теперь?
    Включи debug уровень. Я встроил debug выводы для скана сенсоров, если не локально. `
    Вот это в локал
    TypeError: 2016-08-24 10:32:36.258 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
    TypeError: 2016-08-24 10:32:36.258 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError: 2016-08-24 10:32:36.258 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12)
    TypeError: 2016-08-24 10:32:36.258 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10)
    TypeError: 2016-08-24 10:32:36.258 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
    TypeError: 2016-08-24 10:32:36.258 error at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
    TypeError: 2016-08-24 10:32:36.258 error at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2096:34)
    TypeError: 2016-08-24 10:32:36.258 error at Adapter.emit (events.js:95:17)
    TypeError: 2016-08-24 10:32:36.258 error at Adapter.adapter.on.timer (/opt/iobroker/node_modules/iobroker.owfs/main.js:24:14)
    TypeError: 2016-08-24 10:32:36.258 error at processMessage (/opt/iobroker/node_modules/iobroker.owfs/main.js:169:24)
    TypeError: 2016-08-24 10:32:36.258 error Cannot call method 'readdir' of null
    message 2016-08-24 10:32:36.253 error messagebox.system.adapter.owfs.0 [object Object] Cannot call method 'readdir' of null
    Это стандартно семь датчиков
    inMem	2016-08-24 10:42:12.577	debug	message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472024532539, q=0, from=system.adapter.admin.0, lc=1472024532539
    inMem	2016-08-24 10:42:12.569	debug	message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472024532539, q=0, from=system.adapter.admin.0, lc=1472024532539
    owfs-0	2016-08-24 10:42:08.841	debug	sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
    owfs-0	2016-08-24 10:42:08.839	debug	Result for dir: {}
    owfs-0	2016-08-24 10:42:08.837	debug	Result for list_: []
    owfs-0	2016-08-24 10:42:08.836	debug	Result for list: [""]
    inMem	2016-08-24 10:42:08.703	debug	message megaesp.0.* megaesp.0.p9_P9 val=29, ack=true, ts=1472024528688, q=0, from=system.adapter.megaesp.0, lc=1472024528688
    inMem	2016-08-24 10:42:08.679	debug	message megaesp.0.* megaesp.0.p3_P3_humidity val=79.7, ack=true, ts=1472024528663, q=0, from=system.adapter.megaesp.0, lc=1472024528663
    megaesp-0	2016-08-24 10:42:08.659	debug	detected new value on port [9]: 29, calc state 29
    megaesp-0	2016-08-24 10:42:08.656	debug	Response for 192.168.1.20[all]: 0;0;0;temp:20.00/hum:79.70;temp:19.50;OFF;RGB;NC;NC;29
    megaesp-0	2016-08-24 10:42:08.594	debug	getPortState http://192.168.1.20/sec/?cmd=all
    owfs-0	2016-08-24 10:42:07.515	debug	Connect to 127.0.0.1:4304
    i
    Сейчас семь датчиков
    Когда пять находит
    Нажмите Ctrl+A и Ctrl+C, что бы скопировать в буфер обмена и после этого нажмите мышкой в любом месте.
    inMem 2016-08-24 11:27:44.682 debug message owfs.0.* owfs.0.wires.Sensor3_temperature val=null, ack=false, ts=1472027264623, q=0, from=system.adapter.owfs.0, lc=1472027264623
    inMem 2016-08-24 11:27:44.622 debug message owfs.0.* owfs.0.wires.Sensor2_fasttemp val=null, ack=false, ts=1472027264610, q=0, from=system.adapter.owfs.0, lc=1472027264610
    inMem 2016-08-24 11:27:44.584 debug message owfs.0.* owfs.0.wires.Sensor1_temperature val=null, ack=false, ts=1472027264561, q=0, from=system.adapter.owfs.0, lc=1472027264561
    owfs-0 2016-08-24 11:27:44.368 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.owfs
    owfs-0 2016-08-24 11:27:44.280 debug statesDB connected
    owfs-0 2016-08-24 11:27:44.261 debug objectDB connected
    host-Server1 2016-08-24 11:27:43.103 info instance system.adapter.owfs.0 started with pid 4016
    host-Server1 2016-08-24 11:27:41.146 info instance system.adapter.owfs.0 terminated with code 0 (OK)
    owfs-0 2016-08-24 11:27:41.115 info terminating
    inMem 2016-08-24 11:27:40.763 debug message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472027260728, q=0, from=system.adapter.admin.0, lc=1472027260728
    host-Server1 2016-08-24 11:27:40.588 info stopInstance system.adapter.owfs.0 killing pid 3909
    host-Server1 2016-08-24 11:27:40.586 info object change system.adapter.owfs.0
    owfs-0 2016-08-24 11:27:00.597 debug sendTo 'readdir' to system.adapter.admin.0 from system.adapter.owfs.0
