  4. Grafik hochladen geht nicht mehr
    1.9k
vishow-to
26 Beiträge 2 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • M MarkusL
    @Glasfaser Ja. Keine Änderung.
    GlasfaserG Offline
    GlasfaserG Offline
    @MarkusL
    Da klemmt was ....
    Versuche nochmal ein Bild hochzuladen !
    Dann im Browser F12 drücken , auf Konsole gehen und mir das per Screenshot senden
    M 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      @MarkusL
      Da klemmt was ....
      MarkusL
      @Glasfaser meinst Du mit Konsole den HTML Text, der nach F12 erscheint?
      • M MarkusL
        GlasfaserG Offline
        GlasfaserG Offline
        @MarkusL
        sieht so dann aus :
        Kommen dort Warn oder Errormeldungen
          @MarkusL
          Da klemmt was ....
          MarkusL
          @Glasfaser hier ist der Konsoleneintrag:
          ailed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_moon_phases_8.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_moonset.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_night_fog.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_moonrise.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_pollen.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_night_cloudy.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_rain.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_night_starry.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_rain_gauge.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_rain_heavy.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_rain_light.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_rain_meter.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_sleet.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_snow.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_snow_heavy.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_snow_ice_warning.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_snow_light.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_station.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_station_quadra.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_storm.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_summer.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_sun.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_sunrise.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_sunset.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_e.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_thunderstorm.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_n.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_ne.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_nw.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_s.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_se.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_sw.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_directions_w.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_no_wind.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_winter.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_speed.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_speed_bft.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0web.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0weather_wind_speed_ms.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0win10.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0wind.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0xmg.jpg:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0yamaha.jpg:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          :8082/vis.0yamaha.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          fileManager.js:982 TypeError: Cannot read property 'name' of undefined
          at upload (fileManager.js:961)
          at HTMLButtonElement.<anonymous> (fileManager.js:988)
          at HTMLButtonElement.dispatch (jquery-1.11.2.min.js:3)
          at HTMLButtonElement.r.handle (jquery-1.11.2.min.js:3)
          5821 log entries are not shown.
          3fileManager.js:982 TypeError: Cannot read property 'name' of undefined
          • M MarkusL
            GlasfaserG Offline
            GlasfaserG Offline
            @MarkusL
            Nein , das ist nur eine Ausgabe das er die zugewiesenen ( alten ) Bilder nicht findet .
            Starrte mal dein System neu ( Reboot )
              @MarkusL
              MarkusL
              @Glasfaser Hilft leider nichts. Die Files sind zwar im vis.0 Ordner vorhanden, aber anscheinend nicht registriert. Auf jeden Fall tauchen sie nicht im Datei Manager auf. Kann ich die Registrierung manuell über das Verzeichnis laufen lassen?
              • M MarkusL
                GlasfaserG Offline
                GlasfaserG Offline
                @MarkusL
                Die Bilder müssen zwingend über den Dateimanager hochgeladen werden ( Registrierung).
                Lege die Bilder in dein VIS.0/projekt
                  @MarkusL
                  MarkusL
                  @Glasfaser Das hilft aber ohne Registrierung nichts, oder? Ich kann sie zwar nach vis.0 kopieren, aber ohne eine Registrierung komme ich damit ja auch nicht weiter. Oder kann ich die Registrierung händisch anstossen?
                  • M MarkusL
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @MarkusL
                    Nimm doch mal bitte ein Bild ... zb. was auf dein Desktop liegt und lade es über den Dateimanager in dein Projekt hoch . nennen wie es vis.0/DeineProjekt da ich nicht weiß wie es heißt .
                    Funktioniert es auch dort nicht !??
                      @MarkusL
                      MarkusL
                      @Glasfaser Das ist genau das was ich mache....
                      • M MarkusL
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @MarkusL
                        Ok ... und das Bild ist dann anschließend nicht über den Datenpunkt im Vis auswählbar / Sichtbar
                          @MarkusL
                          MarkusL
                          @Glasfaser nein. Es bleibt auch im Upload Fenster des Datei Manager stehen (früher sind die hochgeladenen Bilder dort verschwunden, so dass man den Fortgang schön anschauen konnte). Im Datei Manager ist es nicht zu finden.
                          • M MarkusL
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @MarkusL
                            Welche js-controller hast du 2.2.8 .
