  4. [gelöst]NPM Module bei Javascript-Adapter Update nicht mitgespeichert
    1.0k
    6.1k
19 Beiträge 5 Kommentatoren 3.3k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Sollte mit 2.1.6 gefixt sein.
      ich habe eben mal nach deinem BTLE script gesehen.
      Da kam letztens eine Meldung, dass noble nicht da ist.
      So war es dann auch.
      noble wieder eingetragen,
      Skript neu gestartet - scan off
      javascript Instanz neu gestartet - scan off!
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        @Bluefox:
        Sollte mit 2.1.6 gefixt sein. `
        Verhält sich jetzt anders:
        javascript.0 29 21:34:21.663 error javascript.0 Cannot install npm packet: w
        javascript.0 29 21:34:21.663 error javascript.0 Cannot install w: 1
        javascript.0 29 21:34:21.659 error javascript.0 /npm-debug.log
        javascript.0 29 21:34:21.659 error javascript.0 ERR!
        javascript.0 29 21:34:21.658 error javascript.0
        javascript.0 29 21:34:21.658 error javascript.0 npm
        javascript.0 29 21:34:21.658 error javascript.0 Please include the following file with any support request:
        javascript.0 29 21:34:21.658 error javascript.0 ERR!
        javascript.0 29 21:34:21.657 error javascript.0 npm
        javascript.0 29 21:34:21.638 error javascript.0 There is likely additional logging output above.
        javascript.0 29 21:34:21.636 error javascript.0 ERR!
        javascript.0 29 21:34:21.636 error javascript.0 npm ERR! npm owner ls w npm
        javascript.0 29 21:34:21.635 error javascript.0
        javascript.0 29 21:34:21.635 error javascript.0 ERR!
        javascript.0 29 21:34:21.635 error javascript.0 npm
        javascript.0 29 21:34:21.634 error javascript.0 Exit status 1 npm ERR! npm ERR! Failed at the w@0.0.1 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the w package, npm ERR! not with npm itself. npm ERR
        javascript.0 29 21:34:21.633 error javascript.0 ERR!
        javascript.0 29 21:34:21.632 error javascript.0 ERR! node v4.4.5 npm ERR! npm v2.15.5 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm
        javascript.0 29 21:34:21.631 error javascript.0 npm
        javascript.0 29 21:34:21.630 error javascript.0 npm ERR! Linux 4.4.0-22-generic npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
        javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! not ok
        javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! node-gyp -v v3.3.1
        javascript.0 29 21:34:21.624 error javascript.0 cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/w gyp ERR! node -v v4.4.5
        javascript.0 29 21:34:21.624 error javascript.0 ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR!
        javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic
        javascript.0 29 21:34:21.624 error javascript.0 ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js
        javascript.0 29 21:34:21.623 error javascript.0 ERR! stack Error: make failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        javascript.0 29 21:34:21.623 error javascript.0 gyp
        javascript.0 29 21:34:21.622 error javascript.0 build error
        javascript.0 29 21:34:21.622 error javascript.0 ERR!
        javascript.0 29 21:34:21.622 error javascript.0 gyp
        javascript.0 29 21:34:21.622 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1
        javascript.0 29 21:34:21.622 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird verlassen
        javascript.0 29 21:34:21.621 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte
        javascript.0 29 21:34:21.617 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
        javascript.0 29 21:34:21.600 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
        javascript.0 29 21:34:21.600 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
        javascript.0 29 21:34:21.226 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
        javascript.0 29 21:34:20.684 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
        javascript.0 29 21:34:20.684 error javascript.0 Cannot install w: 1
        javascript.0 29 21:34:20.676 error javascript.0 npm ERR! Please include the following file with any support request: npm ERR! /npm-debug.log
        javascript.0 29 21:34:20.673 error javascript.0
        javascript.0 29 21:34:20.654 error javascript.0 ERR! There is likely additional logging output above.
