  4. [gelöst]Admin aufrufbar, aber lädt nix....
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
admin adaptererrorproblem
19 Beiträge 2 Kommentatoren 2.6k Aufrufe 1 Beobachtet
    @andyb sagte in Admin aufrufbar, aber lädt nix....:
    Vis ist auch über die Tablets nicht mehr erreichbar....
    wenn doch, läge es ja nicht an der Installation
    andyb
    @Homoran
    das ist der obere Teil....ich fang leider nix damit an
    andy@nuciobprod:~$ iobroker stop
    andy@nuciobprod:~$ cd /opt/iobroker
    andy@nuciobprod:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js --logs
    2020-03-27 18:43:10.466  - info: host.nuciobprod iobroker.js-controller version 2.2.9 js-controller starting
    2020-03-27 18:43:10.474  - info: host.nuciobprod Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-03-27 18:43:10.475  - info: host.nuciobprod hostname: nuciobprod, node: v10.19.0
    2020-03-27 18:43:10.477  - info: host.nuciobprod ip addresses: 192.168.1.xxx
    2020-03-27 18:43:11.736  - info: host.nuciobprod connected to Objects and States
    2020-03-27 18:43:12.186  - info: host.nuciobprod 77 instances found
    host.nuciobprod check instance "system.adapter.discovery.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.feiertage.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.tr-064.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.mihome.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.hue.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.ping.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.hm-rpc.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.hm-rpc.1" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.hm-rpc.2" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.hm-rega.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.web.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.sonos.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.backitup.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.pushbullet.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.harmony.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.cloud.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.simple-api.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.socketio.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.ical.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.parser.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.mobile.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.terminal.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.landroid-s.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-bars.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-canvas-gauges.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-weather.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-timeandweather.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-metro.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-justgage.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-players.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.daswetter.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.email.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.info.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.netatmo.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.text2command.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.telegram.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.javascript.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.javascript.1" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.alexa2.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.google-sharedlocations.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.places.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.node-red.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.fullcalendar.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.dwd.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-fancyswitch.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-jqui-mfd.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-map.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-hqwidgets.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.sql.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.mqtt.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.weatherunderground.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-history.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.ical.1" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.ical.2" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.owntracks.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.fullybrowser.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.spotify-premium.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.mqtt.1" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.habpanel.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.shuttercontrol.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.ring.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.iot.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.vis-inventwo.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.ical.3" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.trashschedule.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.nina.0" for host "nuciobprod"
