  4. nach update von dem js-controller fehler
    6.8k
object.anonymous
9 Beiträge 2 Kommentatoren 884 Aufrufe 1 Beobachtet
  • R Offline
    Ragnar-Lodbrok
    ich überwache wann die Waschmaschiene fertig ist, was bis jetzt immer wunderbar ging.
    Seit dem Update des JS habe ich diesen Fehler:
    Was ist at Object.<anonymous> ?
    javascript.0	2020-09-02 17:27:24.219	error	(16965) at processImmediate (timers.js:658:5)
    javascript.0	2020-09-02 17:27:24.219	error	(16965) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-09-02 17:27:24.219	error	(16965) at runCallback (timers.js:705:18)
    javascript.0	2020-09-02 17:27:24.219	error	(16965) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.0	2020-09-02 17:27:24.219	error	(16965) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.0	2020-09-02 17:27:24.219	error	(16965) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.0	2020-09-02 17:27:24.219	error	(16965) at Object.<anonymous> (script.js.System-intern.Waschmaschine:8:80)
    javascript.0	2020-09-02 17:27:24.218	error	(16965) at script.js.System-intern.Waschmaschine:8:19
    javascript.0	2020-09-02 17:27:24.218	error	(16965) Error in callback: ReferenceError: unbenannt is not defined
    javascript.0	2020-09-02 17:25:40.209	error	(16965) at process.topLevelDomainCallback (domain.js:126:23)
    javascript.0	2020-09-02 17:25:40.209	error	(16965) at processImmediate (timers.js:658:5)
    javascript.0	2020-09-02 17:25:40.209	error	(16965) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-09-02 17:25:40.209	error	(16965) at runCallback (timers.js:705:18)
    javascript.0	2020-09-02 17:25:40.209	error	(16965) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.0	2020-09-02 17:25:40.209	error	(16965) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.0	2020-09-02 17:25:40.209	error	(16965) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.0	2020-09-02 17:25:40.208	error	(16965) at Object.<anonymous> (script.js.System-intern.Waschmaschine:8:80)
    javascript.0	2020-09-02 17:25:40.208	error	(16965) at script.js.System-intern.Waschmaschine:8:19
    javascript.0	2020-09-02 17:25:40.208	error	(16965) Error in callback: ReferenceError: unbenannt is not defined
    javascript.0	2020-09-02 17:24:12.214	error	(16965) at process.topLevelDomainCallback (domain.js:126:23)
    javascript.0	2020-09-02 17:24:12.213	error	(16965) at processImmediate (timers.js:658:5)
    javascript.0	2020-09-02 17:24:12.213	error	(16965) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-09-02 17:24:12.213	error	(16965) at runCallback (timers.js:705:18)
    Hardwaresystem: NUC
    Arbeitsspeicher: 64GB
    Festplattenart: SSD
    Betriebssystem:Debian
    Nodejs-Version:3.1.6|
    ioBroker 4.2.1
    • R Ragnar-Lodbrok
      @Ragnar-Lodbrok
      Was steht in Zeilen 7 und 8 des erzeugten Javascript-Codes ?
      • R Offline
        Ragnar-Lodbrok
              <field name="OP">AND</field>
              <value name="A">
        <block xmlns="https://developers.google.com/blockly/xml" type="schedule" id="rX*VvB{_?-2wsjy+)f85" x="212" y="412">
          <field name="SCHEDULE">{"time":{"start":"10:00","end":"20:00","mode":"hours","interval":1},"period":{"days":1}}</field>
          <statement name="STATEMENT">
            <block type="controls_if" id="tgx}w*8Nfo7}3;n,niO^">
              <value name="IF0">
                <block type="logic_operation" id="LnS=VjTC^$~g~:({%166" inline="false">
                  <value name="A">
                    <block type="time_compare_ex" id="Df^%Q70?B)tq;Pa#*mfx">
                      <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                      <field name="USE_ACTUAL_TIME">TRUE</field>
                      <field name="OPTION">between</field>
                      <value name="START_TIME">
                        <shadow type="text" id="D32Z#J0))0rE6VN8J;]U">
                          <field name="TEXT">11:00</field>
                        </shadow>
                      </value>
        Hardwaresystem: NUC
        Festplattenart: SSD
        ioBroker 4.2.1
        • R Ragnar-Lodbrok
                <value name="A">
                <value name="IF0">
                    <value name="A">
                          </shadow>
                        </value>
          @Ragnar-Lodbrok
          Nicht XML-Export, sondern erzeugter Javascript-Code.
          • R Offline
            Ragnar-Lodbrok
            sorry :-)
            (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
            Hardwaresystem: NUC
            Festplattenart: SSD
            ioBroker 4.2.1
            • R Ragnar-Lodbrok
              sorry :-)
              @Ragnar-Lodbrok
              Das ist wirklich Zeile 8 ? Ich würde ein getState() erwarten:
              • R Offline
                Ragnar-Lodbrok
                doch das ist die Zeile.
                Hardwaresystem: NUC
                Festplattenart: SSD
                ioBroker 4.2.1
                • R Ragnar-Lodbrok
                  @Ragnar-Lodbrok
                  Prüfe mal den Datenpunkt "CURRENT" bzw. dessen Zuweisung.
                  • R Ragnar-Lodbrok
                    @Ragnar-Lodbrok
                    Du stoppst timeout, verwendest dann aber timeout2. Stoppe timeout2 !