        javascript.0 29 21:34:20.653 error javascript.0 npm ERR! npm ERR! npm owner ls w npm
        javascript.0 29 21:34:20.653 error javascript.0 npm ERR! npm ERR! Failed at the w@0.0.1 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the w package, npm ERR! not with npm itself. npm ERR! Tell the auth
        javascript.0 29 21:34:20.651 error javascript.0 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm ERR! Exit status 1
        javascript.0 29 21:34:20.651 error javascript.0 ERR! node v4.4.5 npm ERR! npm v2.15.5
        javascript.0 29 21:34:20.650 error javascript.0 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
        javascript.0 29 21:34:20.650 error javascript.0 ERR! Linux 4.4.0-22-generic
        javascript.0 29 21:34:20.643 error javascript.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/w gyp ERR! node -v v4.4.5 gyp ERR! node-gyp -v v3.3.1 gyp ERR! not ok
        javascript.0 29 21:34:20.642 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd
        javascript.0 29 21:34:20.641 error javascript.0 stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:1
        javascript.0 29 21:34:20.640 error javascript.0
        javascript.0 29 21:34:20.638 error javascript.0 ERR!
        javascript.0 29 21:34:20.638 error javascript.0 gyp
        javascript.0 29 21:34:20.637 error javascript.0 ERR! build error gyp ERR! stack Error: make failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        javascript.0 29 21:34:20.637 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1 gyp
        javascript.0 29 21:34:20.637 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird
        javascript.0 29 21:34:20.632 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
        javascript.0 29 21:34:20.613 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
        javascript.0 29 21:34:20.612 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
        javascript.0 29 21:34:20.233 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
        javascript.0 29 21:34:19.683 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
        javascript.0 29 21:34:19.681 error javascript.0 Cannot install w: 1
        javascript.0 29 21:34:19.673 error javascript.0 /npm-debug.log
        javascript.0 29 21:34:19.672 error javascript.0 ERR!
        javascript.0 29 21:34:19.670 error javascript.0
        javascript.0 29 21:34:19.669 error javascript.0 npm
        javascript.0 29 21:34:19.667 error javascript.0 Please include the following file with any support request:
        javascript.0 29 21:34:19.666 error javascript.0 ERR!
        javascript.0 29 21:34:19.664 error javascript.0
        javascript.0 29 21:34:19.662 error javascript.0 npm
        javascript.0 29 21:34:19.660 error javascript.0
        javascript.0 29 21:34:19.639 error javascript.0 npm ERR! node v4.4.5 npm ERR! npm v2.15.5 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the w@0.0.1 install s
        javascript.0 29 21:34:19.639 error javascript.0 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
        javascript.0 29 21:34:19.634 error javascript.0 ERR! Linux 4.4.0-22-generic
        javascript.0 29 21:34:19.634 error javascript.0 npm
        javascript.0 29 21:34:19.629 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modul
        javascript.0 29 21:34:19.628 error javascript.0 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at Child
        javascript.0 29 21:34:19.627 error javascript.0 ERR! build error gyp ERR! stack Error: make failed with exit code: 2
        javascript.0 29 21:34:19.626 error javascript.0 gyp
        javascript.0 29 21:34:19.624 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1
        javascript.0 29 21:34:19.624 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird
        javascript.0 29 21:34:19.622 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
        javascript.0 29 21:34:19.603 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
        javascript.0 29 21:34:19.602 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
        javascript.0 29 21:34:19.232 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
        javascript.0 29 21:34:18.510 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
        javascript.0 29 21:34:18.510 info javascript.0 starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.javascript
        Nach dem Update auf 2.1.6 gab es erst keinen Unterschied.
        dewpoint war noch eingetragen.
        gelöscht und wieder eingetragen und dann kamen die Fehler oben.
        • ruhr70R Offline
          ruhr70R Offline
          ruhr70
          @Homoran:
          javascript Instanz neu gestartet - scan off! `
          Was heisst "scan off"?
          Meinst Du den Datenpunkt:
          javascript.0.Bluetooth.Control_ScanOn
          Wenn ja, einfach auf true setzen, damit der Scan gestartet wird.
          Ansonsten… was steht im Datenpunkt:
          javascript.0.Bluetooth.InfoSkript.Status_noble
          • ruhr70R Offline
            ruhr70R Offline
            ruhr70
            @ruhr70:
            @Bluefox:
            gelöscht und wieder eingetragen und dann kamen die Fehler oben. `
            Nachtrag:
            in /opt/iobroker/node_modules/iobroker.javascript/node_modules/ wurden mit der Version 2.1.16 und dem Eintrag "dewpoint" nun folgende Unterverzeichnisse installiert:
            /d
            /e
            /i
            /n
            /o
            /p
            /t
            Bis auf das w ergibt das ja "dewpoint". :lol:
            [EDIT] die Verzeichnisse sind nicht leer. Jedes Verzeichnis hat aber einen anderen Inhalt.