    host.nuciobprod check instance "system.adapter.admin.0" for host "nuciobprod"
    2020-03-27 18:43:12.313  - info: host.nuciobprod starting 37 instances
    2020-03-27 18:43:12.321  - warn: host.nuciobprod startInstance cannot find adapter "google-sharedlocations@1.5.2". Try to install it... 1 attempt
    2020-03-27 18:43:12.321  - info: host.nuciobprod iobroker install google-sharedlocations@1.5.2 using installedVersion
    2020-03-27 18:43:12.366  - info: host.nuciobprod instance system.adapter.admin.0 started with pid 28122
    2020-03-27 18:43:14.161  - error: host.nuciobprod iobroker npm-install: host.nuciobprod Unknown packetName google-sharedlocations
    2020-03-27 18:43:14.169  - info: host.nuciobprod iobroker npm-install: host.nuciobprod download google-sharedlocationsFile not found: google-sharedlocations
    2020-03-27 18:43:14.174  - info: host.nuciobprod iobroker npm-install: exit 1
    2020-03-27 18:43:16.332  - info: host.nuciobprod instance scheduled system.adapter.feiertage.0 0 0 * * *
    2020-03-27 18:43:16.345  - info: host.nuciobprod instance system.adapter.feiertage.0 started with pid 28137
    2020-03-27 18:43:20.332  - info: host.nuciobprod instance system.adapter.mihome.0 started with pid 28152
    2020-03-27 18:43:20.825  - info: host.nuciobprod instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:43:24.334  - info: host.nuciobprod instance system.adapter.hue.0 started with pid 28167
    2020-03-27 18:43:28.333  - info: host.nuciobprod instance system.adapter.hm-rpc.0 started with pid 28182
    2020-03-27 18:43:32.335  - info: host.nuciobprod instance system.adapter.web.0 started with pid 28198
    2020-03-27 18:43:36.513  - info: host.nuciobprod instance system.adapter.sonos.0 started with pid 28213
    2020-03-27 18:43:40.341  - info: host.nuciobprod instance system.adapter.backitup.0 started with pid 28228
    2020-03-27 18:43:44.330  - info: host.nuciobprod instance system.adapter.pushbullet.0 started with pid 28239
    { Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/js/config.js'
        at Object.openSync (fs.js:443:3)
        at Object.writeFileSync (fs.js:1194:35)
        at indicateError (/opt/iobroker/node_modules/iobroker.vis/main.js:259:12)
        at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.vis/main.js:340:29)
        at IncomingMessage.emit (events.js:203:15)
        at endReadableNT (_stream_readable.js:1145:12)
        at process._tickCallback (internal/process/next_tick.js:63:19)
      errno: -13,
      syscall: 'open',
      code: 'EACCES',
      path: '/opt/iobroker/node_modules/iobroker.vis/www/js/config.js' }
    2020-03-27 18:43:51.079  - error: host.nuciobprod Caught by controller[0]: { Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/js/config.js'
    2020-03-27 18:43:51.080  - error: host.nuciobprod Caught by controller[0]:     at Object.openSync (fs.js:443:3)
    2020-03-27 18:43:51.080  - error: host.nuciobprod Caught by controller[0]:     at Object.writeFileSync (fs.js:1194:35)
    2020-03-27 18:43:51.081  - error: host.nuciobprod Caught by controller[0]:     at indicateError (/opt/iobroker/node_modules/iobroker.vis/main.js:259:12)
    2020-03-27 18:43:51.082  - error: host.nuciobprod Caught by controller[0]:     at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.vis/main.js:340:29)
    2020-03-27 18:43:51.082  - error: host.nuciobprod Caught by controller[0]:     at IncomingMessage.emit (events.js:203:15)
    2020-03-27 18:43:51.083  - error: host.nuciobprod Caught by controller[0]:     at endReadableNT (_stream_readable.js:1145:12)
    2020-03-27 18:43:51.084  - error: host.nuciobprod Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
    2020-03-27 18:43:51.084  - error: host.nuciobprod Caught by controller[0]:   errno: -13,
    2020-03-27 18:43:51.085  - error: host.nuciobprod Caught by controller[0]:   syscall: 'open',
    2020-03-27 18:43:51.085  - error: host.nuciobprod Caught by controller[0]:   code: 'EACCES',
    2020-03-27 18:43:51.086  - error: host.nuciobprod Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.vis/www/js/config.js' }
    2020-03-27 18:43:51.086  - info: host.nuciobprod instance system.adapter.vis.0 terminated while should be started once
    2020-03-27 18:43:52.332  - info: host.nuciobprod instance system.adapter.cloud.0 started with pid 28273