                            Zeige mal bitte :
                            cd /opt/iobroker
                            iobroker list adapters
                            iobroker list instances
                            nodejs -v
                            node -v
                            npm -v
                            M GlasfaserG 2 Antworten Letzte Antwort
                              @MarkusL
                              Zeige mal bitte :
                              cd /opt/iobroker
                              nodejs -v
                              node -v
                              npm -v
                              MarkusL
                              @Glasfaser hier die Adapter:
                              C:\iobroker\iobrokervm>iobroker list adapters
                              system.adapter.admin : admin - v4.0.4
                              system.adapter.alexa2 : alexa2 - v3.0.7
                              system.adapter.backitup : backitup - v1.3.6
                              system.adapter.cloud : cloud - v3.0.1
                              system.adapter.daswetter : daswetter - v2.8.1
                              system.adapter.denon : denon - v1.7.2
                              system.adapter.discovery : discovery - v2.2.2
                              system.adapter.dwd : dwd - v2.4.3
                              system.adapter.email : email - v1.0.6
                              system.adapter.flot : flot - v1.9.2
                              system.adapter.fritzbox : fritzbox - v0.2.1
                              system.adapter.fritzdect : fritzdect - v0.2.4
                              system.adapter.history : history - v1.8.7
                              system.adapter.hm-rega : hm-rega - v2.5.5
                              system.adapter.hm-rpc : hm-rpc - v1.12.7
                              system.adapter.hue : hue - v3.2.3
                              system.adapter.ical : ical - v1.7.0
                              system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
                              system.adapter.icons-fatcow-hosting : icons-fatcow-hosting - v0.1.0
                              system.adapter.icons-icons8 : icons-icons8 - v0.0.1
                              system.adapter.icons-material-png : icons-material-png - v0.1.0
                              system.adapter.icons-material-svg : icons-material-svg - v0.1.0
                              system.adapter.icons-mfd-png : icons-mfd-png - v1.0.2
                              system.adapter.icons-mfd-svg : icons-mfd-svg - v1.0.2
                              system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
                              system.adapter.icons-ultimate-png : icons-ultimate-png - v1.0.1
                              system.adapter.info : info - v1.5.7
                              system.adapter.iot : iot - v1.3.2
                              system.adapter.javascript : javascript - v4.1.12
                              system.adapter.mobile : mobile - v0.5.0
                              system.adapter.mqtt : mqtt - v2.1.1
                              system.adapter.node-red : node-red - v1.13.0
                              system.adapter.phantomjs : phantomjs - v1.0.1
                              system.adapter.ping : ping - v1.3.2
                              system.adapter.pollenflug : pollenflug - v1.0.4
                              system.adapter.pushover : pushover - v1.2.2
                              system.adapter.rpi2 : rpi2 - v1.1.1
                              system.adapter.scenes : scenes - v1.1.0
                              system.adapter.simple-api : simple-api - v2.3.2
                              system.adapter.socketio : socketio - v3.0.0
                              system.adapter.solvis : solvis - v0.0.3
                              system.adapter.sourceanalytix : sourceanalytix - v0.3.0
                              system.adapter.sql : sql - v1.9.5
                              system.adapter.synology : synology - v0.0.4
                              system.adapter.telegram : telegram - v1.5.0
                              system.adapter.tr-064 : tr-064 - v3.1.4
                              system.adapter.tvspielfilm : tvspielfilm - v1.0.4
                              system.adapter.vis : vis - v1.2.4
                              system.adapter.vis-bars : vis-bars - v0.1.4
                              system.adapter.vis-canvas-gauges : vis-canvas-gauges - v0.1.5
                              system.adapter.vis-colorpicker : vis-colorpicker - v1.1.1
                              system.adapter.vis-fancyswitch : vis-fancyswitch - v1.1.0
                              system.adapter.vis-history : vis-history - v1.0.0
                              system.adapter.vis-hqwidgets : vis-hqwidgets - v1.1.3
                              system.adapter.vis-jqui-mfd : vis-jqui-mfd - v1.0.12
                              system.adapter.vis-justgage : vis-justgage - v1.0.2
                              system.adapter.vis-lcars : vis-lcars - v1.0.4
                              system.adapter.vis-map : vis-map - v1.0.3
                              system.adapter.vis-material : vis-material - v0.1.3
                              system.adapter.vis-material-webfont : vis-material-webfont - v0.0.3
                              system.adapter.vis-materialdesign : vis-materialdesign - v0.2.59
                              system.adapter.vis-metro : vis-metro - v1.1.2
                              system.adapter.vis-plumb : vis-plumb - v1.0.2
                              system.adapter.vis-rgraph : vis-rgraph - v0.0.2
                              system.adapter.vis-timeandweather : vis-timeandweather - v1.1.7
                              system.adapter.vis-weather : vis-weather - v2.5.2
                              system.adapter.web : web - v3.0.0
                              system.adapter.yr : yr - v2.0.3
                              hier die Instanzen:
                              C:\iobroker\iobrokervm>iobroker list instances
                              • system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.alexa2.0 : alexa2 - disabled
                              • system.adapter.backitup.0 : backitup - enabled
                                system.adapter.cloud.0 : cloud - disabled
                                system.adapter.daswetter.0 : daswetter - enabled
                              • system.adapter.denon.0 : denon - enabled
                              • system.adapter.discovery.0 : discovery - enabled
                                system.adapter.dwd.0 : dwd - enabled
                              • system.adapter.email.0 : email - enabled
                                system.adapter.flot.0 : flot - enabled