    owfs-0 2016-08-24 11:27:00.596 debug Result for dir: {'10.DB1979020800':['address','alias','crc8','errata','family','id','locator','power','r_address','r_id','r_locator','scratchpad','temperature','temphigh','templow','type'],'28.ECB1CD040000':['address','alias','crc8','errata','family','fasttemp','id','locator','power','r_address','r_id','r_locator','scratchpad','temperature','temperature10','temperature11','temperature12','temperature9','temphigh','templow','type'],'28.3C3B63040000':['address','alias','crc8','errata','family','fasttemp','id','locator','power','r_address','r_id','r_locator','scratchpad','temperature','temperature10','temperature11','temperature12','temperature9','temphigh','templow','type'],'28.6659CE040000':['address','alias','crc8','errata','family','fasttemp','id','locator','power','r_address','r_id','r_locator','scratchpad','temperature','temperature10','temperature11','temperature12','temperature9','temphigh','templow','type'],'28.3E0764040000':['address','alias','crc8','errata','family','fasttemp','id','locator','power','r_address','r_id','r_locator','scratchpad','temperature','temperature10','temperature11','temperature12','temperature9','temphigh','templow','type']}
    owfs-0 2016-08-24 11:27:00.543 debug Result for list_: ['10.DB1979020800','28.ECB1CD040000','28.3C3B63040000','28.6659CE040000','28.3E0764040000']
    owfs-0 2016-08-24 11:27:00.542 debug Result for list: ['/10.DB1979020800','/28.ECB1CD040000','/28.3C3B63040000','/28.6659CE040000','/28.3E0764040000']
    owfs-0 2016-08-24 11:26:59.580 debug Connect to 127.0.0.1:4304
    inMem 2016-08-24 11:26:59.577 debug message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=86, ack=false, time=1472027219565, _id=83207467
    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
    admin: 3.6.0
    javascript: 4.1.10
    web: 2.4.1 vis: 1.1.10
    cloud: 2.6.2
    Server: DELL FX170 / linux: Debian 9.5 Stretch
    Adapter: MegaD-2561, Mega-ES…
    • H Offline
      Haus
      #86
      @jeorgep:
      > Можешь опробовать owfs с гита?
      У меня совсем не работает - в файле состояние датчика изменилось, а адаптер не видит,
      возможно потому, что нет возможности выбора: локальный или owserver,
      а owserver сервис у меня выключен.
      По крайней мере я не нахожу опции выбора в настройках адаптера.
      Но так как там нет и функции поиска датчиков - подозреваю, что у меня установлено что-то не верно.
      Как я делал :
      остановил iobroker
      скачал отсюда архив https://github.com/ioBroker/ioBroker.ow … master.zip
      распаковал в папку /opt/iobroker
      установил:
      npm install ioBroker.owfs-master
      После чего проверил версию в файле:
      /opt/iobroker/node_modules/iobroker.owfs/package.json
      "version": "0.3.0",
      и запустил iobroker
      проверил версию в WEB интерфейсе - тоже 0.3.0
      Что должно быть в веб настройках адаптера? `
      cd /opt/iobroker
      npm install https://github.com/ioBroker/ioBroker.owfs/tarball/master/
      iobroker upload owfs
      iobroker restart owfs
      admin: 3.6.0
      javascript: 4.1.10
      cloud: 2.6.2
      • J Offline
        jeorgep
        #87
        cd /opt/iobroker
        Да, спасибо - все получилось!
        Работает и чтение и запись в локальном режиме.
        Работает быстро!
        Найдено 30 датчиков в локальном режиме.
        Если некорректно работает в локальном режиме - возможно стоит посмотреть конфигурацию owfs.
        Мой /etc/owfs.conf
        ! server: server = localhost:4304
        Celsius
        owfs: device = /dev/i2c-0
        mountpoint = /mnt/1wire
        allow_other
        timeout_volatile = 60
        timeout_stable = 60
        timeout_directory = 30
        timeout_presence = 60
        timeout_network = 0
        timeout_persistent_low = 600
        timeout_persistent_high = 3600
        format = fic
        cache_size = 0
        /etc/systemd/system/multi-user.target.wants/owfs.service
        [Unit]
        Description=1-wire filesystem FUSE mount
        Documentation=man:owfs(1)
        [Service]
        Type=forking
        ExecStart=/opt/owfs/bin/owfs -c /etc/owfs.conf --pid-file /var/run/owfs/owfs.pid -C
        ExecStop=/usr/bin/umount /mnt/1wire
        RuntimeDirectory=owfs
        [Install]
        WantedBy=multi-user.target
        Система Armbian VERSION=5.16
        Orange Pi + 2
          spectrekr
          #88
          Т.е. получается, что даже если используешь локальный режим, то всеравно должен присутствовать owfs сервер в системе?
