  4. Test Adapter Shelly v3.1.x
    6.6k
shellyadapter
282 Beiträge 36 Kommentatoren 62.7k Aufrufe 36 Beobachtet
  • K K_o_bold
    auch mit der aktuellsten Version leider ohne Erfolg:
    shelly.0	2020-06-17 22:13:22.184	info	(5007) Listening for Shelly packets in the network
    shelly.0	2020-06-17 22:13:22.150	info	(5007) Starting Shelly adapter in CoAP modus.
    shelly.0	2020-06-17 22:13:22.133	info	(5007) Polltime of the shelly devices: 10 sec.
    shelly.0	2020-06-17 22:13:22.133	info	(5007) Starting Adapter shelly.0 in version 3.3.2
    shelly.0	2020-06-17 22:13:22.119	info	(5007) starting. Version 3.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.20.1, js-controller: 3.1.4
    shelly.0	2020-06-17 22:13:22.035	debug	(5007) Plugin sentry Initialize Plugin (enabled=true)
    shelly.0	2020-06-17 22:13:21.861	debug	(5007) statesDB connected
    shelly.0	2020-06-17 22:13:21.861	debug	(5007) States connected to redis: 127.0.0.1:6379
    shelly.0	2020-06-17 22:13:21.857	debug	(5007) States create System PubSub Client
    shelly.0	2020-06-17 22:13:21.856	debug	(5007) States create User PubSub Client
    shelly.0	2020-06-17 22:13:21.853	debug	(5007) Redis States: Use Redis connection: 127.0.0.1:6379
    shelly.0	2020-06-17 22:13:21.851	debug	(5007) objectDB connected
    shelly.0	2020-06-17 22:13:21.847	debug	(5007) Objects connected to redis: 127.0.0.1:9001
    shelly.0	2020-06-17 22:13:21.840	debug	(5007) Objects client initialize lua scripts
    shelly.0	2020-06-17 22:13:21.840	debug	(5007) Objects create User PubSub Client
    shelly.0	2020-06-17 22:13:21.839	debug	(5007) Objects create System PubSub Client
    shelly.0	2020-06-17 22:13:21.837	debug	(5007) Objects client ready ... initialize now
    shelly.0	2020-06-17 22:13:21.820	debug	(5007) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.nuc	2020-06-17 22:13:21.213	info	instance system.adapter.shelly.0 started with pid 5007
    harrymH Offline
    harrymH Offline
    harrym
    schrieb am zuletzt editiert von harrym
    #207
    @K_o_bold stell den adapter bitte von info auf debug um .... unter instanzen, expertenmodus ... dann auf debug wechseln.
    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
    • harrymH harrym
      K_o_bold
      schrieb am zuletzt editiert von K_o_bold
      #208
      @harrym ,
      die logs die ich gepostet habe, wurden aus dem debug modus erzeugt.
      Die COAP Einstellungen im Adapter sehen wie folgt aus:
      Und der Shelly GAS ist nicht im mqtt Modus
      StuebiS 1 Antwort Letzte Antwort
      • K K_o_bold
        @harrym ,
        StuebiS Offline
        StuebiS Offline
        Stuebi
        schrieb am zuletzt editiert von Stuebi
        #209
        @K_o_bold , ich benötige immer folgende Infos mit jeweils kurzem Hinweis woher die Infos kommen wie z.B. (status, settings, CoAP oder MQTT). Bei neuen Geräten wird immer CoAP und MQTT implementiert und nicht einmal nur MQTT oder CoAP!
        Ab der Version 3.3.2 wird die CoAP Messages bei unbekannten Shelly Geräten im Logfile ohne in den Debug Modus zu wechseln angezeigt.
