  4. Harmony Adapter lässt sich nicht installieren
5 Beiträge 2 Kommentatoren 1.3k Aufrufe
  • C Offline
    csamaggi
    Halo ihr lieben,
    ich wollte nun meinen IO um den Harmony Adapter erweitern, doch dieser lässt sich nicht installieren hier mal der Auszug vom Log.
    iobroker	2017-01-28 19:03:54.003	info	exit 25
    iobroker	2017-01-28 19:03:53.967	error	host.ioBroker-Pi Cannot install iobroker.harmony: 1
    iobroker	2017-01-28 19:03:53.916	info	npm ERR! /npm-debug.log
    iobroker	2017-01-28 19:03:53.916	info	npm ERR! Please include the following file with any support request:
    iobroker	2017-01-28 19:03:53.628	info	Please check if you have git installed and in your PATH.
    iobroker	2017-01-28 19:03:53.624	info	npm ERR!
    iobroker	2017-01-28 19:03:53.624	info	npm ERR! This is most likely not a problem with npm itself.
    iobroker	2017-01-28 19:03:53.624	info	npm ERR! Failed using git.
    iobroker	2017-01-28 19:03:53.624	info	npm ERR! not found: git
    iobroker	2017-01-28 19:03:53.604	info	npm ERR! code ENOGIT
    iobroker	2017-01-28 19:03:53.601	info	npm ERR! npm v2.15.9
    iobroker	2017-01-28 19:03:53.601	info	npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.5.0
    iobroker	2017-01-28 19:03:53.594	info	npm ERR! Linux 4.4.13-v7+
    iobroker	2017-01-28 19:03:52.907	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
    iobroker	2017-01-28 19:03:52.885	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! g
    iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
    iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
    iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    iobroker	2017-01-28 19:03:52.726	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    iobroker	2017-01-28 19:03:52.716	info	at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    iobroker	2017-01-28 19:03:52.713	info	npm WARN addRemoteGit
    iobroker	2017-01-28 19:03:52.709	info	npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    iobroker	2017-01-28 19:03:50.967	info	engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.5.0","npm":"2.15.9"})
    iobroker	2017-01-28 19:03:50.964	info	WARN
    iobroker	2017-01-28 19:03:50.961	info	npm
    iobroker	2017-01-28 19:03:43.969	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    iobroker	2017-01-28 19:03:40.135	info	add harmony
    MFG Maggi
      dir fehlt ein Paket
      sudo apt-get install git
      Jetzt sag nicht dass du eine Installation unter Windoof hast.
      Da gibt es exakt zu diesem Thema bereits einiges.
      • C Offline
        csamaggi
        Also ich habe die Installation nicht unter Windows sondern auf einem Raspi2B.
          @csamaggi:
          Also ich habe die Installation nicht unter Windows sondern auf einem Raspi2B. `
          Dann führe den oben genannten Befehl ais ind versuche es nochmal.
          • C Offline
            csamaggi
            Danke das läuft nun schon mal.
            82.8k