                              • system.adapter.fritzbox.0 : fritzbox - enabled
                                system.adapter.fritzdect.0 : fritzdect - disabled
                              • system.adapter.history.0 : history - enabled
                              • system.adapter.hm-rega.0 : hm-rega - enabled
                                system.adapter.hm-rega.1 : hm-rega - disabled
                                system.adapter.hm-rega.2 : hm-rega - disabled
                              • system.adapter.hm-rpc.0 : hm-rpc - enabled, port: 0
                                system.adapter.hm-rpc.1 : hm-rpc - disabled, port: 0
                                system.adapter.hm-rpc.2 : hm-rpc - disabled, port: 0
                              • system.adapter.hue.0 : hue - enabled, port: 80
                                system.adapter.ical.0 : ical - enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png - enabled
                                system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting - enabled
                                system.adapter.icons-icons8.0 : icons-icons8 - enabled
                                system.adapter.icons-material-png.0 : icons-material-png - enabled
                                system.adapter.icons-material-svg.0 : icons-material-svg - enabled
                                system.adapter.icons-mfd-png.0 : icons-mfd-png - enabled
                                system.adapter.icons-mfd-svg.0 : icons-mfd-svg - enabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png - enabled
                                system.adapter.icons-ultimate-png.0 : icons-ultimate-png - enabled
                              • system.adapter.info.0 : info - enabled
                              • system.adapter.iot.0 : iot - enabled
                                system.adapter.javascript.0 : javascript - enabled
                                system.adapter.mobile.0 : mobile - enabled
                                system.adapter.mqtt.0 : mqtt - disabled, port: 1883
                                system.adapter.node-red.0 : node-red - disabled, port: 1880, bind: 0.0.0.0
                              • system.adapter.phantomjs.0 : phantomjs - enabled
                                system.adapter.ping.0 : ping - disabled
                              • system.adapter.pollenflug.0 : pollenflug - enabled
                              • system.adapter.pushover.0 : pushover - enabled
                              • system.adapter.scenes.0 : scenes - enabled
                              • system.adapter.simple-api.0 : simple-api - enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              • system.adapter.socketio.0 : socketio - enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                system.adapter.solvis.0 : solvis - disabled
                              • system.adapter.sourceanalytix.0 : sourceanalytix - enabled
                              • system.adapter.sql.0 : sql - enabled, port: 0
                                system.adapter.synology.0 : synology - disabled, port: 5000
                                system.adapter.synology.1 : synology - disabled, port: 5000
                                system.adapter.synology.2 : synology - disabled, port: 5000
                                system.adapter.telegram.0 : telegram - disabled, port: 8443, bind: 0.0.0.0
                              • system.adapter.tr-064.0 : tr-064 - enabled
                                system.adapter.tvspielfilm.0 : tvspielfilm - enabled
                                system.adapter.vis-bars.0 : vis-bars - enabled
                                system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges - enabled
                                system.adapter.vis-colorpicker.0 : vis-colorpicker - enabled
                                system.adapter.vis-fancyswitch.0 : vis-fancyswitch - enabled
                                system.adapter.vis-history.0 : vis-history - enabled
                                system.adapter.vis-hqwidgets.0 : vis-hqwidgets - enabled
                                system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd - enabled
                                system.adapter.vis-justgage.0 : vis-justgage - enabled
                                system.adapter.vis-lcars.0 : vis-lcars - enabled
                                system.adapter.vis-map.0 : vis-map - enabled
                                system.adapter.vis-material-webfont.0 : vis-material-webfont - enabled
                                system.adapter.vis-material.0 : vis-material - enabled
                                system.adapter.vis-materialdesign.0 : vis-materialdesign - enabled
                                system.adapter.vis-metro.0 : vis-metro - enabled
                                system.adapter.vis-plumb.0 : vis-plumb - enabled
                                system.adapter.vis-rgraph.0 : vis-rgraph - enabled
                                system.adapter.vis-timeandweather.0 : vis-timeandweather - enabled
                                system.adapter.vis-weather.0 : vis-weather - enabled
                                system.adapter.vis.0 : vis - enabled
                              • system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                system.adapter.yr.0 : yr - enabled
                              • instance is alive
                              und
                              node: v10.17.0
                              npm: 6.11.3
                              Danke!
                                @MarkusL
                                Zeige mal bitte :
                                cd /opt/iobroker
                                nodejs -v
                                node -v
                                npm -v
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @MarkusL
                                Mhh ... alles Top aktuell 🤔
                                Das Problem ist jetzt ... du hast Windows und da kenne ich mich nicht aus .
                                Ich kann mir kein Reim daraus machen , warum der Dateimanger nicht funktioniert bzw. die Bilder nicht registriert .
                                Ich weis nicht ob der Fixer was noch machen kann ... ein Versuch ist es Wert .
                                curl -sL https://iobroker.net/fix.sh | bash -
                                  @MarkusL
                                  MarkusL
                                  @Glasfaser hast Du eine Idee, wie ich die Registrierung manuell anstossen kann. Ich habe das Gefühl, dass sich das System beim Registrieren der vielen Bilder verschluckt hat.
                                  • M MarkusL
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @MarkusL
                                    Höchsten das kenne ich , ob es geht ??!