    TypeError: Cannot read property 'isValidUTF8' of undefined
        at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
        at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
        at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
        at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
        at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
        at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
        at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
        at TLSSocket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
        at TLSSocket.emit (events.js:198:13)
        at addChunk (_stream_readable.js:288:12)
    ================================== > LOG REDIRECT system.adapter.cloud.0 => false [Process stopped]
    2020-03-27 18:43:56.177  - error: host.nuciobprod Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
    2020-03-27 18:43:56.178  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
    2020-03-27 18:43:56.178  - error: host.nuciobprod Caught by controller[0]:     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    2020-03-27 18:43:56.179  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    2020-03-27 18:43:56.179  - error: host.nuciobprod Caught by controller[0]:     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    2020-03-27 18:43:56.179  - error: host.nuciobprod Caught by controller[0]:     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    2020-03-27 18:43:56.180  - error: host.nuciobprod Caught by controller[0]:     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    2020-03-27 18:43:56.180  - error: host.nuciobprod Caught by controller[0]:     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    2020-03-27 18:43:56.181  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    2020-03-27 18:43:56.181  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.emit (events.js:198:13)
    2020-03-27 18:43:56.181  - error: host.nuciobprod Caught by controller[0]:     at addChunk (_stream_readable.js:288:12)
    2020-03-27 18:43:56.182  - info: host.nuciobprod instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:43:56.182  - info: host.nuciobprod Restart adapter system.adapter.cloud.0 because enabled
    ================================== > LOG REDIRECT system.adapter.cloud.0 => false [system.adapter.cloud.0.logging]
    2020-03-27 18:43:56.336  - info: host.nuciobprod instance system.adapter.socketio.0 started with pid 28288
    2020-03-27 18:44:00.477  - info: host.nuciobprod instance scheduled system.adapter.ical.0 3,33 * * * *
    2020-03-27 18:44:00.496  - info: host.nuciobprod instance system.adapter.ical.0 started with pid 28304
    2020-03-27 18:44:04.334  - info: host.nuciobprod instance system.adapter.parser.0 started with pid 28319
    2020-03-27 18:44:08.336  - info: host.nuciobprod instance system.adapter.terminal.0 started with pid 28334
    2020-03-27 18:44:12.036  - info: host.nuciobprod instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:44:12.321  - info: host.nuciobprod instance scheduled system.adapter.daswetter.0 57 */3 * * *
    2020-03-27 18:44:16.336  - info: host.nuciobprod instance system.adapter.email.0 started with pid 28349
    2020-03-27 18:44:20.337  - info: host.nuciobprod instance system.adapter.info.0 started with pid 28364
    2020-03-27 18:44:24.336  - info: host.nuciobprod instance system.adapter.netatmo.0 started with pid 28383
    2020-03-27 18:44:26.202  - info: host.nuciobprod instance system.adapter.cloud.0 started with pid 28394
    2020-03-27 18:44:28.336  - info: host.nuciobprod instance system.adapter.text2command.0 started with pid 28786
    2020-03-27 18:44:30.313  - error: host.nuciobprod Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
    2020-03-27 18:44:30.314  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
    2020-03-27 18:44:30.314  - error: host.nuciobprod Caught by controller[0]:     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    2020-03-27 18:44:30.314  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    2020-03-27 18:44:30.315  - error: host.nuciobprod Caught by controller[0]:     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    2020-03-27 18:44:30.315  - error: host.nuciobprod Caught by controller[0]:     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    2020-03-27 18:44:30.315  - error: host.nuciobprod Caught by controller[0]:     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    2020-03-27 18:44:30.315  - error: host.nuciobprod Caught by controller[0]:     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    2020-03-27 18:44:30.316  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    2020-03-27 18:44:30.316  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.emit (events.js:198:13)