        CoAP Meldungen
        Shelly Gerät muss sich CoAP Modus befinden nun im Logfile nach folgender Info suchen:
        1. Send developer following Info: SHRGBW2#XX2090#1 : {"blk":[{"I":0,"D":"RGBW2"}],"sen":[{"I":118,"T":"S","D":"Input","R":"0/1","L":0},{"I":111,"T":"S","D":"Brightness_0","R":"0/100","L":0},{"I":121,"T":"S","D":"Brightness_1","R":"0/100","L":0},{"I":131,"T":"S","D":"Brightness_2","R":"0/100","L":0},{"I":141,"T":"S","D":"Brightness_3","R":"0/100","L":0},{"I":151,"T":"S","D":"VSwitch_0","R":"0/1","L":0},{"I":161,"T":"S","D":"VSwitch_1","R":"0/1","L":0},{"I":171,"T":"S","D":"VSwitch_2","R":"0/1","L":0},{"I":181,"T":"S","D":"VSwitch_3","R":"0/1","L":0},{"I":211,"T":"P","D":"Power_0","R":"0/288","L":0},{"I":221,"T":"P","D":"Power_1","R":"0/288","L":0},{"I":231,"T":"P","D":"Power_2","R":"0/288","L":0},{"I":241,"T":"P","D":"Power_3","R":"0/288","L":0}]}
        2 .Send developer following Info: SHRGBW2#XX2090#1 : {"G":[[0,111,50],[0,121,50],[0,131,50],[0,141,50],[0,151,0],[0,161,0],[0,171,0],[0,181,0],[0,211,0],[0,221,0],[0,231,0],[0,241,0],[0,118,0]]}
        MQTT
        Prüfe ob das neue Shelly Gerät in der API Dokumentation von Shelly steht https://shelly-api-docs.shelly.cloud . Sollte das Gerät in der Shelly API Dokumentation nicht stehen. Dann ist der ioBroker "MQTT Broker/Client" Adapter zu installieren. Der neue Shelly ist per MQTT mit dem MQTT Broker/Client" Adapter zu verbinden. Ich benötige dann alle Objekte für den neuen Shelly unter "mqtt.0".
        Status (http)
        Output http://ip-shelly/status . Passwort falls vorhanden anonymisieren, IP-Adresse, Hostname, SSID sind nicht zu anoymisieren. Das ist überflüssig
        Settings (http)
        Output http://ip-shelly/settings . Passwort falls vorhanden anonymisieren, IP-Adresse, Hostname, SSID sind nicht zu anoymisieren. Das ist überflüssig
        Stübi
        ioBroker auf Synology DS216+II im Docker Container
          MiB
          #210
          darf ich mal fragen warum der Adapter Shelly's mit FW <1.7.0 nicht mehr unterstüztz?
          Der Shelly 4Pro hat die 1.5.7 und da gibt es keine 1.7.0
          Kann ich den dann nicht mehr über ioBroker steuern?
          harrymH 1 Antwort Letzte Antwort
          • M MiB
            harrymH Offline
            harrymH Offline
            harrym
            #211
            @MiB gilt nur für den Shelly RGBW2.
              MiB
              #212
              Use only version with Shelly firmware greater equal v1.7.0 . Shelly firmware less v1.7.0 will not be supported by this Shelly adapter version anymore
              kann man aus dieser Aussage aber nicht ersehen, ich hoffe mal du hast da recht.
              • M MiB
                harrymH Offline
                harrymH Offline
                harrym
                #213
                @MiB ich habe recht .... weil sich eben mit der FW 1.7 beim RGBW2 etliches geändert hat.
                StuebiS M 2 Antworten Letzte Antwort
                • harrymH harrym
                  StuebiS Offline
                  StuebiS Offline
                  Stuebi
                  #214
                  Wer kann von Euch einmal die Adapter Version 3.3.3 folgende Geräte testen?
                  • Shelly RGBW2 White und Color im CoAP Modus
                  • Shelly RGBW2 White und Color im MQTT Modus
                  • Shelly Button im MQTT Modus
                  • Shelly Gas im CoAP Modus
                  • Shelly Gas im MQTT Modus
                  Leider hat die Shelly Button 1 Firmware 1.7.0 und auch die aktuelle Beta einen Syntaxfehler in den CoAP Nachrichten. Daher funtioniert der Shelly Button nicht im CoAP Modus
                  Die Version 3.3.3 muss noch über GitHub installiert werden. Wie das geht, steht hier
                  Stübi
                  • harrymH harrym
                    MiB
                    #215
                    @harrym sagte in Test Adapter Shelly v3.1.x:
                    der Adapter ist doch aber nicht nur für den RGBW2?
                    @Stuebi was ist mit dem Satz gemeint?
                    "Use only version with Shelly firmware greater equal v1.7.0 . Shelly firmware less v1.7.0 will not be supported by this Shelly adapter version anymore"
                    Grüße Micha
                    • M MiB
                      Grüße Micha
                      StuebiS Offline
                      StuebiS Offline
                      Stuebi
                      #216
                      Moin @MiB
                      genau das was @harrym richtig gesagt hat, es betrifft momentan nur den Shelly RGBW2. Dieser wird nicht umbedingt mit einer FW < 1.7.0 laufen. Ich habe es nicht getestet und kann nicht mit Gewissheit sagen, dass der Adapter mit der alten Firmware läuft.
