  4. ICal Daten in Datenpunkte schreiben
    5.7k
42 Beiträge 4 Kommentatoren 6.3k Aufrufe 3 Beobachtet
    der-eine
    `var idCal = "ical.1";
    var idCalTrigger   = idCal + ".data.trigger";
    var idCalTable     = idCal + ".data.table";
    var idCalHTML      = idCal + ".data.html";
    var idCalHTMLtable = idCal + "_1.json";
    function iCalToHTMLTable() {
        console.log(idCalTable);
        var calTable = getState(idCalTable);
        var inst     = getObject("system.adapter." + idCal);
        var instopt  = inst.native;
        var calendar = {};
        var event = "";
        var date = "";
        for (var i = 0; i < 3; i++) {
            console.log("entry: " + JSON.stringify(entry));
            console.log("caltable: " + JSON.stringify(calTable));
            console.log("caltable inc: " + JSON.stringify(calTable.val[i]));
            var entry = calTable.val[i];
            if (entry._calName != calendar.name) {
                calendar = {};
                for (var c = 0; c < instopt.calendars.length; c++ ) {
                    if (entry._calName == instopt.calendars[c].name ) {
                        calendar = instopt.calendars[c];
                        break;
        event += entry.event + ",";
        date +=  entry.date + ",";
        var event1 = event.split(",")[0];
        var event2 = event.split(",")[1];
        var event3 = event.split(",")[2];
        var date1 = date.split(",")[0];
        var date2 = date.split(",")[1];
        var date3 = date.split(",")[2];
        setState('Hilfsvariablen.0.Kalender.Daniel.event1', event1);
        setState('Hilfsvariablen.0.Kalender.Daniel.event2', event2);
        setState('Hilfsvariablen.0.Kalender.Daniel.event3', event3);
        setState('Hilfsvariablen.0.Kalender.Daniel.date1', date1);
        setState('Hilfsvariablen.0.Kalender.Daniel.date2', date2);
        setState('Hilfsvariablen.0.Kalender.Daniel.date3', date3);
        setState('Hilfsvariablen.0.Kalender.Daniel.event', event);
        setState('Hilfsvariablen.0.Kalender.Daniel.date', date);
    on({id: idCalTable, change: "ne"}, function (obj) {
        iCalToHTMLTable();
    schedule("5,35 * * * *", function () { iCalToHTMLTable(); });
    iCalToHTMLTable();`
    `~~[code]~~javascript.0	2019-02-06 14:11:42.046	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
    javascript.0	2019-02-06 14:11:42.046	error	at script.js.common.Kalender.Daniel.danw:56:1
    javascript.0	2019-02-06 14:11:42.045	error	at iCalToHTMLTable (script.js.common.Kalender.Daniel.danw:21:19)
    javascript.0	2019-02-06 14:11:42.045	error	TypeError: Cannot read property '_calName' of undefined
    javascript.0	2019-02-06 14:11:42.045	error	^
    javascript.0	2019-02-06 14:11:42.045	error	if (entry._calName != calendar.name) {
    javascript.0	2019-02-06 14:11:42.045	error	script.js.common.Kalender.Daniel.danw: script.js.common.Kalender.Daniel.danw:21[/code]`[/i][/i]
      danw
      Ich sehe immernoch nicht die Ausgaben der Logzeilen.
      Wenn Variable entry leer ist, kommt dieser Fehler. Die Frage ist: Warum ist die leer.
      Die Reihenfolge bitte noch tauschen wie folgt:
       `var entry = calTable.val[i];
              console.log("caltable inc: " + JSON.stringify(calTable.val[i]));` [/i][/i]
      It's not a Bug, it's a Feature
        der-eine
        gelöscht
          danw
          Einmal steht etwas in entry, einmal nicht. Wie ist der iCal Adapter eingestellt? Ich habe nur die URL der .ical konfiguriert, mehr nicht.