    2020-03-27 18:44:30.317  - error: host.nuciobprod Caught by controller[0]:     at addChunk (_stream_readable.js:288:12)
    2020-03-27 18:44:30.317  - info: host.nuciobprod instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:44:30.317  - info: host.nuciobprod Restart adapter system.adapter.cloud.0 because enabled
    2020-03-27 18:44:32.336  - info: host.nuciobprod instance system.adapter.javascript.0 started with pid 28811
    2020-03-27 18:44:36.460  - info: host.nuciobprod instance system.adapter.alexa2.0 started with pid 28974
    2020-03-27 18:44:40.347  - info: host.nuciobprod instance system.adapter.places.0 started with pid 28999
    2020-03-27 18:44:44.656  - info: host.nuciobprod instance system.adapter.node-red.0 started with pid 29164
    2020-03-27 18:44:48.350  - info: host.nuciobprod instance system.adapter.fullcalendar.0 started with pid 29191
    2020-03-27 18:44:52.508  - info: host.nuciobprod instance scheduled system.adapter.dwd.0 */5 * * * *
    2020-03-27 18:44:52.524  - info: host.nuciobprod instance system.adapter.dwd.0 started with pid 29376
    2020-03-27 18:44:56.350  - info: host.nuciobprod instance system.adapter.sql.0 started with pid 29396
    2020-03-27 18:44:56.736  - info: host.nuciobprod instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:00.023  - info: host.nuciobprod instance system.adapter.dwd.0 started with pid 29467
    2020-03-27 18:45:00.341  - info: host.nuciobprod instance system.adapter.cloud.0 started with pid 29574
    2020-03-27 18:45:00.347  - info: host.nuciobprod instance scheduled system.adapter.weatherunderground.0 12 */3 * * *
    2020-03-27 18:45:00.362  - info: host.nuciobprod instance system.adapter.weatherunderground.0 started with pid 29580
    2020-03-27 18:45:04.337  - info: host.nuciobprod instance scheduled system.adapter.ical.1 6,36 * * * *
    2020-03-27 18:45:04.353  - info: host.nuciobprod instance system.adapter.ical.1 started with pid 29623
    2020-03-27 18:45:05.462  - error: host.nuciobprod Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
    2020-03-27 18:45:05.462  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
    2020-03-27 18:45:05.463  - error: host.nuciobprod Caught by controller[0]:     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    2020-03-27 18:45:05.463  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    2020-03-27 18:45:05.464  - error: host.nuciobprod Caught by controller[0]:     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    2020-03-27 18:45:05.464  - error: host.nuciobprod Caught by controller[0]:     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    2020-03-27 18:45:05.465  - error: host.nuciobprod Caught by controller[0]:     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    2020-03-27 18:45:05.465  - error: host.nuciobprod Caught by controller[0]:     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    2020-03-27 18:45:05.466  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    2020-03-27 18:45:05.466  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.emit (events.js:198:13)
    2020-03-27 18:45:05.466  - error: host.nuciobprod Caught by controller[0]:     at addChunk (_stream_readable.js:288:12)
    2020-03-27 18:45:05.467  - info: host.nuciobprod instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:05.467  - info: host.nuciobprod Restart adapter system.adapter.cloud.0 because enabled
    2020-03-27 18:45:06.252  - info: host.nuciobprod instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:07.620  - info: host.nuciobprod instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:08.749  - info: host.nuciobprod instance scheduled system.adapter.ical.2 1,31 * * * *
    2020-03-27 18:45:08.768  - info: host.nuciobprod instance system.adapter.ical.2 started with pid 29793
    2020-03-27 18:45:12.351  - info: host.nuciobprod instance system.adapter.fullybrowser.0 started with pid 29813
    2020-03-27 18:45:14.253  - info: host.nuciobprod instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:16.349  - info: host.nuciobprod instance system.adapter.mqtt.1 started with pid 29989
    2020-03-27 18:45:18.925  - info: host.nuciobprod instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:20.350  - info: host.nuciobprod instance system.adapter.iot.0 started with pid 30009
    2020-03-27 18:45:28.339  - info: host.nuciobprod instance scheduled system.adapter.ical.3 4,34 * * * *
    2020-03-27 18:45:28.354  - info: host.nuciobprod instance system.adapter.ical.3 started with pid 30206
    2020-03-27 18:45:32.351  - info: host.nuciobprod instance system.adapter.trashschedule.0 started with pid 30381
    2020-03-27 18:45:35.482  - info: host.nuciobprod instance system.adapter.cloud.0 started with pid 30401