                      Ich kann leider den Shelly Adapter nicht für jede FW supporten. Daher habe ich nun festgelegt, dass FW 1.7.0 für alle Shelly Geräte Voraussetzung ist. Alles andere ist eben auf eigene Gefahr.
                      Thorsten
                      • StuebiS Stuebi
                        Stübi
                        K_o_bold
                        #217
                        @Stuebi ,
                        ich habe den Shelly Gas im mqtt Modus mit folgendem Ergebnis getestet:
                        Der Shelly Gas lässt sich über mqtt nicht einbinden.
                        mqtt Einstellungen auf der Benutzeroberfläche sind die selben wie bei meinen anderen Shellys
                        CoAP geht bei mir gar nicht. Wenn ich mqtt deaktiviere, befindet sich der Shelly Gas in der "Status json" immer noch im mqtt Modus.
                        log mqtt Modus:
                        shelly.0	2020-06-21 15:52:21.219	info	(32414) Destroy 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1)
                        shelly.0	2020-06-21 15:52:21.218	info	(32414) Close Client: 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1) (false)
                        shelly.0	2020-06-21 15:52:21.212	error	(32414) Shelly Device unknown, configuratin for Shelly device 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1) for MQTT does not exist!
                        shelly.0	2020-06-21 15:51:22.463	info	(32414) Destroy 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1)
                        shelly.0	2020-06-21 15:51:22.462	info	(32414) Close Client: 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1) (false)
                        shelly.0	2020-06-21 15:51:22.456	error	(32414) Shelly Device unknown, configuratin for Shelly device 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1) for MQTT does not exist!
                        shelly.0	2020-06-21 15:50:26.426	info	(32414) Destroy 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1)
                        shelly.0	2020-06-21 15:50:26.426	info	(32414) Close Client: 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1) (false)
                        shelly.0	2020-06-21 15:50:26.420	error	(32414) Shelly Device unknown, configuratin for Shelly device 192.168.178.99 (shellygas / shellygas-50029178B567 / undefined#50029178B567#1) for MQTT does not exist!
                        shelly.0	2020-06-21 15:50:26.057	info	(32414) Shelly device 192.168.178.46 (shelly1 / shelly1-C426FE / SHSW-1#C426FE#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:26.036	info	(32414) Shelly device 192.168.178.47 (shelly1 / shelly1-B8F8D6 / SHSW-1#B8F8D6#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.879	info	(32414) Shelly device 192.168.178.78 (shelly1 / shelly1-689E9C / SHSW-1#689E9C#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.847	info	(32414) Shelly device 192.168.178.55 (shellyplug-s / shellyplug-s-7AEDDC / SHPLG-S#7AEDDC#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.694	info	(32414) Shelly device 192.168.178.42 (shelly1 / shelly1-C495C7 / SHSW-1#C495C7#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.658	info	(32414) Shelly device 192.168.178.61 (shellyplug-s / shellyplug-s-7AE316 / SHPLG-S#7AE316#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.564	info	(32414) Shelly device 192.168.178.73 (shelly1 / shelly1-BA0265 / SHSW-1#BA0265#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.500	info	(32414) Shelly device 192.168.178.79 (shelly1 / shelly1-68B4C7 / SHSW-1#68B4C7#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.425	info	(32414) Shelly device 192.168.178.80 (shelly1 / shelly1-769FE7 / SHSW-1#769FE7#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.397	info	(32414) Shelly device 192.168.178.72 (shelly1 / shelly1-BA026A / SHSW-1#BA026A#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.343	info	(32414) Shelly device 192.168.178.66 (shelly1 / shelly1-22F4DE / SHSW-1#22F4DE#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.321	info	(32414) Shelly device 192.168.178.71 (shellyplug-s / shellyplug-s-7AE1DC / SHPLG-S#7AE1DC#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.249	info	(32414) Shelly device 192.168.178.82 (shelly1 / shelly1-76A264 / SHSW-1#76A264#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:25.094	info	(32414) Shelly device 192.168.178.81 (shelly1 / shelly1-771516 / SHSW-1#771516#1) with MQTT connected!
                        shelly.0	2020-06-21 15:50:23.132	info	(32414) Starting Shelly adapter in MQTT modus. Listening on 192.168.178.11:1882
                        shelly.0	2020-06-21 15:50:23.114	info	(32414) Polltime of the shelly devices: 10 sec.