          Т.к. сейчас попробовал установить драйвер в систему, где 1wire работает, но owfs сервера нет, указал каталог с датчиками, драйвер пишет что нашел 6 вместо 5 датчиков, хотя это понятно, так как он читает количество каталогов в данной директории, но в настройках датчики не появляются.
          • BluefoxB Offline
            BluefoxB Offline
            #89
            Там в main.js ошибка небольшая.
            Надо добавить строкой 167
            fs = fs || require('fs');
            • J Offline
              jeorgep
              #90
              @spectrekr:
              Т.к. сейчас попробовал установить драйвер в систему, где 1wire работает, но owfs сервера нет, указал каталог с датчиками, драйвер пишет что нашел 6 вместо 5 датчиков, хотя это понятно, так как он читает количество каталогов в данной директории, но в настройках датчики не появляются. `
              Пакет owfs
              предоставляет 4 сервиса
              /lib/systemd/system/owfs.service
              [Unit]
              ! [Service]
              Type=forking
              ! [Install]
              Формирует виртуальную файловую систему в точке монтирования
              ****/lib/systemd/system/owserver.service****
              [Unit]
              Description=Backend server for 1-wire control
              Documentation=man:owserver(1)
              After=syslog.target network.target
              >! [Service]
              Type=forking
              ExecStart=/opt/owfs/bin/owserver -c /etc/owfs.conf -C --pid-file /var/run/owfs/owserver.pid
              >! [Install]
              Also=owserver.socket
              Предоставляет удаленный доступ к owfs файловой системе
              (по умолчанию порт 4304)
              /lib/systemd/system/owhttpd.service
              [Unit]
              Description=Tiny webserver for 1-wire control
              Documentation=man:owhttpd(1)
              After=network.target
              ! [Service]
              Type=forking
              ExecStart=/opt/owfs/bin/owhttpd -c /etc/owfs.conf --background --pid-file /var/run/owfs/owhttpd.pid
              User=owfs
              Group=owfs
              ! [Install]
              Поднимает легкий http server (на порту 2121 по умолчанию)
              и ****/lib/systemd/system/owftpd.service**** - не пользовался
              Для локального использования в файловой системе достаточно запустить лишь ****owfs**** сервис
              с конфигом /etc/owfs.conf вида:
              Celsius
              allow_other
              timeout_stable = 60
              timeout_network = 0
              format = fic
              cache_size = 0
              Для удаленного использования запускается два сервиса
              ****owfs.service****
              ****owserver.service****
              или три ****+ owhttpd.service****
              Celsius
              server: device = /dev/i2c-0
              http: port = 2121
              allow_other
              timeout_stable = 60
              timeout_network = 0
              format = fic
              cache_size = 0
              В этом варианте можно пользоваться как удаленно так и локально.
              Локальный доступ осуществляется гораздо быстрее - в десятки раз,
              чем удаленный. Поэтому если нет необходимости в удаленном доступе -
              лучше пользоваться локальным. Погасив при этом ненужные сервисы owserver и owhttpd.
              Большое спасибо Bluefox за оперативность!
              • BluefoxB Offline
                BluefoxB Offline
                #91
                @Haus:
                @Bluefox:
                А теперь?
                Вот это в локал
                Когда пять находит
                Помогай. У меня с FAKED
                Ошибка, где то в библиотеке owjs.
                Где то здесь (node_modules/owjs/owjs.js:
                // return array of dir
                    self.list = function (path, callback) {
                        var promise;
                        if (path instanceof Array) {
                            promise = Q.all(path.map(self.list));
                        else {
                            promise = self.send(path, null, OW_DIRALL)
                            .then(function (messages) {
                                var message = messages[0];
                                if (message.header.ret < 0) {
                                    throw new Error(message.header.ret);
                                var str = message.payload;
                                str = str.substring(0, str.length - 1); // remove zero-char from end
                                return str.split(',');
                        return nodify(promise, callback);
                Можешь встроить
                		console.log(JSON.stringify(messages));//<-----
                И выполнить
                iobroker stop owfs
                node node_modules/iobroker.owfs/main.js --force --logs
                  spectrekr
                  #92
                  @jeorgep:
                  Большое спасибо Bluefox за оперативность! `
                  Проблема в том что у меня 1wire реализован через gpio на raspberry и owfs пакет не дружит с режимом kernel. Соответственно он мне не создает виртуальную fs.
                  • J Offline
                    jeorgep
                    #93
                    @spectrekr:
                    Проблема в том что у меня 1wire реализован через gpio на raspberry и owfs пакет не дружит с режимом kernel. Соответственно он мне не создает виртуальную fs. `
                    Гм, не знаю - у меня мастер восьмиканальный железный.
                    Попробуй так:
                    systemctl disable owserver.service
                    systemctl disable owhttpd.service
                    Проверь есть ли у тебя /lib/systemd/system/owfs.service
                    (он может отсутствовать)
                    Если нет - создай по образу моего.
                    systemctl enable owfs.service
                    в /etc/owfs.conf
                    Закомментируй строки типа
                    (то что у тебя)
                    и поставь
                    (то устройство что у тебя)
                    После этого перезагрузи Raspberry.
