  4. Homekit Anfängerfrage
4 Beiträge 2 Kommentatoren 1.3k Aufrufe
  • V Offline
    V Offline
    venni
    ich bin durch die Forensuche durch die Installation von homekit gekommen.
    Sollte nach der Installation der Status nicht mit Host verbunden sein?
    LG
    venni
    • V Offline
      V Offline
      venni
      Dashier steht noch im Log:
      2016-03-12 19:14:51.664 - debug: homekit.0 objectDB connected
      2016-03-12 19:14:51.739 - error: host.raspberrypi instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
      2016-03-12 19:14:51.741 - info: host.raspberrypi Restart adapter system.adapter.homekit.0 because enabled
      2016-03-12 19:15:21.820 - info: host.raspberrypi instance system.adapter.homekit.0 started with pid 17813
      2016-03-12 19:15:25.396 - error: uncaught exception: Cannot find module './build/Release/bignum'
      2016-03-12 19:15:25.442 - error: Error: Cannot find module './build/Release/bignum'
      at Function.Module._resolveFilename (module.js:336:15)
      at Function.Module._load (module.js:278:25)
      at Module.require (module.js:365:17)
      at new require (module.js:384:17)
      at Object. <anonymous>(/opt/iobroker/node_modules/bignum/index.js:4:14)
      at Module._compile (module.js:460:26)
      at Object.Module._extensions..js (module.js:478:10)
      at Module.load (module.js:355:32)
      at Function.Module._load (module.js:310:12)
      at Module.require (module.js:365:17)</anonymous>
      • V Offline
        V Offline
        venni
        bignum konnte ich nachinstallieren.
        Danach kam das hier:
        2016-03-12 19:45:46.194 - info: homekit.0 starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
        2016-03-12 19:45:46.231 - debug: homekit.0 requesting all states
        2016-03-12 19:45:46.259 - debug: homekit.0 requesting all objects
        2016-03-12 19:45:49.311 - debug: homekit.0 received all objects
        2016-03-12 19:45:49.422 - debug: homekit.0 received all states
        2016-03-12 19:45:49.432 - info: homekit.0 hap-nodejs starting…
        2016-03-12 19:45:49.458 - error: uncaught exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
        2016-03-12 19:45:49.467 - error: Error: Cannot find module 'hap-nodejs/node_modules/node-persist'
        at require (module.js:384:17)
        at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:215:19)
        at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
        at /opt/iobroker/node_modules/iobroker.homekit/main.js:168:61
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2473:60
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:151:27)
        at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
        Also hap-nodejs auch noch installiert.
        Dann aber das:
        2016-03-12 19:46:17.383 - info: homekit.0 hap-nodejs starting...
        2016-03-12 19:46:17.402 - error: uncaught exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
        2016-03-12 19:46:17.409 - error: Error: Cannot find module 'hap-nodejs/node_modules/node-persist'
        Der Pfad stimmte nicht.
        also "node-persist" zum Test mal von "/opt/iobroker/node_modules/node-persist" nach "/opt/iobroker/node_modules/hap-nodejs/node_modules/node-persist" kopiert.
        Nun wieder was neues (fängt an und bricht dann wieder mit einer Exception ab):
        2016-03-12 20:58:50.764 - debug: homekit.0 objectDB connected
        2016-03-12 20:58:50.817 - debug: homekit.0 statesDB connected
        2016-03-12 20:58:50.972 - info: homekit.0 starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
        2016-03-12 20:58:50.987 - debug: homekit.0 requesting all states
        2016-03-12 20:58:50.993 - debug: homekit.0 requesting all objects
        2016-03-12 20:58:52.244 - info: host.raspberrypi instance system.adapter.web.0 started with pid 29146
        2016-03-12 20:58:53.421 - debug: homekit.0 received all states
        2016-03-12 20:58:54.114 - debug: homekit.0 received all objects
        2016-03-12 20:58:54.125 - info: homekit.0 hap-nodejs starting...
        2016-03-12 20:58:54.294 - debug: homekit.0 < hap Type for Humidity = HM-TC-IT-WM-W-EU
        2016-03-12 20:58:54.316 - debug: homekit.0 > iobroker subscribe Humidity hm-rpc.0.LEQ0441129.1.HUMIDITY
        2016-03-12 20:58:54.321 - error: uncaught exception: Cannot read property 'CurrentRelativeHumidity' of undefined
        2016-03-12 20:58:54.330 - error: TypeError: Cannot read property 'CurrentRelativeHumidity' of undefined
        at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit/main.js:511:41)
        at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:280:67)
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
        at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        Ich gebs jetzt langsam auf 😢</anonymous></anonymous></anonymous></anonymous></anonymous>
        • V Offline
          V Offline
          versteckt
          Hallo venni!
          Für mich klingt das stark nach Problemen, die bereits bei der Installation aufgetreten sind.
          Welche node bzw. npm Version bzw. welches Betriebssystem hast du im Einsatz?
          LG Christian
          Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
          homegear für Homematic und MAX!
          occ, zWave, rpi, hmm und homekit Entwickler
          82.9k