                        shelly.0	2020-06-21 15:50:23.114	info	(32414) Starting Adapter shelly.0 in version 3.3.3
                        Shelly Gas Status json mqtt:
                        {"wifi_sta": {"verbunden": true, "ssid": "xxx", "ip": "192.168.178.99", "rssi": - 60}, "cloud": {"enabled": false, " verbunden ": false}," mqtt ": {" verbunden ": false}," Zeit ":" 15:55 "," unixtime ": 1592754937," serial ": 1," has_update ": false," mac ": "50029178B567", "gas_sensor": {"sensor_state": "normal", "self_test_state": "not_completed", "alarm_state": "none"}, "Konzentration": {"ppm": 0, "is_valid": true }, "update": {"status": "idle", "has_update": false, "new_version": "20200601-123447/v1.7.0@d7961837", "old_version": "20200601-123447/v1.7.0@d7961837 "}," ram_total ": 50528," ram_free ": 39228," ram_lwm ": 33840," fs_size ": 233681," fs_free ": 134787," uptime ": 363}
                        Shelly Gas settings json mqtt:
                        {"device":{"type":"SHGS-1","mac":"50029178B567","hostname":"shellygas-50029178B567","num_inputs":0, "num_outputs":0},"wifi_ap":{"enabled":false,"ssid":"shellygas-50029178B567","key":""},"wifi_sta":{"enabled":true,"ssid":"xxx","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":true,"server":"192.168.178.11:1882","user":"mqttadmin","id":"shellygas-50029178B567","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"","fw":"20200601-123447/v1.7.0@d7961837","discoverable":true,"build_info":{"build_id":"20200601-123447/v1.7.0@d7961837","build_timestamp":"2020-06-01T12:34:47Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Berlin","lat":49.120998,"lng":9.209170,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":true,"tz_dst_auto":true,"time":"15:57","unixtime":1592755024,"hwinfo":{"hw_revision":"prod-2020-04-09", "batch_id":1},"set_volume":11,"alarm_off_url":null,"alarm_mild_url":null,"alarm_heavy_url":null}
                        • K K_o_bold
                          @Stuebi ,
                          log mqtt Modus:
                          StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          #218
                          @K_o_bold , hast du auch die Version 3.3.3 gestern über GitHub installiert? Lautet Log, sieht es nicht danach aus
                          harrymH K 2 Antworten Letzte Antwort
                          • StuebiS Stuebi
                            harrymH Offline
                            harrymH Offline
                            harrym
                            #219
                            @Stuebi
                            hat er ... ich verstehs gerade auch nicht.
                            • StuebiS Stuebi
                              K_o_bold
                              #220
                              @Stuebi ,
                              Gestern nicht. Das war vorgestern.
                              Hast du gestern noch was unter gleicher Versionsnummer geändert?
                              • harrymH harrym
                                @Stuebi
                                StuebiS Offline
                                StuebiS Offline
                                Stuebi
                                #221
                                @harrym , vielleicht eine alte 3.3.3? Am besten nochmals installieren. Ich habe den Gas auch seit gestern zu Hause rumliegen . Bei mir gehts super mit MQTT und CoAP
                                • K K_o_bold
                                  @Stuebi ,
                                  StuebiS Offline
                                  StuebiS Offline
                                  Stuebi
                                  #222
                                  @K_o_bold , jaaaaaaaa
                                  • StuebiS Stuebi
                                    harrymH Offline
                                    harrymH Offline
                                    harrym
                                    #223
                                    @Stuebi OK, das ist dann unfair gggggggggggg
                                    • StuebiS Stuebi
                                      K_o_bold
                                      #224
                                      @Stuebi ,
                                      ok...dann jetzt mit aktuellster frisch gezogener Version von "github".
                                      mqtt --> sofort gefunden, super geil ;-)
                                      CoAP --> weiterhin Probleme. Im log erscheint kein Eintrag..
                                      Kurze Zwischenfrage:
                                      Im CoAP Modus bin ich automatisch, wenn mqtt deaktiviert wird, oder?
                                      --> Selbst ein Neustart des Shelly Gas hat nichts gebracht... laut status bin ich noch im mqtt Modus ???
                                      Status im CoAP Modus:
                                      {"wifi_sta":{"connected":true,"ssid":"xxx","ip":"192.168.178.99","rssi":-61},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"17:13","unixtime":1592759605,"serial":1,"has_update":false,"mac":"50029178B567","gas_sensor":{"sensor_state":"normal","self_test_state":"not_completed","alarm_state":"none"},"concentration":{"ppm":0,"is_valid":true},"update":{"status":"idle","has_update":false,"new_version":"20200601-123447/v1.7.0@d7961837","old_version":"20200601-123447/v1.7.0@d7961837"},"ram_total":50528,"ram_free":39576,"ram_lwm":35472,"fs_size":233681,"fs_free":134787,"uptime":81}
                                      Edit: Ja, ich habe den adapter auf CoAP umgestellt...