                    Именно после перегрузки он может подхватить конфиг
                      spectrekr
                      #94
                      @jeorgep:
                      Игрался и настраивал, не поддерживается. Там старые версии ядра еще можно было пропатчить, чтоб owfs заработал, на 4 версии ядра информации вообще не нашел. Внешнее устройство на i2c или USB в этом плане лучше.
                      • H Offline
                        Haus
                        #95
                        @jeorgep:
                        @spectrekr:
                        Именно после перегрузки он может подхватить конфиг `
                        Не :o , я на DELL FX170 вся инфа в подписе
                        admin: 3.6.0
                        javascript: 4.1.10
                        cloud: 2.6.2
                        • H Offline
                          Haus
                          #96
                          @Bluefox:
                          @Haus:
                          @Bluefox:
                          А теперь?
                          Вот это в локал
                          Когда пять находит
                          filename="2016-08-24 13_57_25-ioBroker.admin.png" index="0">~~
                                  var promise;
                                  else {
                          Можешь встроить
                          И выполнить
                          iobroker stop owfs
                          Сделал, считал когда пять
                          2016-08-24 18:34:08.823 - debug: owfs.0 Connect to 127.0.0.1:4304
                          [{"header":{"version":0,"payload":85,"ret":0,"controlflags":32,"size":84,"offset":32770},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000\u0000"}]
                          Result for list: ["/10.DB1979020800","/28.ECB1CD040000","/28.3C3B63040000","/28.6659CE040000","/28.3E0764040000"]
                          2016-08-24 18:34:09.757 - debug: owfs.0 Result for list: ["/10.DB1979020800","/28.ECB1CD040000","/28.3C3B63040000","/28.6659CE040000","/28.3E0764040000"]
                          Result for list_: ["10.DB1979020800","28.ECB1CD040000","28.3C3B63040000","28.6659CE040000","28.3E0764040000"]
                          2016-08-24 18:34:09.758 - debug: owfs.0 Result for list_: ["10.DB1979020800","28.ECB1CD040000","28.3C3B63040000","28.6659CE040000","28.3E0764040000"]
                          [{"header":{"version":0,"payload":392,"ret":0,"controlflags":32,"size":391,"offset":0},"payload":"/10.DB1979020800/address,/10.DB1979020800/alias,/10.DB1979020800/crc8,/10.DB1979020800/errata,/10.DB1979020800/family,/10.DB1979020800/id,/10.DB1979020800/locator,/10.DB1979020800/power,/10.DB1979020800/r_address,/10.DB1979020800/r_id,/10.DB1979020800/r_locator,/10.DB1979020800/scratchpad,/10.DB1979020800/temperature,/10.DB1979020800/temphigh,/10.DB1979020800/templow,/10.DB1979020800/type\u0000"}]
                          [{"header":{"version":0,"payload":541,"ret":0,"controlflags":32,"size":540,"offset":0},"payload":"/28.ECB1CD040000/address,/28.ECB1CD040000/alias,/28.ECB1CD040000/crc8,/28.ECB1CD040000/errata,/28.ECB1CD040000/family,/28.ECB1CD040000/fasttemp,/28.ECB1CD040000/id,/28.ECB1CD040000/locator,/28.ECB1CD040000/power,/28.ECB1CD040000/r_address,/28.ECB1CD040000/r_id,/28.ECB1CD040000/r_locator,/28.ECB1CD040000/scratchpad,/28.ECB1CD040000/temperature,/28.ECB1CD040000/temperature10,/28.ECB1CD040000/temperature11,/28.ECB1CD040000/temperature12,/28.ECB1CD040000/temperature9,/28.ECB1CD040000/temphigh,/28.ECB1CD040000/templow,/28.ECB1CD040000/type\u0000"}]
                          [{"header":{"version":0,"payload":541,"ret":0,"controlflags":32,"size":540,"offset":0},"payload":"/28.3C3B63040000/address,/28.3C3B63040000/alias,/28.3C3B63040000/crc8,/28.3C3B63040000/errata,/28.3C3B63040000/family,/28.3C3B63040000/fasttemp,/28.3C3B63040000/id,/28.3C3B63040000/locator,/28.3C3B63040000/power,/28.3C3B63040000/r_address,/28.3C3B63040000/r_id,/28.3C3B63040000/r_locator,/28.3C3B63040000/scratchpad,/28.3C3B63040000/temperature,/28.3C3B63040000/temperature10,/28.3C3B63040000/temperature11,/28.3C3B63040000/temperature12,/28.3C3B63040000/temperature9,/28.3C3B63040000/temphigh,/28.3C3B63040000/templow,/28.3C3B63040000/type\u0000"}]
                          [{"header":{"version":0,"payload":541,"ret":0,"controlflags":32,"size":540,"offset":0},"payload":"/28.6659CE040000/address,/28.6659CE040000/alias,/28.6659CE040000/crc8,/28.6659CE040000/errata,/28.6659CE040000/family,/28.6659CE040000/fasttemp,/28.6659CE040000/id,/28.6659CE040000/locator,/28.6659CE040000/power,/28.6659CE040000/r_address,/28.6659CE040000/r_id,/28.6659CE040000/r_locator,/28.6659CE040000/scratchpad,/28.6659CE040000/temperature,/28.6659CE040000/temperature10,/28.6659CE040000/temperature11,/28.6659CE040000/temperature12,/28.6659CE040000/temperature9,/28.6659CE040000/temphigh,/28.6659CE040000/templow,/28.6659CE040000/type\u0000"}]