            der-eine
                var calendar = {};
                var event = "";
                var date = "";
                                break;
                iCalToHTMLTable();
            iCalToHTMLTable();`
            `~~[code]~~14:18:17.394	info	javascript.0 Stop script script.js.common.Kalender.Daniel.danw
            14:18:17.446	info	javascript.0 Start javascript script.js.common.Kalender.Daniel.danw
            14:18:17.447	error	javascript.0 script.js.common.Kalender.Daniel.danw compile failed:
             at script.js.common.Kalender.Daniel.danw:27[/code]`
            `~~[code]~~javascript.0	2019-02-06 14:18:51.431	error	at TCP.onread (net.js:601:20)
            javascript.0	2019-02-06 14:18:51.431	error	at Socket.Readable.push (_stream_readable.js:208:10)
            javascript.0	2019-02-06 14:18:51.431	error	at readableAddChunk (_stream_readable.js:250:11)
            javascript.0	2019-02-06 14:18:51.431	error	at addChunk (_stream_readable.js:263:12)
            javascript.0	2019-02-06 14:18:51.431	error	at Socket.emit (events.js:211:7)
            javascript.0	2019-02-06 14:18:51.431	error	at emitOne (events.js:116:13)
            javascript.0	2019-02-06 14:18:51.430	error	at Socket._ultron.on (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:138:22)
            javascript.0	2019-02-06 14:18:51.430	error	at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:139:10)
            javascript.0	2019-02-06 14:18:51.430	error	at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:165:16)
            javascript.0	2019-02-06 14:18:51.430	error	at Receiver.getData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:330:12)
            javascript.0	2019-02-06 14:18:51.430	error	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
            javascript.0	2019-02-06 14:18:51.430	error	at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
            javascript.0	2019-02-06 14:18:51.429	error	at WebSocket.emit (events.js:211:7)
            javascript.0	2019-02-06 14:18:51.429	error	at emitOne (events.js:116:13)
            javascript.0	2019-02-06 14:18:51.429	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
            javascript.0	2019-02-06 14:18:51.429	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
            javascript.0	2019-02-06 14:18:51.425	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
            javascript.0	2019-02-06 14:18:51.425	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
            javascript.0	2019-02-06 14:18:51.425	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
            javascript.0	2019-02-06 14:18:51.425	error	at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
            javascript.0	2019-02-06 14:18:51.424	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
            javascript.0	2019-02-06 14:18:51.424	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
            javascript.0	2019-02-06 14:18:51.424	error	at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
            javascript.0	2019-02-06 14:18:51.424	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
            javascript.0	2019-02-06 14:18:51.424	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
            javascript.0	2019-02-06 14:18:51.424	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
            javascript.0	2019-02-06 14:18:51.423	error	at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
            javascript.0	2019-02-06 14:18:51.423	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
            javascript.0	2019-02-06 14:18:51.423	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
            javascript.0	2019-02-06 14:18:51.423	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
            javascript.0	2019-02-06 14:18:51.422	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
            javascript.0	2019-02-06 14:18:51.422	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
            javascript.0	2019-02-06 14:18:51.422	error	at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:837:17)
            javascript.0	2019-02-06 14:18:51.422	error	at createActiveObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1214:20)
            javascript.0	2019-02-06 14:18:51.421	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1160:37)
            javascript.0	2019-02-06 14:18:51.421	error	at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:971:28)
            javascript.0	2019-02-06 14:18:51.421	error	at Object.createScript (vm.js:80:10)
            javascript.0	2019-02-06 14:18:51.421	error	SyntaxError: Unexpected token }
            javascript.0	2019-02-06 14:18:51.421	error	^
            javascript.0	2019-02-06 14:18:51.421	error	}
            javascript.0	2019-02-06 14:18:51.420	error	at script.js.common.Kalender.Daniel.danw:27
            javascript.0	2019-02-06 14:18:51.420	error	script.js.common.Kalender.Daniel.danw compile failed:
            javascript.0	2019-02-06 14:18:51.415	info	Start javascript script.js.common.Kalender.Daniel.danw
            javascript.0	2019-02-06 14:18:50.260	info	Stop script script.js.common.Kalender.Daniel.danw[/code]</anonymous></anonymous></anonymous></anonymous>`[/i][/i][/i]
              der-eine
              Hier sind die Einstellungen
                danw
                @der-eine:
                    var calendar = {};
                    var event = "";
                    var date = "";
                                    break;
                    iCalToHTMLTable();
                iCalToHTMLTable();`
                Jetzt hast du die Hälfte des Scriptes ersetzt. Das macht so keinen Spass. Ich bin raus.[/i][/i][/i]
                  der-eine
                  Verstehe jetzt das Problem nicht aber wie ich am Anfang geschrieben habe, kenne ich mich mit JS nicht aus und suche deshalb Hilfe!
                  Es tut mir leid wenn ich nicht alles richtig kopiert habe oder evtl an die falsche Stelle aber ich bin auch kein Programmierer ansonsten würde ich nicht nach Hilfe fragen…
                  Trotzdem danke für Deine Zeit
                  • W Offline
                    W Offline
                    webseb79
                    ich habe das oben genannte Script bei mir laufen und bekomme auch die Datenpunkte gefüllt.
                    Kann man das Datum auch trennen?
                    D.h. einen Termin mit Zeitangabe von ... bis ... extra auslesen?
                    Somit hat man dann Date: 13.04.2019 Event: Forum lesen Zeit: 12:00 bis 15:00 Uhr.
                    Wäre das möglich?
                    Und kann man auch den Ort auslesen wenn man einen angibt ?
                    Danke im voraus
                    Sebastian
                      seppel786
                      schrieb am zuletzt editiert von seppel786
                      Re: ICal Daten in Datenpunkte schreiben
                      ich habe obenstehendes Skript bei mir eingebunden und bekomme die gleiche Fehlermeldung wie der uneinsichtige Kollege :-)
                      var idCal = "ical.0";
                          var calendar = {};
                          var event = "";
                          var date = "";
                              console.log("test entry: " + JSON.stringify(entry));
                              console.log(" test caltable: " + JSON.stringify(calTable));
                              console.log("test caltable inc: " + JSON.stringify(calTable.val[i]));
                                  calendar = {};
                                          break;
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Termin_1_Text', event1);
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Termin_2_Text', event2);
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Termin_3_Text', event3);
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Datum_1', date1);
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Datum_2', date2);
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Datum_3', date3);
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Termin', event);
                          setState('javascript.0.EigeneDatenpunkte.Kalender.Datum', date);
                          iCalToHTMLTable();
                      iCalToHTMLTable();
                      Anbei die Logs:
                      Könnte hier mir jemand auf die Sprünge helfen, da JS nicht gerade mein Steckenpferd ist.
                      Danke Euch!
                      Gruß Seppel
                        seppel786
                        Hat niemand eine Idee?