            Es wurden wirklich die npm Module:
            d, e, i, n, o, p und t installiert :lol: :o :shock:
              Nee läuft einfach nicht, weil:
              21:44:30.825	[info]	javascript.0 Stop script script.js.Anwesenheit.Bluetoothscanner
              21:44:30.920	[info]	javascript.0 Start javascript script.js.Anwesenheit.Bluetoothscanner
              21:44:30.922	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' at script.js.Anwesenheit.Bluetoothscanner:350:15
              21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: --== script.js.Anwesenheit.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
              21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
              21:44:30.923	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: node.js Module "noble" steht nicht zur Verfügung
              21:44:30.923	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Voraussetzung für noble: https://github.com/sandeepmistry/noble#prerequisites
              21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
              21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
              21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: warn: Das Skript wurde nicht gestartet. Siehe Fehlermeldungen.
              Skript ist aber als aktiv markiert!
              Ich will jetzt die Instanz nicht noch löschen und neu installieren.
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                Schau mal bitte unter:
                Findest Du dort noble?
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  @ruhr70:
                  @ruhr70:
                  @Bluefox:
                  Wie entsorgt man eigentlich am Besten Node Module, die man nicht benötigt?
                  Für das Modul d einfach das Verzeichnis:
                  /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                  löschen?
                    bei mir sind die Verzeichnisse n,o,b,l und e angelegt worden :mrgreen:
                    • BluefoxB Offline
                      BluefoxB Offline
                      @ruhr70:
                      @ruhr70:
                      @ruhr70:
                      löschen? `
                      Ja :lol:
                      Es gibt neue Version. :?
                      • ruhr70R Offline
                        ruhr70R Offline
                        ruhr70
                        @Bluefox:
                        @ruhr70:
                        löschen? `
                        Ja :lol:
                        Es gibt neue Version. :? `
                        :D
                        Wir nähern uns der Version 3.0 :mrgreen:
                        Jetzt funktioniert es! Danke!
                        dewpoint wurde nach dem Update installiert, ohne das ich was tun musste und die einzelnen Module d,e,p,o,i,n,t sind auch alle automatisch verschwunden. Das lässt Rückschlüsse auf die Installation zu (zum Verständnis für mich). Danke!
                          Auch bei mir war noble dann von selbst drin.
                          Ich hatte nur vorher die anderen Verzeichnisse gelöscht.
                          Die Meldung des fehlenden noble ist jetzt weg, aber er fängt nicht mehr an zu scannen:
                          22:07:54.286	[info]	javascript.0 Start javascript script.js.Anwesenheit.Bluetoothscanner
                          22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: --== script.js.Anwesenheit.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
                          22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
                          22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
                          22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
                          22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: dpAnlegen() - Datenpunkte angelegt (createState) in javascript.0.Bluetooth.
                          22:07:54.288	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: registered 0 subscriptions and 0 schedules
                          22:07:55.314	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Kommando Bluetooth Scanner an: false
                          Seltsamerweise war noble auch poweredOn, als noble gar nicht da war
                          • ruhr70R Offline
                            ruhr70R Offline
                            ruhr70
                            Du musst den Datenpunkt hier auf true setzen:
                              Danke!
                              Aber warum, musste ich doch noch nie?
                              Auch neustart von script oder Instanz hatte den Scan nicht gestartet.
                              • ruhr70R Offline
                                ruhr70R Offline
                                ruhr70
                                @Homoran:
                                Danke!
                                Rainer `
                                Das Skript ist so geschrieben, dass Du es komplett benutzen kannst, ohne im Skript was anzupassen. Ausser Du möchtest die Blacklists oder eigenen Geräte pflegen (muss man aber nicht).
                                Über den Datenpunkt kann man das Skript steuern (Scan starten oder stoppen), z.B. über VIS.
                                Wenn die Voraussetzungen nicht gegeben sind, wird der Datenpunkt automatisch auf false gesetzt. Ich dachte, es macht keinen Sinn, dass dort ein true drin steht, wenn der Scan nicht läuft. Durch das Update vom Javascript-Adpater fehlte Dir das Module Noble. Das Skript hat es erkannt und sich selbst gestoppt.
                                  Danke und Gute N8