                          [{"header":{"version":0,"payload":541,"ret":0,"controlflags":32,"size":540,"offset":0},"payload":"/28.3E0764040000/address,/28.3E0764040000/alias,/28.3E0764040000/crc8,/28.3E0764040000/errata,/28.3E0764040000/family,/28.3E0764040000/fasttemp,/28.3E0764040000/id,/28.3E0764040000/locator,/28.3E0764040000/power,/28.3E0764040000/r_address,/28.3E0764040000/r_id,/28.3E0764040000/r_locator,/28.3E0764040000/scratchpad,/28.3E0764040000/temperature,/28.3E0764040000/temperature10,/28.3E0764040000/temperature11,/28.3E0764040000/temperature12,/28.3E0764040000/temperature9,/28.3E0764040000/temphigh,/28.3E0764040000/templow,/28.3E0764040000/type\u0000"}]
                          Result for dir: {"10.DB1979020800":["address","alias","crc8","errata","family","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temphigh","templow","type"],"28.ECB1CD040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"],"28.3C3B63040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"],"28.6659CE040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"],"28.3E0764040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"]}
                          2016-08-24 18:34:09.807 - debug: owfs.0 Result for dir: {"10.DB1979020800":["address","alias","crc8","errata","family","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temphigh","templow","type"],"28.ECB1CD040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"],"28.3C3B63040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"],"28.6659CE040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"],"28.3E0764040000":["address","alias","crc8","errata","family","fasttemp","id","locator","power","r_address","r_id","r_locator","scratchpad","temperature","temperature10","temperature11","temperature12","temperature9","temphigh","templow","type"]}
                          2016-08-24 18:34:09.808 - debug: owfs.0 sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
                          2016-08-24 18:34:13.959 - debug: inMem message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472052853910, q=0, from=system.adapter.admin.0, lc=1472052853910
                          Тут добавил датчик считал и получил 0
                          Read /28.3E0764040000/fasttemp:22.5
                          2016-08-24 17:25:39.499  - debug: owfs.0 Read /28.3E0764040000/fasttemp:22.5
                          2016-08-24 17:25:39.524  - debug: inMem message  owfs.0.* owfs.0.wires.Sensor8_fasttemp val=22.5, ack=true, ts=1472048739505, q=0, from=system.adapter.owfs.0, lc=1472040899036
                          2016-08-24 17:25:50.314  - debug: inMem message  messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=107, ack=false, time=1472048750295, _id=83207507
                          2016-08-24 17:25:50.322  - debug: owfs.0 Connect to 127.0.0.1:4304
                          [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":102,"ret":0,"controlflags":32,"size":101,"offset":32770},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF76034B0400\u0000"}]
                          2016-08-24 17:25:51.429  - debug: owfs.0 Result for list: [""]
                          2016-08-24 17:25:51.431  - debug: owfs.0 Result for list_: []
                          Result for dir: {}
                          2016-08-24 17:25:51.432  - debug: owfs.0 Result for dir: {}
                          2016-08-24 17:25:51.432  - debug: owfs.0 sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
                          Read /28.ECB1CD040000/fasttemp:24.5
                          2016-08-24 17:26:04.757  - debug: owfs.0 Read /28.ECB1CD040000/fasttemp:24.5
                          2016-08-24 17:26:04.786  - debug: inMem message  owfs.0.* owfs.0.wires.Sensor2_fasttemp val=24.5, ack=true, ts=1472048764764, q=0, from=system.adapter.owfs.0, lc=1472046903492
                          Read /28.6659CE040000/fasttemp:21
                          2016-08-24 17:26:05.067  - debug: owfs.0 Read /28.6659CE040000/fasttemp:21
                          2016-08-24 17:26:05.090  - debug: inMem message  owfs.0.* owfs.0.wires.Sensor6_fasttemp val=21, ack=true, ts=1472048765074, q=0, from=system.adapter.owfs.0, lc=1472048466105
                          Read /28.ECB1CD040000/temperature:24.5625
                          Вот это при локальном поиске
                          2016-08-24 17:22:09.831 - debug: owfs.0 Read /28.ECB1CD040000/temperature:24.5
                          2016-08-24 17:22:09.858 - debug: inMem message owfs.0.* owfs.0.wires.Sensor3_temperature val=24.5, ack=true, ts=1472048529838, q=0, from=system.adapter.owfs.0, lc=1472048319346