    2020-03-27 18:45:36.352  - info: host.nuciobprod instance system.adapter.nina.0 started with pid 30408
    2020-03-27 18:45:38.820  - info: host.nuciobprod instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:39.139  - error: host.nuciobprod Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
    2020-03-27 18:45:39.140  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
    2020-03-27 18:45:39.140  - error: host.nuciobprod Caught by controller[0]:     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    2020-03-27 18:45:39.141  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    2020-03-27 18:45:39.141  - error: host.nuciobprod Caught by controller[0]:     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    2020-03-27 18:45:39.142  - error: host.nuciobprod Caught by controller[0]:     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    2020-03-27 18:45:39.142  - error: host.nuciobprod Caught by controller[0]:     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    2020-03-27 18:45:39.143  - error: host.nuciobprod Caught by controller[0]:     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    2020-03-27 18:45:39.143  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    2020-03-27 18:45:39.144  - error: host.nuciobprod Caught by controller[0]:     at TLSSocket.emit (events.js:198:13)
    2020-03-27 18:45:39.144  - error: host.nuciobprod Caught by controller[0]:     at addChunk (_stream_readable.js:288:12)
    2020-03-27 18:45:39.145  - info: host.nuciobprod instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
    2020-03-27 18:45:39.145  - info: host.nuciobprod Restart adapter system.adapter.cloud.0 because enabled
    2020-03-27 18:46:09.158  - info: host.nuciobprod instance system.adapter.cloud.0 started with pid 31108
    • A andyb
      @Homoran
        errno: -13,
        syscall: 'open',
        code: 'EACCES',
      lass mal den fixer drüber laufen
        andyb
        @Homoran
        so?
        curl -sL https://iobroker.net/fix.sh | bash -
        • A andyb
          @Homoran
          so?
          @andyb jepp - steht so auch in meiner Signatur
            andyb
            @Homoran 😇
              andyb
              leider kein erfolg
              ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
              2020-03-27 18:58:44.484  - error: host.nuciobprod Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
              2020-03-27 18:58:44.485  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
              2020-03-27 18:58:44.486  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
              2020-03-27 18:58:44.486  - error: host.nuciobprod Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
              2020-03-27 18:58:44.487  - error: host.nuciobprod Caught by controller[0]:     at afterWrite (_stream_writable.js:485:3)
              2020-03-27 18:58:44.487  - error: host.nuciobprod Caught by controller[0]:     at onwrite (_stream_writable.js:476:7)
              2020-03-27 18:58:44.488  - error: host.nuciobprod Caught by controller[0]:     at InflateRaw.afterTransform (_stream_transform.js:94:3)
              2020-03-27 18:58:44.488  - error: host.nuciobprod Caught by controller[0]:     at Zlib.processCallback (zlib.js:557:8)
              2020-03-27 18:58:44.488  - info: host.nuciobprod instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
              2020-03-27 18:58:44.489  - info: host.nuciobprod Restart adapter system.adapter.admin.0 because enabled
              • A andyb
                leider kein erfolg
                @andyb Sorry, dann bin ich mit meinem Latein am Ende.
                Vielleicht kann sich da jetzt jemand anderes einklinken
                A 3 Antworten Letzte Antwort
                  andyb
                  @Homoran
                  Schade....Danke
                    andyb
                    schrieb am zuletzt editiert von andyb
                    @Homoran Jetzt wirds ganz komisch.....
                    Hab gerade mein Backup in Proxmox von vor 2 Wochen zurück gespielt, das lief 100%
                    Immer noch gleiches Problem. Muss wohl ganz wo anderst ein Problem vorliegen. Sehr komisch
                    Gerade noch einen clean install auf einer neuen engine gemacht, der läuft.....
                      andyb
                      @Homoran
                      So, Problem gelöscht......wäre leider auch viel einfacher gewesen.
                      Ich habe nun alles restored usw und das Problem war wieder das gleiche.
                      Alle Adapter waren letzter Stand stable und der Fehler kam wieder.
                      Update von socket.io von 2.1.2 (2019-09-28) (im stable letzte und aktuelle version) auf 3.0.2 (2020-03-07) von github.....und et läuft wieder :-)