                                      • K K_o_bold
                                        @Stuebi ,
                                        harrymH Offline
                                        harrymH Offline
                                        harrym
                                        #225
                                        @K_o_bold sagte in Test Adapter Shelly v3.1.x:
                                        was ich mitbekommen habe, coap ist jetzt immer aktiv ..... ohne Gewährleistung g
                                        • SlowmanS Offline
                                          SlowmanS Offline
                                          Slowman
                                          #226
                                          Seit, wann der Fehler ist, weiß ich nicht. Bekomme immer diese Fehlermeldung:
                                          shelly.0	2020-08-12 17:49:31.218	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#00598C#2.Relay0.Energy and request{"url":"http://192.168.2.109/settings","timeout":5000} for 192.168.2.109 (shelly1pm / shelly1pm-00598C /
                                          shelly.0	2020-08-12 17:49:31.205	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#E64888#2.Relay0.Energy and request{"url":"http://192.168.2.108/settings","timeout":5000} for 192.168.2.108 (shelly1pm / shelly1pm-E64888 /
                                          shelly.0	2020-08-12 17:49:31.040	info	(28717) Shelly device 192.168.2.109 (shelly1pm / shelly1pm-00598C / SHSW-PM#00598C#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:31.029	info	(28717) Shelly device 192.168.2.108 (shelly1pm / shelly1pm-E64888 / SHSW-PM#E64888#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:30.960	info	(28717) Shelly device 192.168.2.104 (shelly1 / shelly1-BA07C9 / SHSW-1#BA07C9#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:30.933	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#E6491D#2.Relay0.Energy and request{"url":"http://192.168.2.105/settings","timeout":5000} for 192.168.2.105 (shelly1pm / shelly1pm-E6491D /
                                          shelly.0	2020-08-12 17:49:30.801	error	(28717) Error in function httpIoBrokerState for state SHPLG-S#F8C02D#2.Relay0.Energy and request{"url":"http://192.168.2.111/settings","timeout":5000} for 192.168.2.111 (shellyplug-s / shellyplug-s-F8
                                          shelly.0	2020-08-12 17:49:30.755	info	(28717) Shelly device 192.168.2.105 (shelly1pm / shelly1pm-E6491D / SHSW-PM#E6491D#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:30.740	error	(28717) Error in function httpIoBrokerState for state SHPLG-S#F8C1C4#2.Relay0.Energy and request{"url":"http://192.168.2.110/settings","timeout":5000} for 192.168.2.110 (shellyplug-s / shellyplug-s-F8
                                          shelly.0	2020-08-12 17:49:30.668	info	(28717) Shelly device 192.168.2.111 (shellyplug-s / shellyplug-s-F8C02D / SHPLG-S#F8C02D#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:30.600	info	(28717) Shelly device 192.168.2.110 (shellyplug-s / shellyplug-s-F8C1C4 / SHPLG-S#F8C1C4#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:28.260	info	(28717) Shelly device 192.168.2.106 (shelly1 / shelly1-2271D5 / SHSW-1#2271D5#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:25.542	info	(28717) Shelly device 192.168.2.103 (shelly1 / shelly1-B9F6D8 / SHSW-1#B9F6D8#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:24.608	info	(28717) Shelly device 192.168.2.102 (shelly1 / shelly1-B9FD25 / SHSW-1#B9FD25#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:23.093	info	(28717) Shelly device 192.168.2.101 (shelly1 / shelly1-B9F815 / SHSW-1#B9F815#2) with CoAP connected!
                                          shelly.0	2020-08-12 17:49:18.929	info	(28717) Listening for Shelly packets in the network
                                          shelly.0	2020-08-12 17:49:18.895	info	(28717) Starting Shelly adapter in CoAP modus.
                                          shelly.0	2020-08-12 17:49:18.871	info	(28717) Polltime of the shelly devices: 10 sec.
                                          shelly.0	2020-08-12 17:49:18.870	info	(28717) Starting Adapter shelly.0 in version 3.3.4
                                          shelly.0	2020-08-12 17:49:18.851	info	(28717) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.18.2, js-controller: 3.1.6
                                          Neustarten des Adapter bzw. auf Version 3.32 brachte kein Erfolg. Shellys sind alle mit der aktuellen Firmware v1.8.0
                                          Danke für einen Tipp
                                          harrymH StuebiS 2 Antworten Letzte Antwort