                          2016-08-24 17:22:20.355 - debug: inMem message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, path=/mnt/1wire, from=system.adapter.admin.0, path=/mnt/1wire, id=106, ack=false, time=1472048540343, _id=83207506
                          2016-08-24 17:22:20.364 - error: message messagebox.system.adapter.owfs.0 [object Object] Cannot call method 'readdir' of null
                          2016-08-24 17:22:20.370 - error: TypeError: Cannot call method 'readdir' of null
                          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          2016-08-24 17:22:34.683 - debug: owfs.0 Read /28.ECB1CD040000/fasttemp:24.5
                          2016-08-24 17:22:34.710 - debug: inMem message owfs.0.* owfs.0.wires.Sensor2_fasttemp val=24.5, ack=true, ts=1472048554689, q=0, from=system.adapter.owfs.0, lc=1472046903492
                          Read /28.3C3B63040000/fasttemp:22
                          2016-08-24 17:22:34.961 - debug: owfs.0 Read /28.3C3B63040000/fasttemp:22
                          2016-08-24 17:22:34.991 - debug: inMem message owfs.0.* owfs.0.wires.Sensor4_fasttemp val=22, ack=true, ts=1472048554968, q=0, from=system.adapter.owfs.0, lc=1472040658839
                          Read /28.6659CE040000/temperature:21.3125
                          2016-08-24 17:22:35.958 - debug: owfs.0 Read /28.6659CE040000/temperature:21.3125
                          2016-08-24 17:22:35.991 - debug: inMem message owfs.0.* owfs.0.wires.Sensor7_temperature val=21.3125, ack=true, ts=1472048555965, q=0, from=system.adapter.owfs.0, lc=1472048286461</anonymous>
                          admin: 3.6.0
                          javascript: 4.1.10
                          cloud: 2.6.2
                          • J Offline
                            jeorgep
                            #97
                            @spectrekr:
                            @jeorgep: Игрался и настраивал, не поддерживается. Там старые версии ядра еще можно было пропатчить, чтоб owfs заработал, на 4 версии ядра информации вообще не нашел. Внешнее устройство на i2c или USB в этом плане лучше.
                            Ну, и на всякий случай контрольный выстрел, чтобы совесть была чиста :)
                            В /etc/owfs.conf
                            должна быть указана точка монтирования:
                            Она должна существовать и на нее должны бть права:
                            mkdir /mnt/1wire
                            chmod 777 /mnt/1wire
                            chown root:root /mnt/1wire
                            И в /etc/fuse.conf не забыть:
                            user_allow_other
                            В /boot/config.txt Raspberry Pi:
                            Наверное (точно не помню - у меня Orange Pi, там этого нет):
                            dtoverlay=w1-gpio
                            У меня owfs самосборный, не из репозитария debian jessie.
                            А вот что говорит man owfs:
                            * w1 kernel module
                                   This  a  linux-specific option for using the operating system's access to bus masters. Root access is required and the implementation was
                                   still in progress as of owfs v2.7p12 and linux 2.6.30.
                                   Bus masters are recognized and added dynamically. Details of the physical bus master are not accessible, bu they include USB, i2c  and  a
                                   number of GPIO designs on embedded boards.
                                   Access  is  restrict  to superuser due to the netlink broadcast protocol employed by w1\. Multitasking must be configured (threads) on the
                                   compilation.
                                   --w1   Use the linux kernel w1 virtual bus master.
                            • BluefoxB Offline
                              BluefoxB Offline
                              #98
                              Я поправил на git локальный поиск. С большим количеством датчиков по сети пока ничего не делал.
                              • H Offline
                                Haus
                                #99
                                @Bluefox:
                                Я поправил на git локальный поиск. С большим количеством датчиков по сети пока ничего не делал. `
                                Сейчас попробую
                                P.S. локально считывает, сейчас добавлю датчиков
                                admin: 3.6.0
                                javascript: 4.1.10
                                cloud: 2.6.2
                                • H Offline
                                  Haus
                                  #100
                                  @Bluefox:
                                  Добавил датчики, ключи всё гут в новой конфигурации с чебоксом локально.
                                  А вот если сразу убрать чебокс и не сохранить, нажать на поиск сыпятся ошибки
                                  TypeError:	2016-08-25 00:23:40.195	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2096:34)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Adapter.emit (events.js:95:17)
                                  TypeError:	2016-08-25 00:23:40.195	error	at Adapter.adapter.on.timer (/opt/iobroker/node_modules/iobroker.owfs/main.js:24:14)
                                  TypeError:	2016-08-25 00:23:40.195	error	at processMessage (/opt/iobroker/node_modules/iobroker.owfs/main.js:136:39)
                                  TypeError:	2016-08-25 00:23:40.195	error	Cannot read property 'Client' of null
                                  message	2016-08-25 00:23:40.188	error	messagebox.system.adapter.owfs.0 [object Object] Cannot read property 'Client' of null
                                  owfs-0	2016-08-25 00:23:40.183	debug	Connect to 127.0.0.1:4304
                                  inMem	2016-08-25 00:23:40.177	debug	message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=160, ack=false, time=1472
                                  inMem	2016-08-25 00:23:33.570	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472073813535, q=0, from=system.adapter.admin.0, lc=1472073813535
                                  inMem	2016-08-25 00:23:33.567	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472073813535, q=0, from=system.adapter.admin.0, lc=1472073813535
                                  owfs-0	2016-08-25 00:23:30.755	info	starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.owfs
                                  owfs-0	2016-08-25 00:23:30.666	debug	statesDB connected
                                  owfs-0	2016-08-25 00:23:30.631	debug	objectDB connected
                                  host-Server1	2016-08-25 00:23:29.498	info	instance system.adapter.owfs.0 started with pid 21434
                                  host-Server1	2016-08-25 00:23:27.525	info	instance system.adapter.owfs.0 terminated with code 0 (OK)
                                  owfs-0	2016-08-25 00:23:27.498	info	terminating
                                  host-Server1	2016-08-25 00:23:26.971	info	stopInstance system.adapter.owfs.0 killing pid 21185
                                  host-Server1	2016-08-25 00:23:26.970	info	stopInstance system.adapter.owfs.0
                                  host-Server1	2016-08-25 00:23:26.962	info	object change system.adapter.owfs.0
                                  Bluefox, я думаю было бы здорово для каждого датчика сделать своё время опроса. Я раньше хитрил чтобы негонять опрос всех датчиков там где нужно часто (система отопления, котел, трёхходовой), запускал ещё один драйвер ну а в комнатах или ещё где рас в минуту или на улице рас в пять минут ну это ж кастыль
                                  admin: 3.6.0
                                  javascript: 4.1.10
                                  cloud: 2.6.2
                                  • J Offline
                                    jeorgep
                                    #101
                                    @Bluefox:
                                    Тестирую работу owfs.
                                    Установлена версия "version": "0.3.2"
                                    Работает достаточно хорошо, быстро в локальном режиме
                                    (в удаленном пока не тестировал - насколько я понимаю коллеги тестировали, у них работает)
                                    Из замечаний - некорректно работает поиск.
                                    Нашло 8 устройств - реально 15.
                                    (Для меня некритично - я их прописываю ручками).
                                    После редактирования OWFS свойств и записи увидел следующее:
                                    root@art4:~# ps ax | grep owfs
                                     1429 ?        Ssl  897:08 /opt/owfs/bin/owfs -c /etc/owfs.conf --pid-file /var/run/owfs/owfs.pid -C
                                    16952 ?        Sl     2:51 io.owfs.0
                                    17104 pts/5    S+     0:00 grep owfs
                                    29842 ?        Sl     4:21 io.owfs.0
                                    Запустилось два экземпляра адаптера owfs.
                                    В результате чего во вкладке objects неверно отображаются уже отредактированные
                                    обьекты owfs (не учтено последнее изменение)
                                    Возможно это связано с проблеммой http://forum.iobroker.net/viewtopic.php?p=33105#p33105
                                    Хотя здесь удвоились адаптеры на мастере.
                                    Кстати, при решении данной проблеммы нужно учесть, что периодически мастер сигнализирует
                                    об утраченной связи со слейвом, при том что тот жив, там хороший Ethernet,
                                    я на нем сижу по ssh и сессия не рвется:
                                    2016-08-25 06:52:14.141  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 06:52:14.155  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 08:36:34.419  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 08:36:34.429  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 11:13:33.746  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 15:43:56.440  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 15:43:56.461  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 16:33:23.163  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 16:33:23.340  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 17:07:41.211  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    2016-08-25 17:07:41.224  - .[33mwarn.[39m: host.art4 "system.host.art1" is offline
                                    В этом случае вариант:
                                    Если теряется связь с мастером, то все инстанции погасить. И ждать, когда связь снова появится.
                                    выглядит не очень хорошо - в каждом случае будут погашены реально работающие адаптеры на слейве.
                                    В том числе перезапущены скрипты, что есть не очень хорошо.
                                    Возможно следует пересмотреть систему детектирования слейвов или увеличить таймауты?
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      #102
                                      На гите:
                                      0.3.3 (2016-08-25)
                                      • (bluefox) custom poll interval for every sensor
                                      • (bluefox) fix list of sensors over ethernet more than 5
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        #103
                                        ` > Из замечаний - некорректно работает поиск.
                                        Нашло 8 устройств - реально 15. `
                                        Как выглядит папка /mnt/1wire ? Или где там у тебя замонтировано.
                                        • H Offline
                                          Haus
                                          #104
                                          @Bluefox:
                                          На гите:
                                          0.3.3 (2016-08-25)
                                          • (bluefox) fix list of sensors over ethernet more than 5 `
                                            Без чебокса, мастер подключен к серверу.
                                          ! inMem 2016-08-25 23:05:32.311 debug message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472155532267, q=0, from=system.adapter.admin.0, lc=1472155532267
                                          ! inMem 2016-08-25 23:05:32.293 debug message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472155532267, q=0, from=system.adapter.admin.0, lc=1472155532267
                                          ! owfs-0 2016-08-25 23:05:27.269 debug sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
                                          ! owfs-0 2016-08-25 23:05:27.268 error Cannot read dir: Invalid response for list [empty answer]
                                          ! owfs-0 2016-08-25 23:05:27.267 warn Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0
                                          ! owfs-0 2016-08-25 23:05:23.806 debug Connect to 192.168.1.11:4304
                                          ! inMem 2016-08-25 23:05:23.799 debug message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=192.168.1.11, port=4304, from=system.adapter.admin.0, ip=192.168.1.11, port=4304, id=13, ack=false, time
                                          ! megaesp-0 2016-08-25 23:05:16.788 debug Response for 192.168.1.20[all]: 117;123;255;temp:19.50/hum:80.70;temp:19.00;OFF;RGB;NC;NC;31
                                          ! megaesp-0 2016-08-25 23:05:16.769 debug getPortState http://192.168.1.20/sec/?cmd=all
                                          ! owfs-0 2016-08-25 23:05:04.845 debug sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
                                          ! owfs-0 2016-08-25 23:05:04.842 error Cannot read dir: Invalid response for list [empty answer]
                                          ! owfs-0 2016-08-25 23:05:04.839 warn Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0
                                          ! owfs-0 2016-08-25 23:05:01.310 debug Connect to 127.0.0.1:4304
                                          ! inMem 2016-08-25 23:05:01.304 debug message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=12, ack=false, time=14721
                                          ! inMem 2016-08-25 23:04:56.504 debug message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472155496459, q=0, from=system.adapter.admin.0, lc=1472155496459
                                          ! inMem 2016-08-25 23:04:56.495 debug message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472155496459, q=0, from=system.adapter.admin.0, lc=1472155496459
                                          ! owfs-0 2016-08-25 23:04:53.929 info starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.owfs
                                          ! owfs-0 2016-08-25 23:04:53.837 debug statesDB connected
                                          ! owfs-0 2016-08-25 23:04:53.817 debug objectDB connected
                                          ! host-Server1 2016-08-25 23:04:52.702 info instance system.adapter.owfs.0 started with pid 30470
                                          ! host-Server1 2016-08-25 23:04:50.741 info instance system.adapter.owfs.0 terminated with code 0 (OK)
                                          ! owfs-0 2016-08-25 23:04:50.720 info terminating
                                          ! host-Server1 2016-08-25 23:04:50.182 info stopInstance system.adapter.owfs.0 killing pid 29564
                                          ! host-Server1 2016-08-25 23:04:50.181 info stopInstance system.adapter.owfs.0
                                          ! host-Server1 2016-08-25 23:04:50.177 info object change system.adapter.owfs.0
                                          –force --logs
                                          root@Server1:/opt/iobroker# iobroker stop owfs
                                          Adapter "owfs.0 stopped.
                                          root@Server1:/opt/iobroker# node node_modules/iobroker.owfs/main.js --force --logs
                                          2016-08-25 23:53:59.435  - info: owfs.0 starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.owfs
                                          2016-08-25 23:54:24.315  - debug: inMem message  *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472158464267, q=0, from=system.adapter.admin.0, lc=1472158464267
                                          2016-08-25 23:54:26.874  - debug: inMem message  messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=16, ack=false, time=1472158466861, _id=36007437
                                          2016-08-25 23:54:26.880  - debug: owfs.0 Connect to 127.0.0.1:4304
                                          Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"size":271,"offset":32775},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28.FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000,/3A.DB481E000000\u0000"}]
                                          2016-08-25 23:54:30.349  - warn: owfs.0 Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"size":271,"offset":32775},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28.FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000,/3A.DB481E000000\u0000"}]
                                          2016-08-25 23:54:30.351  - error: owfs.0 Cannot read dir: Invalid response for list [empty answer]
                                          2016-08-25 23:54:30.354  - debug: owfs.0 sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
                                          2016-08-25 23:54:34.435  - debug: inMem message  *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472158474389, q=0, from=system.adapter.admin.0, lc=1472158474389
                                          С чебоксом "локальный OWFS"
                                          admin: 3.6.0
                                          javascript: 4.1.10
                                          cloud: 2.6.2
